path: root/net/sched/cls_api.c
2008-05-20net_sched: cls_api: fix return value for non-existant classifiersPatrick McHardy
cls_api should return ENOENT when the requested classifier doesn't exist. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-31[NET_SCHED]: Constify struct tcf_ext_mapPatrick McHardy
2008-01-28[NET_SCHED]: Use NLA_PUT_STRING for string dumpingPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_nest_start/nla_nest_endPatrick McHardy
Use nla_nest_start/nla_nest_end for dumping nested attributes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: act_api: use PTR_ERR in tcf_action_init/tcf_action_getPatrick McHardy
2008-01-28[NET_SCHED]: Convert actions from rtnetlink to new netlink APIPatrick McHardy
2008-01-28[NET_SCHED]: Convert classifiers from rtnetlink to new netlink APIPatrick McHardy
2008-01-28[NET_SCHED]: mark classifier ops __read_mostlyPatrick McHardy
Additionally remove unnecessary NULL initilizations of the next pointer. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PKT_SCHED] net classifier: style cleanup'sStephen Hemminger
Classifier code cleanup. Get rid of printk wrapper, and fix whitespace and other style stuff reported by checkpatch Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Make rtnetlink infrastructure network namespace aware (v3)Denis V. Lunev
After this patch none of the netlink callback support anything except the initial network namespace but the rtnetlink infrastructure now handles multiple network namespaces. Changes from v2: - IPv6 addrlabel processing Changes from v1: - no need for special rtnl_unlock handling - fixed IPv6 ndisc Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Modify all rtnetlink methods to only work in the initial namespace (v2)Denis V. Lunev
Before I can enable rtnetlink to work in all network namespaces I need to be certain that something won't break. So this patch deliberately disables all of the rtnletlink methods in everything except the initial network namespace. After the methods have been audited this extra check can be disabled. Changes from v1: - added IPv6 addrlabel protection Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-28[NET]: Move Qdisc_class_ops and Qdisc_ops in appropriate sections.Eric Dumazet
Qdisc_class_ops are const, and Qdisc_ops are mostly read. Using "const" and "__read_mostly" qualifiers helps to reduce false sharing. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: Kill CONFIG_NET_CLS_POLICEPatrick McHardy
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE, remove the old code. The config option will be kept around to select the equivalent NET_CLS_ACT options for a short time to allow easier upgrades. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-04-25[NET_SCHED]: Eliminate qdisc_tree_lockPatrick McHardy
Since we're now holding the rtnl during the entire dump operation, we can remove qdisc_tree_lock, whose only purpose is to protect dump callbacks from concurrent changes to the qdisc tree. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKT_SCHED] cls: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCHED]: Use kmemdup & kzalloc where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-09-28[NET_SCHED]: Fix fallout from dev->qdisc RCU changePatrick McHardy
The move of qdisc destruction to a rcu callback broke locking in the entire qdisc layer by invalidating previously valid assumptions about the context in which changes to the qdisc tree occur. The two assumptions were: - since changes only happen in process context, read_lock doesn't need bottem half protection. Now invalid since destruction of inner qdiscs, classifiers, actions and estimators happens in the RCU callback unless they're manually deleted, resulting in dead-locks when read_lock in process context is interrupted by write_lock_bh in bottem half context. - since changes only happen under the RTNL, no additional locking is necessary for data not used during packet processing (f.e. u32_list). Again, since destruction now happens in the RCU callback, this assumption is not valid anymore, causing races while using this data, which can result in corruption or use-after-free. Instead of "fixing" this by disabling bottem halfs everywhere and adding new locks/refcounting, this patch makes these assumptions valid again by moving destruction back to process context. Since only the dev->qdisc pointer is protected by RCU, but ->enqueue and the qdisc tree are still protected by dev->qdisc_lock, destruction of the tree can be performed immediately and only the final free needs to happen in the rcu callback to make sure dev_queue_xmit doesn't access already freed memory. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-06-28[NETLINK]: Missing initializations in dumped dataPatrick McHardy
Mostly missing initialization of padding fields of 1 or 2 bytes length, two instances of uninitialized nlmsgerr->msg of 16 bytes length. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Explicit typingJamal Hadi Salim
This patch converts "unsigned flags" to use more explict types like u16 instead and incrementally introduces NLMSG_NEW(). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
