path: root/net/sched/sch_ingress.c
2011-01-10net_sched: factorize qdisc stats handlingEric Dumazet
HTB takes into account skb is segmented in stats updates. Generalize this to all schedulers. They should use qdisc_bstats_update() helper instead of manipulating bstats.bytes and bstats.packets Add bstats_update() helper too for classes that use gnet_stats_basic_packed fields. Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no stab is setup on qdisc. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: make cls_ops->change and cls_ops->delete optionalPatrick McHardy
Some schedulers don't support creating, changing or deleting classes. Make the respective callbacks optionally and consistently return -EOPNOTSUPP for unsupported operations, instead of currently either -EOPNOTSUPP, -ENOSYS or no error. In case of sch_prio and sch_multiq, the removed operations additionally checked for an invalid class. This is not necessary since the class argument can only orginate from ->get() or in case of ->change is 0 for creation of new classes, in which case ->change() incorrectly returned -ENOENT. As a side-effect, this patch fixes a possible (root-only) NULL pointer function call in sch_ingress, which didn't implement a so far mandatory ->delete() operation. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04net_sched: fix class grafting errno codesPatrick McHardy
If the parent qdisc doesn't support classes, use EOPNOTSUPP. If the parent class doesn't exist, use ENOENT. Currently EINVAL is returned in both cases. Additionally check whether grafting is supported and remove a now unnecessary graft function from sch_ingress. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-20net_sched: Add accessor function for packet length for qdiscsJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-01net-sched: change tcf_destroy_chain() to clear start of filter listPatrick McHardy
Pass double tcf_proto pointers to tcf_destroy_chain() to make it clear the start of the filter list for more consistency. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NET_SCHED]: sch_ingress: remove netfilter supportPatrick McHardy
Since the old policer code is gone, TC actions are needed for policing. The ingress qdisc can get packets directly from netif_receive_skb() in case TC actions are enabled or through netfilter otherwise, but since without TC actions there is no policer the only thing it actually does is count packets. Remove the netfilter support and always require TC actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Use nla_nest_start/nla_nest_endPatrick McHardy
Use nla_nest_start/nla_nest_end for dumping nested attributes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_ingress: remove useless printkPatrick McHardy
The printk about ingress qdisc registration error can't be triggered under normal circumstances. Since register_qdisc only fails for two identical registrations, the only way to trigger it is by loading the sch_ingress modules multiple times under different names, in which case we already return -EEXIST to userspace. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_ingress: avoid a few #ifdefsPatrick McHardy
Move the repeating "ifndef CONFIG_NET_CLS_ACT/ifdef CONFIG_NETFILTER" ifdefs into a single condition. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_ingress: move dependencies to KconfigPatrick McHardy
Instead of complaining at scheduler initialization time, check the dependencies in Kconfig. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_ingress: remove unnecessary opsPatrick McHardy
- ->reset is optional - sch_api provides identical defaults for ->dequeue/->requeue - ->drop can't happen since ingress never has a parent qdisc Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_ingress: return proper error code in ingress_graft()Patrick McHardy
2008-01-28[NET_SCHED]: sch_ingress: remove unused inner qdiscPatrick McHardy
2008-01-28[NET_SCHED]: sch_ingress: remove qdisc_priv() wrapperPatrick McHardy
2008-01-28[NET_SCHED]: sch_ingress: remove excessive debuggingPatrick McHardy
Remove excessive debugging statements and some "future use" stuff. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_ingress: formatting fixesPatrick McHardy
2008-01-28[NETFILTER]: Mark hooks __read_mostlyPatrick McHardy
2008-01-28[NETFILTER]: Use nf_register_hooks for multiple registrationsPatrick McHardy
2008-01-28[NET]: Move Qdisc_class_ops and Qdisc_ops in appropriate sections.Eric Dumazet
Qdisc_class_ops are const, and Qdisc_ops are mostly read. Using "const" and "__read_mostly" qualifiers helps to reduce false sharing. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET_SCHED]: Fix prio/ingress classification logic errorPatrick McHardy
Fix handling of empty or completely non-matching filter chains. In that case -1 is returned and tcf_result is uninitialized, the qdisc should fall back to default classification in that case. Noticed by PJ Waskiewicz <peter.p.waskiewicz.jr@intel.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: Kill CONFIG_NET_CLS_POLICEPatrick McHardy
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE, remove the old code. The config option will be kept around to select the equivalent NET_CLS_ACT options for a short time to allow easier upgrades. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: ingress: switch back to using ingress_lockPatrick McHardy
Switch ingress queueing back to use ingress_lock. qdisc_lock_tree now locks both the ingress and egress qdiscs on the device. All changes to data that might be used on both ingress and egress needs to be protected by using qdisc_lock_tree instead of manually taking dev->queue_lock. Additionally the qdisc stats_lock needs to be initialized to ingress_lock for ingress qdiscs. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Unline tcf_destroyPatrick McHardy
Uninline tcf_destroy and add a helper function to destroy an entire filter chain. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
