path: root/net/sctp/protocol.c
2012-01-06sctp: fix incorrect overflow check on autocloseXi Wang
[ Upstream commit 2692ba61a82203404abd7dd2a027bda962861f74 ] Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for limiting the autoclose value. If userspace passes in -1 on 32-bit platform, the overflow check didn't work and autoclose would be set to 0xffffffff. This patch defines a max_autoclose (in seconds) for limiting the value and exposes it through sysctl, with the following intentions. 1) Avoid overflowing autoclose * HZ. 2) Keep the default autoclose bound consistent across 32- and 64-bit platforms (INT_MAX / HZ in this patch). 3) Keep the autoclose value consistent between setsockopt() and getsockopt() calls. Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-07net: refine {udp|tcp|sctp}_mem limitsEric Dumazet
Current tcp/udp/sctp global memory limits are not taking into account hugepages allocations, and allow 50% of ram to be used by buffers of a single protocol [ not counting space used by sockets / inodes ...] Lets use nr_free_buffer_pages() and allow a default of 1/8 of kernel ram per protocol, and a minimum of 128 pages. Heavy duty machines sysadmins probably need to tweak limits anyway. References: https://bugzilla.stlinux.com/show_bug.cgi?id=38032 Reported-by: starlight <starlight@binnacle.cx> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-10sctp: Remove rt->rt_src usage in sctp_v4_get_saddr()David S. Miller
Flow key is available, so fetch it from there. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08sctp: Fix debug message args.David S. Miller
I messed things up when I converted over to the transport flow, I passed the ipv4 address value instead of it's address. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08sctp: Don't use rt->rt_{src,dst} in sctp_v4_xmit()David S. Miller
Now we can pick it out of the transport's flow key. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08inet: Pass flowi to ->queue_xmit().David S. Miller
This allows us to acquire the exact route keying information from the protocol, however that might be managed. It handles all of the possibilities, from the simplest case of storing the key in inet->cork.fl to the more complex setup SCTP has where individual transports determine the flow. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-07net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()Lai Jiangshan
The rcu callback sctp_local_addr_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sctp_local_addr_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-03sctp: Use flowi4's {saddr,daddr} in sctp_v4_dst_saddr() and sctp_v4_get_dst()David S. Miller
Instead of rt->rt_{src,dst} Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: clean up route lookup callsVlad Yasevich
Change the call to take the transport parameter and set the cached 'dst' appropriately inside the get_dst() function calls. This will allow us in the future to clean up source address storage as well. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: remove useless arguments from get_saddr() callVlad Yasevich
There is no point in passing a destination address to a get_saddr() call. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: cache the ipv6 source after route lookupVlad Yasevich
The ipv6 routing lookup does give us a source address, but instead of filling it into the dst, it's stored in the flowi. We can use that instead of going through the entire source address selection again. Also the useless ->dst_saddr member of sctp_pf is removed. And sctp_v6_dst_saddr() is removed, instead by introduce sctp_v6_to_addr(), which can be reused to cleanup some dup code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30sctp: Pass __GFP_NOWARN to hash table allocation attempts.David S. Miller
Like DCCP and other similar pieces of code, there are mechanisms here to try allocating smaller hash tables if the allocation fails. So pass in __GFP_NOWARN like the others do instead of emitting a scary message. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put fl4_* macros to struct flowi4 and use them again.David S. Miller
2011-03-12ipv4: Use flowi4 in public route lookup interfaces.David S. Miller
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-10net: avoid limits overflowEric Dumazet
Robin Holt tried to boot a 16TB machine and found some limits were reached : sysctl_tcp_mem[2], sysctl_udp_mem[2] We can switch infrastructure to use long "instead" of "int", now atomic_long_t primitives are available for free. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Robin Holt <holt@sgi.com> Reviewed-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/sctp: Use pr_fmt and pr_<level>Joe Perches
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to use do { print } while (0) guards. Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when lines were continued. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add a missing newline in "Failed bind hash alloc" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-06-25snmp: add align parameter to snmp_mib_init()Eric Dumazet
In preparation for 64bit snmp counters for some mibs, add an 'align' parameter to snmp_mib_init(), instead of assuming mibs only contain 'unsigned long' fields. Callers can use __alignof__(type) to provide correct alignment. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Herbert Xu <herbert@gondor.apana.org.au> CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> CC: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-30sctp: missing set src and dest port while lookup output routeWei Yongjun
While lookup the output route, we do not set the src and dest port. This will cause we got a wrong route if we had set the outbund transport to IPsec with src or dst port. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-15net: replace ipfragok with skb->local_dfShan Wei
As Herbert Xu said: we should be able to simply replace ipfragok with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function) has droped ipfragok and set local_df value properly. The patch kills the ipfragok parameter of .queue_xmit(). Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-17net: remove INIT_RCU_HEAD() usageAlexey Dobriyan
call_rcu() will unconditionally reinitialize RCU head anyway. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23sctp: Update SWS avaoidance receiver side algorithmVlad Yasevich
We currently send window update SACKs every time we free up 1 PMTU worth of data. That a lot more SACKs then necessary. Instead, we'll now send back the actuall window every time we send a sack, and do window-update SACKs when a fraction of the receive buffer has been opened. The fraction is controlled with a sysctl. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: Introduce for_each_netdev_rcu() iteratorEric Dumazet
Adds RCU management to the list of netdevices. Convert some for_each_netdev() users to RCU version, if it can avoid read_lock-ing dev_base_lock Ie: read_lock(&dev_base_loack); for_each_netdev(net, dev) some_action(); read_unlock(&dev_base_lock); becomes : rcu_read_lock(); for_each_netdev_rcu(net, dev) some_action(); rcu_read_unlock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22mm: replace various uses of num_physpages by totalram_pagesJan Beulich
Sizing of memory allocations shouldn't depend on the number of physical pages found in a system, as that generally includes (perhaps a huge amount of) non-RAM pages. The amount of what actually is usable as storage should instead be used as a basis here. Some of the calculations (i.e. those not intending to use high memory) should likely even use (totalram_pages - totalhigh_pages). Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Airlie <airlied@linux.ie> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04sctp: Sysctl configuration for IPv4 Address ScopingBhaskar Dutta
This patch introduces a new sysctl option to make IPv4 Address Scoping configurable <draft-stewart-tsvwg-sctp-ipv4-00.txt>. In networking environments where DNAT rules in iptables prerouting chains convert destination IP's to link-local/private IP addresses, SCTP connections fail to establish as the INIT chunk is dropped by the kernel due to address scope match failure. For example to support overlapping IP addresses (same IP address with different vlan id) a Layer-5 application listens on link local IP's, and there is a DNAT rule that maps the destination IP to a link local IP. Such applications never get the SCTP INIT if the address-scoping draft is strictly followed. This sysctl configuration allows SCTP to function in such unconventional networking environments. Sysctl options: 0 - Disable IPv4 address scoping draft altogether 1 - Enable IPv4 address scoping (default, current behavior) 2 - Enable address scoping but allow IPv4 private addresses in init/init-ack 3 - Enable address scoping but allow IPv4 link local address in init/init-ack Signed-off-by: Bhaskar Dutta <bhaskar.dutta@globallogic.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-08-09sctp: fix missing destroy of percpu counter variable in sctp_proc_exit()Rafael Laufer
Commit 1748376b6626acf59c24e9592ac67b3fe2a0e026, net: Use a percpu_counter for sockets_allocated added percpu_counter function calls to sctp_proc_init code path, but forgot to add them to sctp_proc_exit(). This resulted in a following Ooops when performing this test # modprobe sctp # rmmod -f sctp # modprobe sctp [ 573.862512] BUG: unable to handle kernel paging request at f8214a24 [ 573.862518] IP: [<c0308b8f>] __percpu_counter_init+0x3f/0x70 [ 573.862530] *pde = 37010067 *pte = 00000000 [ 573.862534] Oops: 0002 [#1] SMP [ 573.862537] last sysfs file: /sys/module/libcrc32c/initstate [ 573.862540] Modules linked in: sctp(+) crc32c libcrc32c binfmt_misc bridge stp bnep lp snd_hda_codec_analog snd_hda_intel snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss arc4 joydev snd_pcm ecb pcmcia snd_seq_dummy snd_seq_oss iwlagn iwlcore snd_seq_midi snd_rawmidi snd_seq_midi_event yenta_socket rsrc_nonstatic thinkpad_acpi snd_seq snd_timer snd_seq_device mac80211 psmouse sdhci_pci sdhci nvidia(P) ppdev video snd soundcore serio_raw pcspkr iTCO_wdt iTCO_vendor_support led_class ricoh_mmc pcmcia_core intel_agp nvram agpgart usbhid parport_pc parport output snd_page_alloc cfg80211 btusb ohci1394 ieee1394 e1000e [last unloaded: sctp] [ 573.862589] [ 573.862593] Pid: 5373, comm: modprobe Tainted: P R (2.6.31-rc3 #6) 7663B15 [ 573.862596] EIP: 0060:[<c0308b8f>] EFLAGS: 00010286 CPU: 1 [ 573.862599] EIP is at __percpu_counter_init+0x3f/0x70 [ 573.862602] EAX: f8214a20 EBX: f80faa14 ECX: c48c0000 EDX: f80faa20 [ 573.862604] ESI: f80a7000 EDI: 00000000 EBP: f69d5ef0 ESP: f69d5eec [ 573.862606] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 573.862610] Process modprobe (pid: 5373, ti=f69d4000 task=c2130c70 task.ti=f69d4000) [ 573.862612] Stack: [ 573.862613] 00000000 f69d5f18 f80a70a8 f80fa9fc 00000000 fffffffc f69d5f30 c018e2d4 [ 573.862619] <0> 00000000 f80a7000 00000000 f69d5f88 c010112b 00000000 c07029c0 fffffffb [ 573.862626] <0> 00000000 f69d5f38 c018f83f f69d5f54 c0557cad f80fa860 00000001 c07010c0 [ 573.862634] Call Trace: [ 573.862644] [<f80a70a8>] ? sctp_init+0xa8/0x7d4 [sctp] [ 573.862650] [<c018e2d4>] ? marker_update_probe_range+0x184/0x260 [ 573.862659] [<f80a7000>] ? sctp_init+0x0/0x7d4 [sctp] [ 573.862662] [<c010112b>] ? do_one_initcall+0x2b/0x160 [ 573.862666] [<c018f83f>] ? tracepoint_module_notify+0x2f/0x40 [ 573.862671] [<c0557cad>] ? notifier_call_chain+0x2d/0x70 [ 573.862678] [<c01588fd>] ? __blocking_notifier_call_chain+0x4d/0x60 [ 573.862682] [<c016b2f1>] ? sys_init_module+0xb1/0x1f0 [ 573.862686] [<c0102ffc>] ? sysenter_do_call+0x12/0x28 [ 573.862688] Code: 89 48 08 b8 04 00 00 00 e8 df aa ec ff ba f4 ff ff ff 85 c0 89 43 14 74 31 b8 b0 18 71 c0 e8 19 b9 24 00 a1 c4 18 71 c0 8d 53 0c <89> 50 04 89 43 0c b8 b0 18 71 c0 c7 43 10 c4 18 71 c0 89 15 c4 [ 573.862725] EIP: [<c0308b8f>] __percpu_counter_init+0x3f/0x70 SS:ESP 0068:f69d5eec [ 573.862730] CR2: 00000000f8214a24 [ 573.862734] ---[ end trace 39c4e0b55e7cf54d ]--- Signed-off-by: Rafael Laufer <rlaufer@cisco.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-10sctp: protocol.c call rcu_barrier() on unload.Jesper Dangaard Brouer
On module unload call rcu_barrier(), this is needed as synchronize_rcu() is not strong enough. The kmem_cache_destroy() does invoke synchronize_rcu() but it does not provide same protection. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->rtable accessorEric Dumazet
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb Delete skb->rtable field Setting rtable is not allowed, just set dst instead as rtable is an alias. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tokenring/tmspci.c drivers/net/ucc_geth_mii.c
2009-03-04SCTP: change sctp_ctl_sock_init() to try IPv4 if IPv6 failsBrian Haley
Change sctp_ctl_sock_init() to try IPv4 if IPv6 socket registration fails. Required if the IPv6 module is loaded with "disable=1", else SCTP will fail to load. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sctp: fix crash during module unloadVlad Yasevich
An extra list_del() during the module load failure and unload resulted in a crash with a list corruption. Now sctp can be unloaded again. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-16sctp: Inherit all socket options from parent correctly.Vlad Yasevich
During peeloff/accept() sctp needs to save the parent socket state into the new socket so that any options set on the parent are inherited by the child socket. This was found when the parent/listener socket issues SO_BINDTODEVICE, but the data was misrouted after a route cache flush. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-16sctp: Allow to disable SCTP checksums via module parameterLucas Nussbaum
This is a new version of my patch, now using a module parameter instead of a sysctl, so that the option is harder to find. Please note that, once the module is loaded, it is still possible to change the value of the parameter in /sys/module/sctp/parameters/, which is useful if you want to do performance comparisons without rebooting. Computation of SCTP checksums significantly affects the performance of SCTP. For example, using two dual-Opteron 246 connected using a Gbe network, it was not possible to achieve more than ~730 Mbps, compared to 941 Mbps after disabling SCTP checksums. Unfortunately, SCTP checksum offloading in NICs is not commonly available (yet). By default, checksums are still enabled, of course. Signed-off-by: Lucas Nussbaum <lucas.nussbaum@ens-lyon.fr> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-27sctp: fix missing label when PROC_FS=nRandy Dunlap
Fix missing label when CONFIG_PROC_FS=n: net/sctp/protocol.c: In function 'sctp_proc_init': net/sctp/protocol.c:106: error: label 'out_nomem' used but not defined make[3]: *** [net/sctp/protocol.o] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: Use a percpu_counter for sockets_allocatedEric Dumazet
Instead of using one atomic_t per protocol, use a percpu_counter for "sockets_allocated", to reduce cache line contention on heavy duty network servers. Note : We revert commit (248969ae31e1b3276fc4399d67ce29a5d81e6fd9 net: af_unix can make unix_nr_socks visbile in /proc), since it is not anymore used after sock_prot_inuse_add() addition Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-03sctp: Drop ipfargok in sctp_xmit functionHerbert Xu
The ipfragok flag controls whether the packet may be fragmented either on the local host on beyond. The latter is only valid on IPv4. In fact, we never want to do the latter even on IPv4 when PMTU is enabled. This is because even though we can't fragment packets within SCTP due to the prtocol's inherent faults, we can still fragment it at IP layer. By setting the DF bit we will improve the PMTU process. RFC 2960 only says that we SHOULD clear the DF bit in this case, so we're compliant even if we set the DF bit. In fact RFC 4960 no longer has this statement. Once we make this change, we only need to control the local fragmentation. There is already a bit in the skb which controls that, local_df. So this patch sets that instead of using the ipfragok argument. The only complication is that there isn't a struct sock object per transport, so for IPv4 we have to resort to changing the pmtudisc field for every packet. This should be safe though as the protocol is single-threaded. Note that after this patch we can remove ipfragok from the rest of the stack too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
