I.e. one-to-many sockets in SCTP are not required to explicitly
call into connect(2) or sctp_connectx(2) prior to data exchange.
Instead, they can directly invoke sendmsg(2) and the SCTP stack
will automatically trigger connection establishment through 4WHS
via sctp_primitive_ASSOCIATE(). However, this in its current
implementation is racy: INIT is being sent out immediately (as
it cannot be bundled anyway) and the rest of the DATA chunks are
queued up for later xmit when connection is established, meaning
sendmsg(2) will return successfully. This behaviour can result
in an undesired side-effect that the kernel made the application
think the data has already been transmitted, although none of it
has actually left the machine, worst case even after close(2)'ing
the socket.
Instead, when the association from client side has been shut down
e.g. first gracefully through SCTP_EOF and then close(2), the
client could afterwards still receive the server's INIT_ACK due
to a connection with higher latency. This INIT_ACK is then considered
out of the blue and hence responded with ABORT as there was no
alive assoc found anymore. This can be easily reproduced f.e.
with sctp_test application from lksctp. One way to fix this race
is to wait for the handshake to actually complete.
The fix defers waiting after sctp_primitive_ASSOCIATE() and
sctp_primitive_SEND() succeeded, so that DATA chunks cooked up
from sctp_sendmsg() have already been placed into the output
queue through the side-effect interpreter, and therefore can then
be bundeled together with COOKIE_ECHO control chunks.
strace from example application (shortened):
socket(PF_INET, SOCK_SEQPACKET, IPPROTO_SCTP) = 3
sendmsg(3, {msg_name(28)={sa_family=AF_INET, sin_port=htons(8888), sin_addr=inet_addr("192.168.1.115")},
msg_iov(1)=[{"hello", 5}], msg_controllen=0, msg_flags=0}, 0) = 5
msg_iov(0)=[], msg_controllen=48, {cmsg_len=48, cmsg_level=0x84 /* SOL_??? */, cmsg_type=, ...},
msg_flags=0}, 0) = 0 // graceful shutdown for SOCK_SEQPACKET via SCTP_EOF
close(3) = 0
tcpdump before patch (fooling the application):
22:33:36.306142 IP 192.168.1.114.41462 > 192.168.1.115.8888: sctp (1) [INIT] [init tag: 3879023686] [rwnd: 106496] [OS: 10] [MIS: 65535] [init TSN: 3139201684]
22:33:36.316619 IP 192.168.1.115.8888 > 192.168.1.114.41462: sctp (1) [INIT ACK] [init tag: 3345394793] [rwnd: 106496] [OS: 10] [MIS: 10] [init TSN: 3380109591]
22:33:36.317600 IP 192.168.1.114.41462 > 192.168.1.115.8888: sctp (1) [ABORT]
tcpdump after patch:
14:28:58.884116 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [INIT] [init tag: 438593213] [rwnd: 106496] [OS: 10] [MIS: 65535] [init TSN: 3092969729]
14:28:58.888414 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [INIT ACK] [init tag: 381429855] [rwnd: 106496] [OS: 10] [MIS: 10] [init TSN: 2141904492]
14:28:58.888638 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [COOKIE ECHO] , (2) [DATA] (B)(E) [TSN: 3092969729] [...]
14:28:58.893278 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [COOKIE ACK] , (2) [SACK] [cum ack 3092969729] [a_rwnd 106491] [#gap acks 0] [#dup tsns 0]
14:28:58.893591 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [DATA] (B)(E) [TSN: 3092969730] [...]
14:28:59.096963 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SACK] [cum ack 3092969730] [a_rwnd 106496] [#gap acks 0] [#dup tsns 0]
14:28:59.097086 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [DATA] (B)(E) [TSN: 3092969731] [...] , (2) [DATA] (B)(E) [TSN: 3092969732] [...]
14:28:59.103218 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SACK] [cum ack 3092969732] [a_rwnd 106486] [#gap acks 0] [#dup tsns 0]
14:28:59.103330 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [SHUTDOWN]
14:28:59.107793 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SHUTDOWN ACK]
14:28:59.107890 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [SHUTDOWN COMPLETE]
Looks like this bug is from the pre-git history museum. ;)
Fixes: 08707d5482df ("lksctp-2_5_31-0_5_1.patch")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Introduce helper macro for_each_cmsghdr as a wrapper of the enumerating
cmsghdr from msghdr, just cleanup.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
It's just silly to hold the skb destructor argument around inside
skb->cb[] as we currently do in SCTP.
Nowadays, we're sort of cheating on data accounting in the sense
that due to commit 4c3a5bdae293 ("sctp: Don't charge for data in
sndbuf again when transmitting packet"), we orphan the skb already
in the SCTP output path, i.e. giving back charged data memory, and
use a different destructor only to make sure the sk doesn't vanish
on skb destruction time. Thus, cb[] is still valid here as we
operate within the SCTP layer. (It's generally actually a big
candidate for future rework, imho.)
However, storing the destructor in the cb[] can easily cause issues
should an non sctp_packet_set_owner_w()'ed skb ever escape the SCTP
layer, since cb[] may get overwritten by lower layers and thus can
corrupt the chunk pointer. There are no such issues at present,
but lets keep the chunk in destructor_arg, as this is the actual
purpose for it.
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Since SCTP day 1, that is, 19b55a2af145 ("Initial commit") from lksctp
tree, the official <netinet/sctp.h> header carries a copy of enum
sctp_sstat_state that looks like (compared to the current in-kernel
enumeration):
User definition: Kernel definition:
enum sctp_sstat_state { typedef enum {
SCTP_EMPTY = 0, <removed>
SCTP_CLOSED = 1, SCTP_STATE_CLOSED = 0,
SCTP_COOKIE_WAIT = 2, SCTP_STATE_COOKIE_WAIT = 1,
SCTP_COOKIE_ECHOED = 3, SCTP_STATE_COOKIE_ECHOED = 2,
SCTP_ESTABLISHED = 4, SCTP_STATE_ESTABLISHED = 3,
SCTP_SHUTDOWN_PENDING = 5, SCTP_STATE_SHUTDOWN_PENDING = 4,
SCTP_SHUTDOWN_SENT = 6, SCTP_STATE_SHUTDOWN_SENT = 5,
SCTP_SHUTDOWN_RECEIVED = 7, SCTP_STATE_SHUTDOWN_RECEIVED = 6,
SCTP_SHUTDOWN_ACK_SENT = 8, SCTP_STATE_SHUTDOWN_ACK_SENT = 7,
}; } sctp_state_t;
This header was later on also placed into the uapi, so that user space
programs can compile without having <netinet/sctp.h>, but the shipped
with <linux/sctp.h> instead.
While RFC6458 under 8.2.1.Association Status (SCTP_STATUS) says that
sstat_state can range from SCTP_CLOSED to SCTP_SHUTDOWN_ACK_SENT, we
nevertheless have a what it appears to be dummy SCTP_EMPTY state from
the very early days.
While it seems to do just nothing, commit 0b8f9e25b0aa ("sctp: remove
completely unsed EMPTY state") did the right thing and removed this dead
code. That however, causes an off-by-one when the user asks the SCTP
stack via SCTP_STATUS API and checks for the current socket state thus
yielding possibly undefined behaviour in applications as they expect
the kernel to tell the right thing.
The enumeration had to be changed however as based on the current socket
state, we access a function pointer lookup-table through this. Therefore,
I think the best way to deal with this is just to add a helper function
sctp_assoc_to_state() to encapsulate the off-by-one quirk.
Reported-by: Tristan Su <sooqing@gmail.com>
Fixes: 0b8f9e25b0aa ("sctp: remove completely unsed EMPTY state")
The SCTP socket extensions API document describes the v4mapping option as
follows:
8.1.15. Set/Clear IPv4 Mapped Addresses (SCTP_I_WANT_MAPPED_V4_ADDR)
This socket option is a Boolean flag which turns on or off the
mapping of IPv4 addresses. If this option is turned on, then IPv4
addresses will be mapped to V6 representation. If this option is
turned off, then no mapping will be done of V4 addresses and a user
will receive both PF_INET6 and PF_INET type addresses on the socket.
See [RFC3542] for more details on mapped V6 addresses.
This description isn't really in line with what the code does though.
Introduce addr_to_user (renamed addr_v4map), which should be called
before any sockaddr is passed back to user space. The new function
places the sockaddr into the correct format depending on the
SCTP_I_WANT_MAPPED_V4_ADDR option.
Audit all places that touched v4mapped and either sanely construct
a v4 or v6 address then call addr_to_user, or drop the
unnecessary v4mapped check entirely.
Audit all places that call addr_to_user and verify they are on a sycall
return path.
Add a custom getname that formats the address properly.
Several bugs are addressed:
- SCTP_I_WANT_MAPPED_V4_ADDR=0 often returned garbage for
addresses to user space
- The addr_len returned from recvmsg was not correct when
returning AF_INET on a v6 socket
- flowlabel and scope_id were not zerod when promoting
a v4 to v6
- Some syscalls like bind and connect behaved differently
depending on v4mapped
Tested bind, getpeername, getsockname, connect, and recvmsg for proper
behaviour in v4mapped = 1 and 0 cases.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
With support of SCTP_SNDINFO/SCTP_RCVINFO as described in RFC6458,
5.3.4/5.3.5, we can now deprecate SCTP_SNDRCV. The RFC already
declares it as deprecated:
This structure mixes the send and receive path. SCTP_SNDINFO
(described in Section 5.3.4) and SCTP_RCVINFO (described in
Section 5.3.5) split this information. These structures should
be used, when possible, since SCTP_SNDRCV is deprecated.
So whenever a user tries to subscribe to sctp_data_io_event via
setsockopt(2) which triggers inclusion of SCTP_SNDRCV cmsg_type,
issue a warning in the log.
This patch implements section 8.1.31. of RFC6458, which adds support
for setting/retrieving SCTP_DEFAULT_SNDINFO:
Applications that wish to use the sendto() system call may wish
to specify a default set of parameters that would normally be
supplied through the inclusion of ancillary data. This socket
option allows such an application to set the default sctp_sndinfo
structure. The application that wishes to use this socket option
simply passes the sctp_sndinfo structure (defined in Section 5.3.4)
to this call. The input parameters accepted by this call include
snd_sid, snd_flags, snd_ppid, and snd_context. The snd_flags
parameter is composed of a bitwise OR of SCTP_UNORDERED, SCTP_EOF,
and SCTP_SENDALL. The snd_assoc_id field specifies the association
to which to apply the parameters. For a one-to-many style socket,
any of the predefined constants are also allowed in this field.
The field is ignored for one-to-one style sockets.
Joint work with Daniel Borkmann.
Signed-off-by: Geir Ola Vaagland <geirola@gmail.com>
This patch implements section 5.3.6. of RFC6458, that is, support
for 'SCTP Next Receive Information Structure' (SCTP_NXTINFO) which
is placed into ancillary data cmsghdr structure for each recvmsg()
call, if this information is already available when delivering the
current message.
This option can be enabled/disabled via setsockopt(2) on SOL_SCTP
level by setting an int value with 1/0 for SCTP_RECVNXTINFO in
user space applications as per RFC6458, section 8.1.30.
The sctp_nxtinfo structure is defined as per RFC as below ...
struct sctp_nxtinfo {
uint16_t nxt_sid;
uint16_t nxt_flags;
uint32_t nxt_ppid;
uint32_t nxt_length;
sctp_assoc_t nxt_assoc_id;
... and provided under cmsg_level IPPROTO_SCTP, cmsg_type
SCTP_NXTINFO, while cmsg_data[] contains struct sctp_nxtinfo.
This patch implements section 5.3.5. of RFC6458, that is, support
for 'SCTP Receive Information Structure' (SCTP_RCVINFO) which is
call.
level by setting an int value with 1/0 for SCTP_RECVRCVINFO in user
space applications as per RFC6458, section 8.1.29.
The sctp_rcvinfo structure is defined as per RFC as below ...
struct sctp_rcvinfo {
uint16_t rcv_sid;
uint16_t rcv_ssn;
uint16_t rcv_flags;
<-- 2 bytes hole -->
uint32_t rcv_ppid;
uint32_t rcv_tsn;
uint32_t rcv_cumtsn;
uint32_t rcv_context;
sctp_assoc_t rcv_assoc_id;
SCTP_RCVINFO, while cmsg_data[] contains struct sctp_rcvinfo.
An sctp_rcvinfo item always corresponds to the data in msg_iov.
This patch implements section 5.3.4. of RFC6458, that is, support
for 'SCTP Send Information Structure' (SCTP_SNDINFO) which can be
placed into ancillary data cmsghdr structure for sendmsg() calls.
The sctp_sndinfo structure is defined as per RFC as below ...
struct sctp_sndinfo {
uint16_t snd_sid;
uint16_t snd_flags;
uint32_t snd_ppid;
uint32_t snd_context;
sctp_assoc_t snd_assoc_id;
... and supplied under cmsg_level IPPROTO_SCTP, cmsg_type
SCTP_SNDINFO, while cmsg_data[] contains struct sctp_sndinfo.
An sctp_sndinfo item always corresponds to the data in msg_iov.
Define separate fields in the sock structure for configuring disabling
checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx.
The SO_NO_CHECK socket option only affects sk_no_check_tx. Also,
removed UDP_CSUM_* defines since they are no longer necessary.
Signed-off-by: Tom Herbert <therbert@google.com>
ip_local_port_range is already per netns, so should ip_local_reserved_ports
be. And since it is none by default we don't actually need it when we don't
enable CONFIG_SYSCTL.
By the way, rename inet_is_reserved_local_port() to inet_is_local_reserved_port()
The busy polling socket option adds support for sockets to busy wait on data
arriving on the napi queue from which they have most recently received a frame.
Currently only tcp and udp support this feature, but theres no reason sctp can't
do so as well. Add it in so appliations can take advantage of it
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Daniel Borkmann <dborkman@redhat.com>
CC: netdev@vger.kernel.org
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Currently, it is possible to create an SCTP socket, then switch
auth_enable via sysctl setting to 1 and crash the system on connect:
Oops[#1]:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.1-mipsgit-20140415 #1
task: ffffffff8056ce80 ti: ffffffff8055c000 task.ti: ffffffff8055c000
Call Trace:
[<ffffffff8043c4e8>] sctp_auth_asoc_set_default_hmac+0x68/0x80
[<ffffffff8042b300>] sctp_process_init+0x5e0/0x8a4
[<ffffffff8042188c>] sctp_sf_do_5_1B_init+0x234/0x34c
[<ffffffff804228c8>] sctp_do_sm+0xb4/0x1e8
[<ffffffff80425a08>] sctp_endpoint_bh_rcv+0x1c4/0x214
[<ffffffff8043af68>] sctp_rcv+0x588/0x630
[<ffffffff8043e8e8>] sctp6_rcv+0x10/0x24
[<ffffffff803acb50>] ip6_input+0x2c0/0x440
[<ffffffff8030fc00>] __netif_receive_skb_core+0x4a8/0x564
[<ffffffff80310650>] process_backlog+0xb4/0x18c
[<ffffffff80313cbc>] net_rx_action+0x12c/0x210
[<ffffffff80034254>] __do_softirq+0x17c/0x2ac
[<ffffffff800345e0>] irq_exit+0x54/0xb0
[<ffffffff800075a4>] ret_from_irq+0x0/0x4
[<ffffffff800090ec>] rm7k_wait_irqoff+0x24/0x48
[<ffffffff8005e388>] cpu_startup_entry+0xc0/0x148
[<ffffffff805a88b0>] start_kernel+0x37c/0x398
Code: dd0900b8 000330f8 0126302d <dcc60000> 50c0fff1 0047182a a48306a0
03e00008 00000000
---[ end trace b530b0551467f2fd ]---
Kernel panic - not syncing: Fatal exception in interrupt
What happens while auth_enable=0 in that case is, that
ep->auth_hmacs is initialized to NULL in sctp_auth_init_hmacs()
when endpoint is being created.
After that point, if an admin switches over to auth_enable=1,
the machine can crash due to NULL pointer dereference during
reception of an INIT chunk. When we enter sctp_process_init()
via sctp_sf_do_5_1B_init() in order to respond to an INIT chunk,
the INIT verification succeeds and while we walk and process
all INIT params via sctp_process_param() we find that
net->sctp.auth_enable is set, therefore do not fall through,
but invoke sctp_auth_asoc_set_default_hmac() instead, and thus,
dereference what we have set to NULL during endpoint
initialization phase.
The fix is to make auth_enable immutable by caching its value
during endpoint initialization, so that its original value is
being carried along until destruction. The bug seems to originate
from the very first days.
Fix in joint work with Daniel Borkmann.
Reported-by: Joshua Kinard <kumba@gentoo.org>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Tested-by: Joshua Kinard <kumba@gentoo.org>
receiver's buffer"
This reverts commit ef2820a735f7 ("net: sctp: Fix a_rwnd/rwnd management
to reflect real state of the receiver's buffer") as it introduced a
serious performance regression on SCTP over IPv4 and IPv6, though a not
as dramatic on the latter. Measurements are on 10Gbit/s with ixgbe NICs.
Current state:
[root@Lab200slot2 ~]# iperf3 --sctp -4 -c 192.168.241.3 -V -l 1452 -t 60
iperf version 3.0.1 (10 January 2014)
Linux Lab200slot2 3.14.0 #1 SMP Thu Apr 3 23:18:29 EDT 2014 x86_64
Time: Fri, 11 Apr 2014 17:56:21 GMT
Connecting to host 192.168.241.3, port 5201
Cookie: Lab200slot2.1397238981.812898.548918
[ 4] local 192.168.241.2 port 38616 connected to 192.168.241.3 port 5201
Starting Test: protocol: SCTP, 1 streams, 1452 byte blocks, omitting 0 seconds, 60 second test
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.09 sec 20.8 MBytes 161 Mbits/sec
[ 4] 1.09-2.13 sec 10.8 MBytes 86.8 Mbits/sec
[ 4] 2.13-3.15 sec 3.57 MBytes 29.5 Mbits/sec
[ 4] 3.15-4.16 sec 4.33 MBytes 35.7 Mbits/sec
[ 4] 4.16-6.21 sec 10.4 MBytes 42.7 Mbits/sec
[ 4] 6.21-6.21 sec 0.00 Bytes 0.00 bits/sec
[ 4] 6.21-7.35 sec 34.6 MBytes 253 Mbits/sec
[ 4] 7.35-11.45 sec 22.0 MBytes 45.0 Mbits/sec
[ 4] 11.45-11.45 sec 0.00 Bytes 0.00 bits/sec
[ 4] 11.45-12.51 sec 16.0 MBytes 126 Mbits/sec
[ 4] 12.51-13.59 sec 20.3 MBytes 158 Mbits/sec
[ 4] 13.59-14.65 sec 13.4 MBytes 107 Mbits/sec
[ 4] 14.65-16.79 sec 33.3 MBytes 130 Mbits/sec
[ 4] 16.79-16.79 sec 0.00 Bytes 0.00 bits/sec
[ 4] 16.79-17.82 sec 5.94 MBytes 48.7 Mbits/sec
(etc)
[root@Lab200slot2 ~]# iperf3 --sctp -6 -c 2001:db8:0:f101::1 -V -l 1400 -t 60
Time: Fri, 11 Apr 2014 19:08:41 GMT
Connecting to host 2001:db8:0:f101::1, port 5201
Cookie: Lab200slot2.1397243321.714295.2b3f7c
[ 4] local 2001:db8:0:f101::2 port 55804 connected to 2001:db8:0:f101::1 port 5201
Starting Test: protocol: SCTP, 1 streams, 1400 byte blocks, omitting 0 seconds, 60 second test
[ 4] 0.00-1.00 sec 169 MBytes 1.42 Gbits/sec
[ 4] 1.00-2.00 sec 201 MBytes 1.69 Gbits/sec
[ 4] 2.00-3.00 sec 188 MBytes 1.58 Gbits/sec
[ 4] 3.00-4.00 sec 174 MBytes 1.46 Gbits/sec
[ 4] 4.00-5.00 sec 165 MBytes 1.39 Gbits/sec
[ 4] 5.00-6.00 sec 199 MBytes 1.67 Gbits/sec
[ 4] 6.00-7.00 sec 163 MBytes 1.36 Gbits/sec
[ 4] 7.00-8.00 sec 174 MBytes 1.46 Gbits/sec
[ 4] 8.00-9.00 sec 193 MBytes 1.62 Gbits/sec
[ 4] 9.00-10.00 sec 196 MBytes 1.65 Gbits/sec
[ 4] 10.00-11.00 sec 157 MBytes 1.31 Gbits/sec
[ 4] 11.00-12.00 sec 175 MBytes 1.47 Gbits/sec
[ 4] 12.00-13.00 sec 192 MBytes 1.61 Gbits/sec
[ 4] 13.00-14.00 sec 199 MBytes 1.67 Gbits/sec
(etc)
After patch:
[root@Lab200slot2 ~]# iperf3 --sctp -4 -c 192.168.240.3 -V -l 1452 -t 60
Linux Lab200slot2 3.14.0+ #1 SMP Mon Apr 14 12:06:40 EDT 2014 x86_64
Time: Mon, 14 Apr 2014 16:40:48 GMT
Connecting to host 192.168.240.3, port 5201
Cookie: Lab200slot2.1397493648.413274.65e131
[ 4] local 192.168.240.2 port 50548 connected to 192.168.240.3 port 5201
[ 4] 0.00-1.00 sec 240 MBytes 2.02 Gbits/sec
[ 4] 1.00-2.00 sec 239 MBytes 2.01 Gbits/sec
[ 4] 2.00-3.00 sec 240 MBytes 2.01 Gbits/sec
[ 4] 3.00-4.00 sec 239 MBytes 2.00 Gbits/sec
[ 4] 4.00-5.00 sec 245 MBytes 2.05 Gbits/sec
[ 4] 5.00-6.00 sec 240 MBytes 2.01 Gbits/sec
[ 4] 6.00-7.00 sec 240 MBytes 2.02 Gbits/sec
[ 4] 7.00-8.00 sec 239 MBytes 2.01 Gbits/sec
With the reverted patch applied, the SCTP/IPv4 performance is back
to normal on latest upstream for IPv4 and IPv6 and has same throughput
as 3.4.2 test kernel, steady and interval reports are smooth again.
Fixes: ef2820a735f7 ("net: sctp: Fix a_rwnd/rwnd management to reflect real state of the receiver's buffer")
Reported-by: Peter Butler <pbutler@sonusnet.com>
Reported-by: Dongsheng Song <dongsheng.song@gmail.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Peter Butler <pbutler@sonusnet.com>
Cc: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nsn.com>
Cc: Alexander Sverdlin <alexander.sverdlin@nsn.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
In function sctp_wake_up_waiters(), we need to involve a test
if the association is declared dead. If so, we don't have any
reference to a possible sibling association anymore and need
to invoke sctp_write_space() instead, and normally walk the
socket's associations and notify them of new wmem space. The
reason for special casing is that otherwise, we could run
into the following issue when a sctp_primitive_SEND() call
from sctp_sendmsg() fails, and tries to flush an association's
outq, i.e. in the following way:
sctp_association_free()
`-> list_del(&asoc->asocs) <-- poisons list pointer
asoc->base.dead = true
sctp_outq_free(&asoc->outqueue)
`-> __sctp_outq_teardown()
`-> sctp_chunk_free()
`-> consume_skb()
`-> sctp_wfree()
`-> sctp_wake_up_waiters() <-- dereferences poisoned pointers
if asoc->ep->sndbuf_policy=0
Therefore, only walk the list in an 'optimized' way if we find
that the current association is still active. We could also use
list_del_init() in addition when we call sctp_association_free(),
but as Vlad suggests, we want to trap such bugs and thus leave
it poisoned as is.
Why is it safe to resolve the issue by testing for asoc->base.dead?
Parallel calls to sctp_sendmsg() are protected under socket lock,
that is lock_sock()/release_sock(). Only within that path under
lock held, we're setting skb/chunk owner via sctp_set_owner_w().
Eventually, chunks are freed directly by an association still
under that lock. So when traversing association list on destruction
time from sctp_wake_up_waiters() via sctp_wfree(), a different
CPU can't be running sctp_wfree() while another one calls
sctp_association_free() as both happens under the same lock.
Therefore, this can also not race with setting/testing against
asoc->base.dead as we are guaranteed for this to happen in order,
under lock. Further, Vlad says: the times we check asoc->base.dead
is when we've cached an association pointer for later processing.
In between cache and processing, the association may have been
freed and is simply still around due to reference counts. We check
asoc->base.dead under a lock, so it should always be safe to check
and not race against sctp_association_free(). Stress-testing seems
fine now, too.
Fixes: cd253f9f357d ("net: sctp: wake up all assocs if sndbuf policy is per socket")
Cc: Vlad Yasevich <vyasevic@redhat.com>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
SCTP charges chunks for wmem accounting via skb->truesize in
sctp_set_owner_w(), and sctp_wfree() respectively as the
reverse operation. If a sender runs out of wmem, it needs to
wait via sctp_wait_for_sndbuf(), and gets woken up by a call
to __sctp_write_space() mostly via sctp_wfree().
__sctp_write_space() is being called per association. Although
we assign sk->sk_write_space() to sctp_write_space(), which
is then being done per socket, it is only used if send space
is increased per socket option (SO_SNDBUF), as SOCK_USE_WRITE_QUEUE
is set and therefore not invoked in sock_wfree().
Commit 4c3a5bdae293 ("sctp: Don't charge for data in sndbuf
again when transmitting packet") fixed an issue where in case
sctp_packet_transmit() manages to queue up more than sndbuf
bytes, sctp_wait_for_sndbuf() will never be woken up again
unless it is interrupted by a signal. However, a still
remaining issue is that if net.sctp.sndbuf_policy=0, that is
accounting per socket, and one-to-many sockets are in use,
the reclaimed write space from sctp_wfree() is 'unfairly'
handed back on the server to the association that is the lucky
one to be woken up again via __sctp_write_space(), while
the remaining associations are never be woken up again
(unless by a signal).
The effect disappears with net.sctp.sndbuf_policy=1, that
is wmem accounting per association, as it guarantees a fair
share of wmem among associations.
Therefore, if we have reclaimed memory in case of per socket
accounting, wake all related associations to a socket in a
fair manner, that is, traverse the socket association list
starting from the current neighbour of the association and
issue a __sctp_write_space() to everyone until we end up
waking ourselves. This guarantees that no association is
preferred over another and even if more associations are
taken into the one-to-many session, all receivers will get
messages from the server and are not stalled forever on
high load. This setting still leaves the advantage of per
socket accounting in touch as an association can still use
up global limits if unused by others.
Fixes: 4eb701dfc618 ("[SCTP] Fix SCTP sendbuffer accouting.")
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Neil Horman <nhorman@tuxdriver.com>
SCTP's sctp_connectx() abi breaks for 64bit kernels compiled with 32bit
emulation (e.g. ia32 emulation or x86_x32). Due to internal usage of
'struct sctp_getaddrs_old' which includes a struct sockaddr pointer,
sizeof(param) check will always fail in kernel as the structure in
64bit kernel space is 4bytes larger than for user binaries compiled
in 32bit mode. Thus, applications making use of sctp_connectx() won't
be able to run under such circumstances.
Introduce a compat interface in the kernel to deal with such
situations by using a 'struct compat_sctp_getaddrs_old' structure
where user data is copied into it, and then sucessively transformed
into a 'struct sctp_getaddrs_old' structure with the help of
compat_ptr(). That fixes sctp_connectx() abi without any changes
needed in user space, and lets the SCTP test suite pass when compiled
in 32bit and run on 64bit kernels.
Fixes: f9c67811ebc0 ("sctp: Fix regression introduced by new sctp_connectx api")
receiver's buffer
Implementation of (a)rwnd calculation might lead to severe performance issues
and associations completely stalling. These problems are described and solution
is proposed which improves lksctp's robustness in congestion state.
1) Sudden drop of a_rwnd and incomplete window recovery afterwards
Data accounted in sctp_assoc_rwnd_decrease takes only payload size (sctp data),
but size of sk_buff, which is blamed against receiver buffer, is not accounted
in rwnd. Theoretically, this should not be the problem as actual size of buffer
is double the amount requested on the socket (SO_RECVBUF). Problem here is
that this will have bad scaling for data which is less then sizeof sk_buff.
E.g. in 4G (LTE) networks, link interfacing radio side will have a large portion
of traffic of this size (less then 100B).
An example of sudden drop and incomplete window recovery is given below. Node B
exhibits problematic behavior. Node A initiates association and B is configured
to advertise rwnd of 10000. A sends messages of size 43B (size of typical sctp
message in 4G (LTE) network). On B data is left in buffer by not reading socket
in userspace.
Lets examine when we will hit pressure state and declare rwnd to be 0 for
scenario with above stated parameters (rwnd == 10000, chunk size == 43, each
chunk is sent in separate sctp packet)
Logic is implemented in sctp_assoc_rwnd_decrease:
socket_buffer (see below) is maximum size which can be held in socket buffer
(sk_rcvbuf). current_alloced is amount of data currently allocated (rx_count)
A simple expression is given for which it will be examined after how many
packets for above stated parameters we enter pressure state:
We start by condition which has to be met in order to enter pressure state:
socket_buffer < currently_alloced;
currently_alloced is represented as size of sctp packets received so far and not
yet delivered to userspace. x is the number of chunks/packets (since there is no
bundling, and each chunk is delivered in separate packet, we can observe each
chunk also as sctp packet, and what is important here, having its own sk_buff):
socket_buffer < x*each_sctp_packet;
each_sctp_packet is sctp chunk size + sizeof(struct sk_buff). socket_buffer is
twice the amount of initially requested size of socket buffer, which is in case
of sctp, twice the a_rwnd requested:
2*rwnd < x*(payload+sizeof(struc sk_buff));
sizeof(struct sk_buff) is 190 (3.13.0-rc4+). Above is stated that rwnd is 10000
and each payload size is 43
20000 < x(43+190);
x > 20000/233;
x ~> 84;
After ~84 messages, pressure state is entered and 0 rwnd is advertised while
received 84*43B ~= 3612B sctp data. This is why external observer notices sudden
drop from 6474 to 0, as it will be now shown in example:
IP A.34340 > B.12345: sctp (1) [INIT] [init tag: 1875509148] [rwnd: 81920] [OS: 10] [MIS: 65535] [init TSN: 1096057017]
IP B.12345 > A.34340: sctp (1) [INIT ACK] [init tag: 3198966556] [rwnd: 10000] [OS: 10] [MIS: 10] [init TSN: 902132839]
IP A.34340 > B.12345: sctp (1) [COOKIE ECHO]
IP B.12345 > A.34340: sctp (1) [COOKIE ACK]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057017] [SID: 0] [SSEQ 0] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057017] [a_rwnd 9957] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057018] [SID: 0] [SSEQ 1] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057018] [a_rwnd 9957] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057019] [SID: 0] [SSEQ 2] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057019] [a_rwnd 9914] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057098] [SID: 0] [SSEQ 81] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057098] [a_rwnd 6517] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057099] [SID: 0] [SSEQ 82] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057099] [a_rwnd 6474] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057100] [SID: 0] [SSEQ 83] [PPID 0x18]
--> Sudden drop
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057100] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
At this point, rwnd_press stores current rwnd value so it can be later restored
in sctp_assoc_rwnd_increase. This however doesn't happen as condition to start
slowly increasing rwnd until rwnd_press is returned to rwnd is never met. This
condition is not met since rwnd, after it hit 0, must first reach rwnd_press by
adding amount which is read from userspace. Let us observe values in above
example. Initial a_rwnd is 10000, pressure was hit when rwnd was ~6500 and the
amount of actual sctp data currently waiting to be delivered to userspace
is ~3500. When userspace starts to read, sctp_assoc_rwnd_increase will be blamed
only for sctp data, which is ~3500. Condition is never met, and when userspace
reads all data, rwnd stays on 3569.
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057100] [a_rwnd 1505] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057100] [a_rwnd 3010] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057101] [SID: 0] [SSEQ 84] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057101] [a_rwnd 3569] [#gap acks 0] [#dup tsns 0]
--> At this point userspace read everything, rwnd recovered only to 3569
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057102] [SID: 0] [SSEQ 85] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057102] [a_rwnd 3569] [#gap acks 0] [#dup tsns 0]
Reproduction is straight forward, it is enough for sender to send packets of
size less then sizeof(struct sk_buff) and receiver keeping them in its buffers.
2) Minute size window for associations sharing the same socket buffer
In case multiple associations share the same socket, and same socket buffer
(sctp.rcvbuf_policy == 0), different scenarios exist in which congestion on one
of the associations can permanently drop rwnd of other association(s).
Situation will be typically observed as one association suddenly having rwnd
dropped to size of last packet received and never recovering beyond that point.
Different scenarios will lead to it, but all have in common that one of the
associations (let it be association from 1)) nearly depleted socket buffer, and
the other association blames socket buffer just for the amount enough to start
the pressure. This association will enter pressure state, set rwnd_press and
announce 0 rwnd.
When data is read by userspace, similar situation as in 1) will occur, rwnd will
increase just for the size read by userspace but rwnd_press will be high enough
so that association doesn't have enough credit to reach rwnd_press and restore
to previous state. This case is special case of 1), being worse as there is, in
the worst case, only one packet in buffer for which size rwnd will be increased.
Consequence is association which has very low maximum rwnd ('minute size', in
our case down to 43B - size of packet which caused pressure) and as such
unusable.
Scenario happened in the field and labs frequently after congestion state (link
breaks, different probabilities of packet drop, packet reordering) and with
scenario 1) preceding. Here is given a deterministic scenario for reproduction:
>From node A establish two associations on the same socket, with rcvbuf_policy
being set to share one common buffer (sctp.rcvbuf_policy == 0). On association 1
repeat scenario from 1), that is, bring it down to 0 and restore up. Observe
scenario 1). Use small payload size (here we use 43). Once rwnd is 'recovered',
bring it down close to 0, as in just one more packet would close it. This has as
a consequence that association number 2 is able to receive (at least) one more
packet which will bring it in pressure state. E.g. if association 2 had rwnd of
10000, packet received was 43, and we enter at this point into pressure,
rwnd_press will have 9957. Once payload is delivered to userspace, rwnd will
increase for 43, but conditions to restore rwnd to original state, just as in
1), will never be satisfied.
--> Association 1, between A.y and B.12345
IP A.55915 > B.12345: sctp (1) [INIT] [init tag: 836880897] [rwnd: 10000] [OS: 10] [MIS: 65535] [init TSN: 4032536569]
IP B.12345 > A.55915: sctp (1) [INIT ACK] [init tag: 2873310749] [rwnd: 81920] [OS: 10] [MIS: 10] [init TSN: 3799315613]
IP A.55915 > B.12345: sctp (1) [COOKIE ECHO]
IP B.12345 > A.55915: sctp (1) [COOKIE ACK]
--> Association 2, between A.z and B.12346
IP A.55915 > B.12346: sctp (1) [INIT] [init tag: 534798321] [rwnd: 10000] [OS: 10] [MIS: 65535] [init TSN: 2099285173]
IP B.12346 > A.55915: sctp (1) [INIT ACK] [init tag: 516668823] [rwnd: 81920] [OS: 10] [MIS: 10] [init TSN: 3676403240]
IP A.55915 > B.12346: sctp (1) [COOKIE ECHO]
IP B.12346 > A.55915: sctp (1) [COOKIE ACK]
--> Deplete socket buffer by sending messages of size 43B over association 1
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315613] [SID: 0] [SSEQ 0] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315613] [a_rwnd 9957] [#gap acks 0] [#dup tsns 0]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315696] [a_rwnd 6388] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315697] [SID: 0] [SSEQ 84] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315697] [a_rwnd 6345] [#gap acks 0] [#dup tsns 0]
--> Sudden drop on 1
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315698] [SID: 0] [SSEQ 85] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315698] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
--> Here userspace read, rwnd 'recovered' to 3698, now deplete again using
association 1 so there is place in buffer for only one more packet
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315799] [SID: 0] [SSEQ 186] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315799] [a_rwnd 86] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315800] [SID: 0] [SSEQ 187] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315800] [a_rwnd 43] [#gap acks 0] [#dup tsns 0]
--> Socket buffer is almost depleted, but there is space for one more packet,
send them over association 2, size 43B
IP B.12346 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3676403240] [SID: 0] [SSEQ 0] [PPID 0x18]
IP A.55915 > B.12346: sctp (1) [SACK] [cum ack 3676403240] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
--> Immediate drop
IP A.60995 > B.12346: sctp (1) [SACK] [cum ack 387491510] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
--> Read everything from the socket, both association recover up to maximum rwnd
they are capable of reaching, note that association 1 recovered up to 3698,
and association 2 recovered only to 43
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315800] [a_rwnd 1548] [#gap acks 0] [#dup tsns 0]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315800] [a_rwnd 3053] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315801] [SID: 0] [SSEQ 188] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315801] [a_rwnd 3698] [#gap acks 0] [#dup tsns 0]
IP B.12346 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3676403241] [SID: 0] [SSEQ 1] [PPID 0x18]
IP A.55915 > B.12346: sctp (1) [SACK] [cum ack 3676403241] [a_rwnd 43] [#gap acks 0] [#dup tsns 0]
A careful reader might wonder why it is necessary to reproduce 1) prior
reproduction of 2). It is simply easier to observe when to send packet over
association 2 which will push association into the pressure state.
Proposed solution:
Both problems share the same root cause, and that is improper scaling of socket
buffer with rwnd. Solution in which sizeof(sk_buff) is taken into concern while
calculating rwnd is not possible due to fact that there is no linear
relationship between amount of data blamed in increase/decrease with IP packet
in which payload arrived. Even in case such solution would be followed,
complexity of the code would increase. Due to nature of current rwnd handling,
slow increase (in sctp_assoc_rwnd_increase) of rwnd after pressure state is
entered is rationale, but it gives false representation to the sender of current
buffer space. Furthermore, it implements additional congestion control mechanism
which is defined on implementation, and not on standard basis.
Proposed solution simplifies whole algorithm having on mind definition from rfc:
o Receiver Window (rwnd): This gives the sender an indication of the space
available in the receiver's inbound buffer.
Core of the proposed solution is given with these lines:
sctp_assoc_rwnd_update:
if ((asoc->base.sk->sk_rcvbuf - rx_count) > 0)
asoc->rwnd = (asoc->base.sk->sk_rcvbuf - rx_count) >> 1;
else
asoc->rwnd = 0;
We advertise to sender (half of) actual space we have. Half is in the braces
depending whether you would like to observe size of socket buffer as SO_RECVBUF
or twice the amount, i.e. size is the one visible from userspace, that is,
from kernelspace.
In this way sender is given with good approximation of our buffer space,
regardless of the buffer policy - we always advertise what we have. Proposed
solution fixes described problems and removes necessity for rwnd restoration
algorithm. Finally, as proposed solution is simplification, some lines of code,
along with some bytes in struct sctp_association are saved.
Version 2 of the patch addressed comments from Vlad. Name of the function is set
to be more descriptive, and two parts of code are changed, in one removing the
superfluous call to sctp_assoc_rwnd_update since call would not result in update
of rwnd, and the other being reordering of the code in a way that call to
sctp_assoc_rwnd_update updates rwnd. Version 3 corrected change introduced in v2
in a way that existing function is not reordered/copied in line, but it is
correctly called. Thanks Vlad for suggesting.
Signed-off-by: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nsn.com>
Reviewed-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
Redefined bh_[un]lock_sock to sctp_bh[un]lock_sock for user
space friendly code which we haven't use in years, so removing them.
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
Redefined {lock|release}_sock to sctp_{lock|release}_sock for user space friendly
Redefined spin_[un]lock to sctp_spin_[un]lock for user space friendly
Redefined local_bh_{disable|enable} to sctp_local_bh_{disable|enable}
for user space friendly code which we haven't use in years, so removing them.
add sctp_spp_sackdelay_{enable|disable} helper function for
avoiding code duplication.
It confuses Smatch when we check "sinit" for NULL and then non-NULL and
that causes a false positive warning later.
This patch removes the net_random and net_srandom macros and replaces
them with direct calls to the prandom ones. As new commits only seem to
use prandom_u32 there is no use to keep them around.
This change makes it easier to grep for users of prandom_u32.
Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Recently I updated the sctp socket option deprecation warnings to be both a bit
more clear and ratelimited to prevent user processes from spamming the log file.
Ben Hutchings suggested that I add the process name and pid to these warnings so
that users can tell who is responsible for using the deprecated apis. This
patch accomplishes that.
CC: Ben Hutchings <bhutchings@solarflare.com>
During a recent discussion regarding some sctp socket options, it was noted that
we have several points at which we issue log warnings that can be flooded at an
unbounded rate by any user. Fix this by converting all the pr_warns in the
sctp_setsockopt path to be pr_warn_ratelimited.
Note there are several debug level messages as well. I'm leaving those alone,
as, if you turn on pr_debug, you likely want lots of verbosity.
CC: David Miller <davem@davemloft.net>
fix checkpatch errors below:
ERROR: that open brace { should be on the previous line
ERROR: open brace '{' following function declarations go on the next line
ERROR: trailing statements should be on next line
ERROR: "(foo*)" should be "(foo *)"
ERROR: "foo * bar" should be "foo *bar"
ERROR: "foo* bar" should be "foo *bar"
fix checkpatch errors while the space is required or prohibited
to the "=,()++..."
drivers/net/ethernet/intel/i40e/i40e_main.c
drivers/net/macvtap.c
Both minor merge hassles, simple overlapping changes.
When we set 0 to rto_min or rto_max, just not change the value. Also
we should check the rto_min > rto_max.
Suggested-by: Vlad Yasevich <vyasevich@gmail.com>
Currently, sctp associations latch a sockets autoclose value to an association
at association init time, subject to capping constraints from the max_autoclose
sysctl value. This leads to an odd situation where an application may set a
socket level autoclose timeout, but sliently sctp will limit the autoclose
timeout to something less than that.
Fix this by modifying the autoclose setsockopt function to check the limit, cap
it and warn the user via syslog that the timeout is capped. This will allow
getsockopt to return valid autoclose timeout values that reflect what subsequent
associations actually use.
While were at it, also elimintate the assoc->autoclose variable, it duplicates
whats in the timeout array, which leads to multiple sources for the same
information, that may differ (as the former isn't subject to any capping). This
gives us the timeout information in a canonical place and saves some space in
the association structure as well.
CC: Wang Weidong <wangweidong1@huawei.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: Neil Horman <nhorman@tuxdriver.com>
- Move sysctl_local_ports from a global variable into struct netns_ipv4.
- Modify inet_get_local_port_range to take a struct net, and update all
of the callers.
- Move the initialization of sysctl_local_ports into
sysctl_net_ipv4.c:ipv4_sysctl_init_net from inet_connection_sock.c
v2:
- Ensure indentation used tabs
- Fixed ip.h so it applies cleanly to todays net-next
v3:
- Compile fixes of strange callers of inet_get_local_port_range.
This patch now successfully passes an allmodconfig build.
Removed manual inlining of inet_get_local_port_range in ipv4_local_port_range
Originally-by: Samya <samya@twitter.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
This was originally reported in [1] and posted by Neil Horman [2], he said:
Fix up a missed null pointer check in the asconf code. If we don't find
a local address, but we pass in an address length of more than 1, we may
dereference a NULL laddr pointer. Currently this can't happen, as the only
users of the function pass in the value 1 as the addrcnt parameter, but
its not hot path, and it doesn't hurt to check for NULL should that ever
be the case.
The callpath from sctp_asconf_mgmt() looks okay. But this could be triggered
from sctp_setsockopt_bindx() call with SCTP_BINDX_REM_ADDR and addrcnt > 1
while passing all possible addresses from the bind list to SCTP_BINDX_REM_ADDR
so that we do *not* find a single address in the association's bind address
list that is not in the packed array of addresses. If this happens when we
have an established association with ASCONF-capable peers, then we could get
a NULL pointer dereference as we only check for laddr == NULL && addrcnt == 1
and call later sctp_make_asconf_update_ip() with NULL laddr.
BUT: this actually won't happen as sctp_bindx_rem() will catch such a case
and return with an error earlier. As this is incredably unintuitive and error
prone, add a check to catch at least future bugs here. As Neil says, its not
hot path. Introduced by 8a07eb0a5 ("sctp: Add ASCONF operation on the
single-homed host").
[1] http://www.spinics.net/lists/linux-sctp/msg02132.html
[2] http://www.spinics.net/lists/linux-sctp/msg02133.html
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Michio Honda <micchie@sfc.wide.ad.jp>
Acked-By: Neil Horman <nhorman@tuxdriver.com>
If we do not add braces around ...
mask |= POLLERR |
sock_flag(sk, SOCK_SELECT_ERR_QUEUE) ? POLLPRI : 0;
... then this condition always evaluates to true as POLLERR is
defined as 8 and binary or'd with whatever result comes out of
sock_flag(). Hence instead of (X | Y) ? A : B, transform it into
X | (Y ? A : B). Unfortunatelty, commit 8facd5fb73 ("net: fix
smatch warnings inside datagram_poll") forgot about SCTP. :-(
Introduced by 7d4c04fc170 ("net: add option to enable error queue
packets waking select").
Cc: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Jacob Keller <jacob.e.keller@intel.com>
With the restructuring of the lksctp.org site, we only allow bug
reports through the SCTP mailing list linux-sctp@vger.kernel.org,
not via SF, as SF is only used for web hosting and nothing more.
While at it, also remove the obvious statement that bugs will be
fixed and incooperated into the kernel.
The SCTP mailing list address to send patches or questions
to is linux-sctp@vger.kernel.org and not
lksctp-developers@lists.sourceforge.net anymore. Therefore,
update all occurences.
Macro get_unused_fd() is used to allocate a file descriptor with
default flags. Those default flags (0) can be "unsafe":
O_CLOEXEC must be used by default to not leak file descriptor
across exec().
Instead of macro get_unused_fd(), functions anon_inode_getfd()
or get_unused_fd_flags() should be used with flags given by userspace.
If not possible, flags should be set to O_CLOEXEC to provide userspace
with a default safe behavor.
In a further patch, get_unused_fd() will be removed so that
new code start using anon_inode_getfd() or get_unused_fd_flags()
with correct flags.
This patch replaces calls to get_unused_fd() with equivalent call to
get_unused_fd_flags(0) to preserve current behavor for existing code.
The hard coded flag value (0) should be reviewed on a per-subsystem basis,
and, if possible, set to O_CLOEXEC.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
We should get rid of all own SCTP debug printk macros and use the ones
that the kernel offers anyway instead. This makes the code more readable
and conform to the kernel code, and offers all the features of dynamic
debbuging that pr_debug() et al has, such as only turning on/off portions
of debug messages at runtime through debugfs. The runtime cost of having
CONFIG_DYNAMIC_DEBUG enabled, but none of the debug statements printing,
is negligible [1]. If kernel debugging is completly turned off, then these
statements will also compile into "empty" functions.
While we're at it, we also need to change the Kconfig option as it /now/
only refers to the ifdef'ed code portions in outqueue.c that enable further
debugging/tracing of SCTP transaction fields. Also, since SCTP_ASSERT code
was enabled with this Kconfig option and has now been removed, we
transform those code parts into WARNs resp. where appropriate BUG_ONs so
that those bugs can be more easily detected as probably not many people
have SCTP debugging permanently turned on.
To turn on all SCTP debugging, the following steps are needed:
# mount -t debugfs none /sys/kernel/debug
# echo -n 'module sctp +p' > /sys/kernel/debug/dynamic_debug/control
This can be done more fine-grained on a per file, per line basis and others
as described in [2].
[1] https://www.kernel.org/doc/ols/2009/ols2009-pages-39-46.pdf
[2] Documentation/dynamic-debug-howto.txt
No need to have an extra ret variable when we directly can return
the value of sctp_get_port_local().
Rather instead of having the endpoint clean the garbage from the
socket, use a sk_destruct handler sctp_destruct_sock(), that does
the job for that when there are no more references on the socket.
At least do this for our crypto transform through crypto_free_hash()
that is allocated when in listening state.
Also, perform sctp_put_port() only when sk is valid. At a later
point in time we can still determine if there's an option of
placing this into sk_prot->unhash() or sctp_endpoint_free() without
any races. For now, leave it in sctp_endpoint_destroy() though.
Currently, SCTP code defines its own timeval functions (since timeval
is rarely used inside the kernel by others), namely tv_lt() and
TIMEVAL_ADD() macros, that operate on SCTP cookie expiration.
We might as well remove all those, and operate directly on ktime
structures for a couple of reasons: ktime is available on all archs;
complexity of ktime calculations depending on the arch is less than
(reduces to a simple arithmetic operations on archs with
BITS_PER_LONG == 64 or CONFIG_KTIME_SCALAR) or equal to timeval
functions (other archs); code becomes more readable; macros can be
thrown out.
