path: root/net/sctp/socket.c
2011-05-12sctp: sctp_sendmsg: Don't test known non-null sinfoJoe Perches
It's already known non-null above. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12sctp: sctp_sendmsg: Don't initialize default_sinfoJoe Perches
This variable only needs initialization when cmsgs.info is NULL. Use memset to ensure padding is also zeroed so kernel doesn't leak any data. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: cache the ipv6 source after route lookupVlad Yasevich
The ipv6 routing lookup does give us a source address, but instead of filling it into the dst, it's stored in the flowi. We can use that instead of going through the entire source address selection again. Also the useless ->dst_saddr member of sctp_pf is removed. And sctp_v6_dst_saddr() is removed, instead by introduce sctp_v6_to_addr(), which can be reused to cleanup some dup code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sctp: implement socket option SCTP_GET_ASSOC_ID_LISTWei Yongjun
This patch Implement socket option SCTP_GET_ASSOC_ID_LIST. SCTP Socket API Extension: 8.2.6. Get the Current Identifiers of Associations (SCTP_GET_ASSOC_ID_LIST) This option gets the current list of SCTP association identifiers of the SCTP associations handled by a one-to-many style socket. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19sctp: Allow bindx_del to accept 0 portVlad Yasevich
We allow 0 port when adding new addresses. It only makes sence to allow 0 port when removing addresses. When removing the currently bound port will be used when the port in the address is set to 0. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19sctp: use memdup_user to copy data from userspaceShan Wei
Use common function to simply code. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07sctp: several declared/set but unused fixesHagen Paul Pfeifer
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22net: add __rcu annotations to sk_wq and wqEric Dumazet
Add proper RCU annotations/verbs to sk_wq and wq members Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access) Fix sunrpc sk_sleep() abuse too Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19sctp: user perfect name for Delayed SACK Timer optionShan Wei
The option name of Delayed SACK Timer should be SCTP_DELAYED_SACK, not SCTP_DELAYED_ACK. Left SCTP_DELAYED_ACK be concomitant with SCTP_DELAYED_SACK, for making compatibility with existing applications. Reference: 8.1.19. Get or Set Delayed SACK Timer (SCTP_DELAYED_SACK) (http://tools.ietf.org/html/draft-ietf-tsvwg-sctpsocket-25) Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/vhost/vhost.c
2010-12-16sctp: fix the return value of getting the sctp partial delivery pointWei Yongjun
Get the sctp partial delivery point using SCTP_PARTIAL_DELIVERY_POINT socket option should return 0 if success, not -ENOTSUPP. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10SCTP: Fix SCTP_SET_PEER_PRIMARY_ADDR to accpet v4mapped addressWei Yongjun
SCTP_SET_PEER_PRIMARY_ADDR does not accpet v4mapped address, using v4mapped address in SCTP_SET_PEER_PRIMARY_ADDR socket option will get -EADDRNOTAVAIL error if v4map is enabled. This patch try to fix it by mapping v4mapped address to v4 address if allowed. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06Fix a typo in datagram.c and sctp/socket.c.David Shwatrz
Hi, This patch fixes a typo in net/core/datagram.c and in net/sctp/socket.c Regards, David Shwartz Signed-off-by: David Shwartz <dshwatrz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-10net: avoid limits overflowEric Dumazet
Robin Holt tried to boot a 16TB machine and found some limits were reached : sysctl_tcp_mem[2], sysctl_udp_mem[2] We can switch infrastructure to use long "instead" of "int", now atomic_long_t primitives are available for free. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Robin Holt <holt@sgi.com> Reviewed-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-10-03sctp: Fix break indentation in sctp_ioctl().David S. Miller
2010-10-03sctp: prevent reading out-of-bounds memoryDan Rosenberg
Two user-controlled allocations in SCTP are subsequently dereferenced as sockaddr structs, without checking if the dereferenced struct members fall beyond the end of the allocated chunk. There doesn't appear to be any information leakage here based on how these members are used and additional checking, but it's still worth fixing. [akpm@linux-foundation.org: remove unfashionable newlines, fix gmail tab->space conversion] Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08sctp: implement SIOCINQ ioctl() (take 3)Diego Elio 'Flameeyes' Pettenò
This simple patch copies the current approach for SIOCINQ ioctl() from DCCP into SCTP so that the userland code working with SCTP can use a similar interface across different protocols to know how much space to allocate for a buffer. Signed-off-by: Diego Elio Pettenò <flameeyes@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-06net: poll() optimizationsEric Dumazet
No need to test twice sk->sk_shutdown & RCV_SHUTDOWN Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/sctp: Use pr_fmt and pr_<level>Joe Perches
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to use do { print } while (0) guards. Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when lines were continued. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add a missing newline in "Failed bind hash alloc" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15net: reserve ports for applications using fixed port numbersAmerigo Wang
(Dropped the infiniband part, because Tetsuo modified the related code, I will send a separate patch for it once this is accepted.) This patch introduces /proc/sys/net/ipv4/ip_local_reserved_ports which allows users to reserve ports for third-party applications. The reserved ports will not be used by automatic port assignments (e.g. when calling connect() or bind() with port number 0). Explicit port allocation behavior is unchanged. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-03Merge branch 'net-next' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/vxy/lksctp-dev Add missing linux/vmalloc.h include to net/sctp/probe.c Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-02Merge branch 'master' of ↵David S. Miller
2010-05-01net: sock_def_readable() and friends RCU conversionEric Dumazet
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we need two atomic operations (and associated dirtying) per incoming packet. RCU conversion is pretty much needed : 1) Add a new structure, called "struct socket_wq" to hold all fields that will need rcu_read_lock() protection (currently: a wait_queue_head_t and a struct fasync_struct pointer). [Future patch will add a list anchor for wakeup coalescing] 2) Attach one of such structure to each "struct socket" created in sock_alloc_inode(). 3) Respect RCU grace period when freeing a "struct socket_wq" 4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct socket_wq" 5) Change sk_sleep() function to use new sk->sk_wq instead of sk->sk_sleep 6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside a rcu_read_lock() section. 7) Change all sk_has_sleeper() callers to : - Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock) - Use wq_has_sleeper() to eventually wakeup tasks. - Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock) 8) sock_wake_async() is modified to use rcu protection as well. 9) Exceptions : macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq" instead of dynamically allocated ones. They dont need rcu freeing. Some cleanups or followups are probably needed, (possible sk_callback_lock conversion to a spinlock for example...). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-30sctp: Use correct address family in sctp_getsockopt_peer_addrs()Vlad Yasevich
The function should use the address family of the address when trying to determine the length of the structure. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2010-04-28sctp: per_cpu variables should be in bh_disabled sectionVlad Yasevich
Since the change of the atomics to percpu variables, we now have to disable BH in process context when touching percpu variables. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28sctp: avoid irq lock inversion while call sk->sk_data_ready()Wei Yongjun
sk->sk_data_ready() of sctp socket can be called from both BH and non-BH contexts, but the default sk->sk_data_ready(), sock_def_readable(), can not be used in this case. Therefore, we have to make a new function sctp_data_ready() to grab sk->sk_data_ready() with BH disabling. ========================================================= [ INFO: possible irq lock inversion dependency detected ] 2.6.33-rc6 #129 --------------------------------------------------------- sctp_darn/1517 just changed the state of lock: (clock-AF_INET){++.?..}, at: [<c06aab60>] sock_def_readable+0x20/0x80 but this lock took another, SOFTIRQ-unsafe lock in the past: (slock-AF_INET){+.-...} and interrupts could create inverse lock ordering between them. other info that might help us debug this: 1 lock held by sctp_darn/1517: #0: (sk_lock-AF_INET){+.+.+.}, at: [<cdfe363d>] sctp_sendmsg+0x23d/0xc00 [sctp] Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27net: sk_add_backlog() take rmem_alloc into accountEric Dumazet
Current socket backlog limit is not enough to really stop DDOS attacks, because user thread spend many time to process a full backlog each round, and user might crazy spin on socket lock. We should add backlog size and receive_queue size (aka rmem_alloc) to pace writers, and let user run without being slow down too much. Introduce a sk_rcvqueues_full() helper, to avoid taking socket lock in stress situations. Under huge stress from a multiqueue/RPS enabled NIC, a single flow udp receiver can now process ~200.000 pps (instead of ~100 pps before the patch) on a 8 core machine. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-03-30sctp: eliminate useless codeHagen Paul Pfeifer
Remove duplicate declaration of symbol: struct hlist_node *node was already declared, the seconds declaration shadows the first one. CC: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05sctp: use limited socket backlogZhu Yi
Make sctp adapt to the limited socket backlog change. Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-21net/sctp: Eliminate useless codeJulia Lawall
The variable newinet is initialized twice to the same (side effect-free) expression. Drop one initialization. A simplified version of the semantic match that finds this problem is: (http://coccinelle.lip6.fr/) // <smpl> @forall@ idexpression *x; identifier f!=ERR_PTR; @@ x = f(...) ... when != x ( x = f(...,<+...x...+>,...) | * x = f(...) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03net/sctp/socket.c: squish warningAndrew Morton
net/sctp/socket.c: In function 'sctp_setsockopt_autoclose': net/sctp/socket.c:2090: warning: comparison is always false due to limited range of data type Cc: Andrei Pelinescu-Onciul <andrei@iptel.org> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02sctp: fix sctp_setsockopt_autoclose compile warningAndrei Pelinescu-Onciul
Fix the following warning, when building on 64 bits: net/sctp/socket.c:2091: warning: large integer implicitly truncated to unsigned type Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23sctp: limit maximum autoclose setsockopt valueAndrei Pelinescu-Onciul
To avoid overflowing the maximum timer interval when transforming the autoclose interval from seconds to jiffies, limit the maximum autoclose value to MAX_SCHEDULE_TIMEOUT/HZ. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: remove deprecated SCTP_GET_*_OLD stuffsAmerigo Wang
SCTP_GET_*_OLD stuffs are schedlued to be removed. Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-23sctp: allow setting path_maxrxt independent of SPP_PMTUD_ENABLEAndrei Pelinescu-Onciul
Since draft-ietf-tsvwg-sctpsocket-15.txt, setting the SPP_MTUD_ENABLE flag when changing pathmaxrxt via the SCTP_PEER_ADDR_PARAMS setsockopt is not required any longer. Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-11-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/can/Kconfig
2009-11-13sctp: Fix regression introduced by new sctp_connectx apiVlad Yasevich
A new (unrealeased to the user) sctp_connectx api c6ba68a26645dbc5029a9faa5687ebe6fcfc53e4 sctp: support non-blocking version of the new sctp_connectx() API introduced a regression cought by the user regression test suite. In particular, the API requires the user library to re-allocate the buffer and could potentially trigger a SIGFAULT. This change corrects that regression by passing the original address buffer to the kernel unmodified, but still allows for a returned association id. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13sctp: Set source addresses on the association before adding transportsVlad Yasevich
Recent commit 8da645e101a8c20c6073efda3c7cc74eec01b87f sctp: Get rid of an extra routing lookup when adding a transport introduced a regression in the connection setup. The behavior was different between IPv4 and IPv6. IPv4 case ended up working because the route lookup routing returned a NULL route, which triggered another route lookup later in the output patch that succeeded. In the IPv6 case, a valid route was returned for first call, but we could not find a valid source address at the time since the source addresses were not set on the association yet. Thus resulted in a hung connection. The solution is to set the source addresses on the association prior to adding peers. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04sctp: Fix SCTP_MAXSEG socket option to comply to spec.Vlad Yasevich
We had a bug that we never stored the user-defined value for MAXSEG when setting the value on an association. Thus future PMTU events ended up re-writing the frag point and increasing it past user limit. Additionally, when setting the option on the socket/endpoint, we effect all current associations, which is against spec. Now, we store the user 'maxseg' value along with the computed 'frag_point'. We inherit 'maxseg' from the socket at association creation and use it as an upper limit for 'frag_point' when its set. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-09-04sctp: Send user messages to the lower layer as oneVlad Yasevich
Currenlty, sctp breaks up user messages into fragments and sends each fragment to the lower layer by itself. This means that for each fragment we go all the way down the stack and back up. This also discourages bundling of multiple fragments when they can fit into a sigle packet (ex: due to user setting a low fragmentation threashold). We introduce a new command SCTP_CMD_SND_MSG and hand the whole message down state machine. The state machine and the side-effect parser will cork the queue, add all chunks from the message to the queue, and then un-cork the queue thus causing the chunks to get transmitted. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
