[ Upstream commit add52379dde2e5300e2d574b172e62c6cf43b3d3 ]
If INIT-ACK is received with SupportedExtensions parameter which
indicates that the peer does not support AUTH, the packet will be
silently ignore, and sctp_process_init() do cleanup all of the
transports in the association.
When T1-Init timer is expires, OOPS happen while we try to choose
a different init transport.
The solution is to only clean up the non-active transports, i.e
the ones that the peer added. However, that introduces a problem
with sctp_connectx(), because we don't mark the proper state for
the transports provided by the user. So, we'll simply mark
user-provided transports as ACTIVE. That will allow INIT
retransmissions to work properly in the sctp_connectx() context
and prevent the crash.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[ Upstream commit 0ef46e285c062cbe35d60c0adbff96f530d31c86 ]
Do not enable peer features like addip and auth, if they
are administratively disabled localy. If the peer resports
that he supports something that we don't, neither end can
use it so enabling it is pointless. This solves a problem
when talking to a peer that has auth and addip enabled while
we do not. Found by Andrei Pelinescu-Onciul <andrei@iptel.org>.
[ Upstream commit d97240552cd98c4b07322f30f66fd9c3ba4171de ]
The number of identifiers needs to be checked against the option
length. Also, the identifier index provided needs to be verified
to make sure that it doesn't exceed the bounds of the array.
[ Upstream commit 328fc47ea0bcc27d9afa69c3ad6e52431cadd76c ]
The bonds check to prevent buffer overlflow was not exactly
right. It still allowed overflow of up to 8 bytes which is
sizeof(struct sctp_authkey).
Since optlen is already checked against the size of that struct,
we are guaranteed not to cause interger overflow either.
[ Upstream commit 30c2235cbc477d4629983d440cdc4f496fec9246 ]
The structure used for SCTP_AUTH_KEY option contains a
length that needs to be verfied to prevent buffer overflow
conditions. Spoted by Eugene Teo <eteo@redhat.com>.
[ Upstream commit 5e739d1752aca4e8f3e794d431503bfca3162df4 ]
All of the SCTP-AUTH socket options could cause a panic
if the extension is disabled and the API is envoked.
Additionally, there were some additional assumptions that
certain pointers would always be valid which may not
always be the case.
This patch hardens the API and address all of the crash
scenarios.
commit 735ce972fbc8a65fb17788debd7bbe7b4383cc62 upstream
As noticed by Gabriel Campana, the kmalloc() length arg
passed in by sctp_getsockopt_local_addrs_old() can overflow
if ->addr_num is large enough.
Therefore, enforce an appropriate limit.
All IP addresses that are present in a system are duplicated on
struct sctp_sockaddr_entry. They are linked in the global list
called sctp_local_addr_list. And this struct unions IPv4 and IPv6
addresses.
So, there can be rare case, when a sockaddr_in.sin_addr coincides
with the corresponding part of the sockaddr_in6 and the notifier
for IPv4 will carry away an IPv6 entry.
The fix is to check the family before comparing the addresses.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Fix 3 warnings about discarding const qualifiers:
net/sctp/ulpevent.c:862: warning: passing argument 1 of 'sctp_event2skb' discards qualifiers from pointer target type
net/sctp/sm_statefuns.c:4393: warning: passing argument 1 of 'SCTP_ASOC' discards qualifiers from pointer target type
net/sctp/socket.c:5874: warning: passing argument 1 of 'cmsg_nxthdr' discards qualifiers from pointer target type
When receiving an error length INIT-ACK during COOKIE-WAIT,
a 0-vtag ABORT will be responsed. This action violates the
protocol apparently. This patch achieves the following things.
1 If the INIT-ACK contains all the fixed parameters, use init-tag
recorded from INIT-ACK as vtag.
2 If the INIT-ACK doesn't contain all the fixed parameters,
just reflect its vtag.
Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
RFC 4890 has the following text:
The HMAC algorithm based on SHA-1 MUST be supported and
included in the HMAC-ALGO parameter.
As a result, we need to check in sctp_verify_param() that HMAC_SHA1 is
present in the list. If not, we should probably treat this as a
protocol violation.
It should also be a protocol violation if the HMAC parameter is empty.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
There is a race is SCTP between the loading of the module
and the access by the socket layer to the protocol functions.
In particular, a list of addresss that SCTP maintains is
not initialized prior to the registration with the protosw.
Thus it is possible for a user application to gain access
to SCTP functions before everything has been initialized.
The problem shows up as odd crashes during connection
initializtion when we try to access the SCTP address list.
The solution is to refactor how we do registration and
initialize the lists prior to registering with the protosw.
Care must be taken since the address list initialization
depends on some other pieces of SCTP initialization. Also
the clean-up in case of failure now also needs to be refactored.
Acked-by: Sridhar Samudrala <sri@us.ibm.com>
Since the lists are circular, we need to explicitely tag
the address to be deleted since we might end up freeing
the list head instead. This fixes some interesting SCTP
crashes.
Signed-off-by: Chidambar 'ilLogict' Zinnoury <illogict@online.fr>
Brings max_burst socket option set/get into line with the latest ietf
socket extensions api draft, while maintaining backwards
compatibility.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
If an address family is not listed in "Supported Address Types"
parameter(INIT Chunk), but the packet is sent by that family, this
address family should be considered as supported by peer. Otherwise,
an error condition will occur. For instance, if kernel receives an
IPV6 SCTP INIT chunk with "Support Address Types" parameter which
indicates just supporting IPV4 Address family. Kernel will reply an
IPV6 SCTP INIT ACK packet, but the source ipv6 address in ipv6 header
will be vacant. This is not correct.
refer to RFC4460 as following:
IMPLEMENTATION NOTE: If an SCTP endpoint lists in the 'Supported
Address Types' parameter either IPv4 or IPv6, but uses the other
family for sending the packet containing the INIT chunk, or if it
also lists addresses of the other family in the INIT chunk, then
the address family that is not listed in the 'Supported Address
Types' parameter SHOULD also be considered as supported by the
receiver of the INIT chunk. The receiver of the INIT chunk SHOULD
NOT respond with any kind of error indication.
Here is a fix to comply to RFC.
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
In addition to commit 160f17 ("[SCTP]: Use proc_create() to setup
->proc_fops first") use proc_create in two more places.
Use proc_create() to make sure that ->proc_fops be setup before gluing
PDE to main tree.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
The new SCTP socket api (draft 16) updates the AUTH API structures.
We never exported these since we knew they would change.
Update the rest to match the draft.
The chunks are stored inside a parameter structure in the kernel
and when we copy them to the user, we need to account for
the parameter header.
I noticed while looking into some odd behavior in sctp, that the variable
name sctp_pf_inet6_specific was used twice to represent two different
pieces of data (its both a structure name and a pointer to that type of
structure), which is confusing to say the least, and potentially dangerous
depending on the variable scope. This patch cleans that up, and makes the
protocol and address family registration names in SCTP more regular,
increasing readability.
ipv6.c | 12 ++++++------
protocol.c | 12 ++++++------
2 files changed, 12 insertions(+), 12 deletions(-)
sctp_assoc_change notification may contain the data from a received
ABORT chunk. Set the length correctly to account for that.
This counter is currently write-only.
Drawing an analogy with the similar tcp counter, I think
that this one should be pointed by the sockets_allocated
members of sctp_prot and sctpv6_prot.
This makes the code use a good proc API and the text ~50 bytes shorter.
SCPT already depends in INET, so this doesn't create additional
dependencies.
In a few instances, we need to remove the chunk from the transmitted list
prior to freeing it. This is because the free code doesn't do that any
more and so we need to do it manually.
While recevied ASCONF chunk with serial number less then needed, kernel
will treat this chunk as a retransmitted ASCONF chunk and find cached
ASCONF-ACK chunk used sctp_assoc_lookup_asconf_ack(). But this function
will always return NO-NULL. So response with cached ASCONF-ACKs chunk
will cause kernel panic.
In function sctp_assoc_lookup_asconf_ack(), if the cached ASCONF-ACKs
list asconf_ack_list is empty, or if the serial being requested does not
exists, the function as it currectly stands returns the actuall
list_head asoc->asconf_ack_list, this is not a cache ASCONF-ACK chunk
but a bogus pointer.
Thomas Dreibholz has reported that port numbers are not filled
in the results of sctp_getladdrs() when the socket was bound
to an ephemeral port. This is only true, if the address was
not specified either. So, fill in the port number correctly.
When we recieve a FORWARD_TSN chunk, we need to reap
all the queued fast-forwarded chunks from the ordering queue
However, if we don't have them queued, we need to see if
the next expected one is there as well. If it is, start
deliver from that point instead of waiting for the next
chunk to arrive.
When a user reads a partial notification message, do not
update rwnd since notifications must not be counted towards
receive window.
Tested-by: Oliver Roll <mail@oliroll.de>
I was notified by Randy Stewart that lksctp claims to be
"the reference implementation". First of all, "the
refrence implementation" was the original implementation
of SCTP in usersapce written ty Randy and a few others.
Second, after looking at the definiton of 'reference implementation',
we don't really meet the requirements.
identifier
If SCTP-AUTH is enabled, received AUTH chunk with BAD shared key
identifier will cause kernel panic.
Test as following:
step1: enabled /proc/sys/net/sctp/auth_enable
step 2: connect to SCTP server with auth capable. Association is
established between endpoints. Then send a AUTH chunk with a bad
shareid, SCTP server will kernel panic after received that AUTH chunk.
SCTP client SCTP server
INIT ---------->
(with auth capable)
<---------- INIT-ACK
(with auth capable)
COOKIE-ECHO ---------->
<---------- COOKIE-ACK
AUTH ---------->
AUTH chunk is like this:
AUTH chunk
Chunk type: AUTH (15)
Chunk flags: 0x00
Chunk length: 28
Shared key identifier: 10
HMAC identifier: SHA-1 (1)
HMAC: 0000000000000000000000000000000000000000
The assignment of NULL to key can safely be removed, since key_for_each
(which is just list_for_each_entry under the covers does an initial
assignment to key anyway).
If the endpoint_shared_keys list is empty, or if the key_id being
requested does not exist, the function as it currently stands returns
the actuall list_head (in this case endpoint_shared_keys. Since that
list_head isn't surrounded by an actuall data structure, the last
iteration through list_for_each_entry will do a container_of on key, and
we wind up returning a bogus pointer, instead of NULL, as we should.
> Neil Horman wrote:
>> On Tue, Jan 22, 2008 at 05:29:20PM +0900, Wei Yongjun wrote:
>> FWIW, Ack from me. The assignment of NULL to key can safely be
>> removed, since
>> key_for_each (which is just list_for_each_entry under the covers does
>> an initial
>> requested does
>> not exist, the function as it currently stands returns the actuall
>> list_head (in
>> this case endpoint_shared_keys. Since that list_head isn't
>> surrounded by an
>> actuall data structure, the last iteration through
>> container_of on key, and we wind up returning a bogus pointer,
>> instead of NULL,
>> as we should. Wei's patch corrects that.
>> Regards
>> Neil
>> Acked-by: Neil Horman <nhorman@tuxdriver.com>
> Yep, the patch is correct.
> -vlad
If STCP is started while /proc/sys/net/sctp/auth_enable is set 0 and
association is established between endpoints. Then if
/proc/sys/net/sctp/auth_enable is set 1, a received AUTH chunk will
cause kernel panic.
Test as following:
step 1: echo 0> /proc/sys/net/sctp/auth_enable
step 2:
INIT --------->
<--------- INIT-ACK
COOKIE-ECHO --------->
<--------- COOKIE-ACK
step 3:
echo 1> /proc/sys/net/sctp/auth_enable
step 4:
AUTH -----------> Kernel Panic
This patch fix this probleam to treat AUTH chunk as unknow chunk if peer
has initialized with no auth capable.
> Sorry for the delay. Was on vacation without net access.
>> peer has initialized with no auth capable.
Signed-off-by: Oliver Pinter <oliver.pntr@gmail.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch fix miss of check for report unrecognized HMAC Algorithm
parameter. When AUTH is disabled, goto fall through path to report
unrecognized parameter, else, just break
Needed to propagate it down to the ip_route_output_flow.
Signed-off-by: Denis V. Lunev <den@openvz.org>
When parameter validation fails, there should be error causes that
specify what type of failure we've encountered. If the causes are not
there, we lacked memory to allocated them. Thus make that the default
value for the error.
Reported by Andrew Morton.
net/sctp/sm_statefuns.c: In function 'sctp_sf_do_5_1C_ack':
net/sctp/sm_statefuns.c:484: warning: 'error' may be used uninitialized in this function
When a new address is added, we must check if the new address does not
already exists. This patch makes this check to be aware of a network
namespace, so the check will look if the address already exists for
the specified network namespace. While the addresses are browsed, the
addresses which do not belong to the namespace are discarded.
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
The patch extends the inet_addr_type and inet_dev_addr_type with the
network namespace pointer. That allows to access the different tables
relatively to the network namespace.
The modification of the signature function is reported in all the
callers of the inet_addr_type using the pointer to the well known
init_net.
Acked-by: Benjamin Thery <benjamin.thery@bull.net>
Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com>
This patch includes many places, that only required
replacing the ctl_table-s with appropriate ctl_paths
and call register_sysctl_paths().
Nothing special was done with them.
This patch introduces new memory accounting functions for each network
protocol. Most of them are renamed from memory accounting functions
for stream protocols. At the same time, some stream memory accounting
functions are removed since other functions do same thing.
Renaming:
sk_stream_free_skb() -> sk_wmem_free_skb()
__sk_stream_mem_reclaim() -> __sk_mem_reclaim()
sk_stream_mem_reclaim() -> sk_mem_reclaim()
sk_stream_mem_schedule -> __sk_mem_schedule()
sk_stream_pages() -> sk_mem_pages()
sk_stream_rmem_schedule() -> sk_rmem_schedule()
sk_stream_wmem_schedule() -> sk_wmem_schedule()
sk_charge_skb() -> sk_mem_charge()
Removeing
sk_stream_rfree(): consolidates into sock_rfree()
sk_stream_set_owner_r(): consolidates into skb_set_owner_r()
sk_stream_mem_schedule()
The following functions are added.
sk_has_account(): check if the protocol supports accounting
sk_mem_uncharge(): do the opposite of sk_mem_charge()
In addition, to achieve consolidation, updating sk_wmem_queued is
removed from sk_mem_charge().
Next, to consolidate memory accounting functions, this patch adds
memory accounting calls to network core functions. Moreover, present
memory accounting call is renamed to new accounting call.
Finally we replace present memory accounting calls with new interface
in TCP and SCTP.
Signed-off-by: Takahiro Yasui <tyasui@redhat.com>
Signed-off-by: Hideo Aoki <haoki@redhat.com>
The Security Considerations section of RFC 5061 has the following
text:
If an SCTP endpoint that supports this extension receives an INIT
that indicates that the peer supports the ASCONF extension but does
NOT support the [RFC4895] extension, the receiver of such an INIT
MUST send an ABORT in response. Note that an implementation is
allowed to silently discard such an INIT as an option as well, but
under NO circumstance is an implementation allowed to proceed with
the association setup by sending an INIT-ACK in response.
An implementation that receives an INIT-ACK that indicates that the
peer does not support the [RFC4895] extension MUST NOT send the
COOKIE-ECHO to establish the association. Instead, the
implementation MUST discard the INIT-ACK and report to the upper-
layer user that an association cannot be established destroying the
Transmission Control Block (TCB).
Follow the recomendations.
ADD-IP spec has a special case for processing ABORTs:
F4) ... One special consideration is that ABORT
Chunks arriving destined to the IP address being deleted MUST be
ignored (see Section 5.3.1 for further details).
Check if the address we received on is in the DEL state, and if
so, ignore the ABORT.
The processing of the ASCONF chunks has changed a lot in the
spec. New items are:
1. A list of ASCONF-ACK chunks is now cached
2. The source of the packet is used in response.
3. New handling for unexpect ASCONF chunks.
C4) Both ASCONF and ASCONF-ACK Chunks MUST NOT be sent in any SCTP
state except ESTABLISHED, SHUTDOWN-PENDING, SHUTDOWN-RECEIVED,
and SHUTDOWN-SENT.
ADD-IP draft section 5.2 specifies that if an association can not
be found using the source and destination of the IP packet,
then, if the packet contains ASCONF chunks, the Address Parameter
TLV should be used to lookup an association.
