path: root/net/sctp/outqueue.c
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-02sctp: Remove outqueue empty stateVlad Yasevich
The SCTP outqueue structure maintains a data chunks that are pending transmission, the list of chunks that are pending a retransmission and a length of data in flight. It also tries to keep the emtpy state so that it can performe shutdown sequence or notify user. The problem is that the empy state is inconsistently tracked. It is possible to completely drain the queue without sending anything when using PR-SCTP. In this case, the empty state will not be correctly state as report by Jamal Hadi Salim <jhs@mojatatu.com>. This can cause an association to be perminantly stuck in the SHUTDOWN_PENDING state. Additionally, SCTP is incredibly inefficient when setting the empty state. Even though all the data is availaible in the outqueue structure, we ignore it and walk a list of trasnports. In the end, we can completely remove the extra empty state and figure out if the queue is empty by looking at 3 things: length of pending data, length of in-flight data, and exisiting of retransmit data. All of these are already in the strucutre. Reported-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Tested-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-26sctp: fix checkpatch errors with space required or prohibitedwangweidong
fix checkpatch errors while the space is required or prohibited to the "=,()++..." Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Wang Weidong <wangweidong1@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06sctp: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Vlad Yasevich <vyasevich@gmail.com> CC: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-28sctp: Restore 'resent' bit to avoid retransmitted chunks for RTT measurementsXufeng Zhang
Currently retransmitted DATA chunks could also be used for RTT measurements since there are no flag to identify whether the transmitted DATA chunk is a new one or a retransmitted one. This problem is introduced by commit ae19c5486 ("sctp: remove 'resent' bit from the chunk") which inappropriately removed the 'resent' bit completely, instead of doing this, we should set the resent bit only for the retransmitted DATA chunks. Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-23net: sctp: find the correct highest_new_tsn in sackChang Xiangzhong
Function sctp_check_transmitted(transport t, ...) would iterate all of transport->transmitted queue and looking for the highest __newly__ acked tsn. The original algorithm would depend on the order of the assoc->transport_list (in function sctp_outq_sack line 1215 - 1226). The result might not be the expected due to the order of the tranport_list. Solution: checking if the exising is smaller than the new one before assigning Signed-off-by: Chang Xiangzhong <changxiangzhong@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-09net: sctp: trivial: update bug report in header commentDaniel Borkmann
With the restructuring of the lksctp.org site, we only allow bug reports through the SCTP mailing list linux-sctp@vger.kernel.org, not via SF, as SF is only used for web hosting and nothing more. While at it, also remove the obvious statement that bugs will be fixed and incooperated into the kernel. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-24net: sctp: trivial: update mailing list addressDaniel Borkmann
The SCTP mailing list address to send patches or questions to is linux-sctp@vger.kernel.org and not lksctp-developers@lists.sourceforge.net anymore. Therefore, update all occurences. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-09net: sctp: confirm route during forward progressDaniel Borkmann
This fix has been proposed originally by Vlad Yasevich. He says: When SCTP makes forward progress (receives a SACK that acks new chunks, renegs, or answeres 0-window probes) or when HB-ACK arrives, mark the route as confirmed so we don't unnecessarily send NUD probes. Having a simple SCTP client/server that exchange data chunks every 1sec, without this patch ARP requests are sent periodically every 40-60sec. With this fix applied, an ARP request is only done once right at the "session" beginning. Also, when clearing the related ARP cache entry manually during the session, a new request is correctly done. I have only "backported" this to net-next and tested that it works, so full credit goes to Vlad. Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-02net: sctp: get rid of SCTP_DBG_TSNS entirelyDaniel Borkmann
After having reworked the debugging framework, Neil and Vlad agreed to get rid of the leftover SCTP_DBG_TSNS code for a couple of reasons: We can use systemtap scripts to investigate these things, we now have pr_debug() helpers that make life easier, and if we really need anything else besides those tools, we will be forced to come up with something better than we have there. Therefore, get rid of this ifdef debugging code entirely for now. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: Neil Horman <nhorman@tuxdriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-01net: sctp: rework debugging framework to use pr_debug and friendsDaniel Borkmann
We should get rid of all own SCTP debug printk macros and use the ones that the kernel offers anyway instead. This makes the code more readable and conform to the kernel code, and offers all the features of dynamic debbuging that pr_debug() et al has, such as only turning on/off portions of debug messages at runtime through debugfs. The runtime cost of having CONFIG_DYNAMIC_DEBUG enabled, but none of the debug statements printing, is negligible [1]. If kernel debugging is completly turned off, then these statements will also compile into "empty" functions. While we're at it, we also need to change the Kconfig option as it /now/ only refers to the ifdef'ed code portions in outqueue.c that enable further debugging/tracing of SCTP transaction fields. Also, since SCTP_ASSERT code was enabled with this Kconfig option and has now been removed, we transform those code parts into WARNs resp. where appropriate BUG_ONs so that those bugs can be more easily detected as probably not many people have SCTP debugging permanently turned on. To turn on all SCTP debugging, the following steps are needed: # mount -t debugfs none /sys/kernel/debug # echo -n 'module sctp +p' > /sys/kernel/debug/dynamic_debug/control This can be done more fine-grained on a per file, per line basis and others as described in [2]. [1] https://www.kernel.org/doc/ols/2009/ols2009-pages-39-46.pdf [2] Documentation/dynamic-debug-howto.txt Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13sctp: fully initialize sctp_outq in sctp_outq_initNeil Horman
In commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86 (refactor sctp_outq_teardown to insure proper re-initalization) we modified sctp_outq_teardown to use sctp_outq_init to fully re-initalize the outq structure. Steve West recently asked me why I removed the q->error = 0 initalization from sctp_outq_teardown. I did so because I was operating under the impression that sctp_outq_init would properly initalize that value for us, but it doesn't. sctp_outq_init operates under the assumption that the outq struct is all 0's (as it is when called from sctp_association_init), but using it in __sctp_outq_teardown violates that assumption. We should do a memset in sctp_outq_init to ensure that the entire structure is in a known state there instead. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: "West, Steve (NSN - US/Fort Worth)" <steve.west@nsn.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: netdev@vger.kernel.org CC: davem@davemloft.net Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: sctp: outqueue: simplify sctp_outq_uncork functionDaniel Borkmann
Just a minor edit to simplify the function. No need for this error variable here. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: sctp: sctp_outq: remove 'malloced' from its structDaniel Borkmann
sctp_outq is embedded into sctp_association, and thus never kmalloced in any way. Also, malloced is always 0, thus kfree() is never called. Therefore, remove that dead piece of code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-04net: remove redundant check for timer pending state before del_timerYing Xue
As in del_timer() there has already placed a timer_pending() function to check whether the timer to be deleted is pending or not, it's unnecessary to check timer pending state again before del_timer() is called. Signed-off-by: Ying Xue <ying.xue@windriver.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-17sctp: refactor sctp_outq_teardown to insure proper re-initalizationNeil Horman
Jamie Parsons reported a problem recently, in which the re-initalization of an association (The duplicate init case), resulted in a loss of receive window space. He tracked down the root cause to sctp_outq_teardown, which discarded all the data on an outq during a re-initalization of the corresponding association, but never reset the outq->outstanding_data field to zero. I wrote, and he tested this fix, which does a proper full re-initalization of the outq, fixing this problem, and hopefully future proofing us from simmilar issues down the road. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Jamie Parsons <Jamie.Parsons@metaswitch.com> Tested-by: Jamie Parsons <Jamie.Parsons@metaswitch.com> CC: Jamie Parsons <Jamie.Parsons@metaswitch.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: "David S. Miller" <davem@davemloft.net> CC: netdev@vger.kernel.org Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-03sctp: Add support to per-association statistics via a new ↵Michele Baldessari
SCTP_GET_ASSOC_STATS call The current SCTP stack is lacking a mechanism to have per association statistics. This is an implementation modeled after OpenSolaris' SCTP_GET_ASSOC_STATS. Userspace part will follow on lksctp if/when there is a general ACK on this. V4: - Move ipackets++ before q->immediate.func() for consistency reasons - Move sctp_max_rto() at the end of sctp_transport_update_rto() to avoid returning bogus RTO values - return asoc->rto_min when max_obs_rto value has not changed V3: - Increase ictrlchunks in sctp_assoc_bh_rcv() as well - Move ipackets++ to sctp_inq_push() - return 0 when no rto updates took place since the last call V2: - Implement partial retrieval of stat struct to cope for future expansion - Kill the rtxpackets counter as it cannot be precise anyway - Rename outseqtsns to outofseqtsns to make it clearer that these are out of sequence unexpected TSNs - Move asoc->ipackets++ under a lock to avoid potential miscounts - Fold asoc->opackets++ into the already existing asoc check - Kill unneeded (q->asoc) test when increasing rtxchunks - Do not count octrlchunks if sending failed (SCTP_XMIT_OK != 0) - Don't count SHUTDOWNs as SACKs - Move SCTP_GET_ASSOC_STATS to the private space API - Adjust the len check in sctp_getsockopt_assoc_stats() to allow for future struct growth - Move association statistics in their own struct - Update idupchunks when we send a SACK with dup TSNs - return min_rto in max_rto when RTO has not changed. Also return the transport when max_rto last changed. Signed-off: Michele Baldessari <michele@acksyn.org> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-04sctp: check src addr when processing SACK to update transport stateNicolas Dichtel
Suppose we have an SCTP connection with two paths. After connection is established, path1 is not available, thus this path is marked as inactive. Then traffic goes through path2, but for some reasons packets are delayed (after rto.max). Because packets are delayed, the retransmit mechanism will switch again to path1. At this time, we receive a delayed SACK from path2. When we update the state of the path in sctp_check_transmitted(), we do not take into account the source address of the SACK, hence we update the wrong path. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-04sctp: use list_move_tail instead of list_del/list_add_tailWei Yongjun
Using list_move_tail() instead of list_del() + list_add_tail(). spatch with a semantic match is used to found this problem. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the mib per network namespaceEric W. Biederman
Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22sctp: Implement quick failover draft from tsvwgNeil Horman
I've seen several attempts recently made to do quick failover of sctp transports by reducing various retransmit timers and counters. While its possible to implement a faster failover on multihomed sctp associations, its not particularly robust, in that it can lead to unneeded retransmits, as well as false connection failures due to intermittent latency on a network. Instead, lets implement the new ietf quick failover draft found here: http://tools.ietf.org/html/draft-nishida-tsvwg-sctp-failover-05 This will let the sctp stack identify transports that have had a small number of errors, and avoid using them quickly until their reliability can be re-established. I've tested this out on two virt guests connected via multiple isolated virt networks and believe its in compliance with the above draft and works well. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: Sridhar Samudrala <sri@us.ibm.com> CC: "David S. Miller" <davem@davemloft.net> CC: linux-sctp@vger.kernel.org CC: joe@perches.com Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-20sctp: Do not account for sizeof(struct sk_buff) in estimated rwndThomas Graf
When checking whether a DATA chunk fits into the estimated rwnd a full sizeof(struct sk_buff) is added to the needed chunk size. This quickly exhausts the available rwnd space and leads to packets being sent which are much below the PMTU limit. This can lead to much worse performance. The reason for this behaviour was to avoid putting too much memory pressure on the receiver. The concept is not completely irational because a Linux receiver does in fact clone an skb for each DATA chunk delivered. However, Linux also reserves half the available socket buffer space for data structures therefore usage of it is already accounted for. When proposing to change this the last time it was noted that this behaviour was introduced to solve a performance issue caused by rwnd overusage in combination with small DATA chunks. Trying to reproduce this I found that with the sk_buff overhead removed, the performance would improve significantly unless socket buffer limits are increased. The following numbers have been gathered using a patched iperf supporting SCTP over a live 1 Gbit ethernet network. The -l option was used to limit DATA chunk sizes. The numbers listed are based on the average of 3 test runs each. Default values have been used for sk_(r|w)mem. Chunk Size Unpatched No Overhead ------------------------------------- 4 15.2 Kbit [!] 12.2 Mbit [!] 8 35.8 Kbit [!] 26.0 Mbit [!] 16 95.5 Kbit [!] 54.4 Mbit [!] 32 106.7 Mbit 102.3 Mbit 64 189.2 Mbit 188.3 Mbit 128 331.2 Mbit 334.8 Mbit 256 537.7 Mbit 536.0 Mbit 512 766.9 Mbit 766.6 Mbit 1024 810.1 Mbit 808.6 Mbit Signed-off-by: Thomas Graf <tgraf@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24sctp: HEARTBEAT negotiation after ASCONFMichio Honda
This patch fixes BUG that the ASCONF receiver transmits DATA chunks to the newly added UNCONFIRMED destination. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/bluetooth/l2cap_core.c
2011-07-07sctp: Enforce retransmission limit during shutdownThomas Graf
When initiating a graceful shutdown while having data chunks on the retransmission queue with a peer which is in zero window mode the shutdown is never completed because the retransmission error count is reset periodically by the following two rules: - Do not timeout association while doing zero window probe. - Reset overall error count when a heartbeat request has been acknowledged. The graceful shutdown will wait for all outstanding TSN to be acknowledged before sending the SHUTDOWN request. This never happens due to the peer's zero window not acknowledging the continuously retransmitted data chunks. Although the error counter is incremented for each failed retransmission, the receiving of the SACK announcing the zero window clears the error count again immediately. Also heartbeat requests continue to be sent periodically. The peer acknowledges these requests causing the error counter to be reset as well. This patch changes behaviour to only reset the overall error counter for the above rules while not in shutdown. After reaching the maximum number of retransmission attempts, the T5 shutdown guard timer is scheduled to give the receiver some additional time to recover. The timer is stopped as soon as the receiver acknowledges any data. The issue can be easily reproduced by establishing a sctp association over the loopback device, constantly queueing data at the sender while not reading any at the receiver. Wait for the window to reach zero, then initiate a shutdown by killing both processes simultaneously. The association will never be freed and the chunks on the retransmission queue will be retransmitted indefinitely. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add ASCONF operation on the single-homed hostMichio Honda
In this case, the SCTP association transmits an ASCONF packet including addition of the new IP address and deletion of the old address. This patch implements this functionality. In this case, the ASCONF chunk is added to the beginning of the queue, because the other chunks cannot be transmitted in this state. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: move chunk from retransmit queue to abandoned listWei Yongjun
If there is still data waiting to retransmit and remain in retransmit queue, while doing the next retransmit, if the chunk is abandoned, we should move it to abandoned list. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: remove completely unsed EMPTY stateVlad Yasevich
SCTP does not SCTP_STATE_EMPTY and we can never be in that state. Remove useless code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19sctp: teach CACC algorithm about removed transportsVlad Yasevich
When we have have to remove a transport due to ASCONF, we move the data to a new active path. This can trigger CACC algorithm to not mark that data as missing when SACKs arrive. This is because the transport passed to the CACC algorithm is the one this data is sitting on, not the one it was sent on (that one may be gone). So, by sending the original transport (even if it's NULL), we may start marking data as missing. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07sctp: several declared/set but unused fixesHagen Paul Pfeifer
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/sctp: Use pr_fmt and pr_<level>Joe Perches
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to use do { print } while (0) guards. Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when lines were continued. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add a missing newline in "Failed bind hash alloc" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-30sctp: Optimize computation of highest new tsn in SACK.Vlad Yasevich
Right now, if the highest tsn in the SACK doesn't change, we'll end up scanning the transmitted lists on the transports twice: once for locating the highest _new_ tsn, and once for actually tagging chunks as acked. This is a waste, since we can record the highest _new_ tsn at the same time as tagging chunks. Long ago this was not possible because we would try to mark chunks as missing at the same time as tagging them acked and this approach didn't work. Now that the two steps are separate, we can re-use the old approach. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: correctly mark missing chunks in fast recoveryVlad Yasevich
According to RFC 4960 Section 7.2.4: If an endpoint is in Fast Recovery and a SACK arrives that advances the Cumulative TSN Ack Point, the miss indications are incremented for all TSNs reported missing in the SACK. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: Do not force T3 timer on fast retransmissions.Vlad Yasevich
We don't need to force the T3 timer any more and it's actually wrong to do as it causes too long of a delay. The timer will be started if one is not running, but if one is running, we leave it alone. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: remove 'resent' bit from the chunkVlad Yasevich
The 'resent' bit is used to make sure that we don't update rto estimate based on retransmitted chunks. However, we already have the 'rto_pending' bit that we test when need to update rto, so 'resent' bit is just extra. Additionally, we currently have a bug in that we always set a 'resent' bit and thus rto estimate is only updated by Heartbeats. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: use sctp_chunk_is_data macro to decide a chunk is data chunkShan Wei
sctp_chunk_is_data macro is defined to decide that whether a chunk is data chunk or not. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: fix to retranmit at least one DATA chunkWei Yongjun
While doing retranmit, if control chunk exists, such as FORWARD TSN chunk, and the DATA chunk can not be bundled with this control chunk because of PMTU limit, no DATA chunk will be retranmitted in the current implementation. This patch makes sure to retranmit at least one DATA chunk in this case. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-30sctp: assure at least one T3-rtx timer is running if a FORWARD TSN is sentWei Yongjun
PR-SCTP extension section 3.5 Sender Side Implementation of PR-SCTP: C5) If a FORWARD TSN is sent, the sender MUST assure that at least one T3-rtx timer is running. So this patch fix to assure at least one T3-rtx timer is running if a FORWARD TSN is or will to sent. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-29sctp: on T3_RTX retransmit all the in-flight chunksAndrei Pelinescu-Onciul
When retransmitting due to T3 timeout, retransmit all the in-flight chunks for the corresponding transport/path, including chunks sent less then 1 rto ago. This is the correct behaviour according to rfc4960 section 6.3.3 E3 and "Note: Any DATA chunks that were sent to the address for which the T3-rtx timer expired but did not fit in one MTU (rule E3 above) should be marked for retransmission and sent as soon as cwnd allows (normally, when a SACK arrives). ". This fixes problems when more then one path is present and the T3 retransmission of the first chunk that timeouts stops the T3 timer for the initial active path, leaving all the other in-flight chunks waiting forever or until a new chunk is transmitted on the same path and timeouts (and this will happen only if the cwnd allows sending new chunks, but since cwnd was dropped to MTU by the timeout => it will wait until the first heartbeat). Example: 10 packets in flight, sent at 0.1 s intervals on the primary path. The primary path is down and the first packet timeouts. The first packet is retransmitted on another path, the T3 timer for the primary path is stopped and cwnd is set to MTU. All the other 9 in-flight packets will not be retransmitted (unless more new packets are sent on the primary path which depend on cwnd allowing it, and even in this case the 9 packets will be retransmitted only after a new packet timeouts which even in the best case would be more then RTO). This commit reverts d0ce92910bc04e107b2f3f2048f07e94f570035d and also removes the now unused transport->last_rto, introduced in b6157d8e03e1e780660a328f7183bcbfa4a93a19. p.s The problem is not only when multiple paths are there. It can happen in a single homed environment. If the application stops sending data, it possible to have a hung association. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23sctp: Update max.burst implementationVlad Yasevich
Current implementation of max.burst ends up limiting new data during cwnd decay period. The decay is happening becuase the connection is idle and we are allowed to fill the congestion window. The point of max.burst is to limit micro-bursts in response to large acks. This still happens, as max.burst is still applied to each transmit opportunity. It will also apply if a very large send is made (greater then allowed by burst). Tested-by: Florian Niederbacher <florian.niederbacher@student.uibk.ac.at> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: implement the sender side for SACK-IMMEDIATELY extensionWei Yongjun
This patch implement the sender side for SACK-IMMEDIATELY extension. Section 4.1. Sender Side Considerations Whenever the sender of a DATA chunk can benefit from the corresponding SACK chunk being sent back without delay, the sender MAY set the I-bit in the DATA chunk header. Reasons for setting the I-bit include o The sender is in the SHUTDOWN-PENDING state. o The application requests to set the I-bit of the last DATA chunk of a user message when providing the user message to the SCTP implementation. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: Failover transmitted list on transport deleteVlad Yasevich
Add-IP feature allows users to delete an active transport. If that transport has chunks in flight, those chunks need to be moved to another transport or association may get into unrecoverable state. Reported-by: Rafael Laufer <rlaufer@cisco.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-03-13sctp: fix to send FORWARD-TSN chunk only if peer has such capableWei Yongjun
RFC3758 Section 3.3.1. Sending Forward-TSN-Supported param in INIT Note that if the endpoint chooses NOT to include the parameter, then at no time during the life of the association can it send or process a FORWARD TSN. If peer does not support PR-SCTP capable, don't send FORWARD-TSN chunk to peer. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sctp: use time_before or time_after for comparing jiffiesWei Yongjun
The functions time_before or time_after are more robust for comparing jiffies against other values. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
