RFC4960, section 3.3.7 said:
If an endpoint receives an ABORT with a format error or no TCB is
found, it MUST silently discard it.
When an endpoint receives ABORT that parameter value is invalid,
drop it.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
When an endpoint receives ERROR that parameter value is invalid,
send an ABORT to peer with a Protocol Violation error code.
When processing an ACK for ADD_IP parameter, we only release
the routes on non-active transports. This can cause a wrong
source address to be used. We can release the routes and
cause new route lookups and source address selection so that
new addresses can be used as source. Additionally, we don't need
to lookup routes for all transports at the same time. We can let
the transmit code path update the cached route when the transport
actually sends something.
We allow 0 port when adding new addresses. It only
makes sence to allow 0 port when removing addresses.
When removing the currently bound port will be used
when the port in the address is set to 0.
When we have have to remove a transport due to ASCONF, we move
the data to a new active path. This can trigger CACC algorithm
to not mark that data as missing when SACKs arrive. This is
because the transport passed to the CACC algorithm is the one
this data is sitting on, not the one it was sent on (that one
may be gone). So, by sending the original transport (even if
it's NULL), we may start marking data as missing.
Use common function to simply code.
Remove SCTP_CMD_TRANSMIT command as it never be used.
The 'p' member of struct sctp_paramhdr is common part for
IPv4 addr parameter and IPv6 addr parameter in union sctp_addr_param.
For addr-related code, use specified addr parameter.
Otherwise, use common header to access type/length member.
Update the comment about sctp_sf_violation_paramlen() to be
more precise.
Since we can not update retran path to unconfirmed transports,
when we remove a peer, the retran path may not be update if the
other transports are all unconfirmed, and we will still using
the removed transport as the retran path. This may cause panic
if retrasnmit happen.
commit fbdf501c9374966a56829ecca3a7f25d2b49a305
sctp: Do no select unconfirmed transports for retransmissions
Introduced the initial falt.
commit d598b166ced20d9b9281ea3527c0e18405ddb803
sctp: Make sure we always return valid retransmit path
Solved the problem, but forgot to change the DEBUG statement.
Thus it was still possible to dereference a NULL pointer.
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
Sometime the ASCONF_ACK parameters can equal to the fourfold of
ASCONF parameters, this only happend in some special case:
ASCONF parameter is :
Unrecognized Parameter (4 bytes)
ASCONF_ACK parameter should be:
Error Cause Indication parameter (8 bytes header)
+ Error Cause (4 bytes header)
+ Unrecognized Parameter (4bytes)
Four 4bytes Unrecognized Parameters in ASCONF chunk will cause panic.
Pid: 0, comm: swapper Not tainted 2.6.38-next+ #22 Bochs Bochs
EIP: 0060:[<c0717eae>] EFLAGS: 00010246 CPU: 0
EIP is at skb_put+0x60/0x70
EAX: 00000077 EBX: c09060e2 ECX: dec1dc30 EDX: c09469c0
ESI: 00000000 EDI: de3c8d40 EBP: dec1dc58 ESP: dec1dc2c
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process swapper (pid: 0, ti=dec1c000 task=c09aef20 task.ti=c0980000)
Stack:
c09469c0 e1894fa4 00000044 00000004 de3c8d00 de3c8d00 de3c8d44 de3c8d40
c09060e2 de25dd80 de3c8d40 dec1dc7c e1894fa4 dec1dcb0 00000040 00000004
00000000 00000800 00000004 00000004 dec1dce0 e1895a2b dec1dcb4 de25d960
Call Trace:
[<e1894fa4>] ? sctp_addto_chunk+0x4e/0x89 [sctp]
[<e1894fa4>] sctp_addto_chunk+0x4e/0x89 [sctp]
[<e1895a2b>] sctp_process_asconf+0x32f/0x3d1 [sctp]
[<e188d554>] sctp_sf_do_asconf+0xf8/0x173 [sctp]
[<e1890b02>] sctp_do_sm+0xb8/0x159 [sctp]
[<e18a2248>] ? sctp_cname+0x0/0x52 [sctp]
[<e189392d>] sctp_assoc_bh_rcv+0xac/0xe3 [sctp]
[<e1897d76>] sctp_inq_push+0x2d/0x30 [sctp]
[<e18a21b2>] sctp_rcv+0x7a7/0x83d [sctp]
[<c077a95c>] ? ipv4_confirm+0x118/0x125
[<c073a970>] ? nf_iterate+0x34/0x62
[<c074789d>] ? ip_local_deliver_finish+0x0/0x194
[<c0747992>] ip_local_deliver_finish+0xf5/0x194
[<c0747a6e>] NF_HOOK.clone.1+0x3d/0x44
[<c0747ab3>] ip_local_deliver+0x3e/0x44
[<c074775c>] ip_rcv_finish+0x29f/0x2c7
[<c07474bd>] ? ip_rcv_finish+0x0/0x2c7
[<c0747cae>] ip_rcv+0x1f5/0x233
[<c071dce3>] __netif_receive_skb+0x310/0x336
[<c07221f3>] netif_receive_skb+0x4b/0x51
[<e0a4ed3d>] cp_rx_poll+0x1e7/0x29c [8139cp]
[<c072275e>] net_rx_action+0x65/0x13a
[<c0445a54>] __do_softirq+0xa1/0x149
[<c04459b3>] ? __do_softirq+0x0/0x149
<IRQ>
[<c0445891>] ? irq_exit+0x37/0x72
[<c040a7e9>] ? do_IRQ+0x81/0x95
[<c07b3670>] ? common_interrupt+0x30/0x38
[<c0428058>] ? native_safe_halt+0xa/0xc
[<c040f5d7>] ? default_idle+0x58/0x92
[<c0408fb0>] ? cpu_idle+0x96/0xb2
[<c0797989>] ? rest_init+0x5d/0x5f
[<c09fd90c>] ? start_kernel+0x34b/0x350
[<c09fd0cb>] ? i386_start_kernel+0xba/0xc1
Like DCCP and other similar pieces of code, there are mechanisms
here to try allocating smaller hash tables if the allocation
fails. So pass in __GFP_NOWARN like the others do instead of
emitting a scary message.
Reported-by: Dave Jones <davej@redhat.com>
Create two sets of port member accessors, one set prefixed by fl4_*
and the other prefixed by fl6_*
This will let us to create AF optimal flow instances.
It will work because every context in which we access the ports,
we have to be fully aware of which AF the flowi is anyways.
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Instead of on the stack.
Add proper RCU annotations/verbs to sk_wq and wq members
Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access)
Fix sunrpc sk_sleep() abuse too
net/sctp/tsnmap.c: In function ‘sctp_tsnmap_num_gabs’:
net/sctp/tsnmap.c:347: warning: ‘start’ may be used uninitialized in this function
net/sctp/tsnmap.c:347: warning: ‘end’ may be used uninitialized in this function
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809 re-worked the
handling of unknown parameters. sctp_init_cause_fixed() can now
return -ENOSPC if there is not enough tailroom in the error
chunk skb. When this happens, the error header is not appended to
the error chunk. In that case, the payload of the unknown parameter
should not be appended either.
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
The option name of Delayed SACK Timer should be SCTP_DELAYED_SACK,
not SCTP_DELAYED_ACK.
Left SCTP_DELAYED_ACK be concomitant with SCTP_DELAYED_SACK,
for making compatibility with existing applications.
Reference:
8.1.19. Get or Set Delayed SACK Timer (SCTP_DELAYED_SACK)
(http://tools.ietf.org/html/draft-ietf-tsvwg-sctpsocket-25)
Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com>
drivers/net/bnx2x/bnx2x.h
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/vhost/vhost.c
Get the sctp partial delivery point using SCTP_PARTIAL_DELIVERY_POINT
socket option should return 0 if success, not -ENOTSUPP.
SCTP_SET_PEER_PRIMARY_ADDR does not accpet v4mapped address, using
v4mapped address in SCTP_SET_PEER_PRIMARY_ADDR socket option will
get -EADDRNOTAVAIL error if v4map is enabled. This patch try to
fix it by mapping v4mapped address to v4 address if allowed.
This patch fixes a typo in net/core/datagram.c and in net/sctp/socket.c
Regards,
David Shwartz
Signed-off-by: David Shwartz <dshwatrz@gmail.com>
Robin Holt tried to boot a 16TB machine and found some limits were
reached : sysctl_tcp_mem[2], sysctl_udp_mem[2]
We can switch infrastructure to use long "instead" of "int", now
atomic_long_t primitives are available for free.
Reported-by: Robin Holt <holt@sgi.com>
Reviewed-by: Robin Holt <holt@sgi.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
net/ipv4/Kconfig
net/ipv4/tcp_timer.c
The sctp_asoc_get_hmac() function iterates through a peer's hmac_ids
array and attempts to ensure that only a supported hmac entry is
returned. The current code fails to do this properly - if the last id
in the array is out of range (greater than SCTP_AUTH_HMAC_ID_MAX), the
id integer remains set after exiting the loop, and the address of an
out-of-bounds entry will be returned and subsequently used in the parent
function, causing potentially ugly memory corruption. This patch resets
the id integer to 0 on encountering an invalid id so that NULL will be
returned after finishing the loop if no valid ids are found.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Two user-controlled allocations in SCTP are subsequently dereferenced as
sockaddr structs, without checking if the dereferenced struct members fall
beyond the end of the allocated chunk. There doesn't appear to be any
information leakage here based on how these members are used and
additional checking, but it's still worth fixing.
[akpm@linux-foundation.org: remove unfashionable newlines, fix gmail tab->space conversion]
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
drivers/net/qlcnic/qlcnic_init.c
net/ipv4/ip_output.c
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
sctp_packet_config() is called when getting the packet ready
for appending of chunks. The function should not touch the
current state, since it's possible to ping-pong between two
transports when sending, and that can result packet corruption
followed by skb overlfow crash.
Reported-by: Thomas Dreibholz <dreibh@iem.uni-due.de>
net/mac80211/main.c
Add a list_has_sctp_addr function to simplify loop
Based on a patches by Dan Carpenter and David Miller
This simple patch copies the current approach for SIOCINQ ioctl() from DCCP
into SCTP so that the userland code working with SCTP can use a similar
interface across different protocols to know how much space to allocate for
a buffer.
Signed-off-by: Diego Elio Pettenò <flameeyes@gmail.com>
No need to test twice sk->sk_shutdown & RCV_SHUTDOWN
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to
use do { print } while (0) guards.
Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when
lines were continued.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Add a missing newline in "Failed bind hash alloc"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
In preparation for 64bit snmp counters for some mibs,
add an 'align' parameter to snmp_mib_init(), instead
of assuming mibs only contain 'unsigned long' fields.
Callers can use __alignof__(type) to provide correct
alignment.
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
CC: Vlad Yasevich <vladislav.yasevich@hp.com>
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
