path: root/net/sched/sch_hfsc.c
2016-08-08net/sched/sch_hfsc.c: remove unused cl_myfadjMichal Soltys
The code using this variable has been commented out in the past as it was causing issues in upperlimited link-sharing scenarios. Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-08net/sched/sch_hfsc.c: keep fsc and virtual times in sync; fix an old bugMichal Soltys
This patch simplifies how we update fsc and calculate vt from it - while keeping the expected functionality identical with how hfsc behaves curently. It also fixes a certain issue introduced with a very old patch. The idea is, that instead of correcting cl_vt before fsc curve update (rtsc_min) and correcting cl_vt after calculation (rtsc_y2x) to keep cl_vt local to the current period - we can simply rely on virtual times and curve values always being in sync - analogously to how rsc and usc function, except that we use virtual time here. Why hasn't it been done since the beginning this way ? The likely scenario (basing on the code trying to correct curves whenever possible) was to keep the virtual times as small as possible - as they have tendency to "gallop" forward whenever their siblings and other fair sharing subtrees are idling. On top of that, current code is subtly bugged, so cumulative time (without any corrections) is always kept and used in init_vf() when a new backlog period begins (using cl_cvtoff). Is cumulative value safe ? Generally yes, though corner cases are easy to create. For example consider: 1gbit interface some 100kbit leaf, everything else idle With current tick (64ns) 1s is 15625000 ticks, but the leaf is alone and it's virtual time, so in reality it's 10000 times more. ITOW 38 bits are needed to hold 1 second. 54 - 1 day, 59 - 1 month, 63 - 1 year (all logarithms rounded up). It's getting somewhat dangerous, but also requires setup excusing this kind of values not mentioning permanently backlogged class for a year. In near most extreme case (10gbit, 10kbit leaf), we have "enough" to hold ~13.6 days in 64 bits. Well, the issue remains mostly theoretical and cl_cvtoff has been working fine for all those years. Sensible configuration are de-facto immune to this issue, and not so sensible can solve it with a cronjob and its period inversely proportional to the insanity of such setup =) Now let's explain the subtle bug mentioned earlier. The issue is related to how offsets are kept and how we calculate virtual times and update fair service curve(s). The issue itself is subtle, but easy to observe with long m1 segments. It was introduced in rather old patch: Commit 99296150c7: "[NET_SCHED]: O(1) children vtoff adjustment in HFSC scheduler" (available in git://git.kernel.org/pub/scm/linux/kernel/git/tglx/history.git) Originally when a new backlog period was started, cl_vtoff of each sibling was updated with cl_cvtmax from past period - naturally moving all cl_vt to proper starting point. That patch adjusted it so cumulative offset is kept in the parent, and there is no need for traversing the list (as any subsequent child activation derives new vt from already active sibling(s)). But with this change, cl_vtoff (of each sibling) is no longer persistent across the inactivity periods, as it's calculated from parent's cl_cvtoff on a new backlog period, conflicting with the following curve correction from the previous period: if (cl->cl_virtual.x == vt) { cl->cl_virtual.x -= cl->cl_vtoff; cl->cl_vtoff = 0; } This essentially tries to keep curve as if it was local to the period and resets cl_vtoff (cumulative vt offset of the class) to 0 when possible (read: when we have an intersection or if a new curve is below the old one). But then it's recalculated from cl_cvtoff on next active period. Then rtsc_min() call preceding the above if() doesn't really do what we expect it to do in such scenario - as it calculates the minimum of corrected curve (from the previous backlog period) and the new uncorrected curve (with offset derived from cl_cvtoff). Example: tc class add dev $ife parent 1:0 classid 1:1 hfsc ls m2 100mbit ul m2 100mbit tc class add dev $ife parent 1:1 classid 1:10 hfsc ls m1 80mbit d 10s m2 20mbit tc class add dev $ife parent 1:1 classid 1:11 hfsc ls m2 20mbit start B, keep it backlogged, let it run 6s (30s worth of vt as A is idle) pause B briefly to force cl_cvtoff update in parent (whole 1:1 going idle) start A, let it run 10s pause A briefly to force rtsc_min() At this point we would expect A to continue at 20mbit after a brief moment of 80mbit. But instead A will use 80mbit for full 10s again. It's the effect of first correcting A (during 'start A'), and then - after unpausing - calculating rtsc_min() from old corrected and new uncorrected curve. The patch fixes this bug and keepis vt and fsc in sync (virtual times are cumulative, not local to the backlog period). Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-08hfsc: reduce hfsc_sched to 14 cachelinesFlorian Westphal
hfsc_sched is huge (size: 920, cachelines: 15), but we can get it to 14 cachelines by placing level after filter_cnt (covering 4 byte hole) and reducing period/nactive/flags to u32 (period is just a counter, incremented when class becomes active -- 2**32 is plenty for this purpose, also, long is only 32bit wide on 32bit platforms anyway). cl_vtperiod is exported to userspace via tc_hfsc_stats, but its period member is already u32, so no precision is lost there either. Cc: Michal Soltys <soltys@ziu.info> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-01net/sched/sch_hfsc.c: anchor virtual curve at proper vt in hfsc_change_fsc()Michal Soltys
cl->cl_vt alone is relative only to the current backlog period, while the curve operates on cumulative virtual time. This patch adds missing cl->cl_vtoff. Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-01net/sched/sch_hfsc.c: go passive after vt updateMichal Soltys
When a class is going passive, it should update its cl_vt first to be consistent with the last dequeue operation. Otherwise its cl_vt will be one packet behind and parent's cvtmax might not be updated as well. One possible side effect is if some class goes passive and subsequently goes active /without/ its parent going passive - with cl_vt lagging one packet behind - comparison made in init_vf() will be affected (same period). Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-01net/sched/sch_hfsc.c: remove leftover dlist and droplistMichal Soltys
This is update to: commit a09ceb0e08140a ("sched: remove qdisc->drop") That commit removed qdisc->drop, but left alone dlist and droplist that no longer serve any meaningful purpose. Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-01net/sched/sch_hfsc.c: add unlikely() in qdisc_peek_len()Michal Soltys
The condition can only succeed on wrong configurations. Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-01net/sched/sch_hfsc.c: handle corner cases where head may change invalidating ↵Michal Soltys
calculated deadline Realtime scheduling implemented in HFSC uses head of the queue to make the decision about which packet to schedule next. But in case of any head drop, the deadline calculated for the previous head is not necessarily correct for the next head (unless both packets have the same length). Thanks to peek() function used during dequeue - which internally is a dequeue operation - hfsc is almost safe from this issue, as peek() dequeues and isolates the head storing it temporarily until the real dequeue happens. But there is one exception: if after the class activation a drop happens before the first dequeue operation, there's never a chance to do the peek(). Adding peek() call in enqueue - if this is the first packet in a new backlog period AND the scheduler has realtime curve defined - fixes that one corner case. The 1st hfsc_dequeue() will use that peeked packet, similarly as every subsequent hfsc_dequeue() call uses packet peeked by the previous call. Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-25net_sched: drop packets after root qdisc lock is releasedEric Dumazet
Qdisc performance suffers when packets are dropped at enqueue() time because drops (kfree_skb()) are done while qdisc lock is held, delaying a dequeue() draining the queue. Nominal throughput can be reduced by 50 % when this happens, at a time we would like the dequeue() to proceed as fast as possible. Even FQ is vulnerable to this problem, while one of FQ goals was to provide some flow isolation. This patch adds a 'struct sk_buff **to_free' parameter to all qdisc->enqueue(), and in qdisc_drop() helper. I measured a performance increase of up to 12 %, but this patch is a prereq so that future batches in enqueue() can fly. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-10net_sched: remove generic throttled managementEric Dumazet
__QDISC_STATE_THROTTLED bit manipulation is rather expensive for HTB and few others. I already removed it for sch_fq in commit f2600cf02b5b ("net: sched: avoid costly atomic operation in fq_dequeue()") and so far nobody complained. When one ore more packets are stuck in one or more throttled HTB class, a htb dequeue() performs two atomic operations to clear/set __QDISC_STATE_THROTTLED bit, while root qdisc lock is held. Removing this pair of atomic operations bring me a 8 % performance increase on 200 TCP_RR tests, in presence of throttled classes. This patch has no side effect, since nothing actually uses disc_is_throttled() anymore. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/sched/act_police.c net/sched/sch_drr.c net/sched/sch_hfsc.c net/sched/sch_prio.c net/sched/sch_red.c net/sched/sch_tbf.c In net-next the drop methods of the packet schedulers got removed, so the bug fixes to them in 'net' are irrelevant. A packet action unload crash fix conflicts with the addition of the new firstuse timestamp. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-08sched: remove qdisc->dropFlorian Westphal
after removal of TCA_CBQ_OVL_STRATEGY from cbq scheduler, there are no more callers of ->drop() outside of other ->drop functions, i.e. nothing calls them. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-07net: sched: do not acquire qdisc spinlock in qdisc/class stats dumpEric Dumazet
Large tc dumps (tc -s {qdisc|class} sh dev ethX) done by Google BwE host agent [1] are problematic at scale : For each qdisc/class found in the dump, we currently lock the root qdisc spinlock in order to get stats. Sampling stats every 5 seconds from thousands of HTB classes is a challenge when the root qdisc spinlock is under high pressure. Not only the dumps take time, they also slow down the fast path (queue/dequeue packets) by 10 % to 20 % in some cases. An audit of existing qdiscs showed that sch_fq_codel is the only qdisc that might need the qdisc lock in fq_codel_dump_stats() and fq_codel_dump_class_stats() In v2 of this patch, I now use the Qdisc running seqcount to provide consistent reads of packets/bytes counters, regardless of 32/64 bit arches. I also changed rate estimators to use the same infrastructure so that they no longer need to lock root qdisc lock. [1] http://static.googleusercontent.com/media/research.google.com/en//pubs/archive/43838.pdf Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: John Fastabend <john.fastabend@gmail.com> Cc: Kevin Athey <kda@google.com> Cc: Xiaotian Pei <xiaotian@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-03sch_hfsc: always keep backlog updatedWANG Cong
hfsc updates backlog lazily, that is only when we dump the stats. This is problematic after we begin to update backlog in qdisc_tree_reduce_backlog(). Reported-by: Stas Nichiporovich <stasn77@gmail.com> Tested-by: Stas Nichiporovich <stasn77@gmail.com> Fixes: 2ccccf5fb43f ("net_sched: update hierarchical backlog too") Cc: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-29net_sched: update hierarchical backlog tooWANG Cong
When the bottom qdisc decides to, for example, drop some packet, it calls qdisc_tree_decrease_qlen() to update the queue length for all its ancestors, we need to update the backlog too to keep the stats on root qdisc accurate. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-29net_sched: introduce qdisc_replace() helperWANG Cong
Remove nearly duplicated code and prepare for the following patch. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-27net: sched: consolidate tc_classify{,_compat}Daniel Borkmann
For classifiers getting invoked via tc_classify(), we always need an extra function call into tc_classify_compat(), as both are being exported as symbols and tc_classify() itself doesn't do much except handling of reclassifications when tp->classify() returned with TC_ACT_RECLASSIFY. CBQ and ATM are the only qdiscs that directly call into tc_classify_compat(), all others use tc_classify(). When tc actions are being configured out in the kernel, tc_classify() effectively does nothing besides delegating. We could spare this layer and consolidate both functions. pktgen on single CPU constantly pushing skbs directly into the netif_receive_skb() path with a dummy classifier on ingress qdisc attached, improves slightly from 22.3Mpps to 23.1Mpps. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-30net: sched: enable per cpu qstatsJohn Fastabend
After previous patches to simplify qstats the qstats can be made per cpu with a packed union in Qdisc struct. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-30net: sched: restrict use of qstats qlenJohn Fastabend
This removes the use of qstats->qlen variable from the classifiers and makes it an explicit argument to gnet_stats_copy_queue(). The qlen represents the qdisc queue length and is packed into the qstats at the last moment before passnig to user space. By handling it explicitely we avoid, in the percpu stats case, having to figure out which per_cpu variable to put it in. It would probably be best to remove it from qstats completely but qstats is a user space ABI and can't be broken. A future patch could make an internal only qstats structure that would avoid having to allocate an additional u32 variable on the Qdisc struct. This would make the qstats struct 128bits instead of 128+32. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-30net: sched: implement qstat helper routinesJohn Fastabend
This adds helpers to manipulate qstats logic and replaces locations that touch the counters directly. This simplifies future patches to push qstats onto per cpu counters. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-30net: sched: make bstats per cpu and estimator RCU safeJohn Fastabend
In order to run qdisc's without locking statistics and estimators need to be handled correctly. To resolve bstats make the statistics per cpu. And because this is only needed for qdiscs that are running without locks which is not the case for most qdiscs in the near future only create percpu stats when qdiscs set the TCQ_F_CPUSTATS flag. Next because estimators use the bstats to calculate packets per second and bytes per second the estimator code paths are updated to use the per cpu statistics. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-13net: rcu-ify tcf_protoJohn Fastabend
rcu'ify tcf_proto this allows calling tc_classify() without holding any locks. Updaters are protected by RTNL. This patch prepares the core net_sched infrastracture for running the classifier/action chains without holding the qdisc lock however it does nothing to ensure cls_xxx and act_xxx types also work without locking. Additional patches are required to address the fall out. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-13net_sched: return nla_nest_end() instead of skb->lenYang Yingliang
nla_nest_end() already has return skb->len, so replace return skb->len with return nla_nest_end instead(). Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-11net_sched: add 64bit rate estimatorsEric Dumazet
struct gnet_stats_rate_est contains u32 fields, so the bytes per second field can wrap at 34360Mbit. Add a new gnet_stats_rate_est64 structure to get 64bit bps/pps fields, and switch the kernel to use this structure natively. This structure is dumped to user space as a new attribute : TCA_STATS_RATE_EST64 Old tc command will now display the capped bps (to 34360Mbit), instead of wrapped values, and updated tc command will display correct information. Old tc command output, after patch : eric:~# tc -s -d qd sh dev lo qdisc pfifo 8001: root refcnt 2 limit 1000p Sent 80868245400 bytes 1978837 pkt (dropped 0, overlimits 0 requeues 0) rate 34360Mbit 189696pps backlog 0b 0p requeues 0 This patch carefully reorganizes "struct Qdisc" layout to get optimal performance on SMP. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10net_sched: update bstats in dequeue()Eric Dumazet
Class bytes/packets stats can be misleading because they are updated in enqueue() while packet might be dropped later. We already fixed all qdiscs but sch_atm. This patch makes the final cleanup. class rate estimators can now match qdisc ones. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-01pkt_sched: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-23sch_hfsc: report backlog informationEric Dumazet
Add backlog (byte count) information in hfsc classes and qdisc, so that "tc -s" can report it to user, instead of 0 values : qdisc hfsc 1: root refcnt 6 default 20 Sent 45141660 bytes 30545 pkt (dropped 0, overlimits 91751 requeues 0) rate 1492Kbit 126pps backlog 103226b 74p requeues 0 ... class hfsc 1:20 parent 1:1 leaf 1201: rt m1 0bit d 0us m2 400000bit ls m1 0bit d 0us m2 200000bit Sent 49534912 bytes 33519 pkt (dropped 0, overlimits 0 requeues 0) backlog 81822b 56p requeues 0 period 23 work 49451576 bytes rtwork 13277552 bytes level 0 ... Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: John A. Sullivan III <jsullivan@opensourcedevel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/sched/sch_hfsc.c net/sched/sch_htb.c net/sched/sch_tbf.c
2011-01-20net_sched: accurate bytes/packets stats/ratesEric Dumazet
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed a problem with pfifo_head drops that incorrectly decreased sch->bstats.bytes and sch->bstats.packets Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a previously enqueued packet, and bstats cannot be changed, so bstats/rates are not accurate (over estimated) This patch changes the qdisc_bstats updates to be done at dequeue() time instead of enqueue() time. bstats counters no longer account for dropped frames, and rates are more correct, since enqueue() bursts dont have effect on dequeue() rate. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20net_sched: move TCQ_F_THROTTLED flagEric Dumazet
In commit 371121057607e (net: QDISC_STATE_RUNNING dont need atomic bit ops) I moved QDISC_STATE_RUNNING flag to __state container, located in the cache line containing qdisc lock and often dirtied fields. I now move TCQ_F_THROTTLED bit too, so that we let first cache line read mostly, and shared by all cpus. This should speedup HTB/CBQ for example. Not using test_bit()/__clear_bit()/__test_and_set_bit allows to use an "unsigned int" for __state container, reducing by 8 bytes Qdisc size. Introduce helpers to hide implementation details. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jesper Dangaard Brouer <hawk@diku.dk> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Jamal Hadi Salim <hadi@cyberus.ca> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10net_sched: factorize qdisc stats handlingEric Dumazet
HTB takes into account skb is segmented in stats updates. Generalize this to all schedulers. They should use qdisc_bstats_update() helper instead of manipulating bstats.bytes and bstats.packets Add bstats_update() helper too for classes that use gnet_stats_basic_packed fields. Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no stab is setup on qdisc. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21net_sched: remove the unused parameter of qdisc_create_dflt()Changli Gao
The first parameter dev isn't in use in qdisc_create_dflt(). Signed-off-by: Changli Gao <xiaosuo@gmail.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-01net/sched/sch_hfsc.c: initialize parent's cl_cfmin properly in init_vf()Michal Soltys
This patch fixes init_vf() function, so on each new backlog period parent's cl_cfmin is properly updated (including further propgation towards the root), even if the activated leaf has no upperlimit curve defined. Signed-off-by: Michal Soltys <soltys@ziu.info> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net_sched: sch_hfsc: fix classification loopsPatrick McHardy
When attaching filters to a class pointing to a class higher up in the hierarchy, classification may enter an endless loop. Currently this is prevented for filters that are already resolved, but not for filters resolved at runtime. Only allow filters to point downwards in the hierarchy, similar to what CBQ does. Reported-by: Pawel Staszewski <pstaszewski@itcare.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07pkt_sched: gen_estimator: Dont report fake rate estimatorsEric Dumazet
Jarek Poplawski a écrit : > > > Hmm... So you made me to do some "real" work here, and guess what?: > there is one serious checkpatch warning! ;-) Plus, this new parameter > should be added to the function description. Otherwise: > Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> > > Thanks, > Jarek P. > > PS: I guess full "Don't" would show we really mean it... Okay :) Here is the last round, before the night ! Thanks again [RFC] pkt_sched: gen_estimator: Don't report fake rate estimators We currently send TCA_STATS_RATE_EST elements to netlink users, even if no estimator is running. # tc -s -d qdisc qdisc pfifo_fast 0: dev eth0 root bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 Sent 112833764978 bytes 1495081739 pkt (dropped 0, overlimits 0 requeues 0) rate 0bit 0pps backlog 0b 0p requeues 0 User has no way to tell if the "rate 0bit 0pps" is a real estimation, or a fake one (because no estimator is active) After this patch, tc command output is : $ tc -s -d qdisc qdisc pfifo_fast 0: dev eth0 root bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 Sent 561075 bytes 1196 pkt (dropped 0, overlimits 0 requeues 0) backlog 0b 0p requeues 0 We add a parameter to gnet_stats_copy_rate_est() function so that it can use gen_estimator_active(bstats, r), as suggested by Jarek. This parameter can be NULL if check is not necessary, (htb for example has a mandatory rate estimator) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-06net_sched: remove some unnecessary checks in classful schedulersPatrick McHardy
The class argument to the ->graft(), ->leaf(), ->dump(), ->dump_stats() all originate from either ->get() or ->walk() and are always valid. Remove unnecessary checks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-17net: restore gnet_stats_basic to previous definitionEric Dumazet
In 5e140dfc1fe87eae27846f193086724806b33c7d "net: reorder struct Qdisc for better SMP performance" the definition of struct gnet_stats_basic changed incompatibly, as copies of this struct are shipped to userland via netlink. Restoring old behavior is not welcome, for performance reason. Fix is to use a private structure for kernel, and teach gnet_stats_copy_basic() to convert from kernel to user land, using legacy structure (struct gnet_stats_basic) Based on a report and initial patch from Michael Spang. Reported-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09pkt_sched: Use PSCHED_SHIFT in PSCHED time conversionJarek Poplawski
Use PSCHED_SHIFT constant instead of '10' in PSCHED_US2NS() and PSCHED_NS2US() macros to enable changing this value later. Additionally use PSCHED_SHIFT in sch_hfsc SM_SHIFT and ISM_SHIFT definitions. This part of the patch is based on feedback from Patrick McHardy <kaber@trash.net>. Reported-by: Antonio Almeida <vexwek@gmail.com> Tested-by: Antonio Almeida <vexwek@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-15pkt_sched: Change misleading code in class delete.Jarek Poplawski
While looking for a possible reason of bugzilla report on HTB oops: http://bugzilla.kernel.org/show_bug.cgi?id=12858 I found the code in htb_delete calling htb_destroy_class on zero refcount is very misleading: it can suggest this is a common path, and destroy is called under sch_tree_lock. Actually, this can never happen like this because before deletion cops->get() is done, and after delete a class is still used by tclass_notify. The class destroy is always called from cops->put(), so without sch_tree_lock. This doesn't mean much now (since 2.6.27) because all vulnerable calls were moved from htb_destroy_class to htb_delete, but there was a bug in older kernels. The same change is done for other classful scheds, which, it seems, didn't have similar locking problems here. Reported-by: m0sia <m0sia@m0sia.ru> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01pkt_sched: sch_hfsc: sch_htb: Add non-work-conserving warning handler.Jarek Poplawski
Patrick McHardy <kaber@trash.net> suggested: > How about making this flag and the warning message (in a out-of-line > function) globally available? Other qdiscs (f.i. HFSC) can't deal with > inner non-work-conserving qdiscs as well. This patch uses qdisc->flags field of "suspected" child qdisc. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25tc: check for errors in gen_rate_estimator creationStephen Hemminger
The functions gen_new_estimator and gen_replace_estimator can return errors, but they were being ignored. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25pkt_sched: fix warning in net/sched/sch_hfsc.cIngo Molnar
this warning: net/sched/sch_hfsc.c: In function ‘hfsc_enqueue’: net/sched/sch_hfsc.c:1577: warning: ‘err’ may be used uninitialized in this function triggers because GCC does not recognize the (correct) error flow between hfsc_classify(), 'cl' and 'err'. Annotate it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20pkt_sched: remove unnecessary xchg() in packet schedulersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-13pkt_sched: Remove qdisc->ops->requeue() etc.Jarek Poplawski
After implementing qdisc->ops->peek() and changing sch_netem into classless qdisc there are no more qdisc->ops->requeue() users. This patch removes this method with its wrappers (qdisc_requeue()), and also unused qdisc->requeue structure. There are a few minor fixes of warnings (htb_enqueue()) and comments btw. The idea to kill ->requeue() and a similar patch were first developed by David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31pkt_sched: Add peek emulation for non-work-conserving qdiscs.Jarek Poplawski
This patch adds qdisc_peek_dequeued() wrapper to emulate peek method with qdisc->dequeue() and storing "peeked" skb in qdisc->gso_skb until dequeuing. This is mainly for compatibility reasons not to break some strange configs because peeking is expected for non-work-conserving parent qdiscs to query work-conserving child qdiscs. This implementation requires using qdisc_dequeue_peeked() wrapper instead of directly calling qdisc->dequeue() for all qdiscs ever querried with qdisc->ops->peek() or qdisc_peek_dequeued(). Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31pkt_sched: Use qdisc->ops->peek() instead of ->dequeue() & ->requeue()Jarek Poplawski
Use qdisc->ops->peek() instead of ->dequeue() & ->requeue() pair. After this patch the only remaining user of qdisc->ops->requeue() is netem_enqueue(). Based on ideas of Herbert Xu, Patrick McHardy and David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
