path: root/net/sched/sch_tbf.c
2012-04-01pkt_sched: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-29sch_tbf: report backlog informationEric Dumazet
Provide child qdisc backlog (byte count) information so that "tc -s qdisc" can report it to user. qdisc netem 30: root refcnt 18 limit 1000 delay 20.0ms 10.0ms Sent 948517 bytes 898 pkt (dropped 0, overlimits 0 requeues 1) rate 175056bit 16pps backlog 114b 1p requeues 1 qdisc tbf 40: parent 30: rate 256000bit burst 20Kb/8 mpu 0b lat 0us Sent 948517 bytes 898 pkt (dropped 15, overlimits 611 requeues 0) backlog 18168b 12p requeues 0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/sched/sch_hfsc.c net/sched/sch_htb.c net/sched/sch_tbf.c
2011-01-20net_sched: accurate bytes/packets stats/ratesEric Dumazet
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed a problem with pfifo_head drops that incorrectly decreased sch->bstats.bytes and sch->bstats.packets Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a previously enqueued packet, and bstats cannot be changed, so bstats/rates are not accurate (over estimated) This patch changes the qdisc_bstats updates to be done at dequeue() time instead of enqueue() time. bstats counters no longer account for dropped frames, and rates are more correct, since enqueue() bursts dont have effect on dequeue() rate. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20net_sched: move TCQ_F_THROTTLED flagEric Dumazet
In commit 371121057607e (net: QDISC_STATE_RUNNING dont need atomic bit ops) I moved QDISC_STATE_RUNNING flag to __state container, located in the cache line containing qdisc lock and often dirtied fields. I now move TCQ_F_THROTTLED bit too, so that we let first cache line read mostly, and shared by all cpus. This should speedup HTB/CBQ for example. Not using test_bit()/__clear_bit()/__test_and_set_bit allows to use an "unsigned int" for __state container, reducing by 8 bytes Qdisc size. Introduce helpers to hide implementation details. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> CC: Jesper Dangaard Brouer <hawk@diku.dk> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Jamal Hadi Salim <hadi@cyberus.ca> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10net_sched: factorize qdisc stats handlingEric Dumazet
HTB takes into account skb is segmented in stats updates. Generalize this to all schedulers. They should use qdisc_bstats_update() helper instead of manipulating bstats.bytes and bstats.packets Add bstats_update() helper too for classes that use gnet_stats_basic_packed fields. Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no stab is setup on qdisc. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10net: Use NET_XMIT_SUCCESS where possible.Ben Greear
This is based on work originally done by Patric McHardy. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17tbf: stop wanton destruction of children (v2)stephen hemminger
Several netem users use TBF for rate control. But every time the parameters of TBF are changed it destroys the child qdisc, requiring reconfigation. Better to just keep child qdisc and just notify it of changed limit. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: remove some unnecessary checks in classful schedulersPatrick McHardy
The class argument to the ->graft(), ->leaf(), ->dump(), ->dump_stats() all originate from either ->get() or ->walk() and are always valid. Remove unnecessary checks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: make cls_ops->change and cls_ops->delete optionalPatrick McHardy
Some schedulers don't support creating, changing or deleting classes. Make the respective callbacks optionally and consistently return -EOPNOTSUPP for unsupported operations, instead of currently either -EOPNOTSUPP, -ENOSYS or no error. In case of sch_prio and sch_multiq, the removed operations additionally checked for an invalid class. This is not necessary since the class argument can only orginate from ->get() or in case of ->change is 0 for creation of new classes, in which case ->change() incorrectly returned -ENOENT. As a side-effect, this patch fixes a possible (root-only) NULL pointer function call in sch_ingress, which didn't implement a so far mandatory ->delete() operation. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: make cls_ops->tcf_chain() optionalPatrick McHardy
Some qdiscs don't support attaching filters. Handle this centrally in cls_api and return a proper errno code (EOPNOTSUPP) instead of EINVAL. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21net/*: use linux/kernel.h swap()Ilpo Järvinen
tcp_sack_swap seems unnecessary so I pushed swap to the caller. Also removed comment that seemed then pointless, and added include when not already there. Compile tested. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20pkt_sched: remove unnecessary xchg() in packet schedulersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-13pkt_sched: Remove qdisc->ops->requeue() etc.Jarek Poplawski
After implementing qdisc->ops->peek() and changing sch_netem into classless qdisc there are no more qdisc->ops->requeue() users. This patch removes this method with its wrappers (qdisc_requeue()), and also unused qdisc->requeue structure. There are a few minor fixes of warnings (htb_enqueue()) and comments btw. The idea to kill ->requeue() and a similar patch were first developed by David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31pkt_sched: Add peek emulation for non-work-conserving qdiscs.Jarek Poplawski
This patch adds qdisc_peek_dequeued() wrapper to emulate peek method with qdisc->dequeue() and storing "peeked" skb in qdisc->gso_skb until dequeuing. This is mainly for compatibility reasons not to break some strange configs because peeking is expected for non-work-conserving parent qdiscs to query work-conserving child qdiscs. This implementation requires using qdisc_dequeue_peeked() wrapper instead of directly calling qdisc->dequeue() for all qdiscs ever querried with qdisc->ops->peek() or qdisc_peek_dequeued(). Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31pkt_sched: Use qdisc->ops->peek() instead of ->dequeue() & ->requeue()Jarek Poplawski
Use qdisc->ops->peek() instead of ->dequeue() & ->requeue() pair. After this patch the only remaining user of qdisc->ops->requeue() is netem_enqueue(). Based on ideas of Herbert Xu, Patrick McHardy and David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18pkt_sched: Fix return value corruption in HTB and TBF.David S. Miller
Based upon a bug report by Josip Rodin. Packet schedulers should only return NET_XMIT_DROP iff the packet really was dropped. If the packet does reach the device after we return NET_XMIT_DROP then TCP can crash because it depends upon the enqueue path return values being accurate. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04net_sched: Add qdisc __NET_XMIT_STOLEN flagJarek Poplawski
Patrick McHardy <kaber@trash.net> noticed: "The other problem that affects all qdiscs supporting actions is TC_ACT_QUEUED/TC_ACT_STOLEN getting mapped to NET_XMIT_SUCCESS even though the packet is not queued, corrupting upper qdiscs' qlen counters." and later explained: "The reason why it translates it at all seems to be to not increase the drops counter. Within a single qdisc this could be avoided by other means easily, upper qdiscs would still increase the counter when we return anything besides NET_XMIT_SUCCESS though. This means we need a new NET_XMIT return value to indicate this to the upper qdiscs. So I'd suggest to introduce NET_XMIT_STOLEN, return that to upper qdiscs and translate it to NET_XMIT_SUCCESS in dev_queue_xmit, similar to NET_XMIT_BYPASS." David Miller <davem@davemloft.net> noticed: "Maybe these NET_XMIT_* values being passed around should be a set of bits. They could be composed of base meanings, combined with specific attributes. So you could say "NET_XMIT_DROP | __NET_XMIT_NO_DROP_COUNT" The attributes get masked out by the top-level ->enqueue() caller, such that the base meanings are the only thing that make their way up into the stack. If it's only about communication within the qdisc tree, let's simply code it that way." This patch is trying to realize these ideas. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-20net_sched: Add accessor function for packet length for qdiscsJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-20net_sched: Add qdisc_enqueue wrapperJussi Kivilinna
2008-07-05net-sched: consolidate default fifo qdisc setupPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in packet schedulersPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_nest_start/nla_nest_endPatrick McHardy
Use nla_nest_start/nla_nest_end for dumping nested attributes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move Qdisc_class_ops and Qdisc_ops in appropriate sections.Eric Dumazet
Qdisc_class_ops are const, and Qdisc_ops are mostly read. Using "const" and "__read_mostly" qualifiers helps to reduce false sharing. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET_SCHED]: Cleanup L2T macros and handle oversized packetsJesper Dangaard Brouer
Change L2T (length to time) macros, in all rate based schedulers, to call a common function qdisc_l2t() that does the rate table lookup. This function handles if the packet size lookup is larger than the rate table, which often occurs with TSO enabled. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: Kill CONFIG_NET_CLS_POLICEPatrick McHardy
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE, remove the old code. The config option will be kept around to select the equivalent NET_CLS_ACT options for a short time to allow easier upgrades. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15[NET_SCHED]: act_api: qdisc internal reclassify supportPatrick McHardy
The behaviour of NET_CLS_POLICE for TC_POLICE_RECLASSIFY was to return it to the qdisc, which could handle it internally or ignore it. With NET_CLS_ACT however, tc_classify starts over at the first classifier and never returns it to the qdisc. This makes it impossible to support qdisc-internal reclassification, which in turn makes it impossible to remove the old NET_CLS_POLICE code without breaking compatibility since we have two qdiscs (CBQ and ATM) that support this. This patch adds a tc_classify_compat function that handles reclassification the old way and changes CBQ and ATM to use it. This again is of course not fully backwards compatible with the previous NET_CLS_ACT behaviour. Unfortunately there is no way to fully maintain compatibility *and* support qdisc internal reclassification with NET_CLS_ACT, but this seems like the better choice over keeping the two incompatible options around forever. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET_SCHED]: Remove unnecessary includesPatrick McHardy
2007-04-25[NET_SCHED]: turn PSCHED_GET_TIME into inline functionPatrick McHardy
2007-04-25[NET_SCHED]: turn PSCHED_TDIFF_SAFE into inline functionPatrick McHardy
Also rename to psched_tdiff_bounded. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: sch_tbf: use hrtimer based watchdogPatrick McHardy
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops (part 5): netem/tbf/hfsc ->requeue failuresPatrick McHardy
When peeking at the next packet in a child qdisc by calling dequeue/requeue, the upper qdisc qlen counter may get out of sync in case the requeue fails. The qdisc and the child qdisc both have their counter decremented, but since no packet is given to the upper qdisc it won't decrement its counter itself. requeue should not fail, so this is mostly for "correctness". Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops (part 2): "simple" qdiscsPatrick McHardy
Convert the "simple" qdiscs to use qdisc_tree_decrease_qlen() where necessary: - all graft operations - destruction of old child qdiscs in prio, red and tbf change operation - purging of queue in sfq change operation Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Set parent classid in default qdiscsPatrick McHardy
Set parent classids in default qdiscs to allow walking up the tree from outside the qdiscs. This is needed by the next patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PKT_SCHED]: Restore TBF change semanticPatrick McHardy
When TBF was converted to a classful qdisc, the semantic of the limit parameter was broken. On initilization an inner bfifo qdisc is created for backwards compatibility, when changing parameters however the new limit is ignored and the current child qdisc remains in place. Always replace the child qdisc by the default bfifo when limit is above zero, otherwise don't touch the inner qdisc. Current tc version enforce a limit above zero, other users can avoid creating the inner qdisc by using zero. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PKT_SCHED]: Qdisc drop operation is optionalPatrick McHardy
The drop operation is optional and qdiscs must check if childs support it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
