path: root/net/sched/act_skbedit.c
2015-07-08net: sched: add percpu stats to actionsEric Dumazet
Reuse existing percpu infrastructure John Fastabend added for qdisc. This patch adds a new cpustats parameter to tcf_hash_create() and all actions pass false, meaning this patch should have no effect yet. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: John Fastabend <john.fastabend@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-12net_sched: act: move tcf_hashinfo_init() into tcf_register_action()WANG Cong
Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-12net_sched: act: refactor cleanup opsWANG Cong
For bindcnt and refcnt etc., they are common for all actions, not need to repeat such operations for their own, they can be unified now. Actions just need to do its specific cleanup if needed. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-12net_sched: act: hide struct tcf_common from APIWANG Cong
Now we can totally hide it from modules. tcf_hash_*() API's will operate on struct tc_action, modules don't need to care about the details. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-21net_sched: act: fetch hinfo from a->ops->hinfoWANG Cong
Every action ops has a pointer to hash info, so we don't need to hard-code it in each module. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-19net_sched: act: remove capab from struct tc_action_opsWANG Cong
It is not actually implemented. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13net_sched: act: move idx_gen into struct tcf_hashinfoWANG Cong
There is no need to store the index separatedly since tcf_hashinfo is allocated statically too. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-27net_sched: act: Dont increment refcnt on replaceJamal Hadi Salim
This is a bug fix. The existing code tries to kill many birds with one stone: Handling binding of actions to filters, new actions and replacing of action attributes. A simple test case to illustrate: XXXX moja@fe1:~$ sudo tc actions add action drop index 12 moja@fe1:~$ actions get action gact index 12 action order 1: gact action drop random type none pass val 0 index 12 ref 1 bind 0 moja@fe1:~$ sudo tc actions replace action ok index 12 moja@fe1:~$ actions get action gact index 12 action order 1: gact action drop random type none pass val 0 index 12 ref 2 bind 0 XXXX The above shows the refcounf being wrongly incremented on replace. There are more complex scenarios with binding of actions to filters that i am leaving out that didnt work as well... Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-20net_sched: fix a regression in tc actionsWANG Cong
This patch fixes: 1) pass mask rather than size to tcf_hashinfo_init() 2) the cleanup should be in reversed order in mirred_cleanup_module() Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Fixes: 369ba56787d7469c0afd ("net_sched: init struct tcf_hashinfo at register time") Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18net_sched: init struct tcf_hashinfo at register timeWANG Cong
It looks weird to store the lock out of the struct but still points to a static variable. Just move them into the struct. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Merge 'net' into 'net-next' to get the AF_PACKET bug fix that Daniel's direct transmit changes depend upon. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net/*: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: John Fastabend <john.r.fastabend@intel.com> CC: Alex Duyck <alexander.h.duyck@intel.com> CC: Marcel Holtmann <marcel@holtmann.org> CC: Gustavo Padovan <gustavo@padovan.org> CC: Johan Hedberg <johan.hedberg@gmail.com> CC: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-05net_sched: Use default action walker methodsJamal Hadi Salim
2013-01-14pkt_sched: namespace aware act_mirredBenjamin LaHaise
Eric Dumazet pointed out that act_mirred needs to find the current net_ns, and struct net pointer is not provided in the call chain. His original patch made use of current->nsproxy->net_ns to find the network namespace, but this fails to work correctly for userspace code that makes use of netlink sockets in different network namespaces. Instead, pass the "struct net *" down along the call chain to where it is needed. This version removes the ifb changes as Eric has submitted that patch separately, but is otherwise identical to the previous version. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Tested-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-01pkt_sched: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-06net: sched: constify tcf_proto and tc_actionEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10net_sched: factorize qdisc stats handlingEric Dumazet
HTB takes into account skb is segmented in stats updates. Generalize this to all schedulers. They should use qdisc_bstats_update() helper instead of manipulating bstats.bytes and bstats.packets Add bstats_update() helper too for classes that use gnet_stats_basic_packed fields. Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no stab is setup on qdisc. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17net sched: fix some kernel memory leaksEric Dumazet
We leak at least 32bits of kernel memory to user land in tc dump, because we dont init all fields (capab ?) of the dumped structure. Use C99 initializers so that holes and non explicit fields are zeroed. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-22pkt_sched: skbedit add support for setting markjamal
This adds support for setting the skb mark. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25tc: propogate errors from tcf_hash_createStephen Hemminger
Allow tcf_hash_create to return different errors on estimator failure. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-12pkt_action: add new action skbeditAlexander Duyck
This new action will have the ability to change the priority and/or queue_mapping fields on an sk_buff. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
