commit 2e3219b5c8a2e44e0b83ae6e04f52f20a82ac0f2 upstream.
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809
sctp: Fix skb_over_panic resulting from multiple invalid \
parameter errors (CVE-2010-1173) (v4)
cause 'error cause' never be add the the ERROR chunk due to
some typo when check valid length in sctp_init_cause_fixed().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809 upstream.
Ok, version 4
Change Notes:
1) Minor cleanups, from Vlads notes
Summary:
Hey-
Recently, it was reported to me that the kernel could oops in the
following way:
<5> kernel BUG at net/core/skbuff.c:91!
<5> invalid operand: 0000 [#1]
<5> Modules linked in: sctp netconsole nls_utf8 autofs4 sunrpc iptable_filter
ip_tables cpufreq_powersave parport_pc lp parport vmblock(U) vsock(U) vmci(U)
vmxnet(U) vmmemctl(U) vmhgfs(U) acpiphp dm_mirror dm_mod button battery ac md5
ipv6 uhci_hcd ehci_hcd snd_ens1371 snd_rawmidi snd_seq_device snd_pcm_oss
snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_ac97_codec snd soundcore
pcnet32 mii floppy ext3 jbd ata_piix libata mptscsih mptsas mptspi mptscsi
mptbase sd_mod scsi_mod
<5> CPU: 0
<5> EIP: 0060:[<c02bff27>] Not tainted VLI
<5> EFLAGS: 00010216 (2.6.9-89.0.25.EL)
<5> EIP is at skb_over_panic+0x1f/0x2d
<5> eax: 0000002c ebx: c033f461 ecx: c0357d96 edx: c040fd44
<5> esi: c033f461 edi: df653280 ebp: 00000000 esp: c040fd40
<5> ds: 007b es: 007b ss: 0068
<5> Process swapper (pid: 0, threadinfo=c040f000 task=c0370be0)
<5> Stack: c0357d96 e0c29478 00000084 00000004 c033f461 df653280 d7883180
e0c2947d
<5> 00000000 00000080 df653490 00000004 de4f1ac0 de4f1ac0 00000004
df653490
<5> 00000001 e0c2877a 08000800 de4f1ac0 df653490 00000000 e0c29d2e
00000004
<5> Call Trace:
<5> [<e0c29478>] sctp_addto_chunk+0xb0/0x128 [sctp]
<5> [<e0c2947d>] sctp_addto_chunk+0xb5/0x128 [sctp]
<5> [<e0c2877a>] sctp_init_cause+0x3f/0x47 [sctp]
<5> [<e0c29d2e>] sctp_process_unk_param+0xac/0xb8 [sctp]
<5> [<e0c29e90>] sctp_verify_init+0xcc/0x134 [sctp]
<5> [<e0c20322>] sctp_sf_do_5_1B_init+0x83/0x28e [sctp]
<5> [<e0c25333>] sctp_do_sm+0x41/0x77 [sctp]
<5> [<c01555a4>] cache_grow+0x140/0x233
<5> [<e0c26ba1>] sctp_endpoint_bh_rcv+0xc5/0x108 [sctp]
<5> [<e0c2b863>] sctp_inq_push+0xe/0x10 [sctp]
<5> [<e0c34600>] sctp_rcv+0x454/0x509 [sctp]
<5> [<e084e017>] ipt_hook+0x17/0x1c [iptable_filter]
<5> [<c02d005e>] nf_iterate+0x40/0x81
<5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151
<5> [<c02e0c7f>] ip_local_deliver_finish+0xc6/0x151
<5> [<c02d0362>] nf_hook_slow+0x83/0xb5
<5> [<c02e0bb2>] ip_local_deliver+0x1a2/0x1a9
<5> [<c02e103e>] ip_rcv+0x334/0x3b4
<5> [<c02c66fd>] netif_receive_skb+0x320/0x35b
<5> [<e0a0928b>] init_stall_timer+0x67/0x6a [uhci_hcd]
<5> [<c02c67a4>] process_backlog+0x6c/0xd9
<5> [<c02c690f>] net_rx_action+0xfe/0x1f8
<5> [<c012a7b1>] __do_softirq+0x35/0x79
<5> [<c0107efb>] handle_IRQ_event+0x0/0x4f
<5> [<c01094de>] do_softirq+0x46/0x4d
Its an skb_over_panic BUG halt that results from processing an init chunk in
which too many of its variable length parameters are in some way malformed.
The problem is in sctp_process_unk_param:
if (NULL == *errp)
*errp = sctp_make_op_error_space(asoc, chunk,
ntohs(chunk->chunk_hdr->length));
if (*errp) {
sctp_init_cause(*errp, SCTP_ERROR_UNKNOWN_PARAM,
WORD_ROUND(ntohs(param.p->length)));
sctp_addto_chunk(*errp,
WORD_ROUND(ntohs(param.p->length)),
param.v);
When we allocate an error chunk, we assume that the worst case scenario requires
that we have chunk_hdr->length data allocated, which would be correct nominally,
given that we call sctp_addto_chunk for the violating parameter. Unfortunately,
we also, in sctp_init_cause insert a sctp_errhdr_t structure into the error
chunk, so the worst case situation in which all parameters are in violation
requires chunk_hdr->length+(sizeof(sctp_errhdr_t)*param_count) bytes of data.
The result of this error is that a deliberately malformed packet sent to a
listening host can cause a remote DOS, described in CVE-2010-1173:
http://cve.mitre.org/cgi-bin/cvename.cgi?name=2010-1173
I've tested the below fix and confirmed that it fixes the issue. We move to a
strategy whereby we allocate a fixed size error chunk and ignore errors we don't
have space to report. Tested by me successfully
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
[ Upstream commit cb0dc77de0d23615a845e45844a2e22fc224d7fe ]
broken by commit 5e739d1752aca4e8f3e794d431503bfca3162df4; AFAICS should
be -stable fodder as well...
Aced-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[ Upstream commit 759af00ebef858015eb68876ac1f383bcb6a1774 ]
Recent changes to the retransmit code exposed a long standing
bug where it was possible for a chunk to be time stamped
after the retransmit timer was reset. This caused a rare
situation where the retrnamist timer has expired, but
nothing was marked for retrnasmission because all of
timesamps on data were less then 1 rto ago. As result,
the timer was never restarted since nothing was retransmitted,
and this resulted in a hung association that did couldn't
complete the data transfer. The solution is to timestamp
the chunk when it's added to the packet for transmission
purposes. After the packet is trsnmitted the rtx timer
is restarted. This guarantees that when the timer expires,
there will be data to retransmit.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[ Upstream commit 6574df9a89f9f7da3a4e5cee7633d430319d3350 ]
Commit 62aeaff5ccd96462b7077046357a6d7886175a57
(sctp: Start T3-RTX timer when fast retransmitting lowest TSN)
introduced a regression where it was possible to forcibly
restart the sctp retransmit timer at the transmission of any
new chunk. This resulted in much longer timeout times and
sometimes hung sctp connections.
commit ae53b5bd77719fed58086c5be60ce4f22bffe1c6 upstream.
There is a race between sctp_rcv() and sctp_accept() where we
have moved the association from the listening socket to the
accepted socket, but sctp_rcv() processing cached the old
socket and continues to use it.
The easy solution is to check for the socket mismatch once we've
grabed the socket lock. If we hit a mis-match, that means
that were are currently holding the lock on the listening socket,
but the association is refrencing a newly accepted socket. We need
to drop the lock on the old socket and grab the lock on the new one.
A more proper solution might be to create accepted sockets when
the new association is established, similar to TCP. That would
eliminate the race for 1-to-1 style sockets, but it would still
existing for 1-to-many sockets where a user wished to peeloff an
association. For now, we'll live with this easy solution as
it addresses the problem.
Reported-by: Michal Hocko <mhocko@suse.cz>
Reported-by: Karsten Keil <kkeil@suse.de>
[ Upstream commit: 9fcb95a105758b81ef0131cd18e2db5149f13e95 ]
If FWD-TSN chunk is received with bad stream ID, the sctp will not do the
validity check, this may cause memory overflow when overwrite the TSN of
the stream ID.
The FORWARD-TSN chunk is like this:
FORWARD-TSN chunk
Type = 192
Flags = 0
Length = 172
NewTSN = 99
Stream = 10000
StreamSequence = 0xFFFF
This patch fix this problem by discard the chunk if stream ID is not
less than MIS.
Since call to function sctp_sf_abort_violation() need paramter 'arg' with
'struct sctp_chunk' type, it will read the chunk type and chunk length from
the chunk_hdr member of chunk. But call to sctp_sf_violation_paramlen()
always with 'struct sctp_paramhdr' type's parameter, it will be passed to
sctp_sf_abort_violation(). This may cause kernel panic.
|-- sctp_sf_abort_violation()
|-- sctp_make_abort_violation()
This patch fixed this problem. This patch also fix two place which called
sctp_sf_violation_paramlen() with wrong paramter type.
If INIT-ACK is received with SupportedExtensions parameter which
indicates that the peer does not support AUTH, the packet will be
silently ignore, and sctp_process_init() do cleanup all of the
transports in the association.
When T1-Init timer is expires, OOPS happen while we try to choose
a different init transport.
The solution is to only clean up the non-active transports, i.e
the ones that the peer added. However, that introduces a problem
with sctp_connectx(), because we don't mark the proper state for
the transports provided by the user. So, we'll simply mark
user-provided transports as ACTIVE. That will allow INIT
retransmissions to work properly in the sctp_connectx() context
and prevent the crash.
Do not enable peer features like addip and auth, if they
are administratively disabled localy. If the peer resports
that he supports something that we don't, neither end can
use it so enabling it is pointless. This solves a problem
when talking to a peer that has auth and addip enabled while
we do not. Found by Andrei Pelinescu-Onciul <andrei@iptel.org>.
Loopback used to clobber the ip_summed filed which sctp then used
to figure out if it needed to do checksumming or not. Now that
loopback doesn't do that any more, sctp needs to set the ip_summed
field correctly.
The number of identifiers needs to be checked against the option
length. Also, the identifier index provided needs to be verified
to make sure that it doesn't exceed the bounds of the array.
The bonds check to prevent buffer overlflow was not exactly
right. It still allowed overflow of up to 8 bytes which is
sizeof(struct sctp_authkey).
Since optlen is already checked against the size of that struct,
we are guaranteed not to cause interger overflow either.
The structure used for SCTP_AUTH_KEY option contains a
length that needs to be verfied to prevent buffer overflow
conditions. Spoted by Eugene Teo <eteo@redhat.com>.
All of the SCTP-AUTH socket options could cause a panic
if the extension is disabled and the API is envoked.
Additionally, there were some additional assumptions that
certain pointers would always be valid which may not
always be the case.
This patch hardens the API and address all of the crash
scenarios.
ipv6_dev_get_saddr()
ipv6_dev_get_saddr() blindly de-references dst_dev to get the network
namespace, but some callers might pass NULL. Change callers to pass a
namespace pointer instead.
Signed-off-by: Brian Haley <brian.haley@hp.com>
The ipfragok flag controls whether the packet may be fragmented
either on the local host on beyond. The latter is only valid on
IPv4.
In fact, we never want to do the latter even on IPv4 when PMTU is
enabled. This is because even though we can't fragment packets
within SCTP due to the prtocol's inherent faults, we can still
fragment it at IP layer. By setting the DF bit we will improve
the PMTU process.
RFC 2960 only says that we SHOULD clear the DF bit in this case,
so we're compliant even if we set the DF bit. In fact RFC 4960
no longer has this statement.
Once we make this change, we only need to control the local
fragmentation. There is already a bit in the skb which controls
that, local_df. So this patch sets that instead of using the
ipfragok argument.
The only complication is that there isn't a struct sock object
per transport, so for IPv4 we have to resort to changing the
pmtudisc field for every packet. This should be safe though
as the protocol is single-threaded.
Note that after this patch we can remove ipfragok from the rest
of the stack too.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
netns: fix ip_rt_frag_needed rt_is_expired
netfilter: nf_conntrack_extend: avoid unnecessary "ct->ext" dereferences
netfilter: fix double-free and use-after free
netfilter: arptables in netns for real
netfilter: ip{,6}tables_security: fix future section mismatch
selinux: use nf_register_hooks()
netfilter: ebtables: use nf_register_hooks()
Revert "pkt_sched: sch_sfq: dump a real number of flows"
qeth: use dev->ml_priv instead of dev->priv
syncookies: Make sure ECN is disabled
net: drop unused BUG_TRAP()
net: convert BUG_TRAP to generic WARN_ON
drivers/net: convert BUG_TRAP to generic WARN_ON
Removes legacy reinvent-the-wheel type thing. The generic
machinery integrates much better to automated debugging aids
such as kerneloops.org (and others), and is unambiguous due to
better naming. Non-intuively BUG_TRAP() is actually equal to
WARN_ON() rather than BUG_ON() though some might actually be
promoted to BUG_ON() but I left that to future.
I could make at least one BUILD_BUG_ON conversion.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
This patch adds support for flag values which are ORed to the type passwd
to socket and socketpair. The additional code is minimal. The flag
values in this implementation can and must match the O_* flags. This
avoids overhead in the conversion.
The internal functions sock_alloc_fd and sock_map_fd get a new parameters
and all callers are changed.
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#include <netinet/in.h>
#include <sys/socket.h>
#define PORT 57392
/* For Linux these must be the same. */
#define SOCK_CLOEXEC O_CLOEXEC
int
main (void)
int fd;
fd = socket (PF_INET, SOCK_STREAM, 0);
if (fd == -1)
puts ("socket(0) failed");
return 1;
int coe = fcntl (fd, F_GETFD);
if (coe == -1)
puts ("fcntl failed");
return 1;
if (coe & FD_CLOEXEC)
puts ("socket(0) set close-on-exec flag");
return 1;
close (fd);
fd = socket (PF_INET, SOCK_STREAM|SOCK_CLOEXEC, 0);
if (fd == -1)
puts ("socket(SOCK_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
if ((coe & FD_CLOEXEC) == 0)
puts ("socket(SOCK_CLOEXEC) does not set close-on-exec flag");
return 1;
close (fd);
int fds[2];
if (socketpair (PF_UNIX, SOCK_STREAM, 0, fds) == -1)
puts ("socketpair(0) failed");
return 1;
for (int i = 0; i < 2; ++i)
coe = fcntl (fds[i], F_GETFD);
if (coe == -1)
return 1;
printf ("socketpair(0) set close-on-exec flag for fds[%d]\n", i);
return 1;
close (fds[i]);
if (socketpair (PF_UNIX, SOCK_STREAM|SOCK_CLOEXEC, 0, fds) == -1)
puts ("socketpair(SOCK_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
printf ("socketpair(SOCK_CLOEXEC) does not set close-on-exec flag for fds[%d]\n", i);
return 1;
close (fds[i]);
puts ("OK");
return 0;
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Acked-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Commit 20c2c1fd6c842caf70dcb1d94b9d58861949fd3d
(sctp: add sctp/remaddr table to complete RFC remote address table OID)
added an unused sctp_assoc_proc_exit() function that seems to have been
unintentionally created when copying the assocs code.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
sctp_outq_flush() can now become static.
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Update sctp global memory limit allocations to be the same as TCP.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
When multiple socket bind to the same port with SO_REUSEADDR,
only 1 can be listining.
SCTP permits multiple listen call and on subsequent calls
we leak he memory allocated for the crypto transforms.
valgrind reports uninizialized memory accesses when running
sctp inside the network simulation cradle simulator:
Conditional jump or move depends on uninitialised value(s)
at 0x570E34A: sctp_assoc_sync_pmtu (associola.c:1324)
by 0x57427DA: sctp_packet_transmit (output.c:403)
by 0x5710EFF: sctp_outq_flush (outqueue.c:824)
by 0x5710B88: sctp_outq_uncork (outqueue.c:701)
by 0x5745262: sctp_cmd_interpreter (sm_sideeffect.c:1548)
by 0x57444B7: sctp_side_effects (sm_sideeffect.c:976)
by 0x5744460: sctp_do_sm (sm_sideeffect.c:945)
by 0x572157D: sctp_primitive_ASSOCIATE (primitive.c:94)
by 0x5725C04: __sctp_connect (socket.c:1094)
by 0x57297DC: sctp_connect (socket.c:3297)
at 0x575D3A5: mod_timer (timer.c:630)
by 0x5752B78: sctp_cmd_hb_timers_start (sm_sideeffect.c:555)
by 0x5754133: sctp_cmd_interpreter (sm_sideeffect.c:1448)
by 0x5753607: sctp_side_effects (sm_sideeffect.c:976)
by 0x57535B0: sctp_do_sm (sm_sideeffect.c:945)
by 0x571E9AE: sctp_endpoint_bh_rcv (endpointola.c:474)
by 0x573347F: sctp_inq_push (inqueue.c:104)
by 0x572EF93: sctp_rcv (input.c:256)
by 0x5689623: ip_local_deliver_finish (ip_input.c:230)
by 0x5689759: ip_local_deliver (ip_input.c:268)
by 0x5689CAC: ip_rcv_finish (dst.h:246)
#1 is due to "if (t->pmtu_pending)".
8a4794914f9cf2681235ec2311e189fe307c28c7 "[SCTP] Flag a pmtu change request"
suggests it should be initialized to 0.
#2 is the heartbeat timer 'expires' value, which is uninizialised, but
test by mod_timer().
T3_rtx_timer seems to be affected by the same problem, so initialize it, too.
This puts CONFIG_PROC_FS defines around the proc init/exit functions
and also avoids compiling proc.c if procfs is not supported.
Also make SCTP_DBG_OBJCNT depend on procfs.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
The tcp_enter_memory_pressure calls NET_INC_STATS, but doesn't
have where to get the net from.
I decided to add a sk argument, not the net itself, only to factor
all the required sock_net(sk) calls inside the enter_memory_pressure
callback itself.
drivers/net/wireless/iwlwifi/iwl-3945.c
net/mac80211/mlme.c
If we don't have the buffer space or memory allocations fail,
the data chunk is dropped, but TSN is still reported as received.
This introduced a data loss that can't be recovered. We should
only mark TSNs are received after memory allocations finish.
The one exception is the invalid stream identifier, but that's
due to user error and is reported back to the user.
This was noticed by Michael Tuexen.
Socket options SCTP_GET_PEER_ADDR_OLD, SCTP_GET_PEER_ADDR_NUM_OLD,
SCTP_GET_LOCAL_ADDR_OLD, and SCTP_GET_PEER_LOCAL_ADDR_NUM_OLD
have been replaced by newer versions a since 2005. It's time
to officially deprecate them and schedule them for removal.
drivers/net/wireless/iwlwifi/iwl4965-base.c
As noticed by Gabriel Campana, the kmalloc() length arg
passed in by sctp_getsockopt_local_addrs_old() can overflow
if ->addr_num is large enough.
Therefore, enforce an appropriate limit.
RFC 4960, Section 11.4. Protection of Non-SCTP-Capable Hosts
When an SCTP stack receives a packet containing multiple control or
DATA chunks and the processing of the packet requires the sending of
multiple chunks in response, the sender of the response chunk(s) MUST
NOT send more than one packet. If bundling is supported, multiple
response chunks that fit into a single packet MAY be bundled together
into one single response packet. If bundling is not supported, then
the sender MUST NOT send more than one response chunk and MUST
discard all other responses. Note that this rule does NOT apply to a
SACK chunk, since a SACK chunk is, in itself, a response to DATA and
a SACK does not require a response of more DATA.
We implement this by not servicing our outqueue until we reach the end
of the packet. This enables maximum bundling. We also identify
'response' chunks and make sure that we only send 1 packet when sending
such chunks.
This patch add to validate initiate tag and chunk type if verification
tag is 0 when handling ICMP message.
RFC 4960, Appendix C. ICMP Handling
ICMP6) An implementation MUST validate that the Verification Tag
contained in the ICMP message matches the Verification Tag of the peer.
If the Verification Tag is not 0 and does NOT match, discard the ICMP
message. If it is 0 and the ICMP message contains enough bytes to
verify that the chunk type is an INIT chunk and that the Initiate Tag
matches the tag of the peer, continue with ICMP7. If the ICMP message
is too short or the chunk type or the Initiate Tag does not match,
silently discard the packet.
After the sctp_remaddr_proc_init failed, the proper rollback is
not the sctp_remaddr_proc_exit, but the sctp_assocs_proc_exit.
drivers/net/wireless/rt2x00/Kconfig
drivers/net/wireless/rt2x00/rt2x00usb.c
net/sctp/protocol.c
Right now, any time we set a primary transport we set
the changeover_active flag. As a result, we invoke SFR-CACC
even when there has been no changeover events.
Only set changeover_active, when there is a true changeover
event, i.e. we had a primary path and we are changing to
another transport.
This patch remove the proc fs entry which has been created if fail to
set up proc fs entry for the SCTP protocol.
Change struct proto destroy function pointer to return void. Noticed
by Al Viro.
drivers/net/tg3.c
drivers/net/wireless/rt2x00/rt2x00dev.c
net/mac80211/ieee80211_i.h
The default sack frequency should be 2. Also fix copy/paste
error when updating all transports.
Commit e9df2e8fd8fbc95c57dbd1d33dada66c4627b44c ("[IPV6]: Use
appropriate sock tclass setting for routing lookup.") also changed the
way that ECN capable transports mark this capability in IPv6. As a
result, SCTP was not marking ECN capablity because the traffic class
was never set. This patch brings back the markings for IPv6 traffic.
