path: root/net/sched/sch_prio.c
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move Qdisc_class_ops and Qdisc_ops in appropriate sections.Eric Dumazet
Qdisc_class_ops are const, and Qdisc_ops are mostly read. Using "const" and "__read_mostly" qualifiers helps to reduce false sharing. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-23[PKT_SCHED]: Fix sch_prio.c build with CONFIG_NETDEVICES_MULTIQUEUEPavel Emelyanov
Fix one more user of netiff_subqueue_stopped. To check for the queue id one must use the __netiff_subqueue_stoped call. This run out of my sight when I made the: 668f895a85b0c3a62a690425145f13dabebebd7a [NET]: Hide the queue_mapping field inside netif_subqueue_stopped commit :( Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-30[NET_SCHED] sch_prio.c: remove duplicate call of tc_classify()Lucas Nussbaum
When CONFIG_NET_CLS_ACT is enabled, tc_classify() is called twice in prio_classify(). This causes "interesting" behaviour: with the setup below, packets are duplicated, sent twice to ifb0, and then loop in and out of ifb0. The patch uses the previously calculated return value in the switch, which is probably what Patrick had in mind in commit bdba91ec70fb5ccbdeb1c7068319adc6ea9e1a7d -- maybe Patrick can double-check this? -- example setup -- ifconfig ifb0 up tc qdisc add dev ifb0 root netem delay 2s tc qdisc add dev $ETH root handle 1: prio tc filter add dev $ETH parent 1: protocol ip prio 10 u32 \ match ip dst 172.24.110.6/32 flowid 1:1 \ action mirred egress redirect dev ifb0 ping -c1 172.24.110.6 Signed-off-by: Lucas Nussbaum <lucas.nussbaum@imag.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: Fix prio_tune() handling of root qdisc.Peter P Waskiewicz Jr
Fix the check in prio_tune() to see if sch->parent is TC_H_ROOT instead of sch->handle to load or reject the qdisc for multiqueue devices. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET_SCHED]: Fix prio/ingress classification logic errorPatrick McHardy
Fix handling of empty or completely non-matching filter chains. In that case -1 is returned and tcf_result is uninitialized, the qdisc should fall back to default classification in that case. Noticed by PJ Waskiewicz <peter.p.waskiewicz.jr@intel.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-07-10[SCHED]: Qdisc changes and sch_rr added for multiqueuePeter P Waskiewicz Jr
Add the new sch_rr qdisc for multiqueue network device support. Allow sch_prio and sch_rr to be compiled with or without multiqueue hardware support. sch_rr is part of sch_prio, and is referenced from MODULE_ALIAS. This was done since sch_prio and sch_rr only differ in their dequeue routine. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-14[NET_SCHED]: prio qdisc boundary conditionJamal Hadi Salim
This fixes an out-of-boundary condition when the classified band equals q->bands. Caught by Alexey Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Unline tcf_destroyPatrick McHardy
Uninline tcf_destroy and add a helper function to destroy an entire filter chain. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NET_SCHED] sch_prio: class statistics printing enabledJarek Poplawski
This patch adds a dump_stats callback to enable printing of basic statistics of prio classes. (With help of Patrick McHardy). Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops (part 2): "simple" qdiscsPatrick McHardy
Convert the "simple" qdiscs to use qdisc_tree_decrease_qlen() where necessary: - all graft operations - destruction of old child qdiscs in prio, red and tbf change operation - purging of queue in sfq change operation Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Set parent classid in default qdiscsPatrick McHardy
Set parent classids in default qdiscs to allow walking up the tree from outside the qdiscs. This is needed by the next patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PKT_SCHED]: Qdisc drop operation is optionalPatrick McHardy
The drop operation is optional and qdiscs must check if childs support it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[PKT_SCHED] sch_prio: fix qdisc bands initAmnon Aaronsohn
Currently when PRIO is configured to use N bands, it lets the packets be directed to any of the bands 0..N-1. However, PRIO attaches a fifo qdisc only to the bands that appear in the priomap; the rest of the N bands remain with a noop qdisc attached. This patch changes PRIO's behavior so that it attaches a fifo qdisc to all of the N bands. Signed-off-by: Amnon Aaronsohn <bla@cs.huji.ac.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[PKT_SCHED]: Fix qdisc return code.Jamal Hadi Salim
The mapping between TC_ACTION_SHOT and the qdisc return codes is better suited to NET_XMIT_BYPASS so as not to confuse TCP Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
