Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
After previous patch these functions are identical.
Replace __skb_dequeue in qdiscs with __qdisc_dequeue_head.
Next patch will then make __qdisc_dequeue_head handle
single-linked list instead of strcut sk_buff_head argument.
Doesn't change generated code.
Qdisc performance suffers when packets are dropped at enqueue()
time because drops (kfree_skb()) are done while qdisc lock is held,
delaying a dequeue() draining the queue.
Nominal throughput can be reduced by 50 % when this happens,
at a time we would like the dequeue() to proceed as fast as possible.
Even FQ is vulnerable to this problem, while one of FQ goals was
to provide some flow isolation.
This patch adds a 'struct sk_buff **to_free' parameter to all
qdisc->enqueue(), and in qdisc_drop() helper.
I measured a performance increase of up to 12 %, but this patch
is a prereq so that future batches in enqueue() can fly.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
pie_change() can use rtnl_qdisc_drop() to benefit from
deferred freeing.
pie_reset() is already using qdisc_reset_queue()
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Vijay Subramanian <vijaynsu@cisco.com>
This adds helpers to manipulate qstats logic and replaces locations
that touch the counters directly. This simplifies future patches
to push qstats onto per cpu counters.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Fix incorrect comment reported by Norbert Kiesel. Edit another comment to add
more details. Also add references to algorithm (IETF draft and paper) to top of
file.
Signed-off-by: Vijay Subramanian <subramanian.vijay@gmail.com>
CC: Mythili Prabhu <mysuryan@cisco.com>
CC: Norbert Kiesel <nkiesel@gmail.com>
This patch removes the net_random and net_srandom macros and replaces
them with direct calls to the prandom ones. As new commits only seem to
use prandom_u32 there is no use to keep them around.
This change makes it easier to grep for users of prandom_u32.
Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Proportional Integral controller Enhanced (PIE) is a scheduler to address the
bufferbloat problem.
>From the IETF draft below:
" Bufferbloat is a phenomenon where excess buffers in the network cause high
latency and jitter. As more and more interactive applications (e.g. voice over
IP, real time video streaming and financial transactions) run in the Internet,
high latency and jitter degrade application performance. There is a pressing
need to design intelligent queue management schemes that can control latency and
jitter; and hence provide desirable quality of service to users.
We present here a lightweight design, PIE(Proportional Integral controller
Enhanced) that can effectively control the average queueing latency to a target
value. Simulation results, theoretical analysis and Linux testbed results have
shown that PIE can ensure low latency and achieve high link utilization under
various congestion situations. The design does not require per-packet
timestamp, so it incurs very small overhead and is simple enough to implement
in both hardware and software. "
Many thanks to Dave Taht for extensive feedback, reviews, testing and
suggestions. Thanks also to Stephen Hemminger and Eric Dumazet for reviews and
suggestions. Naeem Khademi and Dave Taht independently contributed to ECN
support.
For more information, please see technical paper about PIE in the IEEE
Conference on High Performance Switching and Routing 2013. A copy of the paper
can be found at ftp://ftpeng.cisco.com/pie/.
Please also refer to the IETF draft submission at
http://tools.ietf.org/html/draft-pan-tsvwg-pie-00
All relevant code, documents and test scripts and results can be found at
For problems with the iproute2/tc or Linux kernel code, please contact Vijay
Subramanian (vijaynsu@cisco.com or subramanian.vijay@gmail.com) Mythili Prabhu
(mysuryan@cisco.com)
Signed-off-by: Mythili Prabhu <mysuryan@cisco.com>
CC: Dave Taht <dave.taht@bufferbloat.net>
