path: root/net/sctp/ipv6.c
2007-09-16[SCTP]: Convert bind_addr_list locking to RCUVlad Yasevich
Since the sctp_sockaddr_entry is now RCU enabled as part of the patch to synchronize sctp_localaddr_list, it makes sense to change all handling of these entries to RCU. This includes the sctp_bind_addrs structure and it's list of bound addresses. This list is currently protected by an external rw_lock and that looks like an overkill. There are only 2 writers to the list: bind()/bindx() calls, and BH processing of ASCONF-ACK chunks. These are already seriealized via the socket lock, so they will not step on each other. These are also relatively rare, so we should be good with RCU. The readers are varied and they are easily converted to RCU. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SCTP]: Add RCU synchronization around sctp_localaddr_listVlad Yasevich
sctp_localaddr_list is modified dynamically via NETDEV_UP and NETDEV_DOWN events, but there is not synchronization between writer (even handler) and readers. As a result, the readers can access an entry that has been freed and crash the sytem. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-01SCTP: IPv4 mapped addr not returned in SCTPv6 accept()Dave Johnson
An accept() call on a SCTPv6 socket that returns due to connection of a IPv4 mapped peer will fill out the 'struct sockaddr' with a zero IPv6 address instead of the IPv4 mapped address of the peer. This is due to the v4mapped flag not getting copied into the new socket on accept() as well as a missing check for INET6 socket type in sctp_v4_to_sk_*addr(). Signed-off-by: Dave Johnson <djohnson@sw.starentnetworks.com> Cc: Srinivas Akkipeddi <sakkiped@starentnetworks.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2007-07-05SCTP: Add scope_id validation for link-local bindsVlad Yasevich
SCTP currently permits users to bind to link-local addresses, but doesn't verify that the scope id specified at bind matches the interface that the address is configured on. It was report that this can hang a system. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[SCTP]: Re-order SCTP initializations to avoid race with sctp_rcv()Sridhar Samudrala
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use offsets for skb->{mac,network,transport}_header on 64bit ↵Arnaldo Carvalho de Melo
architectures With this we save 8 bytes per network packet, leaving a 4 bytes hole to be used in further shrinking work, likely with the offsetization of other pointers, such as ->{data,tail,end}, at the cost of adds, that were minimized by the usual practice of setting skb->{mac,nh,n}.raw to a local variable that is then accessed multiple times in each function, it also is not more expensive than before with regards to most of the handling of such headers, like setting one of these headers to another (transport to network, etc), or subtracting, adding to/from it, comparing them, etc. Now we have this layout for sk_buff on a x86_64 machine: [acme@mica net-2.6.22]$ pahole vmlinux sk_buff struct sk_buff { struct sk_buff * next; /* 0 8 */ struct sk_buff * prev; /* 8 8 */ struct rb_node rb; /* 16 24 */ struct sock * sk; /* 40 8 */ ktime_t tstamp; /* 48 8 */ struct net_device * dev; /* 56 8 */ /* --- cacheline 1 boundary (64 bytes) --- */ struct net_device * input_dev; /* 64 8 */ sk_buff_data_t transport_header; /* 72 4 */ sk_buff_data_t network_header; /* 76 4 */ sk_buff_data_t mac_header; /* 80 4 */ /* XXX 4 bytes hole, try to pack */ struct dst_entry * dst; /* 88 8 */ struct sec_path * sp; /* 96 8 */ char cb[48]; /* 104 48 */ /* cacheline 2 boundary (128 bytes) was 24 bytes ago*/ unsigned int len; /* 152 4 */ unsigned int data_len; /* 156 4 */ unsigned int mac_len; /* 160 4 */ union { __wsum csum; /* 4 */ __u32 csum_offset; /* 4 */ }; /* 164 4 */ __u32 priority; /* 168 4 */ __u8 local_df:1; /* 172 1 */ __u8 cloned:1; /* 172 1 */ __u8 ip_summed:2; /* 172 1 */ __u8 nohdr:1; /* 172 1 */ __u8 nfctinfo:3; /* 172 1 */ __u8 pkt_type:3; /* 173 1 */ __u8 fclone:2; /* 173 1 */ __u8 ipvs_property:1; /* 173 1 */ /* XXX 2 bits hole, try to pack */ __be16 protocol; /* 174 2 */ void (*destructor)(struct sk_buff *); /* 176 8 */ struct nf_conntrack * nfct; /* 184 8 */ /* --- cacheline 3 boundary (192 bytes) --- */ struct sk_buff * nfct_reasm; /* 192 8 */ struct nf_bridge_info *nf_bridge; /* 200 8 */ __u16 tc_index; /* 208 2 */ __u16 tc_verd; /* 210 2 */ dma_cookie_t dma_cookie; /* 212 4 */ __u32 secmark; /* 216 4 */ __u32 mark; /* 220 4 */ unsigned int truesize; /* 224 4 */ atomic_t users; /* 228 4 */ unsigned char * head; /* 232 8 */ unsigned char * data; /* 240 8 */ unsigned char * tail; /* 248 8 */ /* --- cacheline 4 boundary (256 bytes) --- */ unsigned char * end; /* 256 8 */ }; /* size: 264, cachelines: 5 */ /* sum members: 260, holes: 1, sum holes: 4 */ /* bit holes: 1, sum bit holes: 2 bits */ /* last cacheline: 8 bytes */ On 32 bits nothing changes, and pointers continue to be used with the compiler turning all this abstraction layer into dust. But there are some sk_buff validation tricks that are now possible, humm... :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SCTP]: Eliminate some pointer attributions to the skb layer headersArnaldo Carvalho de Melo
2007-04-25[SCTP]: Introduce sctp_hdr()Arnaldo Carvalho de Melo
For consistency with all the other skb->h.raw accessors. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF] ipv6: More skb_reset_network_header conversions related to skb_pullArnaldo Carvalho de Melo
Now related to this form: skb->nh.ipv6h = (struct ipv6hdr *)skb_put(skb, length); That, as the others, is done when skb->tail is still equal to skb->data, making the conversion to skb_reset_network_header possible. Also one more case equivalent to skb->nh.raw = skb->data, of this form: iph = (struct ipv6hdr *)skb->data; <SNIP> skb->nh.ipv6h = iph; Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-08[SCTP] ipv6: inconsistent lock state ipv6_add_addr/sctp_v6_copy_addrlistJarek Poplawski
lockdep found that dev->lock taken from softirq in ipv6_add_addr is also taken in sctp_v6_copy_addrlist with softirqs enabled, so lockup is possible. Noticed-by: Simon Arlott <simon@arlott.org> Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCTP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-22[SCTP]: make 2 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - ipv6.c: sctp_inet6addr_event() - protocol.c: sctp_inetaddr_event() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[SCTP]: Handle address add/delete events in a more efficient way.Sridhar Samudrala
Currently in SCTP, we maintain a local address list by rebuilding the whole list from the device list whenever we get a address add/delete event. This patch fixes it by only adding/deleting the address for which we receive the event. Also removed the sctp_local_addr_lock() which is no longer needed as we now use list_for_each_safe() to traverse this list. This fixes the bugs in sctp_copy_laddrs_xxx() routines where we do copy_to_user() while holding this lock. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Annotate ->supported_addrs().Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Annotate ->inaddr_any().Al Viro
2006-12-02[SCTP]: Don't bother setting sin_port in ->from_sk().Al Viro
... the only caller will overwrite immediately Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: ip6_send() doesn't need fl_ip_[sd]port.Al Viro
2006-12-02[SCTP]: Trivial ->ipaddr_h -> ->ipaddr conversions.Al Viro
2006-12-02[SCTP]: ->a_h is gone now.Al Viro
2006-12-02[SCTP]: Trivial parts of a_h -> a switch.Al Viro
2006-12-02[SCTP]: Switch all remaining users of ->saddr_h to ->saddr.Al Viro
2006-12-02[SCTP]: ->get_saddr() switched to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_addr_param() to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_skb() to net-endian.Al Viro
All instances switched, callers updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Annotate ->dst_saddr()Al Viro
switched to taking a pointer to net-endian sctp_addr and a net-endian port number. Instances and callers adjusted; interestingly enough, the only calls are direct calls of specific instances - the method is not used at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] embedded sctp_addr: net-endian mirrorsAl Viro
Add sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr, maintain them as net-endian mirrors of their host-endian counterparts. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Beginning of conversion to net-endian for embedded sctp_addr.Al Viro
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr (to ..._h) The next patch will reintroduce these fields and keep them as net-endian mirrors of the original (renamed) ones. Split in two patches to make sure that we hadn't forgotten any instanes. Later in the series we'll eliminate uses of host-endian variants (basically switching users to net-endian counterparts as we progress through that mess). Then host-endian ones will die. Other embedded host-endian sctp_addr will be easier to switch directly, so we leave them alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Trivial sctp endianness annotations.Al Viro
2006-12-02[IPV6]: 'info' argument of ipv6 ->err_handler() is net-endianAl Viro
2006-10-18[IPV6]: Make sure error handling is done when calling ip6_route_output().Ville Nuorvala
As ip6_route_output() never returns NULL, error checking must be done by looking at dst->error in stead of comparing dst against NULL. Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] ADDRCONF: Convert addrconf_lock to RCU.YOSHIFUJI Hideaki
2006-09-22[SCTP]: CleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global function static: - socket.c: sctp_apply_peer_addr_params() - add proper prototypes for the several global functions in include/net/sctp/sctp.h Note that this fixes wrong prototypes for the following functions: - sctp_snmp_proc_exit() - sctp_eps_proc_exit() - sctp_assocs_proc_exit() The latter was spotted by the GNU C compiler and reported by David Woodhouse. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SCTP]: ADDIP: Don't use an address as source until it is ASCONF-ACKedSridhar Samudrala
This implements Rules D1 and D4 of Sec 4.3 in the ADDIP draft. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[SCTP]: Reject sctp packets with broadcast addresses.Vlad Yasevich
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: Identation & other cleanups related to compat_[gs]etsockopt csetArnaldo Carvalho de Melo
No code changes, just tidying up, in some cases moving EXPORT_SYMBOLs to just after the function exported, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: {get|set}sockopt compatibility layerDmitry Mishin
This patch extends {get|set}sockopt compatibility layer in order to move protocol specific parts to their place and avoid huge universal net/compat.c file in the future. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-13[NET]: Use NIP6_FMT in kernel.hJoe Perches
There are errors and inconsistency in the display of NIP6 strings. ie: net/ipv6/ip6_flowlabel.c There are errors and inconsistency in the display of NIPQUAD strings too. ie: net/netfilter/nf_conntrack_ftp.c This patch: adds NIP6_FMT to kernel.h changes all code to use NIP6_FMT fixes net/ipv6/ip6_flowlabel.c adds NIPQUAD_FMT to kernel.h fixes net/netfilter/nf_conntrack_ftp.c changes a few uses of "%u.%u.%u.%u" to NIPQUAD_FMT for symmetry to NIP6_FMT Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV6]: Move nextheader offset to the IP6CBPatrick McHardy
Move nextheader offset to the IP6CB to make it possible to pass a packet to ip6_input_finish multiple times and have it skip already parsed headers. As a nice side effect this gets rid of the manual hopopts skipping in ip6_input_finish. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Cleanup INET_REFCNT_DEBUG codeArnaldo Carvalho de Melo
2005-07-18[SCTP]: Fix potential null pointer dereference while handling an icmp errorSridhar Samudrala
2005-06-13[SCTP] Fix incorrect setting of sk_bound_dev_if when binding/sending to a ipv6Sridhar Samudrala
link local address. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-28[SCTP] Use ipv6_addr_any() rather than ipv6_addr_type() in sctp_v6_is_any().Brian Haley
Signed-off-by: Brian Haley <Brian.Haley@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
