[ Upstream commit aea92fb2e09e29653b023d4254ac9fbf94221538 ]
skb_cow(skb, sizeof(ip header)) is not very helpful in this context.
First we need to use pskb_may_pull() to make sure the ip header
is in skb linear part, then use skb_try_make_writable() to
address clones issues.
Fixes: 4c30719f4f55 ("[PKT_SCHED] dsmark: handle cloned and non-linear skb's")
Qdisc performance suffers when packets are dropped at enqueue()
time because drops (kfree_skb()) are done while qdisc lock is held,
delaying a dequeue() draining the queue.
Nominal throughput can be reduced by 50 % when this happens,
at a time we would like the dequeue() to proceed as fast as possible.
Even FQ is vulnerable to this problem, while one of FQ goals was
to provide some flow isolation.
This patch adds a 'struct sk_buff **to_free' parameter to all
qdisc->enqueue(), and in qdisc_drop() helper.
I measured a performance increase of up to 12 %, but this patch
is a prereq so that future batches in enqueue() can fly.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
after removal of TCA_CBQ_OVL_STRATEGY from cbq scheduler, there are no
more callers of ->drop() outside of other ->drop functions, i.e.
nothing calls them.
This fix is for dsmark similar to commit 3557619f0f6f7496ed453d4825e249
("net_sched: prio: use qdisc_dequeue_peeked")
and makes use of qdisc_dequeue_peeked() instead of direct dequeue() call.
First time, wrr peeks dsmark, which will then peek into sfq.
sfq dequeues an skb and it's stored in sch->gso_skb.
Next time, wrr tries to dequeue from dsmark, which will call sfq dequeue
directly. This results skipping the previously peeked skb.
So changed dsmark dequeue to call qdisc_dequeue_peeked() instead to use
peeked skb if exists.
Signed-off-by: Kyeong Yoo <kyeong.yoo@alliedtelesis.co.nz>
Similarly, we need to update backlog too when we update qlen.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Remove nearly duplicated code and prepare for the following patch.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
Memory placement in sch_dsmark is silly : Better place mask/value
in the same cache line.
Also, we can embed small arrays in the first cache line and
remove a potential cache miss.
For classifiers getting invoked via tc_classify(), we always need an
extra function call into tc_classify_compat(), as both are being
exported as symbols and tc_classify() itself doesn't do much except
handling of reclassifications when tp->classify() returned with
TC_ACT_RECLASSIFY.
CBQ and ATM are the only qdiscs that directly call into tc_classify_compat(),
all others use tc_classify(). When tc actions are being configured
out in the kernel, tc_classify() effectively does nothing besides
delegating.
We could spare this layer and consolidate both functions. pktgen on
single CPU constantly pushing skbs directly into the netif_receive_skb()
path with a dummy classifier on ingress qdisc attached, improves
slightly from 22.3Mpps to 23.1Mpps.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
tc code implicitly considers skb->protocol even in case of accelerated
vlan paths and expects vlan protocol type here. However, on rx path,
if the vlan header was already stripped, skb->protocol contains value
of next header. Similar situation is on tx path.
So for skbs that use skb->vlan_tci for tagging, use skb->vlan_proto instead.
Reported-by: Jamal Hadi Salim <jhs@mojatatu.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
This adds helpers to manipulate qstats logic and replaces locations
that touch the counters directly. This simplifies future patches
to push qstats onto per cpu counters.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
rcu'ify tcf_proto this allows calling tc_classify() without holding
any locks. Updaters are protected by RTNL.
This patch prepares the core net_sched infrastracture for running
the classifier/action chains without holding the qdisc lock however
it does nothing to ensure cls_xxx and act_xxx types also work without
locking. Additional patches are required to address the fall out.
In dsmark_drop(), the function name printed by pr_debug
is "dsmark_reset", correct it to "dsmark_drop" by using
__func__ .
BTW, replace the other function names with __func__ .
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
Prefer pr_warn(... to pr_warning(...
return is not a function, parentheses are not required.
Use qdisc_drop() helper where possible.
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
net/sched/sch_hfsc.c
net/sched/sch_htb.c
net/sched/sch_tbf.c
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed
a problem with pfifo_head drops that incorrectly decreased
sch->bstats.bytes and sch->bstats.packets
Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a
previously enqueued packet, and bstats cannot be changed, so
bstats/rates are not accurate (over estimated)
This patch changes the qdisc_bstats updates to be done at dequeue() time
instead of enqueue() time. bstats counters no longer account for dropped
frames, and rates are more correct, since enqueue() bursts dont have
effect on dequeue() rate.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Cleanup net/sched code to current CodingStyle and practices.
Reduce inline abuse
HTB takes into account skb is segmented in stats updates.
Generalize this to all schedulers.
They should use qdisc_bstats_update() helper instead of manipulating
bstats.bytes and bstats.packets
Add bstats_update() helper too for classes that use
gnet_stats_basic_packed fields.
Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no
stab is setup on qdisc.
The first parameter dev isn't in use in qdisc_create_dflt().
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The use of xchg() hasn't been necessary since 2.2.something when proper
locking was added to packet schedulers.
After implementing qdisc->ops->peek() and changing sch_netem into
classless qdisc there are no more qdisc->ops->requeue() users. This
patch removes this method with its wrappers (qdisc_requeue()), and
also unused qdisc->requeue structure. There are a few minor fixes of
warnings (htb_enqueue()) and comments btw.
The idea to kill ->requeue() and a similar patch were first developed
by David S. Miller.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
Add qdisc->ops->peek() implementation for work-conserving qdiscs.
With feedback from Patrick McHardy.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Patrick McHardy <kaber@trash.net> noticed that it would be nice to
handle NET_XMIT_BYPASS by NET_XMIT_SUCCESS with an internal qdisc flag
__NET_XMIT_BYPASS and to remove the mapping from dev_queue_xmit().
David Miller <davem@davemloft.net> spotted a serious bug in the first
version of this patch.
Patrick McHardy <kaber@trash.net> noticed:
"The other problem that affects all qdiscs supporting actions is
TC_ACT_QUEUED/TC_ACT_STOLEN getting mapped to NET_XMIT_SUCCESS
even though the packet is not queued, corrupting upper qdiscs'
qlen counters."
and later explained:
"The reason why it translates it at all seems to be to not increase
the drops counter. Within a single qdisc this could be avoided by
other means easily, upper qdiscs would still increase the counter
when we return anything besides NET_XMIT_SUCCESS though.
This means we need a new NET_XMIT return value to indicate this to
the upper qdiscs. So I'd suggest to introduce NET_XMIT_STOLEN,
return that to upper qdiscs and translate it to NET_XMIT_SUCCESS
in dev_queue_xmit, similar to NET_XMIT_BYPASS."
David Miller <davem@davemloft.net> noticed:
"Maybe these NET_XMIT_* values being passed around should be a set of
bits. They could be composed of base meanings, combined with specific
attributes.
So you could say "NET_XMIT_DROP | __NET_XMIT_NO_DROP_COUNT"
The attributes get masked out by the top-level ->enqueue() caller,
such that the base meanings are the only thing that make their
way up into the stack. If it's only about communication within the
qdisc tree, let's simply code it that way."
This patch is trying to realize these ideas.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
It can be obtained via the netdev_queue. So create a helper routine,
qdisc_dev(), to make the transformations nicer looking.
Now, qdisc_alloc() now no longer needs a net_device pointer argument.
A netdev_queue is an entity managed by a qdisc.
Currently there is one RX and one TX queue, and a netdev_queue merely
contains a backpointer to the net_device.
The Qdisc struct is augmented with a netdev_queue pointer as well.
Eventually the 'dev' Qdisc member will go away and we will have the
resulting hierarchy:
net_device --> netdev_queue --> Qdisc
Also, qdisc_alloc() and qdisc_create_dflt() now take a netdev_queue
pointer argument.
Pass double tcf_proto pointers to tcf_destroy_chain() to make it
clear the start of the filter list for more consistency.
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and
nla_nest_cancel() void functions.
Return -EMSGSIZE instead of -1 if the provided message buffer is not
big enough.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
nla_parse() returns more detailed errno codes, propagate them back on
error.
Convert packet schedulers to use the netlink API. Unfortunately a gradual
conversion is not possible without breaking compilation in the middle or
adding lots of casts, so this patch converts them all in one step. The
patch has been mostly generated automatically with some minor edits to
at least allow seperate conversion of classifiers and actions.
Get rid of all style things checkpatch warns about, indentation and
whitespace.
Make dsmark work properly with non-linear and cloned skb's
Before modifying the header, it needs to check that skb header is
writeable.
Note: this makes the assumption, that if it queues a good skb
then a good skb will come out of the embedded qdisc.
Based upon a patch by Stephen Hemminger and suggestions
Remove extraneous macro wrappers for printk and qdisc_priv.
Qdisc_class_ops are const, and Qdisc_ops are mostly read.
Using "const" and "__read_mostly" qualifiers helps to reduce false
sharing.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE,
remove the old code. The config option will be kept around to select
the equivalent NET_CLS_ACT options for a short time to allow easier
upgrades.
Handle act_api classification results.
Spring cleaning time...
There seems to be a lot of places in the network code that have
extra bogus semicolons after conditionals. Most commonly is a
bogus semicolon after: switch() { }
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Uninline tcf_destroy and add a helper function to destroy an entire filter
chain.
Now the skb->nh union has just one member, .raw, i.e. it is just like the
skb->mac union, strange, no? I'm just leaving it like that till the transport
layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or
->mac_header_offset?), ditto for ->{h,nh}.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
