path: root/net/socket.c
2012-10-26cgroup: net_cls: Rework update socket logicDaniel Wagner
The cgroup logic part of net_cls is very similar as the one in net_prio. Let's stream line the net_cls logic with the net_prio one. The net_prio update logic was changed by following commit (note there were some changes necessary later on) commit 406a3c638ce8b17d9704052c07955490f732c2b8 Author: John Fastabend <john.r.fastabend@intel.com> Date: Fri Jul 20 10:39:25 2012 +0000 net: netprio_cgroup: rework update socket logic Instead of updating the sk_cgrp_prioidx struct field on every send this only updates the field when a task is moved via cgroup infrastructure. This allows sockets that may be used by a kernel worker thread to be managed. For example in the iscsi case today a user can put iscsid in a netprio cgroup and control traffic will be sent with the correct sk_cgrp_prioidx value set but as soon as data is sent the kernel worker thread isssues a send and sk_cgrp_prioidx is updated with the kernel worker threads value which is the default case. It seems more correct to only update the field when the user explicitly sets it via control group infrastructure. This allows the users to manage sockets that may be used with other threads. Since classid is now updated when the task is moved between the cgroups, we don't have to call sock_update_classid() from various places to ensure we always using the latest classid value. [v2: Use iterate_fd() instead of open coding] Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Li Zefan <lizefan@huawei.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: Joe Perches <joe@perches.com> Cc: John Fastabend <john.r.fastabend@intel.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: <netdev@vger.kernel.org> Cc: <cgroups@vger.kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-26cgroup: net_cls: Pass in task to sock_update_classid()Daniel Wagner
sock_update_classid() assumes that the update operation always are applied on the current task. sock_update_classid() needs to know on which tasks to work on in order to be able to migrate task between cgroups using the struct cgroup_subsys attach() callback. Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Joe Perches <joe@perches.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: <netdev@vger.kernel.org> Cc: <cgroups@vger.kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-09-27net: remove sk_init() helperEric Dumazet
It seems sk_init() has no value today and even does strange things : # grep . /proc/sys/net/core/?mem_* /proc/sys/net/core/rmem_default:212992 /proc/sys/net/core/rmem_max:131071 /proc/sys/net/core/wmem_default:212992 /proc/sys/net/core/wmem_max:131071 We can remove it completely. Signed-off-by: Eric Dumazet <edumazet@google.com> Reviewed-by: Shan Wei <davidshan@tencent.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-26unexport sock_map_fd(), switch to sock_alloc_file()Al Viro
Both modular callers of sock_map_fd() had been buggy; sctp one leaks descriptor and file if copy_to_user() fails, 9p one shouldn't be exposing file in the descriptor table at all. Switch both to sock_alloc_file(), export it, unexport sock_map_fd() and make it static. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26take descriptor handling from sock_alloc_file() to callersAl Viro
2012-09-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/netfilter/nfnetlink_log.c net/netfilter/xt_LOG.c Rather easy conflict resolution, the 'net' tree had bug fixes to make sure we checked if a socket is a time-wait one or not and elide the logging code if so. Whereas on the 'net-next' side we are calculating the UID and GID from the creds using different interfaces due to the user namespace changes from Eric Biederman. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-05Fix order of arguments to compat_put_time[spec|val]Mikulas Patocka
Commit 644595f89620 ("compat: Handle COMPAT_USE_64BIT_TIME in net/socket.c") introduced a bug where the helper functions to take either a 64-bit or compat time[spec|val] got the arguments in the wrong order, passing the kernel stack pointer off as a user pointer (and vice versa). Because of the user address range check, that in turn then causes an EFAULT due to the user pointer range checking failing for the kernel address. Incorrectly resuling in a failed system call for 32-bit processes with a 64-bit kernel. On odder architectures like HP-PA (with separate user/kernel address spaces), it can be used read kernel memory. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-04net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd ↵Masatake YAMATO
entries lsof reports some of socket descriptors as "can't identify protocol" like: [yamato@localhost]/tmp% sudo lsof | grep dbus | grep iden dbus-daem 652 dbus 6u sock ... 17812 can't identify protocol dbus-daem 652 dbus 34u sock ... 24689 can't identify protocol dbus-daem 652 dbus 42u sock ... 24739 can't identify protocol dbus-daem 652 dbus 48u sock ... 22329 can't identify protocol ... lsof cannot resolve the protocol used in a socket because procfs doesn't provide the map between inode number on sockfs and protocol type of the socket. For improving the situation this patch adds an extended attribute named 'system.sockprotoname' in which the protocol name for /proc/PID/fd/SOCKET is stored. So lsof can know the protocol for a given /proc/PID/fd/SOCKET with getxattr system call. A few weeks ago I submitted a patch for the same purpose. The patch was introduced /proc/net/sockfs which enumerates inodes and protocols of all sockets alive on a system. However, it was rejected because (1) a global lock was needed, and (2) the layout of struct socket was changed with the patch. This patch doesn't use any global lock; and doesn't change the layout of any structs. In this patch, a protocol name is stored to dentry->d_name of sockfs when new socket is associated with a file descriptor. Before this patch dentry->d_name was not used; it was just filled with empty string. lsof may use an extended attribute named 'system.sockprotoname' to retrieve the value of dentry->d_name. It is nice if we can see the protocol name with ls -l /proc/PID/fd. However, "socket:[#INODE]", the name format returned from sockfs_dname() was already defined. To keep the compatibility between kernel and user land, the extended attribute is used to prepare the value of dentry->d_name. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-15net: fix info leak in compat dev_ifconf()Mathias Krause
The implementation of dev_ifconf() for the compat ioctl interface uses an intermediate ifc structure allocated in userland for the duration of the syscall. Though, it fails to initialize the padding bytes inserted for alignment and that for leaks four bytes of kernel stack. Add an explicit memset(0) before filling the structure to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22net: netprio_cgroup: rework update socket logicJohn Fastabend
Instead of updating the sk_cgrp_prioidx struct field on every send this only updates the field when a task is moved via cgroup infrastructure. This allows sockets that may be used by a kernel worker thread to be managed. For example in the iscsi case today a user can put iscsid in a netprio cgroup and control traffic will be sent with the correct sk_cgrp_prioidx value set but as soon as data is sent the kernel worker thread isssues a send and sk_cgrp_prioidx is updated with the kernel worker threads value which is the default case. It seems more correct to only update the field when the user explicitly sets it via control group infrastructure. This allows the users to manage sockets that may be used with other threads. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-20tun: fix a crash bug and a memory leakMikulas Patocka
This patch fixes a crash tun_chr_close -> netdev_run_todo -> tun_free_netdev -> sk_release_kernel -> sock_release -> iput(SOCK_INODE(sock)) introduced by commit 1ab5ecb90cb6a3df1476e052f76a6e8f6511cb3d The problem is that this socket is embedded in struct tun_struct, it has no inode, iput is called on invalid inode, which modifies invalid memory and optionally causes a crash. sock_release also decrements sockets_in_use, this causes a bug that "sockets: used" field in /proc/*/net/sockstat keeps on decreasing when creating and closing tun devices. This patch introduces a flag SOCK_EXTERNALLY_ALLOCATED that instructs sock_release to not free the inode and not decrement sockets_in_use, fixing both memory corruption and sockets_in_use underflow. It should be backported to 3.3 an 3.4 stabke. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-22Merge branch 'for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: "Contains Alex Shi's three patches to remove percpu_xxx() which overlap with this_cpu_xxx(). There shouldn't be any functional change." * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: remove percpu_xxx() functions x86: replace percpu_xxx funcs with this_cpu_xxx net: replace percpu_xxx funcs with this_cpu_xxx or __this_cpu_xxx
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-14net: replace percpu_xxx funcs with this_cpu_xxx or __this_cpu_xxxAlex Shi
percpu_xxx funcs are duplicated with this_cpu_xxx funcs, so replace them for further code clean up. And in preempt safe scenario, __this_cpu_xxx funcs may has a bit better performance since __this_cpu_xxx has no redundant preempt_enable/preempt_disable on some architectures. Signed-off-by: Alex Shi <alex.shi@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-21net: change big iov allocationsEric Dumazet
iov of more than 8 entries are allocated in sendmsg()/recvmsg() through sock_kmalloc() As these allocations are temporary only and small enough, it makes sense to use plain kmalloc() and avoid sk_omem_alloc atomic overhead. Slightly changed fast path to be even faster. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Mike Waychison <mikew@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net sysctl: Initialize the network sysctls sooner to avoid problems.Eric W. Biederman
If the netfilter code is modified to use register_net_sysctl_table the kernel fails to boot because the per net sysctl infrasturce is not setup soon enough. So to avoid races call net_sysctl_init from sock_init(). Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-05tcp: tcp_sendpages() should call tcp_push() onceEric Dumazet
commit 2f533844242 (tcp: allow splice() to build full TSO packets) added a regression for splice() calls using SPLICE_F_MORE. We need to call tcp_flush() at the end of the last page processed in tcp_sendpages(), or else transmits can be deferred and future sends stall. Add a new internal flag, MSG_SENDPAGE_NOTLAST, acting like MSG_MORE, but with different semantic. For all sendpage() providers, its a transparent change. Only sock_sendpage() and tcp_sendpages() can differentiate the two different flags provided by pipe_to_sendpage() Reported-by: Tom Herbert <therbert@google.com> Cc: Nandita Dukkipati <nanditad@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: H.K. Jerry Chu <hkchu@google.com> Cc: Maciej Żenczykowski <maze@google.com> Cc: Mahesh Bandewar <maheshb@google.com> Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Eric Dumazet <eric.dumazet@gmail>com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-11net: get rid of some pointless casts to sockaddrMaciej Żenczykowski
The following 4 functions: move_addr_to_kernel move_addr_to_user verify_iovec verify_compat_iovec are always effectively called with a sockaddr_storage. Make this explicit by changing their signature. This removes a large number of casts from sockaddr_storage to sockaddr. Signed-off-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-20compat: Handle COMPAT_USE_64BIT_TIME in net/socket.cH. Peter Anvin
Use helper functions aware of COMPAT_USE_64BIT_TIME to write struct timeval and struct timespec to userspace in net/socket.c. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-01-12net: reintroduce missing rcu_assign_pointer() callsEric Dumazet
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTER) did a lot of incorrect changes, since it did a complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x, y). We miss needed barriers, even on x86, when y is not NULL. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits) net: pack skb_shared_info more efficiently net_sched: red: split red_parms into parms and vars net_sched: sfq: extend limits cnic: Improve error recovery on bnx2x devices cnic: Re-init dev->stats_addr after chip reset net_sched: Bug in netem reordering bna: fix sparse warnings/errors bna: make ethtool_ops and strings const xgmac: cleanups net: make ethtool_ops const vmxnet3" make ethtool ops const xen-netback: make ops structs const virtio_net: Pass gfp flags when allocating rx buffers. ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call igb: reset PHY after recovering from PHY power down igb: add basic runtime PM support igb: Add support for byte queue limits. e1000: cleanup CE4100 MDIO registers access e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove ...
2012-01-05vfs: fix up ENOIOCTLCMD error handlingLinus Torvalds
We're doing some odd things there, which already messes up various users (see the net/socket.c code that this removes), and it was going to add yet more crud to the block layer because of the incorrect error code translation. ENOIOCTLCMD is not an error return that should be returned to user mode from the "ioctl()" system call, but it should *not* be translated as EINVAL ("Invalid argument"). It should be translated as ENOTTY ("Inappropriate ioctl for device"). That EINVAL confusion has apparently so permeated some code that the block layer actually checks for it, which is sad. We continue to do so for now, but add a big comment about how wrong that is, and we should remove it entirely eventually. In the meantime, this tries to keep the changes localized to just the EINVAL -> ENOTTY fix, and removing code that makes it harder to do the right thing. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-04ethtool: Allow drivers to select RX NFC rule locationsBen Hutchings
Define special location values for RX NFC that request the driver to select the actual rule location. This allows for implementation on devices that use hash-based filter lookup, whereas currently the API is more suited to devices with TCAM lookup or linear search. In ethtool_set_rxnfc() and the compat wrapper ethtool_ioctl(), copy the structure back to user-space after insertion so that the actual location is returned. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22net: add network priority cgroup infrastructure (v4)Neil Horman
This patch adds in the infrastructure code to create the network priority cgroup. The cgroup, in addition to the standard processes file creates two control files: 1) prioidx - This is a read-only file that exports the index of this cgroup. This is a value that is both arbitrary and unique to a cgroup in this subsystem, and is used to index the per-device priority map 2) priomap - This is a writeable file. On read it reports a table of 2-tuples <name:priority> where name is the name of a network interface and priority is indicates the priority assigned to frames egresessing on the named interface and originating from a pid in this cgroup This cgroup allows for skb priority to be set prior to a root qdisc getting selected. This is benenficial for DCB enabled systems, in that it allows for any application to use dcb configured priorities so without application modification Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> CC: Robert Love <robert.w.love@intel.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-09net: add wireless TX status socket optionJohannes Berg
The 802.1X EAPOL handshake hostapd does requires knowing whether the frame was ack'ed by the peer. Currently, we fudge this pretty badly by not even transmitting the frame as a normal data frame but injecting it with radiotap and getting the status out of radiotap monitor as well. This is rather complex, confuses users (mon.wlan0 presence) and doesn't work with all hardware. To get rid of that hack, introduce a real wifi TX status option for data frame transmissions. This works similar to the existing TX timestamping in that it reflects the SKB back to the socket's error queue with a SCM_WIFI_STATUS cmsg that has an int indicating ACK status (0/1). Since it is possible that at some point we will want to have TX timestamping and wifi status in a single errqueue SKB (there's little point in not doing that), redefine SO_EE_ORIGIN_TIMESTAMPING to SO_EE_ORIGIN_TXSTATUS which can collect more than just the timestamp; keep the old constant as an alias of course. Currently the internal APIs don't make that possible, but it wouldn't be hard to split them up in a way that makes it possible. Thanks to Neil Horman for helping me figure out the functions that add the control messages. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-08-24sendmmsg/sendmsg: fix unsafe user pointer accessMathieu Desnoyers
Dereferencing a user pointer directly from kernel-space without going through the copy_from_user family of functions is a bad idea. Two of such usages can be found in the sendmsg code path called from sendmmsg, added by commit c71d8ebe7a4496fb7231151cb70a6baa0cb56f9a upstream. commit 5b47b8038f183b44d2d8ff1c7d11a5c1be706b34 in the 3.0-stable tree. Usages are performed through memcmp() and memcpy() directly. Fix those by using the already copied msg_sys structure instead of the __user *msg structure. Note that msg_sys can be set to NULL by verify_compat_iovec() or verify_iovec(), which requires additional NULL pointer checks. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: David Goulet <dgoulet@ev0ke.net> CC: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> CC: Anton Blanchard <anton@samba.org> CC: David S. Miller <davem@davemloft.net> CC: stable <stable@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07Merge branch 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-08-05net: Fix security_socket_sendmsg() bypass problem.Tetsuo Handa
The sendmmsg() introduced by commit 228e548e "net: Add sendmmsg socket system call" is capable of sending to multiple different destination addresses. SMACK is using destination's address for checking sendmsg() permission. However, security_socket_sendmsg() is called for only once even if multiple different destination addresses are passed to sendmmsg(). Therefore, we need to call security_socket_sendmsg() for each destination address rather than only the first destination address. Since calling security_socket_sendmsg() every time when only single destination address was passed to sendmmsg() is a waste of time, omit calling security_socket_sendmsg() unless destination address of previous datagram and that of current datagram differs. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Anton Blanchard <anton@samba.org> Cc: stable <stable@kernel.org> [3.0+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05net: Cap number of elements for sendmmsgAnton Blanchard
To limit the amount of time we can spend in sendmmsg, cap the number of elements to UIO_MAXIOV (currently 1024). For error handling an application using sendmmsg needs to retry at the first unsent message, so capping is simpler and requires less application logic than returning EINVAL. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable <stable@kernel.org> [3.0+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05net: sendmmsg should only return an error if no messages were sentAnton Blanchard
sendmmsg uses a similar error return strategy as recvmmsg but it turns out to be a confusing way to communicate errors. The current code stores the error code away and returns it on the next sendmmsg call. This means a call with completely valid arguments could get an error from a previous call. Change things so we only return an error if no datagrams could be sent. If less than the requested number of messages were sent, the application must retry starting at the first failed one and if the problem is persistent the error will be returned. This matches the behaviour of other syscalls like read/write - it is not an error if less than the requested number of elements are sent. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable <stable@kernel.org> [3.0+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) tg3: Remove 5719 jumbo frames and TSO blocks tg3: Break larger frags into 4k chunks for 5719 tg3: Add tx BD budgeting code tg3: Consolidate code that calls tg3_tx_set_bd() tg3: Add partial fragment unmapping code tg3: Generalize tg3_skb_error_unmap() tg3: Remove short DMA check for 1st fragment tg3: Simplify tx bd assignments tg3: Reintroduce tg3_tx_ring_info ASIX: Use only 11 bits of header for data size ASIX: Simplify condition in rx_fixup() Fix cdc-phonet build bonding: reduce noise during init bonding: fix string comparison errors net: Audit drivers to identify those needing IFF_TX_SKB_SHARING cleared net: add IFF_SKB_TX_SHARED flag to priv_flags net: sock_sendmsg_nosec() is static forcedeth: fix vlans gianfar: fix bug caused by 87c288c6e9aa31720b72e2bc2d665e24e1653c3e gro: Only reset frag0 when skb can be pulled ...
2011-07-27net: sock_sendmsg_nosec() is staticEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26vfs: dont chain pipe/anon/socket on superblock s_inodes listEric Dumazet
Workloads using pipes and sockets hit inode_sb_list_lock contention. superblock s_inodes list is needed for quota, dirty, pagecache and fsnotify management. pipe/anon/socket fs are clearly not candidates for these. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/vmxnet3/vmxnet3_ethtool.c net/core/dev.c
2011-05-17net: recvmmsg: Strip MSG_WAITFORONE when calling recvmsgAnton Blanchard
recvmmsg fails on a raw socket with EINVAL. The reason for this is packet_recvmsg checks the incoming flags: err = -EINVAL; if (flags & ~(MSG_PEEK|MSG_DONTWAIT|MSG_TRUNC|MSG_CMSG_COMPAT|MSG_ERRQUEUE)) goto out; This patch strips out MSG_WAITFORONE when calling recvmmsg which fixes the issue. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable@kernel.org [2.6.34+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-07net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()Lai Jiangshan
The rcu callback wq_free_rcu() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(wq_free_rcu). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05net: Add sendmmsg socket system callAnton Blanchard
This patch adds a multiple message send syscall and is the send version of the existing recvmmsg syscall. This is heavily based on the patch by Arnaldo that added recvmmsg. I wrote a microbenchmark to test the performance gains of using this new syscall: http://ozlabs.org/~anton/junkcode/sendmmsg_test.c The test was run on a ppc64 box with a 10 Gbit network card. The benchmark can send both UDP and RAW ethernet packets. 64B UDP batch pkts/sec 1 804570 2 872800 (+ 8 %) 4 916556 (+14 %) 8 939712 (+17 %) 16 952688 (+18 %) 32 956448 (+19 %) 64 964800 (+20 %) 64B raw socket batch pkts/sec 1 1201449 2 1350028 (+12 %) 4 1461416 (+22 %) 8 1513080 (+26 %) 16 1541216 (+28 %) 32 1553440 (+29 %) 64 1557888 (+30 %) We see a 20% improvement in throughput on UDP send and 30% on raw socket send. [ Add sparc syscall entries. -DaveM ] Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-11v3 ethtool: add ntuple flow specifier data to network flow classifierAlexander Duyck
This change is meant to add an ntuple data extensions to the rx network flow classification specifiers. The idea is to allow ntuple to be displayed via the network flow classification interface. The first patch had some left over stuff from the original flow extension flags I had added. That bit is removed in this patch. The second had some left over comments that stated we ignored bits in the masks when we actually match them. This work is based on input from Ben Hutchings. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18ethtool: Compat handling for struct ethtool_rxnfcBen Hutchings
This structure was accidentally defined such that its layout can differ between 32-bit and 64-bit processes. Add compat structure definitions and an ioctl wrapper function. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Alexander Duyck <alexander.h.duyck@intel.com> Cc: stable@kernel.org [2.6.30+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23socket: suppress sparse warningsstephen hemminger
Use __force to quiet sparse warnings for cases where the code is simulating user space pointers. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22net: add __rcu annotations to sk_wq and wqEric Dumazet
Add proper RCU annotations/verbs to sk_wq and wq members Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access) Fix sunrpc sk_sleep() abuse too Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-12pass default dentry_operations to mount_pseudo()Al Viro
