path: root/net/sctp
2012-01-11sctp: Do not account for sizeof(struct sk_buff) in estimated rwndThomas Graf
[ Upstream commit a76c0adf60f6ca5ff3481992e4ea0383776b24d2 ] When checking whether a DATA chunk fits into the estimated rwnd a full sizeof(struct sk_buff) is added to the needed chunk size. This quickly exhausts the available rwnd space and leads to packets being sent which are much below the PMTU limit. This can lead to much worse performance. The reason for this behaviour was to avoid putting too much memory pressure on the receiver. The concept is not completely irational because a Linux receiver does in fact clone an skb for each DATA chunk delivered. However, Linux also reserves half the available socket buffer space for data structures therefore usage of it is already accounted for. When proposing to change this the last time it was noted that this behaviour was introduced to solve a performance issue caused by rwnd overusage in combination with small DATA chunks. Trying to reproduce this I found that with the sk_buff overhead removed, the performance would improve significantly unless socket buffer limits are increased. The following numbers have been gathered using a patched iperf supporting SCTP over a live 1 Gbit ethernet network. The -l option was used to limit DATA chunk sizes. The numbers listed are based on the average of 3 test runs each. Default values have been used for sk_(r|w)mem. Chunk Size Unpatched No Overhead ------------------------------------- 4 15.2 Kbit [!] 12.2 Mbit [!] 8 35.8 Kbit [!] 26.0 Mbit [!] 16 95.5 Kbit [!] 54.4 Mbit [!] 32 106.7 Mbit 102.3 Mbit 64 189.2 Mbit 188.3 Mbit 128 331.2 Mbit 334.8 Mbit 256 537.7 Mbit 536.0 Mbit 512 766.9 Mbit 766.6 Mbit 1024 810.1 Mbit 808.6 Mbit Signed-off-by: Thomas Graf <tgraf@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: Ifd4199603bbc8851051b45299b7cf73b07b4daac Reviewed-on: http://git-master/r/74220 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11sctp: fix incorrect overflow check on autocloseXi Wang
[ Upstream commit 2692ba61a82203404abd7dd2a027bda962861f74 ] Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for limiting the autoclose value. If userspace passes in -1 on 32-bit platform, the overflow check didn't work and autoclose would be set to 0xffffffff. This patch defines a max_autoclose (in seconds) for limiting the value and exposes it through sysctl, with the following intentions. 1) Avoid overflowing autoclose * HZ. 2) Keep the default autoclose bound consistent across 32- and 64-bit platforms (INT_MAX / HZ in this patch). 3) Keep the autoclose value consistent between setsockopt() and getsockopt() calls. Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I74631fca684d7a475f1eed5f6823c11b62bbd2bc Reviewed-on: http://git-master/r/74219 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2011-09-16sctp: deal with multiple COOKIE_ECHO chunksMax Matveev
Attempt to reduce the number of IP packets emitted in response to single SCTP packet (2e3216cd) introduced a complication - if a packet contains two COOKIE_ECHO chunks and nothing else then SCTP state machine corks the socket while processing first COOKIE_ECHO and then loses the association and forgets to uncork the socket. To deal with the issue add new SCTP command which can be used to set association explictly. Use this new command when processing second COOKIE_ECHO chunk to restore the context for SCTP state machine. Signed-off-by: Max Matveev <makc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/bluetooth/l2cap_core.c
2011-07-14net: sctp: fix checksum marking for outgoing packetsMichał Mirosław
Packets to devices without NETIF_F_SCTP_CSUM (including NETIF_F_NO_CSUM) should be properly checksummed because the packets can be diverted or rerouted after construction. This still leaves packets diverted from NETIF_F_SCTP_CSUM-enabled devices with broken checksums. Fixing this needs implementing software offload fallback in networking core. For users of sctp_checksum_disable, skb->ip_summed should be left as CHECKSUM_NONE and not CHECKSUM_UNNECESSARY as per include/linux/skbuff.h. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-14Merge branch 'master' of ↵David S. Miller
2011-07-08sctp: ABORT if receive, reassmbly, or reodering queue is not empty while ↵Thomas Graf
closing socket Trigger user ABORT if application closes a socket which has data queued on the socket receive queue or chunks waiting on the reassembly or ordering queue as this would imply data being lost which defeats the point of a graceful shutdown. This behavior is already practiced in TCP. We do not check the input queue because that would mean to parse all chunks on it to look for unacknowledged data which seems too much of an effort. Control chunks or duplicated chunks may also be in the input queue and should not be stopping a graceful shutdown. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07sctp: Enforce retransmission limit during shutdownThomas Graf
When initiating a graceful shutdown while having data chunks on the retransmission queue with a peer which is in zero window mode the shutdown is never completed because the retransmission error count is reset periodically by the following two rules: - Do not timeout association while doing zero window probe. - Reset overall error count when a heartbeat request has been acknowledged. The graceful shutdown will wait for all outstanding TSN to be acknowledged before sending the SHUTDOWN request. This never happens due to the peer's zero window not acknowledging the continuously retransmitted data chunks. Although the error counter is incremented for each failed retransmission, the receiving of the SACK announcing the zero window clears the error count again immediately. Also heartbeat requests continue to be sent periodically. The peer acknowledges these requests causing the error counter to be reset as well. This patch changes behaviour to only reset the overall error counter for the above rules while not in shutdown. After reaching the maximum number of retransmission attempts, the T5 shutdown guard timer is scheduled to give the receiver some additional time to recover. The timer is stopped as soon as the receiver acknowledges any data. The issue can be easily reproduced by establishing a sctp association over the loopback device, constantly queueing data at the sender while not reading any at the receiver. Wait for the window to reach zero, then initiate a shutdown by killing both processes simultaneously. The association will never be freed and the chunks on the retransmission queue will be retransmitted indefinitely. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07sctp: fix missing send up SCTP_SENDER_DRY_EVENT when subscribe itWei Yongjun
We forgot to send up SCTP_SENDER_DRY_EVENT notification when user app subscribes to this event, and there is no data to be sent or retransmit. This is required by the Socket API and used by the DTLS/SCTP implementation. Reported-by: Michael Tüxen <Michael.Tuexen@lurchi.franken.de> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Tested-by: Robin Seggelmann <seggelmann@fh-muenster.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07net: refine {udp|tcp|sctp}_mem limitsEric Dumazet
Current tcp/udp/sctp global memory limits are not taking into account hugepages allocations, and allow 50% of ram to be used by buffers of a single protocol [ not counting space used by sockets / inodes ...] Lets use nr_free_buffer_pages() and allow a default of 1/8 of kernel ram per protocol, and a minimum of 128 pages. Heavy duty machines sysadmins probably need to tweak limits anyway. References: https://bugzilla.stlinux.com/show_bug.cgi?id=38032 Reported-by: starlight <starlight@binnacle.cx> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01sctp: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows useless break;s removed after returns and a comment added to an unnecessary default: break; because of a dubious gcc warning. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-16net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script: $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-11sctp: kzalloc() error handling on deleting last addressMichio Honda
Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06sctp: Guard IPV6 specific code properly.David S. Miller
Outside of net/sctp/ipv6.c, IPV6 specific code needs to be ifdef guarded. This fixes build failures with IPV6 disabled. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add ASCONF operation on the single-homed hostMichio Honda
In this case, the SCTP association transmits an ASCONF packet including addition of the new IP address and deletion of the old address. This patch implements this functionality. In this case, the ASCONF chunk is added to the beginning of the queue, because the other chunks cannot be transmitted in this state. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add socket option operation for Auto-ASCONF.Michio Honda
This patch allows the application to operate Auto-ASCONF on/off behavior via setsockopt() and getsockopt(). Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add sysctl support for Auto-ASCONF.Michio Honda
This patch allows the system administrator to change default Auto-ASCONF on/off behavior via an sysctl value. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add Auto-ASCONF support (core).Michio Honda
SCTP reconfigure the IP addresses in the association by using ASCONF chunks as mentioned in RFC5061. For example, we can start to use the newly configured IP address in the existing association. This patch implements automatic ASCONF operation in the SCTP stack with address events in the host computer, which is called auto_asconf. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add ADD/DEL ASCONF handling at the receiver.Michio Honda
This patch fixes the problem that the original code cannot delete the remote address where the corresponding transport is currently directed, even when the ASCONF is sent from the other address (this situation happens when the single-homed sender transmits ASCONF with ADD and DEL.) Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-31sctp: stop pending timers and purge queues when peer restart asocWei Yongjun
If the peer restart the asoc, we should not only fail any unsent/unacked data, but also stop the T3-rtx, SACK, T4-rto timers, and teardown ASCONF queues. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25sctp: fix memory leak of the ASCONF queue when free asocWei Yongjun
If an ASCONF chunk is outstanding, then the following ASCONF chunk will be queued for later transmission. But when we free the asoc, we forget to free the ASCONF queue at the same time, this will cause memory leak. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24net: convert %p usage to %pKDan Rosenberg
The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". The supporting code for kptr_restrict and %pK are currently in the -mm tree. This patch converts users of %p in net/ to %pK. Cases of printing pointers to the syslog are not covered, since this would eliminate useful information for postmortem debugging and the reading of the syslog is already optionally protected by the dmesg_restrict sysctl. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-21sctp: Fix build failure.David S. Miller
Commit c182f90bc1f22ce5039b8722e45621d5f96862c2 ("SCTP: fix race between sctp_bind_addr_free() and sctp_bind_addr_conflict()") and commit 1231f0baa547a541a7481119323b7f964dda4788 ("net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()"), happening in different trees, introduced a build failure. Simply make the SCTP race fix use kfree_rcu() too. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-19SCTP: fix race between sctp_bind_addr_free() and sctp_bind_addr_conflict()Jacek Luczak
During the sctp_close() call, we do not use rcu primitives to destroy the address list attached to the endpoint. At the same time, we do the removal of addresses from this list before attempting to remove the socket from the port hash As a result, it is possible for another process to find the socket in the port hash that is in the process of being closed. It then proceeds to traverse the address list to find the conflict, only to have that address list suddenly disappear without rcu() critical section. Fix issue by closing address list removal inside RCU critical section. Race can result in a kernel crash with general protection fault or kernel NULL pointer dereference: kernel: general protection fault: 0000 [#1] SMP kernel: RIP: 0010:[<ffffffffa02f3dde>] [<ffffffffa02f3dde>] sctp_bind_addr_conflict+0x64/0x82 [sctp] kernel: Call Trace: kernel: [<ffffffffa02f415f>] ? sctp_get_port_local+0x17b/0x2a3 [sctp] kernel: [<ffffffffa02f3d45>] ? sctp_bind_addr_match+0x33/0x68 [sctp] kernel: [<ffffffffa02f4416>] ? sctp_do_bind+0xd3/0x141 [sctp] kernel: [<ffffffffa02f5030>] ? sctp_bindx_add+0x4d/0x8e [sctp] kernel: [<ffffffffa02f5183>] ? sctp_setsockopt_bindx+0x112/0x4a4 [sctp] kernel: [<ffffffff81089e82>] ? generic_file_aio_write+0x7f/0x9b kernel: [<ffffffffa02f763e>] ? sctp_setsockopt+0x14f/0xfee [sctp] kernel: [<ffffffff810c11fb>] ? do_sync_write+0xab/0xeb kernel: [<ffffffff810e82ab>] ? fsnotify+0x239/0x282 kernel: [<ffffffff810c2462>] ? alloc_file+0x18/0xb1 kernel: [<ffffffff8134a0b1>] ? compat_sys_setsockopt+0x1a5/0x1d9 kernel: [<ffffffff8134aaf1>] ? compat_sys_socketcall+0x143/0x1a4 kernel: [<ffffffff810467dc>] ? sysenter_dispatch+0x7/0x32 Signed-off-by: Jacek Luczak <luczak.jacek@gmail.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> CC: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12sctp: sctp_sendmsg: Don't test known non-null sinfoJoe Perches
It's already known non-null above. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12sctp: sctp_sendmsg: Don't initialize default_sinfoJoe Perches
This variable only needs initialization when cmsgs.info is NULL. Use memset to ensure padding is also zeroed so kernel doesn't leak any data. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-10sctp: Remove rt->rt_src usage in sctp_v4_get_saddr()David S. Miller
Flow key is available, so fetch it from there. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08sctp: Fix debug message args.David S. Miller
I messed things up when I converted over to the transport flow, I passed the ipv4 address value instead of it's address. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08sctp: Don't use rt->rt_{src,dst} in sctp_v4_xmit()David S. Miller
Now we can pick it out of the transport's flow key. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08inet: Pass flowi to ->queue_xmit().David S. Miller
This allows us to acquire the exact route keying information from the protocol, however that might be managed. It handles all of the possibilities, from the simplest case of storing the key in inet->cork.fl to the more complex setup SCTP has where individual transports determine the flow. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08sctp: Store a flowi in transports to provide persistent keying.David S. Miller
Several future simplifications are possible now because of this. For example, the sctp_addr unions can simply refer directly to the flowi information. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-07net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()Lai Jiangshan
The rcu callback sctp_local_addr_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sctp_local_addr_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-03sctp: Use flowi4's {saddr,daddr} in sctp_v4_dst_saddr() and sctp_v4_get_dst()David S. Miller
Instead of rt->rt_{src,dst} Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: clean up route lookup callsVlad Yasevich
Change the call to take the transport parameter and set the cached 'dst' appropriately inside the get_dst() function calls. This will allow us in the future to clean up source address storage as well. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: remove useless arguments from get_saddr() callVlad Yasevich
There is no point in passing a destination address to a get_saddr() call. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: make sctp over IPv6 work with IPsecVlad Yasevich
SCTP never called xfrm_output after it's v6 route lookups so that never really worked with ipsec. Additioanlly, we never passed port nubmers and protocol in the flowi, so any port based policies were never applied as well. Now that we can fixed ipv6 routing lookup code, using ip6_dst_lookup_flow() and pass port numbers. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: cache the ipv6 source after route lookupVlad Yasevich
The ipv6 routing lookup does give us a source address, but instead of filling it into the dst, it's stored in the flowi. We can use that instead of going through the entire source address selection again. Also the useless ->dst_saddr member of sctp_pf is removed. And sctp_v6_dst_saddr() is removed, instead by introduce sctp_v6_to_addr(), which can be reused to cleanup some dup code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: fix sctp to work with ipv6 source address routingWeixing Shi
In the below test case, using the source address routing, sctp can not work. Node-A 1)ifconfig eth0 inet6 add 2001:1::1/64 2)ip -6 rule add from 2001:1::1 table 100 pref 100 3)ip -6 route add 2001:2::1 dev eth0 table 100 4)sctp_darn -H 2001:1::1 -P 250 -l & Node-B 1)ifconfig eth0 inet6 add 2001:2::1/64 2)ip -6 rule add from 2001:2::1 table 100 pref 100 3)ip -6 route add 2001:1::1 dev eth0 table 100 4)sctp_darn -H 2001:2::1 -P 250 -h 2001:1::1 -p 250 -s root cause: Node-A and Node-B use the source address routing, and at begining, source address will be NULL,sctp will search the routing table by the destination address, because using the source address routing table, and the result dst_entry will be NULL. solution: walk through the bind address list to get the source address and then lookup the routing table again to get the correct dst_entry. Signed-off-by: Weixing Shi <Weixing.Shi@windriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Revert wrong fixes for common misspellingsLucas De Marchi
These changes were incorrectly fixed by codespell. They were now manually corrected. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sctp: implement event notification SCTP_SENDER_DRY_EVENTWei Yongjun
This patch implement event notification SCTP_SENDER_DRY_EVENT. SCTP Socket API Extensions: 6.1.9. SCTP_SENDER_DRY_EVENT When the SCTP stack has no more user data to send or retransmit, this notification is given to the user. Also, at the time when a user app subscribes to this event, if there is no data to be sent or retransmit, the stack will immediately send up this notification. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sctp: change auth event type name to SCTP_AUTHENTICATION_EVENTWei Yongjun
This patch change the auth event type name to SCTP_AUTHENTICATION_EVENT, which is based on API extension compliance. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21sctp: implement socket option SCTP_GET_ASSOC_ID_LISTWei Yongjun
This patch Implement socket option SCTP_GET_ASSOC_ID_LIST. SCTP Socket API Extension: 8.2.6. Get the Current Identifiers of Associations (SCTP_GET_ASSOC_ID_LIST) This option gets the current list of SCTP association identifiers of the SCTP associations handled by a one-to-many style socket. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: move chunk from retransmit queue to abandoned listWei Yongjun
If there is still data waiting to retransmit and remain in retransmit queue, while doing the next retransmit, if the chunk is abandoned, we should move it to abandoned list. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: make heartbeat information in sctp_make_heartbeat()Wei Yongjun
Make heartbeat information in sctp_make_heartbeat() instead of make it in sctp_sf_heartbeat() directly for common using. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: fix to check the source address of COOKIE-ECHO chunkWei Yongjun
SCTP does not check whether the source address of COOKIE-ECHO chunk is the original address of INIT chunk or part of the any address parameters saved in COOKIE in CLOSED state. So even if the COOKIE-ECHO chunk is from any address but with correct COOKIE, the COOKIE-ECHO chunk still be accepted. If the COOKIE is not from a valid address, the assoc should not be established. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: handle ootb packet in chunk order as definedShan Wei
Changed the order of processing SHUTDOWN ACK and COOKIE ACK refer to section 8.4:Handle "Out of the Blue" Packets. SHUTDOWN ACK chunk should be processed before processing "Stale Cookie" ERROR or a COOKIE ACK. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: bail from sctp_endpoint_lookup_assoc() if not boundVlad Yasevich
The sctp_endpoint_lookup_assoc() function uses a port hash to lookup the association and then checks to see if any of them are on the current endpoint. However, if the current endpoint is not bound, there can't be any associations on it, thus we can bail early. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20sctp: remove completely unsed EMPTY stateVlad Yasevich
SCTP does not SCTP_STATE_EMPTY and we can never be in that state. Remove useless code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
