path: root/net/sched/cls_route.c
2008-01-31[NET_SCHED]: Constify struct tcf_ext_mapPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in classifiersPatrick McHardy
2008-01-28[NET_SCHED]: Use typeful attribute parsing helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use typeful attribute construction helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_nest_start/nla_nest_endPatrick McHardy
Use nla_nest_start/nla_nest_end for dumping nested attributes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert classifiers from rtnetlink to new netlink APIPatrick McHardy
2008-01-28[NET_SCHED]: mark classifier ops __read_mostlyPatrick McHardy
Additionally remove unnecessary NULL initilizations of the next pointer. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-04-25[NET_SCHED]: ingress: switch back to using ingress_lockPatrick McHardy
Switch ingress queueing back to use ingress_lock. qdisc_lock_tree now locks both the ingress and egress qdiscs on the device. All changes to data that might be used on both ingress and egress needs to be protected by using qdisc_lock_tree instead of manually taking dev->queue_lock. Additionally the qdisc stats_lock needs to be initialized to ingress_lock for ingress qdiscs. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-22[NET]: fix up misplaced inlines.Dave Jones
Turning up the warnings on gcc makes it emit warnings about the placement of 'inline' in function declarations. Here's everything that was under net/ Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
