These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
net/bluetooth/l2cap_core.c
closing socket
Trigger user ABORT if application closes a socket which has data
queued on the socket receive queue or chunks waiting on the
reassembly or ordering queue as this would imply data being lost
which defeats the point of a graceful shutdown.
This behavior is already practiced in TCP.
We do not check the input queue because that would mean to parse
all chunks on it to look for unacknowledged data which seems too
much of an effort. Control chunks or duplicated chunks may also
be in the input queue and should not be stopping a graceful
shutdown.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
We forgot to send up SCTP_SENDER_DRY_EVENT notification when
user app subscribes to this event, and there is no data to be
sent or retransmit.
This is required by the Socket API and used by the DTLS/SCTP
implementation.
Reported-by: Michael Tüxen <Michael.Tuexen@lurchi.franken.de>
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Tested-by: Robin Seggelmann <seggelmann@fh-muenster.de>
Make the case labels the same indent as the switch.
git diff -w shows useless break;s removed after returns
and a comment added to an unnecessary default: break;
because of a dubious gcc warning.
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script:
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp>
Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com>
In this case, the SCTP association transmits an ASCONF packet
including addition of the new IP address and deletion of the old
address. This patch implements this functionality.
In this case, the ASCONF chunk is added to the beginning of the
queue, because the other chunks cannot be transmitted in this state.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch allows the application to operate Auto-ASCONF on/off
behavior via setsockopt() and getsockopt().
SCTP reconfigure the IP addresses in the association by using
ASCONF chunks as mentioned in RFC5061. For example, we can
start to use the newly configured IP address in the existing
association. This patch implements automatic ASCONF operation
in the SCTP stack with address events in the host computer,
which is called auto_asconf.
It's already known non-null above.
This variable only needs initialization when cmsgs.info
is NULL.
Use memset to ensure padding is also zeroed so
kernel doesn't leak any data.
The ipv6 routing lookup does give us a source address,
but instead of filling it into the dst, it's stored in
the flowi. We can use that instead of going through the
entire source address selection again.
Also the useless ->dst_saddr member of sctp_pf is removed.
And sctp_v6_dst_saddr() is removed, instead by introduce
sctp_v6_to_addr(), which can be reused to cleanup some dup
code.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
This patch Implement socket option SCTP_GET_ASSOC_ID_LIST.
SCTP Socket API Extension:
8.2.6. Get the Current Identifiers of Associations
(SCTP_GET_ASSOC_ID_LIST)
This option gets the current list of SCTP association identifiers of
the SCTP associations handled by a one-to-many style socket.
We allow 0 port when adding new addresses. It only
makes sence to allow 0 port when removing addresses.
When removing the currently bound port will be used
when the port in the address is set to 0.
Use common function to simply code.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Add proper RCU annotations/verbs to sk_wq and wq members
Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access)
Fix sunrpc sk_sleep() abuse too
The option name of Delayed SACK Timer should be SCTP_DELAYED_SACK,
not SCTP_DELAYED_ACK.
Left SCTP_DELAYED_ACK be concomitant with SCTP_DELAYED_SACK,
for making compatibility with existing applications.
Reference:
8.1.19. Get or Set Delayed SACK Timer (SCTP_DELAYED_SACK)
(http://tools.ietf.org/html/draft-ietf-tsvwg-sctpsocket-25)
drivers/net/bnx2x/bnx2x.h
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/vhost/vhost.c
Get the sctp partial delivery point using SCTP_PARTIAL_DELIVERY_POINT
socket option should return 0 if success, not -ENOTSUPP.
SCTP_SET_PEER_PRIMARY_ADDR does not accpet v4mapped address, using
v4mapped address in SCTP_SET_PEER_PRIMARY_ADDR socket option will
get -EADDRNOTAVAIL error if v4map is enabled. This patch try to
fix it by mapping v4mapped address to v4 address if allowed.
This patch fixes a typo in net/core/datagram.c and in net/sctp/socket.c
Regards,
David Shwartz
Signed-off-by: David Shwartz <dshwatrz@gmail.com>
Robin Holt tried to boot a 16TB machine and found some limits were
reached : sysctl_tcp_mem[2], sysctl_udp_mem[2]
We can switch infrastructure to use long "instead" of "int", now
atomic_long_t primitives are available for free.
Reported-by: Robin Holt <holt@sgi.com>
Reviewed-by: Robin Holt <holt@sgi.com>
net/ipv4/Kconfig
net/ipv4/tcp_timer.c
Two user-controlled allocations in SCTP are subsequently dereferenced as
sockaddr structs, without checking if the dereferenced struct members fall
beyond the end of the allocated chunk. There doesn't appear to be any
information leakage here based on how these members are used and
additional checking, but it's still worth fixing.
[akpm@linux-foundation.org: remove unfashionable newlines, fix gmail tab->space conversion]
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
This simple patch copies the current approach for SIOCINQ ioctl() from DCCP
into SCTP so that the userland code working with SCTP can use a similar
interface across different protocols to know how much space to allocate for
a buffer.
Signed-off-by: Diego Elio Pettenò <flameeyes@gmail.com>
No need to test twice sk->sk_shutdown & RCV_SHUTDOWN
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to
use do { print } while (0) guards.
Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when
lines were continued.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Add a missing newline in "Failed bind hash alloc"
(Dropped the infiniband part, because Tetsuo modified the related code,
I will send a separate patch for it once this is accepted.)
This patch introduces /proc/sys/net/ipv4/ip_local_reserved_ports which
allows users to reserve ports for third-party applications.
The reserved ports will not be used by automatic port assignments
(e.g. when calling connect() or bind() with port number 0). Explicit
port allocation behavior is unchanged.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
git://git.kernel.org/pub/scm/linux/kernel/git/vxy/lksctp-dev
Add missing linux/vmalloc.h include to net/sctp/probe.c
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we
need two atomic operations (and associated dirtying) per incoming
packet.
RCU conversion is pretty much needed :
1) Add a new structure, called "struct socket_wq" to hold all fields
that will need rcu_read_lock() protection (currently: a
wait_queue_head_t and a struct fasync_struct pointer).
[Future patch will add a list anchor for wakeup coalescing]
2) Attach one of such structure to each "struct socket" created in
sock_alloc_inode().
3) Respect RCU grace period when freeing a "struct socket_wq"
4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct
socket_wq"
5) Change sk_sleep() function to use new sk->sk_wq instead of
sk->sk_sleep
6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside
a rcu_read_lock() section.
7) Change all sk_has_sleeper() callers to :
- Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock)
- Use wq_has_sleeper() to eventually wakeup tasks.
- Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock)
8) sock_wake_async() is modified to use rcu protection as well.
9) Exceptions :
macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq"
instead of dynamically allocated ones. They dont need rcu freeing.
Some cleanups or followups are probably needed, (possible
sk_callback_lock conversion to a spinlock for example...).
The function should use the address family of the address when
trying to determine the length of the structure.
Since the change of the atomics to percpu variables, we now
have to disable BH in process context when touching percpu variables.
sk->sk_data_ready() of sctp socket can be called from both BH and non-BH
contexts, but the default sk->sk_data_ready(), sock_def_readable(), can
not be used in this case. Therefore, we have to make a new function
sctp_data_ready() to grab sk->sk_data_ready() with BH disabling.
[ INFO: possible irq lock inversion dependency detected ]
2.6.33-rc6 #129
sctp_darn/1517 just changed the state of lock:
(clock-AF_INET){++.?..}, at: [<c06aab60>] sock_def_readable+0x20/0x80
but this lock took another, SOFTIRQ-unsafe lock in the past:
(slock-AF_INET){+.-...}
and interrupts could create inverse lock ordering between them.
1 lock held by sctp_darn/1517:
#0: (sk_lock-AF_INET){+.+.+.}, at: [<cdfe363d>] sctp_sendmsg+0x23d/0xc00 [sctp]
Current socket backlog limit is not enough to really stop DDOS attacks,
because user thread spend many time to process a full backlog each
round, and user might crazy spin on socket lock.
We should add backlog size and receive_queue size (aka rmem_alloc) to
pace writers, and let user run without being slow down too much.
Introduce a sk_rcvqueues_full() helper, to avoid taking socket lock in
stress situations.
Under huge stress from a multiqueue/RPS enabled NIC, a single flow udp
receiver can now process ~200.000 pps (instead of ~100 pps before the
patch) on a 8 core machine.
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Remove duplicate declaration of symbol: struct hlist_node *node was
already declared, the seconds declaration shadows the first one.
CC: Vlad Yasevich <vladislav.yasevich@hp.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Make sctp adapt to the limited socket backlog change.
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
The variable newinet is initialized twice to the same (side effect-free)
expression. Drop one initialization.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
// <smpl>
@forall@
idexpression *x;
identifier f!=ERR_PTR;
x = f(...)
... when != x
x = f(...,<+...x...+>,...)
* x = f(...)
// </smpl>
net/sctp/socket.c: In function 'sctp_setsockopt_autoclose':
net/sctp/socket.c:2090: warning: comparison is always false due to limited range of data type
Cc: Andrei Pelinescu-Onciul <andrei@iptel.org>
Fix the following warning, when building on 64 bits:
net/sctp/socket.c:2091: warning: large integer implicitly
truncated to unsigned type
Signed-off-by: Andrei Pelinescu-Onciul <andrei@iptel.org>
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
To avoid overflowing the maximum timer interval when transforming
the autoclose interval from seconds to jiffies, limit the maximum
autoclose value to MAX_SCHEDULE_TIMEOUT/HZ.
