[ Upstream commit 44a63b137f7b6e4c7bd6c9cc21615941cb36509d ]
Hangbin reported an Oops triggered by the syzkaller qdisc rules:
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN PTI
Modules linked in: sch_red
CPU: 0 PID: 28699 Comm: syz-executor5 Not tainted 4.17.0-rc4.kcov #1
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
RIP: 0010:qdisc_hash_add+0x26/0xa0
RSP: 0018:ffff8800589cf470 EFLAGS: 00010203
RAX: dffffc0000000000 RBX: 0000000000000000 RCX: ffffffff824ad971
RDX: 0000000000000007 RSI: ffffc9000ce9f000 RDI: 000000000000003c
RBP: 0000000000000001 R08: ffffed000b139ea2 R09: ffff8800589cf4f0
R10: ffff8800589cf50f R11: ffffed000b139ea2 R12: ffff880054019fc0
R13: ffff880054019fb4 R14: ffff88005c0af600 R15: ffff880054019fb0
FS: 00007fa6edcb1700(0000) GS:ffff88005ce00000(0000) knlGS:0000000000000000
CR2: 0000000020000740 CR3: 000000000fc16000 CR4: 00000000000006f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
red_change+0x2d2/0xed0 [sch_red]
qdisc_create+0x57e/0xef0
tc_modify_qdisc+0x47f/0x14e0
rtnetlink_rcv_msg+0x6a8/0x920
netlink_rcv_skb+0x2a2/0x3c0
netlink_unicast+0x511/0x740
netlink_sendmsg+0x825/0xc30
sock_sendmsg+0xc5/0x100
___sys_sendmsg+0x778/0x8e0
__sys_sendmsg+0xf5/0x1b0
do_syscall_64+0xbd/0x3b0
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x450869
RSP: 002b:00007fa6edcb0c48 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00007fa6edcb16b4 RCX: 0000000000450869
RDX: 0000000000000000 RSI: 00000000200000c0 RDI: 0000000000000013
RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 0000000000008778 R14: 0000000000702838 R15: 00007fa6edcb1700
Code: e9 0b fe ff ff 0f 1f 44 00 00 55 53 48 89 fb 89 f5 e8 3f 07 f3 fe 48 8d 7b 3c 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <0f> b6 14 02 48 89 f8 83 e0 07 83 c0 03 38 d0 7c 04 84 d2 75 51
RIP: qdisc_hash_add+0x26/0xa0 RSP: ffff8800589cf470
When a red qdisc is updated with a 0 limit, the child qdisc is left
unmodified, no additional scheduler is created in red_change(),
the 'child' local variable is rightfully NULL and must not add it
to the hash table.
This change addresses the above issue moving qdisc_hash_add() right
after the child qdisc creation. It additionally removes unneeded checks
for noop_qdisc.
Reported-by: Hangbin Liu <liuhangbin@gmail.com>
Fixes: 49b499718fa1 ("net: sched: make default fifo qdiscs appear in the dump")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
[ Upstream commit 8afa10cbe281b10371fee5a87ab266e48d71a7f9 ]
Check the qmin & qmax values doesn't overflow for the given Wlog value.
Check that qmin <= qmax.
Fixes: a783474591f2 ("[PKT_SCHED]: Generic RED layer")
Signed-off-by: Nogah Frankel <nogahf@mellanox.com>
For TC classes, their ->get() and ->put() are always paired, and the
reference counting is completely useless, because:
1) For class modification and dumping paths, we already hold RTNL lock,
so all of these ->get(),->change(),->put() are atomic.
2) For filter bindiing/unbinding, we use other reference counter than
this one, and they should have RTNL lock too.
3) For ->qlen_notify(), it is special because it is called on ->enqueue()
path, but we already hold qdisc tree lock there, and we hold this
tree lock when graft or delete the class too, so it should not be gone
or changed until we release the tree lock.
Therefore, this patch removes ->get() and ->put(), but:
1) Adds a new ->find() to find the pointer to a class by classid, no
refcnt.
2) Move the original class destroy upon the last refcnt into ->delete(),
right after releasing tree lock. This is fine because the class is
already removed from hash when holding the lock.
For those who also use ->put() as ->unbind(), just rename them to reflect
this change.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
The original reason [1] for having hidden qdiscs (potential scalability
issues in qdisc_match_from_root() with single linked list in case of large
amount of qdiscs) has been invalidated by 59cc1f61f0 ("net: sched: convert
qdisc linked list to hashtable").
This allows us for bringing more clarity and determinism into the dump by
making default pfifo qdiscs visible.
We're not turning this on by default though, at it was deemed [2] too
intrusive / unnecessary change of default behavior towards userspace.
Instead, TCA_DUMP_INVISIBLE netlink attribute is introduced, which allows
applications to request complete qdisc hierarchy dump, including the
ones that have always been implicit/invisible.
Singleton noop_qdisc stays invisible, as teaching the whole infrastructure
about singletons would require quite some surgery with very little gain
(seeing no qdisc or seeing noop qdisc in the dump is probably setting
the same user expectation).
[1] http://lkml.kernel.org/r/1460732328.10638.74.camel@edumazet-glaptop3.roam.corp.google.com
[2] http://lkml.kernel.org/r/20161021.105935.1907696543877061916.davem@davemloft.net
Qdisc performance suffers when packets are dropped at enqueue()
time because drops (kfree_skb()) are done while qdisc lock is held,
delaying a dequeue() draining the queue.
Nominal throughput can be reduced by 50 % when this happens,
at a time we would like the dequeue() to proceed as fast as possible.
Even FQ is vulnerable to this problem, while one of FQ goals was
to provide some flow isolation.
This patch adds a 'struct sk_buff **to_free' parameter to all
qdisc->enqueue(), and in qdisc_drop() helper.
I measured a performance increase of up to 12 %, but this patch
is a prereq so that future batches in enqueue() can fly.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
net/sched/act_police.c
net/sched/sch_drr.c
net/sched/sch_hfsc.c
net/sched/sch_prio.c
net/sched/sch_red.c
net/sched/sch_tbf.c
In net-next the drop methods of the packet schedulers got removed, so
the bug fixes to them in 'net' are irrelevant.
A packet action unload crash fix conflicts with the addition of the
new firstuse timestamp.
after removal of TCA_CBQ_OVL_STRATEGY from cbq scheduler, there are no
more callers of ->drop() outside of other ->drop functions, i.e.
nothing calls them.
Fixes: 2ccccf5fb43f ("net_sched: update hierarchical backlog too")
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
Remove nearly duplicated code and prepare for the following patch.
This adds helpers to manipulate qstats logic and replaces locations
that touch the counters directly. This simplifies future patches
to push qstats onto per cpu counters.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
This patch splits the red_parms structure into two components.
One holding the RED 'constant' parameters, and one containing the
variables.
This permits a size reduction of GRED qdisc, and is a preliminary step
to add an optional RED unit to SFQ.
SFQRED will have a single red_parms structure shared by all flows, and a
private red_vars per flow.
CC: Dave Taht <dave.taht@gmail.com>
CC: Stephen Hemminger <shemminger@vyatta.com>
Now RED uses a Q0.32 number to store max_p (max probability), allow
RED/GRED/CHOKE to use/report full resolution at config/dump time.
Old tc binaries are non aware of new attributes, and still set/get Plog.
New tc binary set/get both Plog and max_p for backward compatibility,
they display "probability value" if they get max_p from new kernels.
# tc -d qdisc show dev ...
qdisc red 10: parent 1:1 limit 360Kb min 30Kb max 90Kb ecn ewma 5
probability 0.09 Scell_log 15
Make sure we avoid potential divides by 0 in reciprocal_value(), if
(max_th - min_th) is big.
Adaptative RED AQM for linux, based on paper from Sally FLoyd,
Ramakrishna Gummadi, and Scott Shenker, August 2001 :
http://icir.org/floyd/papers/adaptiveRed.pdf
Goal of Adaptative RED is to make max_p a dynamic value between 1% and
50% to reach the target average queue : (max_th - min_th) / 2
Every 500 ms:
if (avg > target and max_p <= 0.5)
increase max_p : max_p += alpha;
else if (avg < target and max_p >= 0.01)
decrease max_p : max_p *= beta;
target :[min_th + 0.4*(min_th - max_th),
min_th + 0.6*(min_th - max_th)].
alpha : min(0.01, max_p / 4)
beta : 0.9
max_P is a Q0.32 fixed point number (unsigned, with 32 bits mantissa)
Changes against our RED implementation are :
max_p is no longer a negative power of two (1/(2^Plog)), but a Q0.32
fixed point number, to allow full range described in Adatative paper.
To deliver a random number, we now use a reciprocal divide (thats really
a multiply), but this operation is done once per marked/droped packet
when in RED_BETWEEN_TRESH window, so added cost (compared to previous
AND operation) is near zero.
dump operation gives current max_p value in a new TCA_RED_MAX_P
attribute.
Example on a 10Mbit link :
tc qdisc add dev $DEV parent 1:1 handle 10: est 1sec 8sec red \
limit 400000 min 30000 max 90000 avpkt 1000 \
burst 55 ecn adaptative bandwidth 10Mbit
# tc -s -d qdisc show dev eth3
qdisc red 10: parent 1:1 limit 400000b min 30000b max 90000b ecn
adaptative ewma 5 max_p=0.113335 Scell_log 15
Sent 50414282 bytes 34504 pkt (dropped 35, overlimits 1392 requeues 0)
rate 9749Kbit 831pps backlog 72056b 16p requeues 0
marked 1357 early 35 pdrop 0 other 0
Le mercredi 30 novembre 2011 à 14:36 -0800, Stephen Hemminger a écrit :
> (Almost) nobody uses RED because they can't figure it out.
> According to Wikipedia, VJ says that:
> "there are not one, but two bugs in classic RED."
RED is useful for high throughput routers, I doubt many linux machines
act as such devices.
I was considering adding Adaptative RED (Sally Floyd, Ramakrishna
Gummadi, Scott Shender), August 2001
In this version, maxp is dynamic (from 1% to 50%), and user only have to
setup min_th (target average queue size)
(max_th and wq (burst in linux RED) are automatically setup)
By the way it seems we have a small bug in red_change()
if (skb_queue_empty(&sch->q))
red_end_of_idle_period(&q->parms);
First, if queue is empty, we should call
red_start_of_idle_period(&q->parms);
Second, since we dont use anymore sch->q, but q->qdisc, the test is
meaningless.
Oh well...
[PATCH] sch_red: fix red_change()
Now RED is classful, we must check q->qdisc->q.qlen, and if queue is empty,
we start an idle period, not end it.
net/sched/sch_htb.c
net/sched/sch_tbf.c
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed
a problem with pfifo_head drops that incorrectly decreased
sch->bstats.bytes and sch->bstats.packets
Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a
previously enqueued packet, and bstats cannot be changed, so
bstats/rates are not accurate (over estimated)
This patch changes the qdisc_bstats updates to be done at dequeue() time
instead of enqueue() time. bstats counters no longer account for dropped
frames, and rates are more correct, since enqueue() bursts dont have
effect on dequeue() rate.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Cleanup net/sched code to current CodingStyle and practices.
Reduce inline abuse
HTB takes into account skb is segmented in stats updates.
Generalize this to all schedulers.
They should use qdisc_bstats_update() helper instead of manipulating
bstats.bytes and bstats.packets
Add bstats_update() helper too for classes that use
gnet_stats_basic_packed fields.
Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no
stab is setup on qdisc.
Provide child qdisc backlog (byte count) information so that "tc -s
qdisc" can report it to user.
packet count is already correctly provided.
qdisc red 11: parent 1:11 limit 60Kb min 15Kb max 45Kb ecn
Sent 3116427684 bytes 1415782 pkt (dropped 8, overlimits 7866 requeues 0)
rate 242385Kbit 13630pps backlog 13560b 8p requeues 0
marked 7865 early 1 pdrop 7 other 0
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
The class argument to the ->graft(), ->leaf(), ->dump(), ->dump_stats() all
originate from either ->get() or ->walk() and are always valid.
Remove unnecessary checks.
Some schedulers don't support creating, changing or deleting classes.
Make the respective callbacks optionally and consistently return
-EOPNOTSUPP for unsupported operations, instead of currently either
-EOPNOTSUPP, -ENOSYS or no error.
In case of sch_prio and sch_multiq, the removed operations additionally
checked for an invalid class. This is not necessary since the class
argument can only orginate from ->get() or in case of ->change is 0
for creation of new classes, in which case ->change() incorrectly
returned -ENOENT.
As a side-effect, this patch fixes a possible (root-only) NULL pointer
function call in sch_ingress, which didn't implement a so far mandatory
->delete() operation.
Some qdiscs don't support attaching filters. Handle this centrally in
cls_api and return a proper errno code (EOPNOTSUPP) instead of EINVAL.
The use of xchg() hasn't been necessary since 2.2.something when proper
locking was added to packet schedulers.
After implementing qdisc->ops->peek() and changing sch_netem into
classless qdisc there are no more qdisc->ops->requeue() users. This
patch removes this method with its wrappers (qdisc_requeue()), and
also unused qdisc->requeue structure. There are a few minor fixes of
warnings (htb_enqueue()) and comments btw.
The idea to kill ->requeue() and a similar patch were first developed
by David S. Miller.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
Add qdisc->ops->peek() implementation for work-conserving qdiscs.
With feedback from Patrick McHardy.
Patrick McHardy <kaber@trash.net> noticed:
"The other problem that affects all qdiscs supporting actions is
TC_ACT_QUEUED/TC_ACT_STOLEN getting mapped to NET_XMIT_SUCCESS
even though the packet is not queued, corrupting upper qdiscs'
qlen counters."
and later explained:
"The reason why it translates it at all seems to be to not increase
the drops counter. Within a single qdisc this could be avoided by
other means easily, upper qdiscs would still increase the counter
when we return anything besides NET_XMIT_SUCCESS though.
This means we need a new NET_XMIT return value to indicate this to
the upper qdiscs. So I'd suggest to introduce NET_XMIT_STOLEN,
return that to upper qdiscs and translate it to NET_XMIT_SUCCESS
in dev_queue_xmit, similar to NET_XMIT_BYPASS."
David Miller <davem@davemloft.net> noticed:
"Maybe these NET_XMIT_* values being passed around should be a set of
bits. They could be composed of base meanings, combined with specific
attributes.
So you could say "NET_XMIT_DROP | __NET_XMIT_NO_DROP_COUNT"
The attributes get masked out by the top-level ->enqueue() caller,
such that the base meanings are the only thing that make their
way up into the stack. If it's only about communication within the
qdisc tree, let's simply code it that way."
This patch is trying to realize these ideas.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and
nla_nest_cancel() void functions.
Return -EMSGSIZE instead of -1 if the provided message buffer is not
big enough.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
nla_parse() returns more detailed errno codes, propagate them back on
error.
Convert packet schedulers to use the netlink API. Unfortunately a gradual
conversion is not possible without breaking compilation in the middle or
adding lots of casts, so this patch converts them all in one step. The
patch has been mostly generated automatically with some minor edits to
at least allow seperate conversion of classifiers and actions.
Qdisc_class_ops are const, and Qdisc_ops are mostly read.
Using "const" and "__read_mostly" qualifiers helps to reduce false
sharing.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Convert the "simple" qdiscs to use qdisc_tree_decrease_qlen() where
necessary:
- all graft operations
- destruction of old child qdiscs in prio, red and tbf change operation
- purging of queue in sfq change operation
Set parent classids in default qdiscs to allow walking up the tree
from outside the qdiscs. This is needed by the next patch.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Convert sch_red to a classful qdisc. All qdiscs that maintain accurate
backlog counters are eligible as child qdiscs. When a queue limit larger
than zero is given, a bfifo qdisc is used for backwards compatibility.
Current versions of tc enforce a limit larger than zero, other users
can avoid creating the default qdisc by using zero.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
Introduces a new flag TC_RED_HARDDROP which specifies that if ECN
marking is enabled packets should still be dropped once the
average queue length exceeds the maximum threshold.
This _may_ help to avoid global synchronisation during small
bursts of peers advertising but not caring about ECN. Use this
option very carefully, it does more harm than good if
(qth_max - qth_min) does not cover at least two average burst
cycles.
The difference to the current behaviour, in which we'd run into
the hard queue limit, is that due to the low pass filter of RED
short bursts are less likely to cause a global synchronisation.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Removes the skb trimming code which is not needed since we never
touch the skb upon failure. Removes unnecessary includes,
initializers, and simplifies the code a bit. Removes Jamal's
obsolete email addresses upon his own request.
We should not interrupt and restart an idle period while idling already.
Simplifies code a lot by separating the red algorithm and the
queueing logic. We now differentiate between probability marks
and forced marks but sum them together again to not break
This is part of the grand scheme to eliminate the qlen
member of skb_queue_head, and subsequently remove the
'list' member of sk_buff.
Most users of skb_queue_len() want to know if the queue is
empty or not, and that's trivially done with skb_queue_empty()
which doesn't use the skb_queue_head->qlen member and instead
uses the queue list emptyness as the test.
