commit e72bde6b66299602087c8c2350d36a525e75d06e upstream.
Marco reported an error with hfsc:
root@Calimero:~# tc qdisc add dev eth0 root handle 1:0 hfsc default 1
Error: Attribute failed policy validation.
Apparently a few implementations pass TCA_OPTIONS as a binary instead
of nested attribute, so drop TCA_OPTIONS from the policy.
Fixes: 8b4c3cdd9dd8 ("net: sched: Add policy validation for tc attributes")
Reported-by: Marco Berizzi <pupilla@libero.it>
Signed-off-by: David Ahern <dsahern@gmail.com>
When dumping classes by parent, kernel would return classes twice:
| # tc qdisc add dev lo root prio
| # tc class show dev lo
| class prio 8001:1 parent 8001:
| class prio 8001:2 parent 8001:
| class prio 8001:3 parent 8001:
| # tc class show dev lo parent 8001:
This comes from qdisc_match_from_root() potentially returning the root
qdisc itself if its handle matched. Though in that case, root's classes
were already dumped a few lines above.
Fixes: cb395b2010879 ("net: sched: optimize class dumps")
Signed-off-by: Phil Sutter <phil@nwl.cc>
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Similarly to what has been done in 8b4c3cdd9dd8 ("net: sched: Add policy
validation for tc attributes"), fix classifier code to add validation of
TCA_CHAIN and TCA_KIND netlink attributes.
tested with:
# ./tdc.py -c filter
v2: Let sch_api and cls_api share nla_policy they have in common, thanks
to David Ahern.
v3: Avoid EXPORT_SYMBOL(), as validation of those attributes is not done
by TC modules, thanks to Cong Wang.
While at it, restore the 'Delete / get qdisc' comment to its orginal
position, just above tc_get_qdisc() function prototype.
Fixes: 5bc1701881e39 ("net: sched: introduce multichain support for filters")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
A number of TC attributes are processed without proper validation
(e.g., length checks). Add a tca policy for all input attributes and use
when invoking nlmsg_parse.
The 2 Fixes tags below cover the latest additions. The other attributes
are a string (KIND), nested attribute (OPTIONS which does seem to have
validation in most cases), for dumps only or a flag.
Fixes: d47a6b0e7c492 ("net: sched: introduce ingress/egress block index attributes for qdisc")
This adds 'qdisc_watchdog_init_clockid()' that allows a clockid to be
passed, this allows other time references to be used when scheduling
the Qdisc to run.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@intel.com>
Variants of proc_create{,_data} that directly take a seq_file show
callback and drastically reduces the boilerplate code in the callers.
All trivial callers converted over.
Synchronous pernet_operations are not allowed anymore.
All are asynchronous. So, drop the structure member.
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Offloaded qdiscs are allowed to expose only parts of their statistics.
It means that if backlog is being exposed and qlen is not, it might trigger
a warning in qdisc_tree_reduce_backlog.
Do not warn in case the qdisc that was removed was an offloaded one.
Signed-off-by: Nogah Frankel <nogahf@mellanox.com>
Reviewed-by: Yuval Mintz <yuvalm@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
psched_net_ops only creates and destroyes /proc entry,
and safe to be executed in parallel with any foreigh
pernet_operations.
tcf_action_net_ops initializes and destructs tcf_action_net::egdev_ht,
which is not touched by foreign pernet_operations.
So, make them async.
Acked-by: Andrei Vagin <avagin@virtuozzo.com>
Introduce two new attributes to be used for qdisc creation and dumping.
One for ingress block, one for egress block. Introduce a set of ops that
qdisc which supports block sharing would implement.
Passing block indexes in qdisc change is not supported yet and it is
checked and forbidded.
In future, these attributes are to be reused for specifying block
indexes for classes as well. As of this moment however, it is not
supported so a check is in place to forbid it.
Suggested-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: David Ahern <dsahern@gmail.com>
Overlapping changes all over.
The mini-qdisc bits were a little bit tricky, however.
While working on fixing another bug, I ran into the following panic
on arm64 by simply attaching clsact qdisc, adding a filter and running
traffic on ingress to it:
[ 178.188591] Unable to handle kernel read from unreadable memory at virtual address 810fb501f000
[ 178.197314] Mem abort info:
[ 178.200121] ESR = 0x96000004
[ 178.203168] Exception class = DABT (current EL), IL = 32 bits
[ 178.209095] SET = 0, FnV = 0
[ 178.212157] EA = 0, S1PTW = 0
[ 178.215288] Data abort info:
[ 178.218175] ISV = 0, ISS = 0x00000004
[ 178.222019] CM = 0, WnR = 0
[ 178.224997] user pgtable: 4k pages, 48-bit VAs, pgd = 0000000023cb3f33
[ 178.231531] [0000810fb501f000] *pgd=0000000000000000
[ 178.236508] Internal error: Oops: 96000004 [#1] SMP
[ 178.311855] CPU: 73 PID: 2497 Comm: ping Tainted: G W 4.15.0-rc7+ #5
[ 178.319413] Hardware name: FOXCONN R2-1221R-A4/C2U4N_MB, BIOS G31FB18A 03/31/2017
[ 178.326887] pstate: 60400005 (nZCv daif +PAN -UAO)
[ 178.331685] pc : __netif_receive_skb_core+0x49c/0xac8
[ 178.336728] lr : __netif_receive_skb+0x28/0x78
[ 178.341161] sp : ffff00002344b750
[ 178.344465] x29: ffff00002344b750 x28: ffff810fbdfd0580
[ 178.349769] x27: 0000000000000000 x26: ffff000009378000
[ 178.418715] x1 : 0000000000000054 x0 : 0000000000000000
[ 178.424020] Process ping (pid: 2497, stack limit = 0x000000009f0a3ff4)
[ 178.430537] Call trace:
[ 178.432976] __netif_receive_skb_core+0x49c/0xac8
[ 178.437670] __netif_receive_skb+0x28/0x78
[ 178.441757] process_backlog+0x9c/0x160
[ 178.445584] net_rx_action+0x2f8/0x3f0
Reason is that sch_ingress and sch_clsact are doing mini_qdisc_pair_init()
which sets up miniq pointers to cpu_{b,q}stats from the underlying qdisc.
Problem is that this cannot work since they are actually set up right after
the qdisc ->init() callback in qdisc_create(), so first packet going into
sch_handle_ingress() tries to call mini_qdisc_bstats_cpu_update() and we
therefore panic.
In order to fix this, allocation of {b,q}stats needs to happen before we
call into ->init(). In net-next, there's already such option through commit
d59f5ffa59d8 ("net: sched: a dflt qdisc may be used with per cpu stats").
However, the bug needs to be fixed in net still for 4.15. Thus, include
these bits to reduce any merge churn and reuse the static_flags field to
set TCQ_F_CPUSTATS, and remove the allocation from qdisc_create() since
there is no other user left. Prashant Bhole ran into the same issue but
for net-next, thus adding him below as well as co-author. Same issue was
also reported by Sandipan Das when using bcc.
Fixes: 46209401f8f6 ("net: core: introduce mini_Qdisc and eliminate usage of tp->q for clsact fastpath")
Reference: https://lists.iovisor.org/pipermail/iovisor-dev/2018-January/001190.html
Reported-by: Sandipan Das <sandipan@linux.vnet.ibm.com>
Co-authored-by: Prashant Bhole <bhole_prashant_q7@lab.ntt.co.jp>
Co-authored-by: John Fastabend <john.fastabend@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: Jiri Pirko <jiri@resnulli.us>
/proc has been ignoring struct file_operations::owner field for 10 years.
Specifically, it started with commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba
("Fix rmmod/read/write races in /proc entries"). Notice the chunk where
inode->i_fop is initialized with proxy struct file_operations for
regular files:
- if (de->proc_fops)
- inode->i_fop = de->proc_fops;
+ if (de->proc_fops) {
+ if (S_ISREG(inode->i_mode))
+ inode->i_fop = &proc_reg_file_ops;
+ else
+ inode->i_fop = de->proc_fops;
VFS stopped pinning module at this point.
Move the check of the offload state to after the qdisc dump action was
called, so the qdisc could update it if it was changed.
Fixes: 7a4fa29106d9 ("net: sched: Add TCA_HW_OFFLOAD")
Acked-by: Jiri Pirko <jiri@mellanox.com>
If the qdisc is not found here, it is going to be created. Therefore,
this is not an error path. Remove the extack message set and don't
confuse user with error message in case the qdisc was created
successfully.
Fixes: 09215598119e ("net: sched: sch_api: handle generic qdisc errors")
This patch adds extack support for the function qdisc_alloc which is
a common used function in the tc subsystem. Callers which are interested
in the receiving error can assign extack to get a more detailed
information why qdisc_alloc failed.
Cc: David Ahern <dsahern@gmail.com>
Signed-off-by: Alexander Aring <aring@mojatatu.com>
This patch adds extack support for the function qdisc_get_rtab which is
information why qdisc_get_rtab failed.
This patch adds extack support for graft callback to prepare per-qdisc
specific changes for extack.
This patch adds extack support for block callback to prepare per-qdisc
This patch adds extack support for class change callback api. This prepares
to handle extack support inside each specific class implementation.
This patch adds extack support for change callback for qdisc ops
structtur to prepare per-qdisc specific changes for extack.
This patch adds extack support for init callback to prepare per-qdisc
This patch adds extack support for generic qdisc handling. The extack
will be set deeper to each called function which is not part of netdev
core api.
This patch fix checkpatch issues for upcomming patches according to the
sched api file. It changes mostly how to check on null pointer.
Three sets of overlapping changes, two in the packet scheduler
and one in the meson-gxl PHY driver.
Qdiscs can be offloaded to HW, but current implementation isn't uniform.
Instead, qdiscs either pass information about offload status via their
TCA_OPTIONS or omit it altogether.
Introduce a new attribute - TCA_HW_OFFLOAD that would form a uniform
uAPI for the offloading status of qdiscs.
Signed-off-by: Yuval Mintz <yuvalm@mellanox.com>
This converts the pfifo_fast qdisc to use the skb_array data structure
and set the lockless qdisc bit. pfifo_fast is the first qdisc to support
the lockless bit that can be a child of a qdisc requiring locking. So
we add logic to clear the lock bit on initialization in these cases when
the qdisc graft operation occurs.
This also removes the logic used to pick the next band to dequeue from
and instead just checks a per priority array for packets from top priority
to lowest. This might need to be a bit more clever but seems to work
for now.
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
Add qdisc qlen helper routines for lockless qdiscs to use.
The qdisc qlen is no longer used in the hotpath but it is reported
via stats query on the qdisc so it still needs to be tracked. This
adds the per cpu operations needed along with a helper to return
the summation of per cpu stats.
This patch fixes the following checkpatch error:
ERROR: do not use assignment in if condition
by rearranging the if condition to execute init callback only if init
callback exists. The whole setup afterwards is called in any case,
doesn't matter if init callback is set or not. This patch has the same
behaviour as before, just without assign err variable in if condition.
It also makes the code easier to read.
Reviewed-by: Jamal Hadi Salim <jhs@mojatatu.com>
sched api file. It changes checking on null pointer, remove unnecessary
brackets, add variable names for parameters and adjust 80 char width.
Several conflicts here.
NFP driver bug fix adding nfp_netdev_is_nfp_repr() check to
nfp_fl_output() needed some adjustments because the code block is in
an else block now.
Parallel additions to net/pkt_cls.h and net/sch_generic.h
A bug fix in __tcp_retransmit_skb() conflicted with some of
the rbtree changes in net-next.
The tc action RCU callback fixes in 'net' had some overlap with some
of the recent tcf_block reworking.
Davide found the following script triggers a NULL pointer
dereference:
ip l a name eth0 type dummy
tc q a dev eth0 parent :1 handle 1: htb
This is because for a freshly created netdevice noop_qdisc
is attached and when passing 'parent :1', kernel actually
tries to match the major handle which is 0 and noop_qdisc
has handle 0 so is matched by mistake. Commit 69012ae425d7
tries to fix a similar bug but still misses this case.
Handle 0 is not a valid one, should be just skipped. In
fact, kernel uses it as TC_H_UNSPEC.
Fixes: 69012ae425d7 ("net: sched: fix handling of singleton qdiscs with qdisc_hash")
Fixes: 59cc1f61f09c ("net: sched:convert qdisc linked list to hashtable")
Reported-by: Davide Caratti <dcaratti@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Use tcf_block_q helper to get q pointer to be used for direct call of
sch_tree_lock/unlock instead of tcf_tree_lock/unlock.
Pointer tcm is being initialized and is never read, it is only being used
to determine the size of struct tcmsg. Clean this up by removing
variable tcm and explicitly using the sizeof struct tcmsg rather than *tcm.
Cleans up clang warning:
warning: Value stored to 'tcm' during its initialization is never read
Three cases of simple overlapping changes.
TC filters when used as classifiers are bound to TC classes.
However, there is a hidden difference when adding them in different
orders:
1. If we add tc classes before its filters, everything is fine.
Logically, the classes exist before we specify their ID's in
filters, it is easy to bind them together, just as in the current
code base.
2. If we add tc filters before the tc classes they bind, we have to
do dynamic lookup in fast path. What's worse, this happens all
the time not just once, because on fast path tcf_result is passed
on stack, there is no way to propagate back to the one in tc filters.
This hidden difference hurts performance silently if we have many tc
classes in hierarchy.
This patch intends to close this gap by doing the reverse binding when
we create a new class, in this case we can actually search all the
filters in its parent, match and fixup by classid. And because
tcf_result is specific to each type of tc filter, we have to introduce
a new ops for each filter to tell how to bind the class.
Note, we still can NOT totally get rid of those class lookup in
->enqueue() because cgroup and flow filters have no way to determine
the classid at setup time, they still have to go through dynamic lookup.
For TC classes, their ->get() and ->put() are always paired, and the
reference counting is completely useless, because:
1) For class modification and dumping paths, we already hold RTNL lock,
so all of these ->get(),->change(),->put() are atomic.
2) For filter bindiing/unbinding, we use other reference counter than
this one, and they should have RTNL lock too.
3) For ->qlen_notify(), it is special because it is called on ->enqueue()
path, but we already hold qdisc tree lock there, and we hold this
tree lock when graft or delete the class too, so it should not be gone
or changed until we release the tree lock.
Therefore, this patch removes ->get() and ->put(), but:
1) Adds a new ->find() to find the pointer to a class by classid, no
refcnt.
2) Move the original class destroy upon the last refcnt into ->delete(),
right after releasing tree lock. This is fine because the class is
already removed from hash when holding the lock.
For those who also use ->put() as ->unbind(), just rename them to reflect
this change.
Like for TC actions, ->delete() is a special case,
we have to prepare and fill the notification before delete
otherwise would get use-after-free after we remove the
reference count.
This is not needed if we move them up properly.
syzkaller reported a refcount_t warning [1]
Issue here is that noop_qdisc refcnt was never really considered as
a true refcount, since qdisc_destroy() found TCQ_F_BUILTIN set :
if (qdisc->flags & TCQ_F_BUILTIN ||
!refcount_dec_and_test(&qdisc->refcnt)))
return;
Meaning that all atomic_inc() we did on noop_qdisc.refcnt were not
really needed, but harmless until refcount_t came.
To fix this problem, we simply need to not increment noop_qdisc.refcnt,
since we never decrement it.
[1]
refcount_t: increment on 0; use-after-free.
WARNING: CPU: 0 PID: 21754 at lib/refcount.c:152 refcount_inc+0x47/0x50 lib/refcount.c:152
Kernel panic - not syncing: panic_on_warn set ...
CPU: 0 PID: 21754 Comm: syz-executor7 Not tainted 4.13.0-rc6+ #20
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
panic+0x1e4/0x417 kernel/panic.c:180
__warn+0x1c4/0x1d9 kernel/panic.c:541
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:190
do_trap_no_signal arch/x86/kernel/traps.c:224 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:273
do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:310
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:323
invalid_op+0x1e/0x30 arch/x86/entry/entry_64.S:846
RIP: 0010:refcount_inc+0x47/0x50 lib/refcount.c:152
RSP: 0018:ffff8801c43477a0 EFLAGS: 00010282
RAX: 000000000000002b RBX: ffffffff86093c14 RCX: 0000000000000000
RDX: 000000000000002b RSI: ffffffff8159314e RDI: ffffed0038868ee8
RBP: ffff8801c43477a8 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffff86093ac0
R13: 0000000000000001 R14: ffff8801d0f3bac0 R15: dffffc0000000000
attach_default_qdiscs net/sched/sch_generic.c:792 [inline]
dev_activate+0x7d3/0xaa0 net/sched/sch_generic.c:833
__dev_open+0x227/0x330 net/core/dev.c:1380
__dev_change_flags+0x695/0x990 net/core/dev.c:6726
dev_change_flags+0x88/0x140 net/core/dev.c:6792
dev_ifsioc+0x5a6/0x930 net/core/dev_ioctl.c:256
dev_ioctl+0x2bc/0xf90 net/core/dev_ioctl.c:554
sock_do_ioctl+0x94/0xb0 net/socket.c:968
sock_ioctl+0x2c2/0x440 net/socket.c:1058
vfs_ioctl fs/ioctl.c:45 [inline]
do_vfs_ioctl+0x1b1/0x1520 fs/ioctl.c:685
SYSC_ioctl fs/ioctl.c:700 [inline]
SyS_ioctl+0x8f/0xc0 fs/ioctl.c:691
Fixes: 7b9364050246 ("net, sched: convert Qdisc.refcnt from atomic_t to refcount_t")
Cc: Reshetova, Elena <elena.reshetova@intel.com>
High order GFP_KERNEL allocations can stress the host badly.
Use modern kvmalloc_array()/kvfree() instead of custom
allocations.
Acked-by: Alexei Starovoitov <ast@kernel.org>
This callback is used for deactivating class in parent qdisc.
This is cheaper to test queue length right here.
Also this allows to catch draining screwed backlog and prevent
second deactivation of already inactive parent class which will
crash kernel for sure. Kernel with print warning at destruction
of child qdisc where no packets but backlog is not zero.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
It was added in commit e57a784d8cae ("pkt_sched: set root qdisc
before change() in attach_default_qdiscs()") to hide duplicates
from "tc qdisc show" for incative deivices.
After 59cc1f61f ("net: sched: convert qdisc linked list to hashtable")
it triggered when classful qdisc is added to inactive device because
default qdiscs are added before switching root qdisc.
Anyway after commit ea3274695353 ("net: sched: avoid duplicates in
qdisc dump") duplicates are filtered right in dumper.
This change allows us to later indicate to rtnetlink core that certain
doit functions should be called without acquiring rtnl_mutex.
This change should have no effect, we simply replace the last (now
unused) calcit argument with the new flag.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
A set of overlapping changes in macvlan and the rocker
driver, nothing serious.
When qdisc fail to init, qdisc_create would invoke the destroy callback
to cleanup. But there is no check if the callback exists really. So it
would cause the panic if there is no real destroy callback like the qdisc
codel, fq, and so on.
Take codel as an example following:
When a malicious user constructs one invalid netlink msg, it would cause
codel_init->codel_change->nla_parse_nested failed.
Then kernel would invoke the destroy callback directly but qdisc codel
doesn't define one. It causes one panic as a result.
Now add one the check for destroy to avoid the possible panic.
Fixes: 87b60cfacf9f ("net_sched: fix error recovery at qdisc creation")
Signed-off-by: Gao Feng <gfree.wind@vip.163.com>
Currently, the filter chains are direcly put into the private structures
of qdiscs. In order to be able to have multiple chains per qdisc and to
allow filter chains sharing among qdiscs, there is a need for common
object that would hold the chains. This introduces such object and calls
it "tcf_block".
Helpers to get and put the blocks are provided to be called from
individual qdisc code. Also, the original filter_list pointers are left
in qdisc privs to allow the entry into tcf_block processing without any
added overhead of possible multiple pointer dereference on fast path.
Move tc_classify function to cls_api.c where it belongs, rename it to
fit the namespace.
