path: root/net/sctp/bind_addr.c
2008-04-12[SCTP]: "list_for_each()" -> "list_for_each_entry()" where appropriate.Robert P. J. Day
Replacing (almost) all invocations of list_for_each() with list_for_each_entry() tightens up the code and allows for the deletion of numerous list iterator variables that are no longer necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-11[SCTP]: Fix local_addr deletions during list traversals.Chidambar 'ilLogict' Zinnoury
Since the lists are circular, we need to explicitely tag the address to be deleted since we might end up freeing the list head instead. This fixes some interesting SCTP crashes. Signed-off-by: Chidambar 'ilLogict' Zinnoury <illogict@online.fr> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[SCTP]: Stop claiming that this is a "reference implementation"Vlad Yasevich
I was notified by Randy Stewart that lksctp claims to be "the reference implementation". First of all, "the refrence implementation" was the original implementation of SCTP in usersapce written ty Randy and a few others. Second, after looking at the definiton of 'reference implementation', we don't really meet the requirements. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-01-28[SCTP]: Implement ADD-IP special case processing for ABORT chunkVlad Yasevich
ADD-IP spec has a special case for processing ABORTs: F4) ... One special consideration is that ABORT Chunks arriving destined to the IP address being deleted MUST be ignored (see Section 5.3.1 for further details). Check if the address we received on is in the DEL state, and if so, ignore the ABORT. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[SCTP]: Change use_as_src into a full address stateVlad Yasevich
2007-12-07[SCTP]: Fix the bind_addr info during migration.Vlad Yasevich
During accept/migrate the code attempts to copy the addresses from the parent endpoint to the new endpoint. However, if the parent was bound to a wildcard address, then we end up pointlessly copying all of the current addresses on the system. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07SCTP: Update RCU handling during the ADD-IP caseVlad Yasevich
After learning more about rcu, it looks like the ADD-IP hadling doesn't need to call call_rcu_bh. All the rcu critical sections use rcu_read_lock, so using call_rcu_bh is wrong here. Now, restore the local_bh_disable() code blocks and use normal call_rcu() calls. Also restore the missing return statement. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2007-09-26fix sctp_del_bind_addr() last argument typeAl Viro
It gets pointer to fastcall function, expects a pointer to normal one and calls the sucker. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-16[SCTP]: Convert bind_addr_list locking to RCUVlad Yasevich
Since the sctp_sockaddr_entry is now RCU enabled as part of the patch to synchronize sctp_localaddr_list, it makes sense to change all handling of these entries to RCU. This includes the sctp_bind_addrs structure and it's list of bound addresses. This list is currently protected by an external rw_lock and that looks like an overkill. There are only 2 writers to the list: bind()/bindx() calls, and BH processing of ASCONF-ACK chunks. These are already seriealized via the socket lock, so they will not step on each other. These are also relatively rare, so we should be good with RCU. The readers are varied and they are easily converted to RCU. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SCTP]: Add RCU synchronization around sctp_localaddr_listVlad Yasevich
sctp_localaddr_list is modified dynamically via NETDEV_UP and NETDEV_DOWN events, but there is not synchronization between writer (even handler) and readers. As a result, the readers can access an entry that has been freed and crash the sytem. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCTP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: ->a_h is gone now.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: sctp_make_asconf_update_ip() and sctp_find_unmatch_addr().Al Viro
... switched to taking and returning pointers to net-endian sctp_addr resp. Together, since the only user of sctp_find_unmatch_addr() just passes its value to sctp_make_asconf_update_ip(). sctp_make_asconf_update_ip() is actually endian-agnostic. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Trivial parts of a_h -> a switch.Al Viro
2006-12-02[SCTP]: sctp_copy_one_addr() switched to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_addr_param() to net-endian.Al Viro
2006-12-02[SCTP]: Switch sctp_add_bind_addr() to net-endian.Al Viro
2006-12-02[SCTP]: Switch sctp_del_bind_addr() to net-endian.Al Viro
Callers adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_bind_addr_match() to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->cmp_addr() and sctp_cmp_addr_exact() to net-endian.Al Viro
instances of ->cmp_addr() are fine with switching both arguments to net-endian; callers other than in sctp_cmp_addr_exact() (both as ->cmp_addr(...) and direct calls of instances) adjusted; sctp_cmp_addr_exact() switched to net-endian itself and adjustment is done in its callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] embedded sctp_addr: net-endian mirrorsAl Viro
Add sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr, maintain them as net-endian mirrors of their host-endian counterparts. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Beginning of conversion to net-endian for embedded sctp_addr.Al Viro
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr (to ..._h) The next patch will reintroduce these fields and keep them as net-endian mirrors of the original (renamed) ones. Split in two patches to make sure that we hadn't forgotten any instanes. Later in the series we'll eliminate uses of host-endian variants (basically switching users to net-endian counterparts as we progress through that mess). Then host-endian ones will die. Other embedded host-endian sctp_addr will be easier to switch directly, so we leave them alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] bug: sctp_find_unmatch_addr() compares net-endian to host-endianAl Viro
2006-07-21[SCTP]: ADDIP: Don't use an address as source until it is ASCONF-ACKedSridhar Samudrala
This implements Rules D1 and D4 of Sec 4.3 in the ADDIP draft. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
