path: root/net/sched/em_ipset.c
2012-07-12net: sched: add ipset ematchFlorian Westphal
Can be used to match packets against netfilter ip sets created via ipset(8). skb->sk_iif is used as 'incoming interface', skb->dev is 'outgoing interface'. Since ipset is usually called from netfilter, the ematch initializes a fake xt_action_param, pulls the ip header into the linear area and also sets skb->data to the IP header (otherwise matching Layer 4 set types doesn't work). Tested-by: Mr Dash Four <mr.dash.four@googlemail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
