path: root/net/sched/act_ipt.c
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in actionsPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Use typeful attribute parsing helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use typeful attribute construction helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use NLA_PUT_STRING for string dumpingPatrick McHardy
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert actions from rtnetlink to new netlink APIPatrick McHardy
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETFILTER]: {ip,ip6}_tables: use struct xt_table instead of redefined ↵Jan Engelhardt
structure names Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-02[NET_SCHED]: act_ipt: fix regression in ipt actionPatrick McHardy
The x_tables patch broke target module autoloading in the ipt action by replacing the ipt_find_target call (which does autoloading) by xt_find_target (which doesn't do autoloading). Additionally xt_find_target may return ERR_PTR values in case of an error, which are not handled. Use xt_request_find_target, which does both autoloading and ERR_PTR handling properly. Also don't forget to drop the target module reference again when xt_check_target fails. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCHED]: Use kmemdup & kzalloc where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-09-22[NETFILTER]: x_tables: remove unused size argument to check/destroy functionsPatrick McHardy
The size is verified by x_tables and isn't needed by the modules anymore. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: x_tables: remove unused argument to target functionsPatrick McHardy
2006-09-22[PKT_SCHED]: Kill pkt_act.h inlining.David S. Miller
This was simply making templates of functions and mostly causing a lot of code duplication in the classifier action modules. We solve this more cleanly by having a common "struct tcf_common" that hash worker functions contained once in act_api.c can work with. Callers work with real action objects that have the common struct plus their module specific struct members. You go from a common object to the higher level one using a "to_foo()" macro which makes use of container_of() to do the dirty work. This also kills off act_generic.h which was only used by act_simple.c and keeping it around was more work than the it's value. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-24[NETFILTER]: ipt action: use xt_check_target for basic verificationPatrick McHardy
The targets don't do the basic verification themselves anymore so the ipt action needs to take care of it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NETFILTER]: x_tables: pass registered match/target data to match/target ↵Patrick McHardy
functions This allows to make decisions based on the revision (and address family with a follow-up patch) at runtime. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[NETFILTER] x_tables: Abstraction layer for {ip,ip6,arp}_tablesHarald Welte
This monster-patch tries to do the best job for unifying the data structures and backend interfaces for the three evil clones ip_tables, ip6_tables and arp_tables. In an ideal world we would never have allowed this kind of copy+paste programming... but well, our world isn't (yet?) ideal. o introduce a new x_tables module o {ip,arp,ip6}_tables depend on this x_tables module o registration functions for tables, matches and targets are only wrappers around x_tables provided functions o all matches/targets that are used from ip_tables and ip6_tables are now implemented as xt_FOOBAR.c files and provide module aliases to ipt_FOOBAR and ip6t_FOOBAR o header files for xt_matches are in include/linux/netfilter/, include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers around the xt_FOOBAR.h headers Based on this patchset we're going to further unify the code, gradually getting rid of all the layer 3 specific assumptions. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[PKT_SCHED]: Prefix tc actions with act_Patrick McHardy
Clean up the net/sched directory a bit by prefix all actions with act_. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
