path: root/net/sched/sch_dsmark.c
2015-01-13net: sched: fix skb->protocol use in case of accelerated vlan pathJiri Pirko
tc code implicitly considers skb->protocol even in case of accelerated vlan paths and expects vlan protocol type here. However, on rx path, if the vlan header was already stripped, skb->protocol contains value of next header. Similar situation is on tx path. So for skbs that use skb->vlan_tci for tagging, use skb->vlan_proto instead. Reported-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-30net: sched: implement qstat helper routinesJohn Fastabend
This adds helpers to manipulate qstats logic and replaces locations that touch the counters directly. This simplifies future patches to push qstats onto per cpu counters. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-13net: rcu-ify tcf_protoJohn Fastabend
rcu'ify tcf_proto this allows calling tc_classify() without holding any locks. Updaters are protected by RTNL. This patch prepares the core net_sched infrastracture for running the classifier/action chains without holding the qdisc lock however it does nothing to ensure cls_xxx and act_xxx types also work without locking. Additional patches are required to address the fall out. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-31sch_dsmark: use correct func name in print messagesYang Yingliang
In dsmark_drop(), the function name printed by pr_debug is "dsmark_reset", correct it to "dsmark_drop" by using __func__ . BTW, replace the other function names with __func__ . Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-31net_sched: replace pr_warning with pr_warnYang Yingliang
Prefer pr_warn(... to pr_warning(... Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-10net_sched: remove unnecessary parentheses while returnYang Yingliang
return is not a function, parentheses are not required. Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-04net: sched: factorize code (qdisc_drop())Eric Dumazet
Use qdisc_drop() helper where possible. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-01pkt_sched: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/sched/sch_hfsc.c net/sched/sch_htb.c net/sched/sch_tbf.c
2011-01-20net_sched: accurate bytes/packets stats/ratesEric Dumazet
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed a problem with pfifo_head drops that incorrectly decreased sch->bstats.bytes and sch->bstats.packets Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a previously enqueued packet, and bstats cannot be changed, so bstats/rates are not accurate (over estimated) This patch changes the qdisc_bstats updates to be done at dequeue() time instead of enqueue() time. bstats counters no longer account for dropped frames, and rates are more correct, since enqueue() bursts dont have effect on dequeue() rate. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10net_sched: factorize qdisc stats handlingEric Dumazet
HTB takes into account skb is segmented in stats updates. Generalize this to all schedulers. They should use qdisc_bstats_update() helper instead of manipulating bstats.bytes and bstats.packets Add bstats_update() helper too for classes that use gnet_stats_basic_packed fields. Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no stab is setup on qdisc. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21net_sched: remove the unused parameter of qdisc_create_dflt()Changli Gao
The first parameter dev isn't in use in qdisc_create_dflt(). Signed-off-by: Changli Gao <xiaosuo@gmail.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-11-20pkt_sched: remove unnecessary xchg() in packet schedulersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-13pkt_sched: Remove qdisc->ops->requeue() etc.Jarek Poplawski
After implementing qdisc->ops->peek() and changing sch_netem into classless qdisc there are no more qdisc->ops->requeue() users. This patch removes this method with its wrappers (qdisc_requeue()), and also unused qdisc->requeue structure. There are a few minor fixes of warnings (htb_enqueue()) and comments btw. The idea to kill ->requeue() and a similar patch were first developed by David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31pkt_sched: Add qdisc->ops->peek() implementation.Jarek Poplawski
Add qdisc->ops->peek() implementation for work-conserving qdiscs. With feedback from Patrick McHardy. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-20net: Use hton[sl]() instead of __constant_hton[sl]() where applicableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04net_sched: Add qdisc __NET_XMIT_BYPASS flagJarek Poplawski
Patrick McHardy <kaber@trash.net> noticed that it would be nice to handle NET_XMIT_BYPASS by NET_XMIT_SUCCESS with an internal qdisc flag __NET_XMIT_BYPASS and to remove the mapping from dev_queue_xmit(). David Miller <davem@davemloft.net> spotted a serious bug in the first version of this patch. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04net_sched: Add qdisc __NET_XMIT_STOLEN flagJarek Poplawski
Patrick McHardy <kaber@trash.net> noticed: "The other problem that affects all qdiscs supporting actions is TC_ACT_QUEUED/TC_ACT_STOLEN getting mapped to NET_XMIT_SUCCESS even though the packet is not queued, corrupting upper qdiscs' qlen counters." and later explained: "The reason why it translates it at all seems to be to not increase the drops counter. Within a single qdisc this could be avoided by other means easily, upper qdiscs would still increase the counter when we return anything besides NET_XMIT_SUCCESS though. This means we need a new NET_XMIT return value to indicate this to the upper qdiscs. So I'd suggest to introduce NET_XMIT_STOLEN, return that to upper qdiscs and translate it to NET_XMIT_SUCCESS in dev_queue_xmit, similar to NET_XMIT_BYPASS." David Miller <davem@davemloft.net> noticed: "Maybe these NET_XMIT_* values being passed around should be a set of bits. They could be composed of base meanings, combined with specific attributes. So you could say "NET_XMIT_DROP | __NET_XMIT_NO_DROP_COUNT" The attributes get masked out by the top-level ->enqueue() caller, such that the base meanings are the only thing that make their way up into the stack. If it's only about communication within the qdisc tree, let's simply code it that way." This patch is trying to realize these ideas. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-20net_sched: Add accessor function for packet length for qdiscsJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-20net_sched: Add qdisc_enqueue wrapperJussi Kivilinna
2008-07-08pkt_sched: Remove 'dev' member of struct Qdisc.David S. Miller
It can be obtained via the netdev_queue. So create a helper routine, qdisc_dev(), to make the transformations nicer looking. Now, qdisc_alloc() now no longer needs a net_device pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Create netdev_queue abstraction.David S. Miller
A netdev_queue is an entity managed by a qdisc. Currently there is one RX and one TX queue, and a netdev_queue merely contains a backpointer to the net_device. The Qdisc struct is augmented with a netdev_queue pointer as well. Eventually the 'dev' Qdisc member will go away and we will have the resulting hierarchy: net_device --> netdev_queue --> Qdisc Also, qdisc_alloc() and qdisc_create_dflt() now take a netdev_queue pointer argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-01net-sched: change tcf_destroy_chain() to clear start of filter listPatrick McHardy
Pass double tcf_proto pointers to tcf_destroy_chain() to make it clear the start of the filter list for more consistency. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03netlink: Improve returned error codesThomas Graf
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and nla_nest_cancel() void functions. Return -EMSGSIZE instead of -1 if the provided message buffer is not big enough. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in packet schedulersPatrick McHardy
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PKT_SCHED] dsmark: checkpatch warning cleanupStephen Hemminger
Get rid of all style things checkpatch warns about, indentation and whitespace. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PKT_SCHED] dsmark: handle cloned and non-linear skb'sStephen Hemminger
Make dsmark work properly with non-linear and cloned skb's Before modifying the header, it needs to check that skb header is writeable. Note: this makes the assumption, that if it queues a good skb then a good skb will come out of the embedded qdisc. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PKT_SCHED] dsmark: Use hweight32() instead of convoluted loop.David S. Miller
Based upon a patch by Stephen Hemminger and suggestions from Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PKT_SCHED] dsmark: get rid of wrappersStephen Hemminger
Remove extraneous macro wrappers for printk and qdisc_priv. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move Qdisc_class_ops and Qdisc_ops in appropriate sections.Eric Dumazet
Qdisc_class_ops are const, and Qdisc_ops are mostly read. Using "const" and "__read_mostly" qualifiers helps to reduce false sharing. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: Kill CONFIG_NET_CLS_POLICEPatrick McHardy
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE, remove the old code. The config option will be kept around to select the equivalent NET_CLS_ACT options for a short time to allow easier upgrades. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: sch_dsmark: act_api supportPatrick McHardy
Handle act_api classification results. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Unline tcf_destroyPatrick McHardy
Uninline tcf_destroy and add a helper function to destroy an entire filter chain. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops (part 2): "simple" qdiscsPatrick McHardy
Convert the "simple" qdiscs to use qdisc_tree_decrease_qlen() where necessary: - all graft operations - destruction of old child qdiscs in prio, red and tbf change operation - purging of queue in sfq change operation Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Set parent classid in default qdiscsPatrick McHardy
Set parent classids in default qdiscs to allow walking up the tree from outside the qdiscs. This is needed by the next patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: net/sched annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PKT_SCHED]: Dump child qdisc handle in sch_{atm,dsmark}Patrick McHardy
A qdisc should set tcm_info to the child qdisc handle in its class dump function. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: Logic simplifications and codingstyle/whitespace cleanupsThomas Graf
2005-06-18[PKT_SCHED]: Make dsmark use the new dumping macrosThomas Graf
2005-06-18[PKT_SCHED]: Fix dsmark to apply changes consistentThomas Graf
Fixes dsmark to do all configuration sanity checks first and only apply the changes if all of them can be applied without any errors. Also fixes the weak sanity checks for DSMARK_VALUE and DSMASK_MASK. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
