I.e. one-to-many sockets in SCTP are not required to explicitly
call into connect(2) or sctp_connectx(2) prior to data exchange.
Instead, they can directly invoke sendmsg(2) and the SCTP stack
will automatically trigger connection establishment through 4WHS
via sctp_primitive_ASSOCIATE(). However, this in its current
implementation is racy: INIT is being sent out immediately (as
it cannot be bundled anyway) and the rest of the DATA chunks are
queued up for later xmit when connection is established, meaning
sendmsg(2) will return successfully. This behaviour can result
in an undesired side-effect that the kernel made the application
think the data has already been transmitted, although none of it
has actually left the machine, worst case even after close(2)'ing
the socket.
Instead, when the association from client side has been shut down
e.g. first gracefully through SCTP_EOF and then close(2), the
client could afterwards still receive the server's INIT_ACK due
to a connection with higher latency. This INIT_ACK is then considered
out of the blue and hence responded with ABORT as there was no
alive assoc found anymore. This can be easily reproduced f.e.
with sctp_test application from lksctp. One way to fix this race
is to wait for the handshake to actually complete.
The fix defers waiting after sctp_primitive_ASSOCIATE() and
sctp_primitive_SEND() succeeded, so that DATA chunks cooked up
from sctp_sendmsg() have already been placed into the output
queue through the side-effect interpreter, and therefore can then
be bundeled together with COOKIE_ECHO control chunks.
strace from example application (shortened):
socket(PF_INET, SOCK_SEQPACKET, IPPROTO_SCTP) = 3
sendmsg(3, {msg_name(28)={sa_family=AF_INET, sin_port=htons(8888), sin_addr=inet_addr("192.168.1.115")},
msg_iov(1)=[{"hello", 5}], msg_controllen=0, msg_flags=0}, 0) = 5
msg_iov(0)=[], msg_controllen=48, {cmsg_len=48, cmsg_level=0x84 /* SOL_??? */, cmsg_type=, ...},
msg_flags=0}, 0) = 0 // graceful shutdown for SOCK_SEQPACKET via SCTP_EOF
close(3) = 0
tcpdump before patch (fooling the application):
22:33:36.306142 IP 192.168.1.114.41462 > 192.168.1.115.8888: sctp (1) [INIT] [init tag: 3879023686] [rwnd: 106496] [OS: 10] [MIS: 65535] [init TSN: 3139201684]
22:33:36.316619 IP 192.168.1.115.8888 > 192.168.1.114.41462: sctp (1) [INIT ACK] [init tag: 3345394793] [rwnd: 106496] [OS: 10] [MIS: 10] [init TSN: 3380109591]
22:33:36.317600 IP 192.168.1.114.41462 > 192.168.1.115.8888: sctp (1) [ABORT]
tcpdump after patch:
14:28:58.884116 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [INIT] [init tag: 438593213] [rwnd: 106496] [OS: 10] [MIS: 65535] [init TSN: 3092969729]
14:28:58.888414 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [INIT ACK] [init tag: 381429855] [rwnd: 106496] [OS: 10] [MIS: 10] [init TSN: 2141904492]
14:28:58.888638 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [COOKIE ECHO] , (2) [DATA] (B)(E) [TSN: 3092969729] [...]
14:28:58.893278 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [COOKIE ACK] , (2) [SACK] [cum ack 3092969729] [a_rwnd 106491] [#gap acks 0] [#dup tsns 0]
14:28:58.893591 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [DATA] (B)(E) [TSN: 3092969730] [...]
14:28:59.096963 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SACK] [cum ack 3092969730] [a_rwnd 106496] [#gap acks 0] [#dup tsns 0]
14:28:59.097086 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [DATA] (B)(E) [TSN: 3092969731] [...] , (2) [DATA] (B)(E) [TSN: 3092969732] [...]
14:28:59.103218 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SACK] [cum ack 3092969732] [a_rwnd 106486] [#gap acks 0] [#dup tsns 0]
14:28:59.103330 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [SHUTDOWN]
14:28:59.107793 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SHUTDOWN ACK]
14:28:59.107890 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [SHUTDOWN COMPLETE]
Looks like this bug is from the pre-git history museum. ;)
Fixes: 08707d5482df ("lksctp-2_5_31-0_5_1.patch")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Introduce helper macro for_each_cmsghdr as a wrapper of the enumerating
cmsghdr from msghdr, just cleanup.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
drivers/net/ethernet/amd/xgbe/xgbe-desc.c
drivers/net/ethernet/renesas/sh_eth.c
Overlapping changes in both conflict cases.
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
To accomodate for enough headroom for tunnels, use MAX_HEADER instead
of LL_MAX_HEADER. Robert reported that he has hit after roughly 40hrs
of trinity an skb_under_panic() via SCTP output path (see reference).
I couldn't reproduce it from here, but not using MAX_HEADER as elsewhere
in other protocols might be one possible cause for this.
In any case, it looks like accounting on chunks themself seems to look
good as the skb already passed the SCTP output path and did not hit
any skb_over_panic(). Given tunneling was enabled in his .config, the
headroom would have been expanded by MAX_HEADER in this case.
Reported-by: Robert Święcki <robert@swiecki.net>
Reference: https://lkml.org/lkml/2014/12/1/507
Fixes: 594ccc14dfe4d ("[SCTP] Replace incorrect use of dev_alloc_skb with alloc_skb in sctp_packet_transmit().")
It's just silly to hold the skb destructor argument around inside
skb->cb[] as we currently do in SCTP.
Nowadays, we're sort of cheating on data accounting in the sense
that due to commit 4c3a5bdae293 ("sctp: Don't charge for data in
sndbuf again when transmitting packet"), we orphan the skb already
in the SCTP output path, i.e. giving back charged data memory, and
use a different destructor only to make sure the sk doesn't vanish
on skb destruction time. Thus, cb[] is still valid here as we
operate within the SCTP layer. (It's generally actually a big
candidate for future rework, imho.)
However, storing the destructor in the cb[] can easily cause issues
should an non sctp_packet_set_owner_w()'ed skb ever escape the SCTP
layer, since cb[] may get overwritten by lower layers and thus can
corrupt the chunk pointer. There are no such issues at present,
but lets keep the chunk in destructor_arg, as this is the actual
purpose for it.
drivers/net/ethernet/chelsio/cxgb4vf/sge.c
drivers/net/ethernet/intel/ixgbe/ixgbe_phy.c
sge.c was overlapping two changes, one to use the new
__dev_alloc_page() in net-next, and one to use s->fl_pg_order in net.
ixgbe_phy.c was a set of overlapping whitespace changes.
A very minimal and simple user space application allocating an SCTP
socket, setting SCTP_AUTH_KEY setsockopt(2) on it and then closing
the socket again will leak the memory containing the authentication
key from user space:
unreferenced object 0xffff8800837047c0 (size 16):
comm "a.out", pid 2789, jiffies 4296954322 (age 192.258s)
hex dump (first 16 bytes):
01 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff816d7e8e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811c88d8>] __kmalloc+0xe8/0x270
[<ffffffffa0870c23>] sctp_auth_create_key+0x23/0x50 [sctp]
[<ffffffffa08718b1>] sctp_auth_set_key+0xa1/0x140 [sctp]
[<ffffffffa086b383>] sctp_setsockopt+0xd03/0x1180 [sctp]
[<ffffffff815bfd94>] sock_common_setsockopt+0x14/0x20
[<ffffffff815beb61>] SyS_setsockopt+0x71/0xd0
[<ffffffff816e58a9>] system_call_fastpath+0x12/0x17
[<ffffffffffffffff>] 0xffffffffffffffff
This is bad because of two things, we can bring down a machine from
user space when auth_enable=1, but also we would leave security sensitive
keying material in memory without clearing it after use. The issue is
that sctp_auth_create_key() already sets the refcount to 1, but after
allocation sctp_auth_set_key() does an additional refcount on it, and
thus leaving it around when we free the socket.
Fixes: 65b07e5d0d0 ("[SCTP]: API updates to suport SCTP-AUTH extensions.")
Cc: Vlad Yasevich <vyasevich@gmail.com>
packet
An SCTP server doing ASCONF will panic on malformed INIT ping-of-death
in the form of:
------------ INIT[PARAM: SET_PRIMARY_IP] ------------>
While the INIT chunk parameter verification dissects through many things
in order to detect malformed input, it misses to actually check parameters
inside of parameters. E.g. RFC5061, section 4.2.4 proposes a 'set primary
IP address' parameter in ASCONF, which has as a subparameter an address
parameter.
So an attacker may send a parameter type other than SCTP_PARAM_IPV4_ADDRESS
or SCTP_PARAM_IPV6_ADDRESS, param_type2af() will subsequently return 0
and thus sctp_get_af_specific() returns NULL, too, which we then happily
dereference unconditionally through af->from_addr_param().
The trace for the log:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000078
IP: [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
PGD 0
Oops: 0000 [#1] SMP
Pid: 0, comm: swapper Not tainted 2.6.32-504.el6.x86_64 #1 Bochs Bochs
RIP: 0010:[<ffffffffa01e9c62>] [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
Call Trace:
<IRQ>
[<ffffffffa01f2add>] ? sctp_bind_addr_copy+0x5d/0xe0 [sctp]
[<ffffffffa01e1fcb>] sctp_sf_do_5_1B_init+0x21b/0x340 [sctp]
[<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp]
[<ffffffffa01e5c09>] ? sctp_endpoint_lookup_assoc+0xc9/0xf0 [sctp]
[<ffffffffa01e61f6>] sctp_endpoint_bh_rcv+0x116/0x230 [sctp]
[<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp]
[<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp]
[<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter]
[<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0
[<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120
A minimal way to address this is to check for NULL as we do on all
other such occasions where we know sctp_get_af_specific() could
possibly return with NULL.
Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT")
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Fixes checkpatch warning:
"WARNING: Prefer seq_puts to seq_printf"
Signed-off-by: Michele Baldessari <michele@acksyn.org>
It is often quite helpful to be able to know the state of a transport
outside of the application itself (for troubleshooting purposes or for
monitoring purposes). Add it under /proc/net/sctp/remaddr.
Pull networking fixes from David Miller:
1) Include fixes for netrom and dsa (Fabian Frederick and Florian
Fainelli)
2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO.
3) Several SKB use after free fixes (vxlan, openvswitch, vxlan,
ip_tunnel, fou), from Li ROngQing.
4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy.
5) Use after free in virtio_net, from Michael S Tsirkin.
6) Fix flow mask handling for megaflows in openvswitch, from Pravin B
Shelar.
7) ISDN gigaset and capi bug fixes from Tilman Schmidt.
8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin.
9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov.
10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong
Wang and Eric Dumazet.
11) Don't overwrite end of SKB when parsing malformed sctp ASCONF
chunks, from Daniel Borkmann.
12) Don't call sock_kfree_s() with NULL pointers, this function also has
the side effect of adjusting the socket memory usage. From Cong Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
bna: fix skb->truesize underestimation
net: dsa: add includes for ethtool and phy_fixed definitions
openvswitch: Set flow-key members.
netrom: use linux/uaccess.h
dsa: Fix conversion from host device to mii bus
tipc: fix bug in bundled buffer reception
ipv6: introduce tcp_v6_iif()
sfc: add support for skb->xmit_more
r8152: return -EBUSY for runtime suspend
ipv4: fix a potential use after free in fou.c
ipv4: fix a potential use after free in ip_tunnel_core.c
hyperv: Add handling of IP header with option field in netvsc_set_hash()
openvswitch: Create right mask with disabled megaflows
vxlan: fix a free after use
openvswitch: fix a use after free
ipv4: dst_entry leak in ip_send_unicast_reply()
ipv4: clean up cookie_v4_check()
ipv4: share tcp_v4_save_options() with cookie_v4_check()
ipv4: call __ip_options_echo() in cookie_v4_check()
atm: simplify lanai.c by using module_pci_driver
This scenario is not limited to ASCONF, just taken as one
example triggering the issue. When receiving ASCONF probes
in the form of ...
-------------- INIT[ASCONF; ASCONF_ACK] ------------->
<----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
---- ASCONF_a; [ASCONF_b; ...; ASCONF_n;] JUNK ------>
---- ASCONF_m; [ASCONF_o; ...; ASCONF_z;] JUNK ------>
... where ASCONF_a, ASCONF_b, ..., ASCONF_z are good-formed
ASCONFs and have increasing serial numbers, we process such
ASCONF chunk(s) marked with !end_of_packet and !singleton,
since we have not yet reached the SCTP packet end. SCTP does
only do verification on a chunk by chunk basis, as an SCTP
packet is nothing more than just a container of a stream of
chunks which it eats up one by one.
We could run into the case that we receive a packet with a
malformed tail, above marked as trailing JUNK. All previous
chunks are here goodformed, so the stack will eat up all
previous chunks up to this point. In case JUNK does not fit
into a chunk header and there are no more other chunks in
the input queue, or in case JUNK contains a garbage chunk
header, but the encoded chunk length would exceed the skb
tail, or we came here from an entirely different scenario
and the chunk has pdiscard=1 mark (without having had a flush
point), it will happen, that we will excessively queue up
the association's output queue (a correct final chunk may
then turn it into a response flood when flushing the
queue ;)): I ran a simple script with incremental ASCONF
serial numbers and could see the server side consuming
excessive amount of RAM [before/after: up to 2GB and more].
The issue at heart is that the chunk train basically ends
with !end_of_packet and !singleton markers and since commit
2e3216cd54b1 ("sctp: Follow security requirement of responding
with 1 packet") therefore preventing an output queue flush
point in sctp_do_sm() -> sctp_cmd_interpreter() on the input
chunk (chunk = event_arg) even though local_cork is set,
but its precedence has changed since then. In the normal
case, the last chunk with end_of_packet=1 would trigger the
queue flush to accommodate possible outgoing bundling.
In the input queue, sctp_inq_pop() seems to do the right thing
in terms of discarding invalid chunks. So, above JUNK will
not enter the state machine and instead be released and exit
the sctp_assoc_bh_rcv() chunk processing loop. It's simply
the flush point being missing at loop exit. Adding a try-flush
approach on the output queue might not work as the underlying
infrastructure might be long gone at this point due to the
side-effect interpreter run.
One possibility, albeit a bit of a kludge, would be to defer
invalid chunk freeing into the state machine in order to
possibly trigger packet discards and thus indirectly a queue
flush on error. It would surely be better to discard chunks
as in the current, perhaps better controlled environment, but
going back and forth, it's simply architecturally not possible.
I tried various trailing JUNK attack cases and it seems to
look good now.
Joint work with Vlad Yasevich.
Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet")
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
When receiving a e.g. semi-good formed connection scan in the
form of ...
---------------- ASCONF_a; ASCONF_b ----------------->
... where ASCONF_a equals ASCONF_b chunk (at least both serials
need to be equal), we panic an SCTP server!
The problem is that good-formed ASCONF chunks that we reply with
ASCONF_ACK chunks are cached per serial. Thus, when we receive a
same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do
not need to process them again on the server side (that was the
idea, also proposed in the RFC). Instead, we know it was cached
and we just resend the cached chunk instead. So far, so good.
Where things get nasty is in SCTP's side effect interpreter, that
is, sctp_cmd_interpreter():
While incoming ASCONF_a (chunk = event_arg) is being marked
!end_of_packet and !singleton, and we have an association context,
we do not flush the outqueue the first time after processing the
ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it
queued up, although we set local_cork to 1. Commit 2e3216cd54b1
changed the precedence, so that as long as we get bundled, incoming
chunks we try possible bundling on outgoing queue as well. Before
this commit, we would just flush the output queue.
Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we
continue to process the same ASCONF_b chunk from the packet. As
we have cached the previous ASCONF_ACK, we find it, grab it and
do another SCTP_CMD_REPLY command on it. So, effectively, we rip
the chunk->list pointers and requeue the same ASCONF_ACK chunk
another time. Since we process ASCONF_b, it's correctly marked
with end_of_packet and we enforce an uncork, and thus flush, thus
crashing the kernel.
Fix it by testing if the ASCONF_ACK is currently pending and if
that is the case, do not requeue it. When flushing the output
queue we may relink the chunk for preparing an outgoing packet,
but eventually unlink it when it's copied into the skb right
before transmission.
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for
ASCONF chunk") added basic verification of ASCONF chunks, however,
it is still possible to remotely crash a server by sending a
special crafted ASCONF chunk, even up to pre 2.6.12 kernels:
skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768
head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950
end:0x440 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8144fb1c>] skb_put+0x5c/0x70
[<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp]
[<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp]
[<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20
[<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp]
[<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0
[<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp]
[<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp]
[<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497078>] ip_local_deliver+0x98/0xa0
[<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440
[<ffffffff81496ac5>] ip_rcv+0x275/0x350
[<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750
[<ffffffff81460588>] netif_receive_skb+0x58/0x60
This can be triggered e.g., through a simple scripted nmap
connection scan injecting the chunk after the handshake, for
example, ...
------------------ ASCONF; UNKNOWN ------------------>
... where ASCONF chunk of length 280 contains 2 parameters ...
1) Add IP address parameter (param length: 16)
2) Add/del IP address parameter (param length: 255)
... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the
Address Parameter in the ASCONF chunk is even missing, too.
This is just an example and similarly-crafted ASCONF chunks
could be used just as well.
The ASCONF chunk passes through sctp_verify_asconf() as all
parameters passed sanity checks, and after walking, we ended
up successfully at the chunk end boundary, and thus may invoke
sctp_process_asconf(). Parameter walking is done with
WORD_ROUND() to take padding into account.
In sctp_process_asconf()'s TLV processing, we may fail in
sctp_process_asconf_param() e.g., due to removal of the IP
address that is also the source address of the packet containing
the ASCONF chunk, and thus we need to add all TLVs after the
failure to our ASCONF response to remote via helper function
sctp_add_asconf_response(), which basically invokes a
sctp_addto_chunk() adding the error parameters to the given
skb.
When walking to the next parameter this time, we proceed
with ...
length = ntohs(asconf_param->param_hdr.length);
asconf_param = (void *)asconf_param + length;
... instead of the WORD_ROUND()'ed length, thus resulting here
in an off-by-one that leads to reading the follow-up garbage
parameter length of 12336, and thus throwing an skb_over_panic
for the reply when trying to sctp_addto_chunk() next time,
which implicitly calls the skb_put() with that length.
Fix it by using sctp_walk_params() [ which is also used in
INIT parameter processing ] macro in the verification *and*
in ASCONF processing: it will make sure we don't spill over,
that we walk parameters WORD_ROUND()'ed. Moreover, we're being
more defensive and guard against unknown parameter types and
missized addresses.
Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.")
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu updates from Tejun Heo:
"A lot of activities on percpu front. Notable changes are...
- percpu allocator now can take @gfp. If @gfp doesn't contain
GFP_KERNEL, it tries to allocate from what's already available to
the allocator and a work item tries to keep the reserve around
certain level so that these atomic allocations usually succeed.
This will replace the ad-hoc percpu memory pool used by
blk-throttle and also be used by the planned blkcg support for
writeback IOs.
Please note that I noticed a bug in how @gfp is interpreted while
preparing this pull request and applied the fix 6ae833c7fe0c
("percpu: fix how @gfp is interpreted by the percpu allocator")
just now.
- percpu_ref now uses longs for percpu and global counters instead of
ints. It leads to more sparse packing of the percpu counters on
64bit machines but the overhead should be negligible and this
allows using percpu_ref for refcnting pages and in-memory objects
directly.
- The switching between percpu and single counter modes of a
percpu_ref is made independent of putting the base ref and a
percpu_ref can now optionally be initialized in single or killed
mode. This allows avoiding percpu shutdown latency for cases where
the refcounted objects may be synchronously created and destroyed
in rapid succession with only a fraction of them reaching fully
operational status (SCSI probing does this when combined with
blk-mq support). It's also planned to be used to implement forced
single mode to detect underflow more timely for debugging.
There's a separate branch percpu/for-3.18-consistent-ops which cleans
up the duplicate percpu accessors. That branch causes a number of
conflicts with s390 and other trees. I'll send a separate pull
request w/ resolutions once other branches are merged"
* 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (33 commits)
blk-mq, percpu_ref: start q->mq_usage_counter in atomic mode
percpu_ref: make INIT_ATOMIC and switch_to_atomic() sticky
percpu_ref: add PERCPU_REF_INIT_* flags
percpu_ref: decouple switching to percpu mode and reinit
percpu_ref: decouple switching to atomic mode and killing
percpu_ref: add PCPU_REF_DEAD
percpu_ref: rename things to prepare for decoupling percpu/atomic mode switch
percpu_ref: replace pcpu_ prefix with percpu_
percpu_ref: minor code and comment updates
percpu_ref: relocate percpu_ref_reinit()
Revert "blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe"
Revert "percpu: free percpu allocation info for uniprocessor system"
percpu-refcount: make percpu_ref based on longs instead of ints
percpu-refcount: improve WARN messages
percpu: fix locking regression in the failure path of pcpu_alloc()
percpu-refcount: add @gfp to percpu_ref_init()
proportions: add @gfp to init functions
percpu_counter: add @gfp to percpu_counter_init()
percpu_counter: make percpu_counters_lock irq-safe
Currently association restarts do not take into consideration the
state of the socket. When a restart happens, the current assocation
simply transitions into established state. This creates a condition
where a remote system, through a the restart procedure, may create a
local association that is no way reachable by user. The conditions
to trigger this are as follows:
1) Remote does not acknoledge some data causing data to remain
outstanding.
2) Local application calls close() on the socket. Since data
is still outstanding, the association is placed in SHUTDOWN_PENDING
state. However, the socket is closed.
3) The remote tries to create a new association, triggering a restart
on the local system. The association moves from SHUTDOWN_PENDING
to ESTABLISHED. At this point, it is no longer reachable by
any socket on the local system.
This patch addresses the above situation by moving the newly ESTABLISHED
association into SHUTDOWN-SENT state and bundling a SHUTDOWN after
the COOKIE-ACK chunk. This way, the restarted associate immidiately
enters the shutdown procedure and forces the termination of the
unreachable association.
Reported-by: David Laight <David.Laight@aculab.com>
git://git.kernel.org/pub/scm/linux/kernel/git/axboe/linux-block into for-3.18
This is to receive 0a30288da1ae ("blk-mq, percpu_ref: implement a
kludge for SCSI blk-mq stall during probe") which implements
__percpu_ref_kill_expedited() to work around SCSI blk-mq stall. The
commit reverted and patches to implement proper fix will be added.
Cc: Kent Overstreet <kmo@daterainc.com>
net.ipv4.ip_nonlocal_bind sysctl was global to all network
namespaces. This patch allows to set a different value for each
network namespace.
Signed-off-by: Vincent Bernat <vincent@bernat.im>
Percpu allocator now supports allocation mask. Add @gfp to
percpu_counter_init() so that !GFP_KERNEL allocation masks can be used
with percpu_counters too.
We could have left percpu_counter_init() alone and added
percpu_counter_init_gfp(); however, the number of users isn't that
high and introducing _gfp variants to all percpu data structures would
be quite ugly, so let's just do the conversion. This is the one with
the most users. Other percpu data structures are a lot easier to
convert.
This patch doesn't make any functional difference.
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: "David S. Miller" <davem@davemloft.net>
Cc: x86@kernel.org
Cc: "Theodore Ts'o" <tytso@mit.edu>
CHECKSUM_UNNECESSARY may be applied to the SCTP CRC so we need to
appropriate account for this by decrementing csum_level. This is
done by calling __skb_dec_checksum_unnecessary.
Signed-off-by: Tom Herbert <therbert@google.com>
Since SCTP day 1, that is, 19b55a2af145 ("Initial commit") from lksctp
tree, the official <netinet/sctp.h> header carries a copy of enum
sctp_sstat_state that looks like (compared to the current in-kernel
enumeration):
User definition: Kernel definition:
enum sctp_sstat_state { typedef enum {
SCTP_EMPTY = 0, <removed>
SCTP_CLOSED = 1, SCTP_STATE_CLOSED = 0,
SCTP_COOKIE_WAIT = 2, SCTP_STATE_COOKIE_WAIT = 1,
SCTP_COOKIE_ECHOED = 3, SCTP_STATE_COOKIE_ECHOED = 2,
SCTP_ESTABLISHED = 4, SCTP_STATE_ESTABLISHED = 3,
SCTP_SHUTDOWN_PENDING = 5, SCTP_STATE_SHUTDOWN_PENDING = 4,
SCTP_SHUTDOWN_SENT = 6, SCTP_STATE_SHUTDOWN_SENT = 5,
SCTP_SHUTDOWN_RECEIVED = 7, SCTP_STATE_SHUTDOWN_RECEIVED = 6,
SCTP_SHUTDOWN_ACK_SENT = 8, SCTP_STATE_SHUTDOWN_ACK_SENT = 7,
}; } sctp_state_t;
This header was later on also placed into the uapi, so that user space
programs can compile without having <netinet/sctp.h>, but the shipped
with <linux/sctp.h> instead.
While RFC6458 under 8.2.1.Association Status (SCTP_STATUS) says that
sstat_state can range from SCTP_CLOSED to SCTP_SHUTDOWN_ACK_SENT, we
nevertheless have a what it appears to be dummy SCTP_EMPTY state from
the very early days.
While it seems to do just nothing, commit 0b8f9e25b0aa ("sctp: remove
completely unsed EMPTY state") did the right thing and removed this dead
code. That however, causes an off-by-one when the user asks the SCTP
stack via SCTP_STATUS API and checks for the current socket state thus
yielding possibly undefined behaviour in applications as they expect
the kernel to tell the right thing.
The enumeration had to be changed however as based on the current socket
state, we access a function pointer lookup-table through this. Therefore,
I think the best way to deal with this is just to add a helper function
sctp_assoc_to_state() to encapsulate the off-by-one quirk.
Reported-by: Tristan Su <sooqing@gmail.com>
Fixes: 0b8f9e25b0aa ("sctp: remove completely unsed EMPTY state")
In SCTP, selection of active (T.ACT) and retransmission (T.RET)
transports is being done whenever transport control operations
(UP, DOWN, PF, ...) are engaged through sctp_assoc_control_transport().
Commits 4c47af4d5eb2 ("net: sctp: rework multihoming retransmission
path selection to rfc4960") and a7288c4dd509 ("net: sctp: improve
sctp_select_active_and_retran_path selection") have both improved
it towards a more fine-grained and optimal path selection.
Currently, the selection algorithm for T.ACT and T.RET is as follows:
1) Elect the two most recently used ACTIVE transports T1, T2 for
T.ACT, T.RET, where T.ACT<-T1 and T1 is most recently used
2) In case primary path T.PRI not in {T1, T2} but ACTIVE, set
T.ACT<-T.PRI and T.RET<-T1
3) If only T1 is ACTIVE from the set, set T.ACT<-T1 and T.RET<-T1
4) If none is ACTIVE, set T.ACT<-best(T.PRI, T.RET, T3) where
T3 is the most recently used (if avail) in PF, set T.RET<-T.PRI
Prior to above commits, 4) was simply a camp on T.ACT<-T.PRI and
T.RET<-T.PRI, ignoring possible paths in PF. Camping on T.PRI is
still slightly suboptimal as it can lead to the following scenario:
Setup:
<A> <B>
T1: p1p1 (10.0.10.10) <==> .'`) <==> p1p1 (10.0.10.12) <= T.PRI
T2: p1p2 (10.0.10.20) <==> (_ . ) <==> p1p2 (10.0.10.22)
net.sctp.rto_min = 1000
net.sctp.path_max_retrans = 2
net.sctp.pf_retrans = 0
net.sctp.hb_interval = 1000
T.PRI is permanently down, T2 is put briefly into PF state (e.g. due to
link flapping). Here, the first time transmission is sent over PF path
T2 as it's the only non-INACTIVE path, but the retransmitted data-chunks
are sent over the INACTIVE path T1 (T.PRI), which is not good.
After the patch, it's choosing better transports in both cases by
modifying step 4):
4) If none is ACTIVE, set T.ACT_new<-best(T.ACT_old, T3) where T3 is
the most recently used (if avail) in PF, set T.RET<-T.ACT_new
This will still select a best possible path in PF if available (which
can also include T.PRI/T.RET), and set both T.ACT/T.RET to it.
In case sctp_assoc_control_transport() *just* put T.ACT_old into INACTIVE
as it transitioned from ACTIVE->PF->INACTIVE and stays in INACTIVE just
for a very short while before going back ACTIVE, it will guarantee that
this path will be reselected for T.ACT/T.RET since T3 (PF) is not
available.
Previously, this was not possible, as we would only select between T.PRI
and T.RET, and a possible T3 would be NULL due to the fact that we have
just transitioned T3 in sctp_assoc_control_transport() from PF->INACTIVE
and would select a suboptimal path when T.PRI/T.RET have worse properties.
In the case that T.ACT_old permanently went to INACTIVE during this
transition and there's no PF path available, plus T.PRI and T.RET are
INACTIVE as well, we would now camp on T.ACT_old, but if everything is
being INACTIVE there's really not much we can do except hoping for a
successful HB to bring one of the transports back up again and, thus
cause a new selection through sctp_assoc_control_transport().
Now both tests work fine:
Case 1:
1. T1 S(ACTIVE) T.ACT
T2 S(ACTIVE) T.RET
2. T1 S(ACTIVE) T.ACT, T.RET
T2 S(PF)
3. T1 S(ACTIVE) T.ACT, T.RET
T2 S(INACTIVE)
5. T1 S(PF) T.ACT, T.RET
T2 S(INACTIVE)
[ 5.1 T1 S(INACTIVE) T.ACT, T.RET
T2 S(INACTIVE) ]
6. T1 S(ACTIVE) T.ACT, T.RET
T2 S(INACTIVE)
7. T1 S(ACTIVE) T.ACT
T2 S(ACTIVE) T.RET
Case 2:
T2 S(ACTIVE) T.RET
2. T1 S(PF)
T2 S(ACTIVE) T.ACT, T.RET
3. T1 S(INACTIVE)
5. T1 S(INACTIVE)
T2 S(PF) T.ACT, T.RET
T2 S(INACTIVE) T.ACT, T.RET ]
6. T1 S(INACTIVE)
T2 S(ACTIVE) T.RET
When both transports are the same, we don't have to go down that
road only to realize that we will return the very same transport.
We are guaranteed that curr is always non-NULL. Therefore, just
short-circuit this special case.
Since the transport has always been in state SCTP_UNCONFIRMED, it
therefore wasn't active before and hasn't been used before, and it
always has been, so it is unnecessary to bug the user with a
notification.
Reported-by: Deepak Khandelwal <khandelwal.deepak.1987@gmail.com>
Suggested-by: Vlad Yasevich <vyasevich@gmail.com>
Suggested-by: Michael Tuexen <tuexen@fh-muenster.de>
Suggested-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Zhu Yanjun <Yanjun.Zhu@windriver.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
drivers/net/Makefile
net/ipv6/sysctl_net_ipv6.c
Two ipv6_table_template[] additions overlap, so the index
of the ipv6_table[x] assignments needed to be adjusted.
In the drivers/net/Makefile case, we've gotten rid of the
garbage whereby we had to list every single USB networking
driver in the top-level Makefile, there is just one
"USB_NETWORKING" that guards everything.
Dave reported following splat, caused by improper use of
IP_INC_STATS_BH() in process context.
BUG: using __this_cpu_add() in preemptible [00000000] code: trinity-c117/14551
caller is __this_cpu_preempt_check+0x13/0x20
CPU: 3 PID: 14551 Comm: trinity-c117 Not tainted 3.16.0+ #33
ffffffff9ec898f0 0000000047ea7e23 ffff88022d32f7f0 ffffffff9e7ee207
0000000000000003 ffff88022d32f818 ffffffff9e397eaa ffff88023ee70b40
ffff88022d32f970 ffff8801c026d580 ffff88022d32f828 ffffffff9e397ee3
Call Trace:
[<ffffffff9e7ee207>] dump_stack+0x4e/0x7a
[<ffffffff9e397eaa>] check_preemption_disabled+0xfa/0x100
[<ffffffff9e397ee3>] __this_cpu_preempt_check+0x13/0x20
[<ffffffffc0839872>] sctp_packet_transmit+0x692/0x710 [sctp]
[<ffffffffc082a7f2>] sctp_outq_flush+0x2a2/0xc30 [sctp]
[<ffffffff9e0d985c>] ? mark_held_locks+0x7c/0xb0
[<ffffffff9e7f8c6d>] ? _raw_spin_unlock_irqrestore+0x5d/0x80
[<ffffffffc082b99a>] sctp_outq_uncork+0x1a/0x20 [sctp]
[<ffffffffc081e112>] sctp_cmd_interpreter.isra.23+0x1142/0x13f0 [sctp]
[<ffffffffc081c86b>] sctp_do_sm+0xdb/0x330 [sctp]
[<ffffffff9e0b8f1b>] ? preempt_count_sub+0xab/0x100
[<ffffffffc083b350>] ? sctp_cname+0x70/0x70 [sctp]
[<ffffffffc08389ca>] sctp_primitive_ASSOCIATE+0x3a/0x50 [sctp]
[<ffffffffc083358f>] sctp_sendmsg+0x88f/0xe30 [sctp]
[<ffffffff9e0d673a>] ? lock_release_holdtime.part.28+0x9a/0x160
[<ffffffff9e0d62ce>] ? put_lock_stats.isra.27+0xe/0x30
[<ffffffff9e73b624>] inet_sendmsg+0x104/0x220
[<ffffffff9e73b525>] ? inet_sendmsg+0x5/0x220
[<ffffffff9e68ac4e>] sock_sendmsg+0x9e/0xe0
[<ffffffff9e1c0c09>] ? might_fault+0xb9/0xc0
[<ffffffff9e1c0bae>] ? might_fault+0x5e/0xc0
[<ffffffff9e68b234>] SYSC_sendto+0x124/0x1c0
[<ffffffff9e0136b0>] ? syscall_trace_enter+0x250/0x330
[<ffffffff9e68c3ce>] SyS_sendto+0xe/0x10
[<ffffffff9e7f9be4>] tracesys+0xdd/0xe2
This is a followup of commits f1d8cba61c3c4b ("inet: fix possible
seqlock deadlocks") and 7f88c6b23afbd315 ("ipv6: fix possible seqlock
deadlock in ip6_finish_output2")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
When dealing with ICMPv[46] Error Message, function icmp_socket_deliver()
and icmpv6_notify() do some valid checks on packet's length, but then some
protocols check packet's length redaudantly. So remove those duplicated
statements, and increase counter ICMP_MIB_INERRORS/ICMP6_MIB_INERRORS in
function icmp_socket_deliver() and icmpv6_notify() respectively.
In addition, add missed counter in udp6/udplite6 when socket is NULL.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
The SCTP socket extensions API document describes the v4mapping option as
follows:
8.1.15. Set/Clear IPv4 Mapped Addresses (SCTP_I_WANT_MAPPED_V4_ADDR)
This socket option is a Boolean flag which turns on or off the
mapping of IPv4 addresses. If this option is turned on, then IPv4
addresses will be mapped to V6 representation. If this option is
turned off, then no mapping will be done of V4 addresses and a user
will receive both PF_INET6 and PF_INET type addresses on the socket.
See [RFC3542] for more details on mapped V6 addresses.
This description isn't really in line with what the code does though.
Introduce addr_to_user (renamed addr_v4map), which should be called
before any sockaddr is passed back to user space. The new function
places the sockaddr into the correct format depending on the
SCTP_I_WANT_MAPPED_V4_ADDR option.
Audit all places that touched v4mapped and either sanely construct
a v4 or v6 address then call addr_to_user, or drop the
unnecessary v4mapped check entirely.
Audit all places that call addr_to_user and verify they are on a sycall
return path.
Add a custom getname that formats the address properly.
Several bugs are addressed:
- SCTP_I_WANT_MAPPED_V4_ADDR=0 often returned garbage for
addresses to user space
- The addr_len returned from recvmsg was not correct when
returning AF_INET on a v6 socket
- flowlabel and scope_id were not zerod when promoting
a v4 to v6
- Some syscalls like bind and connect behaved differently
depending on v4mapped
Tested bind, getpeername, getsockname, connect, and recvmsg for proper
behaviour in v4mapped = 1 and 0 cases.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Jason reported an oops caused by SCTP on his ARM machine with
SCTP authentication enabled:
Internal error: Oops: 17 [#1] ARM
CPU: 0 PID: 104 Comm: sctp-test Not tainted 3.13.0-68744-g3632f30c9b20-dirty #1
task: c6eefa40 ti: c6f52000 task.ti: c6f52000
PC is at sctp_auth_calculate_hmac+0xc4/0x10c
LR is at sg_init_table+0x20/0x38
pc : [<c024bb80>] lr : [<c00f32dc>] psr: 40000013
sp : c6f538e8 ip : 00000000 fp : c6f53924
r10: c6f50d80 r9 : 00000000 r8 : 00010000
r7 : 00000000 r6 : c7be4000 r5 : 00000000 r4 : c6f56254
r3 : c00c8170 r2 : 00000001 r1 : 00000008 r0 : c6f1e660
Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005397f Table: 06f28000 DAC: 00000015
Process sctp-test (pid: 104, stack limit = 0xc6f521c0)
Stack: (0xc6f538e8 to 0xc6f54000)
Backtrace:
[<c024babc>] (sctp_auth_calculate_hmac+0x0/0x10c) from [<c0249af8>] (sctp_packet_transmit+0x33c/0x5c8)
[<c02497bc>] (sctp_packet_transmit+0x0/0x5c8) from [<c023e96c>] (sctp_outq_flush+0x7fc/0x844)
[<c023e170>] (sctp_outq_flush+0x0/0x844) from [<c023ef78>] (sctp_outq_uncork+0x24/0x28)
[<c023ef54>] (sctp_outq_uncork+0x0/0x28) from [<c0234364>] (sctp_side_effects+0x1134/0x1220)
[<c0233230>] (sctp_side_effects+0x0/0x1220) from [<c02330b0>] (sctp_do_sm+0xac/0xd4)
[<c0233004>] (sctp_do_sm+0x0/0xd4) from [<c023675c>] (sctp_assoc_bh_rcv+0x118/0x160)
[<c0236644>] (sctp_assoc_bh_rcv+0x0/0x160) from [<c023d5bc>] (sctp_inq_push+0x6c/0x74)
[<c023d550>] (sctp_inq_push+0x0/0x74) from [<c024a6b0>] (sctp_rcv+0x7d8/0x888)
While we already had various kind of bugs in that area
ec0223ec48a9 ("net: sctp: fix sctp_sf_do_5_1D_ce to verify if
we/peer is AUTH capable") and b14878ccb7fa ("net: sctp: cache
auth_enable per endpoint"), this one is a bit of a different
kind.
Giving a bit more background on why SCTP authentication is
needed can be found in RFC4895:
SCTP uses 32-bit verification tags to protect itself against
blind attackers. These values are not changed during the
lifetime of an SCTP association.
Looking at new SCTP extensions, there is the need to have a
method of proving that an SCTP chunk(s) was really sent by
the original peer that started the association and not by a
malicious attacker.
To cause this bug, we're triggering an INIT collision between
peers; normal SCTP handshake where both sides intent to
authenticate packets contains RANDOM; CHUNKS; HMAC-ALGO
parameters that are being negotiated among peers:
---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ---------->
<------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] ---------
RFC4895 says that each endpoint therefore knows its own random
number and the peer's random number *after* the association
has been established. The local and peer's random number along
with the shared key are then part of the secret used for
calculating the HMAC in the AUTH chunk.
Now, in our scenario, we have 2 threads with 1 non-blocking
SEQ_PACKET socket each, setting up common shared SCTP_AUTH_KEY
and SCTP_AUTH_ACTIVE_KEY properly, and each of them calling
sctp_bindx(3), listen(2) and connect(2) against each other,
thus the handshake looks similar to this, e.g.:
<--------- INIT[RANDOM; CHUNKS; HMAC-ALGO] -----------
-------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] -------->
Since such collisions can also happen with verification tags,
the RFC4895 for AUTH rather vaguely says under section 6.1:
In case of INIT collision, the rules governing the handling
of this Random Number follow the same pattern as those for
the Verification Tag, as explained in Section 5.2.4 of
RFC 2960 [5]. Therefore, each endpoint knows its own Random
Number and the peer's Random Number after the association
In RFC2960, section 5.2.4, we're eventually hitting Action B:
B) In this case, both sides may be attempting to start an
association at about the same time but the peer endpoint
started its INIT after responding to the local endpoint's
INIT. Thus it may have picked a new Verification Tag not
being aware of the previous Tag it had sent this endpoint.
The endpoint should stay in or enter the ESTABLISHED
state but it MUST update its peer's Verification Tag from
the State Cookie, stop any init or cookie timers that may
running and send a COOKIE ACK.
In other words, the handling of the Random parameter is the
same as behavior for the Verification Tag as described in
Action B of section 5.2.4.
Looking at the code, we exactly hit the sctp_sf_do_dupcook_b()
case which triggers an SCTP_CMD_UPDATE_ASSOC command to the
side effect interpreter, and in fact it properly copies over
peer_{random, hmacs, chunks} parameters from the newly created
association to update the existing one.
Also, the old asoc_shared_key is being released and based on
the new params, sctp_auth_asoc_init_active_key() updated.
However, the issue observed in this case is that the previous
asoc->peer.auth_capable was 0, and has *not* been updated, so
that instead of creating a new secret, we're doing an early
return from the function sctp_auth_asoc_init_active_key()
leaving asoc->asoc_shared_key as NULL. However, we now have to
authenticate chunks from the updated chunk list (e.g. COOKIE-ACK).
That in fact causes the server side when responding with ...
<------------------ AUTH; COOKIE-ACK -----------------
... to trigger a NULL pointer dereference, since in
sctp_packet_transmit(), it discovers that an AUTH chunk is
being queued for xmit, and thus it calls sctp_auth_calculate_hmac().
Since the asoc->active_key_id is still inherited from the
endpoint, and the same as encoded into the chunk, it uses
asoc->asoc_shared_key, which is still NULL, as an asoc_key
and dereferences it in ...
crypto_hash_setkey(desc.tfm, &asoc_key->data[0], asoc_key->len)
... causing an oops. All this happens because sctp_make_cookie_ack()
called with the *new* association has the peer.auth_capable=1
and therefore marks the chunk with auth=1 after checking
sctp_auth_send_cid(), but it is *actually* sent later on over
the then *updated* association's transport that didn't initialize
its shared key due to peer.auth_capable=0. Since control chunks
in that case are not sent by the temporary association which
are scheduled for deletion, they are issued for xmit via
SCTP_CMD_REPLY in the interpreter with the context of the
*updated* association. peer.auth_capable was 0 in the updated
association (which went from COOKIE_WAIT into ESTABLISHED state),
since all previous processing that performed sctp_process_init()
was being done on temporary associations, that we eventually
throw away each time.
The correct fix is to update to the new peer.auth_capable
value as well in the collision case via sctp_assoc_update(),
so that in case the collision migrated from 0 -> 1,
sctp_auth_asoc_init_active_key() can properly recalculate
the secret. This therefore fixes the observed server panic.
Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing")
Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
MSG_MORE and 'corking' a socket would require that the transmit of
a data chunk be delayed.
Rename the return value to be less specific.
Signed-off-by: David Laight <david.laight@aculab.com>
The check for Nagle contains 6 separate checks all of which must be true
before a data packet is delayed.
Separate out each into its own 'if (test) return SCTP_XMIT_OK' so that
the reasons can be individually described.
Also return directly with SCTP_XMIT_RWND_FULL.
Delete the now-unused 'retval' variable and 'finish' label from
sctp_packet_can_append_data().
With support of SCTP_SNDINFO/SCTP_RCVINFO as described in RFC6458,
5.3.4/5.3.5, we can now deprecate SCTP_SNDRCV. The RFC already
declares it as deprecated:
This structure mixes the send and receive path. SCTP_SNDINFO
(described in Section 5.3.4) and SCTP_RCVINFO (described in
Section 5.3.5) split this information. These structures should
be used, when possible, since SCTP_SNDRCV is deprecated.
So whenever a user tries to subscribe to sctp_data_io_event via
setsockopt(2) which triggers inclusion of SCTP_SNDRCV cmsg_type,
issue a warning in the log.
This patch implements section 8.1.31. of RFC6458, which adds support
for setting/retrieving SCTP_DEFAULT_SNDINFO:
Applications that wish to use the sendto() system call may wish
to specify a default set of parameters that would normally be
supplied through the inclusion of ancillary data. This socket
option allows such an application to set the default sctp_sndinfo
structure. The application that wishes to use this socket option
simply passes the sctp_sndinfo structure (defined in Section 5.3.4)
to this call. The input parameters accepted by this call include
snd_sid, snd_flags, snd_ppid, and snd_context. The snd_flags
parameter is composed of a bitwise OR of SCTP_UNORDERED, SCTP_EOF,
and SCTP_SENDALL. The snd_assoc_id field specifies the association
to which to apply the parameters. For a one-to-many style socket,
any of the predefined constants are also allowed in this field.
The field is ignored for one-to-one style sockets.
Joint work with Daniel Borkmann.
Signed-off-by: Geir Ola Vaagland <geirola@gmail.com>
This patch implements section 5.3.6. of RFC6458, that is, support
for 'SCTP Next Receive Information Structure' (SCTP_NXTINFO) which
is placed into ancillary data cmsghdr structure for each recvmsg()
call, if this information is already available when delivering the
current message.
This option can be enabled/disabled via setsockopt(2) on SOL_SCTP
level by setting an int value with 1/0 for SCTP_RECVNXTINFO in
user space applications as per RFC6458, section 8.1.30.
The sctp_nxtinfo structure is defined as per RFC as below ...
struct sctp_nxtinfo {
uint16_t nxt_sid;
uint16_t nxt_flags;
uint32_t nxt_ppid;
uint32_t nxt_length;
sctp_assoc_t nxt_assoc_id;
... and provided under cmsg_level IPPROTO_SCTP, cmsg_type
SCTP_NXTINFO, while cmsg_data[] contains struct sctp_nxtinfo.
This patch implements section 5.3.5. of RFC6458, that is, support
for 'SCTP Receive Information Structure' (SCTP_RCVINFO) which is
call.
level by setting an int value with 1/0 for SCTP_RECVRCVINFO in user
space applications as per RFC6458, section 8.1.29.
The sctp_rcvinfo structure is defined as per RFC as below ...
struct sctp_rcvinfo {
uint16_t rcv_sid;
uint16_t rcv_ssn;
uint16_t rcv_flags;
<-- 2 bytes hole -->
uint32_t rcv_ppid;
uint32_t rcv_tsn;
uint32_t rcv_cumtsn;
uint32_t rcv_context;
sctp_assoc_t rcv_assoc_id;
SCTP_RCVINFO, while cmsg_data[] contains struct sctp_rcvinfo.
An sctp_rcvinfo item always corresponds to the data in msg_iov.
This patch implements section 5.3.4. of RFC6458, that is, support
for 'SCTP Send Information Structure' (SCTP_SNDINFO) which can be
placed into ancillary data cmsghdr structure for sendmsg() calls.
The sctp_sndinfo structure is defined as per RFC as below ...
struct sctp_sndinfo {
uint16_t snd_sid;
uint16_t snd_flags;
uint32_t snd_ppid;
uint32_t snd_context;
sctp_assoc_t snd_assoc_id;
... and supplied under cmsg_level IPPROTO_SCTP, cmsg_type
SCTP_SNDINFO, while cmsg_data[] contains struct sctp_sndinfo.
An sctp_sndinfo item always corresponds to the data in msg_iov.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
While working on some other SCTP code, I noticed that some
structures shared with user space are leaking uninitialized
stack or heap buffer. In particular, struct sctp_sndrcvinfo
has a 2 bytes hole between .sinfo_flags and .sinfo_ppid that
remains unfilled by us in sctp_ulpevent_read_sndrcvinfo() when
putting this into cmsg. But also struct sctp_remote_error
contains a 2 bytes hole that we don't fill but place into a skb
through skb_copy_expand() via sctp_ulpevent_make_remote_error().
Both structures are defined by the IETF in RFC6458:
* Section 5.3.2. SCTP Header Information Structure:
The sctp_sndrcvinfo structure is defined below:
struct sctp_sndrcvinfo {
uint16_t sinfo_stream;
uint16_t sinfo_ssn;
uint16_t sinfo_flags;
uint32_t sinfo_ppid;
uint32_t sinfo_context;
uint32_t sinfo_timetolive;
uint32_t sinfo_tsn;
uint32_t sinfo_cumtsn;
sctp_assoc_t sinfo_assoc_id;
* 6.1.3. SCTP_REMOTE_ERROR:
A remote peer may send an Operation Error message to its peer.
This message indicates a variety of error conditions on an
association. The entire ERROR chunk as it appears on the wire
is included in an SCTP_REMOTE_ERROR event. Please refer to the
SCTP specification [RFC4960] and any extensions for a list of
possible error formats. An SCTP error notification has the
following format:
struct sctp_remote_error {
uint16_t sre_type;
uint16_t sre_flags;
uint32_t sre_length;
uint16_t sre_error;
sctp_assoc_t sre_assoc_id;
uint8_t sre_data[];
Fix this by setting both to 0 before filling them out. We also
have other structures shared between user and kernel space in
SCTP that contains holes (e.g. struct sctp_paddrthlds), but we
copy that buffer over from user space first and thus don't need
to care about it in that cases.
While at it, we can also remove lengthy comments copied from
the draft, instead, we update the comment with the correct RFC
number where one can look it up.
sctp_init_cmd_seq() and sctp_next_cmd() are only called from one place.
The call sequence for sctp_add_cmd_sf() is likely to be longer than
the inlined code.
With sctp_add_cmd_sf() inlined the compiler can optimise repeated calls.
Only warn if the value is written to alpha or beta. We don't care
emitting a one-time warning when only reading it.
Reported-by: Jiri Pirko <jpirko@redhat.com>
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
RFC4960, section 8.3 says:
On an idle destination address that is allowed to heartbeat,
it is recommended that a HEARTBEAT chunk is sent once per RTO
of that destination address plus the protocol parameter
'HB.interval', with jittering of +/- 50% of the RTO value,
and exponential backoff of the RTO if the previous HEARTBEAT
is unanswered.
Currently, we calculate jitter via sctp_jitter() function first,
and then add its result to the current RTO for the new timeout:
TMO = RTO + (RAND() % RTO) - (RTO / 2)
`------------------------^-=> sctp_jitter()
Instead, we can just simplify all this by directly calculating:
TMO = (RTO / 2) + (RAND() % RTO)
With the help of prandom_u32_max(), we don't need to open code
our own global PRNG, but can instead just make use of the per
CPU implementation of prandom with better quality numbers. Also,
we can now spare us the conditional for divide by zero check
since no div or mod operation needs to be used. Note that
prandom_u32_max() won't emit the same result as a mod operation,
but we really don't care here as we only want to have a random
number scaled into RTO interval.
Note, exponential RTO backoff is handeled elsewhere, namely in
sctp_do_8_2_transport_strike().
