path: root/net/sched
2010-02-08net/sched: Fix module name in KconfigJan Luebbe
The action modules have been prefixed with 'act_', but the Kconfig description was not changed. Signed-off-by: Jan Luebbe <jluebbe@debian.org> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-20net: rename skb->iif to skb->skb_iifEric Dumazet
To help grep games, rename iif to skb_iif Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18netsched: Allow var_sk_bound_if meta to work on all namespacesEric Dumazet
This fix can probably wait 2.6.33, or should use another patch if needed in 2.6.32 (no get_dev_by_index_rcu() before 2.6.33) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17act_mirred: optimization.Changli Gao
move checking if eaction is valid in tcf_mirred_init() Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17act_mirred: cleanupChangli Gao
1. don't let go back using goto. 2. don't call skb_act_clone() until it is necessary. 3. one exit of the critical context. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15net: Optimize hard_start_xmit() return checkingJarek Poplawski
Recent changes in the TX error propagation require additional checking and masking of values returned from hard_start_xmit(), mainly to separate cases where skb was consumed. This aim can be simplified by changing the order of NETDEV_TX and NET_XMIT codes, because the latter are treated similarly to negative (ERRNO) values. After this change much simpler dev_xmit_complete() is also used in sch_direct_xmit(), so it is moved to netdevice.h. Additionally NET_RX definitions in netdevice.h are moved up from between TX codes to avoid confusion while reading the TX comment. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13net: allow to propagate errors through ->ndo_hard_start_xmit()Patrick McHardy
Currently the ->ndo_hard_start_xmit() callbacks are only permitted to return one of the NETDEV_TX codes. This prevents any kind of error propagation for virtual devices, like queue congestion of the underlying device in case of layered devices, or unreachability in case of tunnels. This patches changes the NET_XMIT codes to avoid clashes with the NETDEV_TX codes and changes the two callers of dev_hard_start_xmit() to expect either errno codes, NET_XMIT codes or NETDEV_TX codes as return value. In case of qdisc_restart(), all non NETDEV_TX codes are mapped to NETDEV_TX_OK since no error propagation is possible when using qdiscs. In case of dev_queue_xmit(), the error is propagated upwards. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10net: use rcu for network scheduler APIstephen hemminger
Use RCU to walk list of network devices in qdisc dump. This could be optimized for large number of devices. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-09tree-wide: fix a very frequent spelling mistakeDirk Hohndel
something-bility is spelled as something-blity so a grep for 'blit' would find these lines this is so trivial that I didn't split it by subsystem / copy additional maintainers - all changes are to comments The only purpose is to get fewer false positives when grepping around the kernel sources. Signed-off-by: Dirk Hohndel <hohndel@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-05net_cls: Use __dev_get_by_index()Eric Dumazet
We hold RTNL in tc_dump_tfilter(), we can avoid dev_hold()/dev_put() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04em_meta: avoid one dev_put()Eric Dumazet
Another rcu conversion to avoid one dev_hold()/dev_put() pair Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-22pkt_sched: skbedit add support for setting markjamal
This adds support for setting the skb mark. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13Merge branch 'master' of ↵David S. Miller
2009-10-11Merge branch 'master' of ↵David S. Miller
2009-10-11pkt_sched: pedit use proper structjamal
This probably deserves to go into -stable. Pedit will reject a policy that is large because it uses the wrong structure in the policy validation. This fixes it. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-08netlink: fix typo in initializationJiri Pirko
Commit 9ef1d4c7c7aca1cd436612b6ca785b726ffb8ed8 ("[NETLINK]: Missing initializations in dumped data") introduced a typo in initialization. This patch fixes this. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07pkt_sched: gen_estimator: Dont report fake rate estimatorsEric Dumazet
Jarek Poplawski a écrit : > > > Hmm... So you made me to do some "real" work here, and guess what?: > there is one serious checkpatch warning! ;-) Plus, this new parameter > should be added to the function description. Otherwise: > Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> > > Thanks, > Jarek P. > > PS: I guess full "Don't" would show we really mean it... Okay :) Here is the last round, before the night ! Thanks again [RFC] pkt_sched: gen_estimator: Don't report fake rate estimators We currently send TCA_STATS_RATE_EST elements to netlink users, even if no estimator is running. # tc -s -d qdisc qdisc pfifo_fast 0: dev eth0 root bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 Sent 112833764978 bytes 1495081739 pkt (dropped 0, overlimits 0 requeues 0) rate 0bit 0pps backlog 0b 0p requeues 0 User has no way to tell if the "rate 0bit 0pps" is a real estimation, or a fake one (because no estimator is active) After this patch, tc command output is : $ tc -s -d qdisc qdisc pfifo_fast 0: dev eth0 root bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 Sent 561075 bytes 1196 pkt (dropped 0, overlimits 0 requeues 0) backlog 0b 0p requeues 0 We add a parameter to gnet_stats_copy_rate_est() function so that it can use gen_estimator_active(bstats, r), as suggested by Jarek. This parameter can be NULL if check is not necessary, (htb for example has a mandatory rate estimator) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-17pkt_sched: Fix qstats.qlen updating in dump_statsJarek Poplawski
Some classful qdiscs miss qstats.qlen updating with q.qlen of their child qdiscs in dump_stats methods. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15pkt_sched: Fix qdisc_create on stab error handlingJarek Poplawski
If qdisc_get_stab returns error in qdisc_create there is skipped qdisc ops->destroy, which is necessary because it's after ops->init at the moment, so memory leaks are quite probable. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15pkt_sched: Fix tx queue selection in tc_modify_qdiscJarek Poplawski
After the recent mq change there is the new select_queue qdisc class method used in tc_modify_qdisc, but it works OK only for direct child qdiscs of mq qdisc. Grandchildren always get the first tx queue, which would give wrong qdisc_root etc. results (e.g. for sch_htb as child of sch_prio). This patch fixes it by using parent's dev_queue for such grandchildren qdiscs. The select_queue method's return type is changed BTW. With feedback from: Patrick McHardy <kaber@trash.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14pkt_sched: Fix qdisc_graft WRT ingress qdiscJarek Poplawski
After the recent mq change using ingress qdisc overwrites dev->qdisc; there is also a wrong old qdisc pointer passed to notify_and_destroy. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-10Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-09-09net_sched: fix estimator lock selection for mq child qdiscsPatrick McHardy
When new child qdiscs are attached to the mq qdisc, they are actually attached as root qdiscs to the device queues. The lock selection for new estimators incorrectly picks the root lock of the existing and to be replaced qdisc, which results in a use-after-free once the old qdisc has been destroyed. Mark mq qdisc instances with a new flag and treat qdiscs attached to mq as children similar to regular root qdiscs. Additionally prevent estimators from being attached to the mq qdisc itself since it only updates its byte and packet counters during dumps. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: add classful multiqueue dummy schedulerDavid S. Miller
This patch adds a classful dummy scheduler which can be used as root qdisc for multiqueue devices and exposes each device queue as a child class. This allows to address queues individually and graft them similar to regular classes. Additionally it presents an accumulated view of the statistics of all real root qdiscs in the dummy root. Two new callbacks are added to the qdisc_ops and qdisc_class_ops: - cl_ops->select_queue selects the tx queue number for new child classes. - qdisc_ops->attach() overrides root qdisc device grafting to attach non-shared qdiscs to the queues. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: move dev_graft_qdisc() to sch_generic.cPatrick McHardy
It will be used in a following patch by the multiqueue qdisc. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: reintroduce dev->qdisc for use by sch_apiPatrick McHardy
Currently the multiqueue integration with the qdisc API suffers from a few problems: - with multiple queues, all root qdiscs use the same handle. This means they can't be exposed to userspace in a backwards compatible fashion. - all API operations always refer to queue number 0. Newly created qdiscs are automatically shared between all queues, its not possible to address individual queues or restore multiqueue behaviour once a shared qdisc has been attached. - Dumps only contain the root qdisc of queue 0, in case of non-shared qdiscs this means the statistics are incomplete. This patch reintroduces dev->qdisc, which points to the (single) root qdisc from userspace's point of view. Currently it either points to the first (non-shared) default qdisc, or a qdisc shared between all queues. The following patches will introduce a classful dummy qdisc, which will be used as root qdisc and contain the per-queue qdiscs as children. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: remove some unnecessary checks in classful schedulersPatrick McHardy
The class argument to the ->graft(), ->leaf(), ->dump(), ->dump_stats() all originate from either ->get() or ->walk() and are always valid. Remove unnecessary checks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: make cls_ops->change and cls_ops->delete optionalPatrick McHardy
Some schedulers don't support creating, changing or deleting classes. Make the respective callbacks optionally and consistently return -EOPNOTSUPP for unsupported operations, instead of currently either -EOPNOTSUPP, -ENOSYS or no error. In case of sch_prio and sch_multiq, the removed operations additionally checked for an invalid class. This is not necessary since the class argument can only orginate from ->get() or in case of ->change is 0 for creation of new classes, in which case ->change() incorrectly returned -ENOENT. As a side-effect, this patch fixes a possible (root-only) NULL pointer function call in sch_ingress, which didn't implement a so far mandatory ->delete() operation. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: make cls_ops->tcf_chain() optionalPatrick McHardy
Some qdiscs don't support attaching filters. Handle this centrally in cls_api and return a proper errno code (EOPNOTSUPP) instead of EINVAL. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04net_sched: fix class grafting errno codesPatrick McHardy
If the parent qdisc doesn't support classes, use EOPNOTSUPP. If the parent class doesn't exist, use ENOENT. Currently EINVAL is returned in both cases. Additionally check whether grafting is supported and remove a now unnecessary graft function from sch_ingress. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02tc: Fix unitialized kernel memory leakEric Dumazet
Three bytes of uninitialized kernel memory are currently leaked to user Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/yellowfin.c
2009-09-01pkt_sched: Revert tasklet_hrtimer changes.David S. Miller
These are full of unresolved problems, mainly that conversions don't work 1-1 from hrtimers to tasklet_hrtimers because unlike hrtimers tasklets can't be killed from softirq context. And when a qdisc gets reset, that's exactly what we need to do here. We'll work this out in the net-next-2.6 tree and if warranted we'll backport that work to -stable. This reverts the following 3 changesets: a2cb6a4dd470d7a64255a10b843b0d188416b78f ("pkt_sched: Fix bogon in tasklet_hrtimer changes.") 38acce2d7983632100a9ff3fd20295f6e34074a8 ("pkt_sched: Convert CBQ to tasklet_hrtimer.") ee5f9757ea17759e1ce5503bdae2b07e48e32af9 ("pkt_sched: Convert qdisc_watchdog to tasklet_hrtimer") Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert pseudo-devices to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30pkt_sched: Fix resource limiting in pfifo_fastKrishna Kumar
pfifo_fast_enqueue has this check: if (skb_queue_len(list) < qdisc_dev(qdisc)->tx_queue_len) { which allows each band to enqueue upto tx_queue_len skbs for a total of 3*tx_queue_len skbs. I am not sure if this was the intention of limiting in qdisc. Patch compiled and 32 simultaneous netperf testing ran fine. Also: # tc -s qdisc show dev eth2 qdisc pfifo_fast 0: root bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 Sent 16835026752 bytes 373116 pkt (dropped 0, overlimits 0 requeues 25) rate 0bit 0pps backlog 0b 0p requeues 25 Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-29Speed-up pfifo_fast lookup using a private bitmapKrishna Kumar
Maintain a per-qdisc bitmap for pfifo_fast giving availability of skbs for each band. This allows faster lookup for a skb when there are no high priority skbs. Also, it helps in (rare) cases when there are no skbs on the list, where an immediate lookup is faster than iterating through the three bands. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-25netlink: constify nlmsghdr argumentsPatrick McHardy
Consitfy nlmsghdr arguments to a couple of functions as preparation for the next patch, which will constify the netlink message data in all nfnetlink users. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-08-24pkt_sched: Fix bogon in tasklet_hrtimer changes.David S. Miller
Reported by Stephen Rothwell, luckily it's harmless: net/sched/sch_api.c: In function 'qdisc_watchdog': net/sched/sch_api.c:460: warning: initialization from incompatible pointer type net/sched/sch_cbq.c: In function 'cbq_undelay': net/sched/sch_cbq.c:595: warning: initialization from incompatible pointer type Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23pkt_sched: Convert CBQ to tasklet_hrtimer.David S. Miller
This code expects to run in softirq context, and bare hrtimers run in hw IRQ context. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-22pkt_sched: Convert qdisc_watchdog to tasklet_hrtimerDavid S. Miller
None of this stuff should execute in hw IRQ context, therefore use a tasklet_hrtimer so that it runs in softirq context. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-17net: restore gnet_stats_basic to previous definitionEric Dumazet
In 5e140dfc1fe87eae27846f193086724806b33c7d "net: reorder struct Qdisc for better SMP performance" the definition of struct gnet_stats_basic changed incompatibly, as copies of this struct are shipped to userland via netlink. Restoring old behavior is not welcome, for performance reason. Fix is to use a private structure for kernel, and teach gnet_stats_copy_basic() to convert from kernel to user land, using legacy structure (struct gnet_stats_basic) Based on a report and initial patch from Michael Spang. Reported-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-06net: Avoid enqueuing skb for default qdiscsKrishna Kumar
dev_queue_xmit enqueue's a skb and calls qdisc_run which dequeue's the skb and xmits it. In most cases, the skb that is enqueue'd is the same one that is dequeue'd (unless the queue gets stopped or multiple cpu's write to the same queue and ends in a race with qdisc_run). For default qdiscs, we can remove the redundant enqueue/dequeue and simply xmit the skb since the default qdisc is work-conserving. The patch uses a new flag - TCQ_F_CAN_BYPASS to identify the default fast queue. The controversial part of the patch is incrementing qlen when a skb is requeued - this is to avoid checks like the second line below: + } else if ((q->flags & TCQ_F_CAN_BYPASS) && !qdisc_qlen(q) && >> !q->gso_skb && + !test_and_set_bit(__QDISC_STATE_RUNNING, &q->state)) { Results of a 2 hour testing for multiple netperf sessions (1, 2, 4, 8, 12 sessions on a 4 cpu system-X). The BW numbers are aggregate Mb/s across iterations tested with this version on System-X boxes with Chelsio 10gbps cards: ---------------------------------- Size | ORG BW NEW BW | ---------------------------------- 128K | 156964 159381 | 256K | 158650 162042 | ---------------------------------- Changes from ver1: 1. Move sch_direct_xmit declaration from sch_generic.h to pkt_sched.h 2. Update qdisc basic statistics for direct xmit path. 3. Set qlen to zero in qdisc_reset. 4. Changed some function names to more meaningful ones. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17pkt_sched: Update drops stats in act_policeJarek Poplawski
Action police statistics could be misleading because drops are not shown when expected. With feedback from: Jamal Hadi Salim <hadi@cyberus.ca> Reported-by: Pawel Staszewski <pstaszewski@itcare.pl> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
