[ Upstream commit 5a4753446253a427c0ff1e433b9c4933e5af207c ]
The failure case here should be rare, but it's obviously wrong.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
[ Upstream commit 0ddc942394013f08992fc379ca04cffacbbe3dae ]
I think this is unlikely but possible:
svc_authenticate sets rq_authop and calls svcauth_gss_accept. The
kmalloc(sizeof(*svcdata), GFP_KERNEL) fails, leaving rq_auth_data NULL,
and returning SVC_DENIED.
This causes svc_process_common to go to err_bad_auth, and eventually
call svc_authorise. That calls ->release == svcauth_gss_release, which
tries to dereference rq_auth_data.
Link: https://lore.kernel.org/linux-nfs/3F1B347F-B809-478F-A1E9-0BE98E22B0F0@oracle.com/T/#t
commit 24c5efe41c29ee3e55bcf5a1c9f61ca8709622e8 upstream.
gss_mech_register() calls svcauth_gss_register_pseudoflavor() for each
flavour, but gss_mech_unregister() does not call auth_domain_put().
This is unbalanced and makes it impossible to reload the module.
Change svcauth_gss_register_pseudoflavor() to return the registered
auth_domain, and save it for later release.
Cc: stable@vger.kernel.org (v2.6.12+)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=206651
Signed-off-by: NeilBrown <neilb@suse.de>
commit d47a5dc2888fd1b94adf1553068b8dad76cec96c upstream.
There is no valid case for supporting duplicate pseudoflavor
registrations.
Currently the silent acceptance of such registrations is hiding a bug.
The rpcsec_gss_krb5 module registers 2 flavours but does not unregister
them, so if you load, unload, reload the module, it will happily
continue to use the old registration which now has pointers to the
memory were the module was originally loaded. This could lead to
unexpected results.
So disallow duplicate registrations.
commit 3d96208c30f84d6edf9ab4fac813306ac0d20c10 upstream.
When upcalling gssproxy, cache_head.expiry_time is set as a
timeval, not seconds since boot. As such, RPC cache expiry
logic will not clean expired objects created under
auth.rpcsec.context cache.
This has proven to cause kernel memory leaks on field. Using
64 bit variants of getboottime/timespec
Expiration times have worked this way since 2010's c5b29f885afe "sunrpc:
use seconds since boot in expiry cache". The gssproxy code introduced
in 2012 added gss_proxy_save_rsc and introduced the bug. That's a while
for this to lurk, but it required a bit of an extreme case to make it
obvious.
Signed-off-by: Roberto Bergantinos Corpas <rbergant@redhat.com>
Fixes: 030d794bf498 "SUNRPC: Use gssproxy upcall for server..."
Tested-By: Frank Sorenson <sorenson@redhat.com>
commit b8be5674fa9a6f3677865ea93f7803c4212f3e10 upstream.
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
Cc: <stable@vger.kernel.org>
commit 78794d1890708cf94e3961261e52dcec2cc34722 upstream.
Context expiry times are in units of seconds since boot, not unix time.
The use of get_seconds() here therefore sets the expiry time decades in
the future. This prevents timely freeing of contexts destroyed by
client RPC_GSS_PROC_DESTROY requests. We'd still free them eventually
(when the module is unloaded or the container shut down), but a lot of
contexts could pile up before then.
Fixes: c5b29f885afe "sunrpc: use seconds since boot in expiry cache"
Reported-by: Andy Adamson <andros@netapp.com>
commit c0cb8bf3a8e4bd82e640862cdd8891400405cb89 upstream.
The length of the GSS MIC token need not be a multiple of four bytes.
It is then padded by XDR to a multiple of 4 B, but unwrap_integ_data()
would previously only trim mic.len + 4 B. The remaining up to three
bytes would then trigger a check in nfs4svc_decode_compoundargs(),
leading to a "garbage args" error and mount failure:
nfs4svc_decode_compoundargs: compound not properly padded!
nfsd: failed to decode arguments!
This would prevent older clients using the pre-RFC 4121 MIC format
(37-byte MIC including a 9-byte OID) from mounting exports from v3.9+
servers using krb5i.
The trimming was introduced by commit 4c190e2f913f ("sunrpc: trim off
trailing checksum before returning decrypted or integrity authenticated
buffer").
Fixes: 4c190e2f913f "unrpc: trim off trailing checksum..."
Signed-off-by: Tomáš Trnka <ttrnka@mail.muni.cz>
Acked-by: Jeff Layton <jlayton@poochiereds.net>
If we call groups_alloc() with invalid values then it's might lead to
memory corruption. For example, with a negative value then we might not
allocate enough for sizeof(struct group_info).
(We're doing this in the caller for consistency with other callers of
groups_alloc(). The other alternative might be to move the check out of
all the callers into groups_alloc().)
Reviewed-by: Simo Sorce <simo@redhat.com>
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
It's always set to whatever CONFIG_SUNRPC_DEBUG is, so just use that.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
rq_usedeferral and rq_splice_ok are used as 0 and 1, just defined to bool.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
RPC_MAX_AUTH_SIZE is scattered around several places. Better to set it
once in the auth code, where this kind of estimate should be made. And
while we're at it we can leave it zero when we're not using krb5i or
krb5p.
We can achieve the same result with a cmpxchg(). This also fixes a
potential race in use_gss_proxy(). The value of sn->use_gss_proxy could
go from -1 to 1 just after we check it in use_gss_proxy() but before we
acquire the spinlock. The procfile write would end up returning success
but the value would flip to 0 soon afterward. With this method we not
only avoid locking but the first "setter" always wins.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
An nfsd thread can call use_gss_proxy and find it set to '1' but find
gssp_clnt still NULL, so that when it attempts the upcall the result
will be an unnecessary -EIO.
So, ensure that gssp_clnt is created first, and set the use_gss_proxy
variable only if that succeeds.
It doesn't make much sense to make reads from this procfile hang. As
far as I can tell, only gssproxy itself will open this file and it
never reads from it. Change it to just give the present setting of
sn->use_gss_proxy without waiting for anything.
Note that we do not want to call use_gss_proxy() in this codepath
since an inopportune read of this file could cause it to be disabled
prematurely.
For every other problem here we bail out with an error, but here for
some reason we're setting a negative cache entry (with, note, an
undefined expiry).
It seems simplest just to bail out in the same way as we do in other
cases.
Cc: Simo Sorce <simo@redhat.com>
Reported-by: Andi Kleen <andi@firstfloor.org>
The change made to rsc_parse() in
0dc1531aca7fd1440918bd55844a054e9c29acad "svcrpc: store gss mech in
svc_cred" should also have been propagated to the gss-proxy codepath.
This fixes a crash in the gss-proxy case.
Pull nfsd changes from Bruce Fields:
"Changes this time include:
- 4.1 enabled on the server by default: the last 4.1-specific issues
I know of are fixed, so we're not going to find the rest of the
bugs without more exposure.
- Experimental support for NFSv4.2 MAC Labeling (to allow running
selinux over NFS), from Dave Quigley.
- Fixes for some delicate cache/upcall races that could cause rare
server hangs; thanks to Neil Brown and Bodo Stroesser for extreme
debugging persistence.
- Fixes for some bugs found at the recent NFS bakeathon, mostly v4
and v4.1-specific, but also a generic bug handling fragmented rpc
calls"
* 'for-3.11' of git://linux-nfs.org/~bfields/linux: (31 commits)
nfsd4: support minorversion 1 by default
nfsd4: allow destroy_session over destroyed session
svcrpc: fix failures to handle -1 uid's
sunrpc: Don't schedule an upcall on a replaced cache entry.
net/sunrpc: xpt_auth_cache should be ignored when expired.
sunrpc/cache: ensure items removed from cache do not have pending upcalls.
sunrpc/cache: use cache_fresh_unlocked consistently and correctly.
sunrpc/cache: remove races with queuing an upcall.
nfsd4: return delegation immediately if lease fails
nfsd4: do not throw away 4.1 lock state on last unlock
nfsd4: delegation-based open reclaims should bypass permissions
svcrpc: don't error out on small tcp fragment
svcrpc: fix handling of too-short rpc's
nfsd4: minor read_buf cleanup
nfsd4: fix decoding of compounds across page boundaries
nfsd4: clean up nfs4_open_delegation
NFSD: Don't give out read delegations on creates
nfsd4: allow client to send no cb_sec flavors
nfsd4: fail attempts to request gss on the backchannel
nfsd4: implement minimal SP4_MACH_CRED
Store a pointer to the gss mechanism used in the rq_cred and cl_cred.
This will make it easier to enforce SP4_MACH_CRED, which needs to
compare the mechanism used on the exchange_id with that used on
protected operations.
Common helper to zero out fields of the svc_cred.
Somebody noticed LTP was complaining about O_NONBLOCK opens of
/proc/net/rpc/use-gss-proxy succeeding and then a following read
hanging.
I'm not convinced LTP really has any business opening random proc files
and expecting them to behave a certain way. Maybe this isn't really a
bug.
But in any case the O_NONBLOCK behavior could be useful for someone that
wants to test whether gss-proxy is up without waiting.
Reported-by: Jan Stancek <jstancek@redhat.com>
This should return zero on success and -EBUSY on error so the type
needs to be int instead of bool.
Pull nfsd changes from J Bruce Fields:
"Highlights include:
- Some more DRC cleanup and performance work from Jeff Layton
- A gss-proxy upcall from Simo Sorce: currently krb5 mounts to the
server using credentials from Active Directory often fail due to
limitations of the svcgssd upcall interface. This replacement
lifts those limitations. The existing upcall is still supported
for backwards compatibility.
- More NFSv4.1 support: at this point, if a user with a current
client who upgrades from 4.0 to 4.1 should see no regressions. In
theory we do everything a 4.1 server is required to do. Patches
for a couple minor exceptions are ready for 3.11, and with those
and some more testing I'd like to turn 4.1 on by default in 3.11."
Fix up semantic conflict as per Stephen Rothwell and linux-next:
Commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS
authentication") adds two new users of "PDE(inode)->data", but we're
supposed to use "PDE_DATA(inode)" instead since commit d9dda78bad87
("procfs: new helper - PDE_DATA(inode)").
The old PDE() macro is no longer available since commit c30480b92cf4
("proc: Make the PROC_I() and PDE() macros internal to procfs")
* 'for-3.10' of git://linux-nfs.org/~bfields/linux: (60 commits)
NFSD: SECINFO doesn't handle unsupported pseudoflavors correctly
NFSD: Simplify GSS flavor encoding in nfsd4_do_encode_secinfo()
nfsd: make symbol nfsd_reply_cache_shrinker static
svcauth_gss: fix error return code in rsc_parse()
nfsd4: don't remap EISDIR errors in rename
svcrpc: fix gss-proxy to respect user namespaces
SUNRPC: gssp_procedures[] can be static
SUNRPC: define {create,destroy}_use_gss_proxy_proc_entry in !PROC case
nfsd4: better error return to indicate SSV non-support
nfsd: fix EXDEV checking in rename
SUNRPC: Use gssproxy upcall for server RPCGSS authentication.
SUNRPC: Add RPC based upcall mechanism for RPCGSS auth
SUNRPC: conditionally return endtime from import_sec_context
SUNRPC: allow disabling idle timeout
SUNRPC: attempt AF_LOCAL connect on setup
nfsd: Decode and send 64bit time values
nfsd4: put_client_renew_locked can be static
nfsd4: remove unused macro
nfsd4: remove some useless code
nfsd4: implement SEQ4_STATUS_RECALLABLE_STATE_REVOKED
Fix to return a negative error code from the error handling
case instead of 0, as returned elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Pull NFS client bugfixes and cleanups from Trond Myklebust:
- NLM: stable fix for NFSv2/v3 blocking locks
- NFSv4.x: stable fixes for the delegation recall error handling code
- NFSv4.x: Security flavour negotiation fixes and cleanups by Chuck
Lever
- SUNRPC: A number of RPCSEC_GSS fixes and cleanups also from Chuck
- NFSv4.x assorted state management and reboot recovery bugfixes
- NFSv4.1: In cases where we have already looked up a file, and hold a
valid filehandle, use the new open-by-filehandle operation instead of
opening by name.
- Allow the NFSv4.1 callback thread to freeze
- NFSv4.x: ensure that file unlock waits for readahead to complete
- NFSv4.1: ensure that the RPC layer doesn't override the NFS session
table size negotiation by limiting the number of slots.
- NFSv4.x: Fix SETATTR spec compatibility issues
* tag 'nfs-for-3.10-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (67 commits)
NFSv4: Warn once about servers that incorrectly apply open mode to setattr
NFSv4: Servers should only check SETATTR stateid open mode on size change
NFSv4: Don't recheck permissions on open in case of recovery cached open
NFSv4.1: Don't do a delegated open for NFS4_OPEN_CLAIM_DELEG_CUR_FH modes
NFSv4.1: Use the more efficient open_noattr call for open-by-filehandle
NFS: Retry SETCLIENTID with AUTH_SYS instead of AUTH_NONE
NFSv4: Ensure that we clear the NFS_OPEN_STATE flag when appropriate
LOCKD: Ensure that nlmclnt_block resets block->b_status after a server reboot
NFSv4: Ensure the LOCK call cannot use the delegation stateid
NFSv4: Use the open stateid if the delegation has the wrong mode
nfs: Send atime and mtime as a 64bit value
NFSv4: Record the OPEN create mode used in the nfs4_opendata structure
NFSv4.1: Set the RPC_CLNT_CREATE_INFINITE_SLOTS flag for NFSv4.1 transports
SUNRPC: Allow rpc_create() to request that TCP slots be unlimited
SUNRPC: Fix a livelock problem in the xprt->backlog queue
NFSv4: Fix handling of revoked delegations by setattr
NFSv4 release the sequence id in the return on close case
nfs: remove unnecessary check for NULL inode->i_flock from nfs_delegation_claim_locks
NFS: Ensure that NFS file unlock waits for readahead to complete
NFS: Add functionality to allow waiting on all outstanding reads to complete
Though I wonder whether we should really just depend on CONFIG_PROC_FS
at some point.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
for-3.10
Note conflict: Chuck's patches modified (and made static)
gss_mech_get_by_OID, which is still needed by gss-proxy patches.
The conflict resolution is a bit minimal; we may want some more cleanup.
The main advantge of this new upcall mechanism is that it can handle
big tickets as seen in Kerberos implementations where tickets carry
authorization data like the MS-PAC buffer with AD or the Posix Authorization
Data being discussed in IETF on the krbwg working group.
The Gssproxy program is used to perform the accept_sec_context call on the
kernel's behalf. The code is changed to also pass the input buffer straight
to upcall mechanism to avoid allocating and copying many pages as tokens can
be as big (potentially more in future) as 64KiB.
Signed-off-by: Simo Sorce <simo@redhat.com>
[bfields: containerization, negotiation api]
We expose this parameter for a future caller.
It will be used to extract the endtime from the gss-proxy upcall mechanism,
in order to set the rsc cache expiration time.
The NFSv4 SECINFO operation returns a list of security flavors that
the server supports for a particular share. An NFSv4 client is
supposed to pick a pseudoflavor it supports that corresponds to one
of the flavors returned by the server.
GSS flavors in this list have a GSS tuple that identify a specific
GSS pseudoflavor.
Currently our client ignores the GSS tuple's "qop" value. A
matching pseudoflavor is chosen based only on the OID and service
value.
So far this omission has not had much effect on Linux. The NFSv4
protocol currently supports only one qop value: GSS_C_QOP_DEFAULT,
also known as zero.
However, if an NFSv4 server happens to return something other than
zero in the qop field, our client won't notice. This could cause
the client to behave in incorrect ways that could have security
implications.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
krb5 mounts started failing as of
683428fae8c73d7d7da0fa2e0b6beb4d8df4e808 "sunrpc: Update svcgss xdr
handle to rpsec_contect cache".
The problem is that mounts are usually done with some host principal
which isn't normally mapped to any user, in which case svcgssd passes
down uid -1, which the kernel is then expected to map to the
export-specific anonymous uid or gid.
The new uid_valid/gid_valid checks were therefore causing that downcall
to fail.
(Note the regression may not have been seen with older userspace that
tended to map unknown principals to an anonymous id on their own rather
than leaving it to the kernel.)
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
"Miscellaneous bugfixes, plus:
- An overhaul of the DRC cache by Jeff Layton. The main effect is
just to make it larger. This decreases the chances of intermittent
errors especially in the UDP case. But we'll need to watch for any
reports of performance regressions.
- Containerized nfsd: with some limitations, we now support
per-container nfs-service, thanks to extensive work from Stanislav
Kinsbursky over the last year."
Some notes about conflicts, since there were *two* non-data semantic
conflicts here:
- idr_remove_all() had been added by a memory leak fix, but has since
become deprecated since idr_destroy() does it for us now.
- xs_local_connect() had been added by this branch to make AF_LOCAL
connections be synchronous, but in the meantime Trond had changed the
calling convention in order to avoid a RCU dereference.
There were a couple of more obvious actual source-level conflicts due to
the hlist traversal changes and one just due to code changes next to
each other, but those were trivial.
* 'for-3.9' of git://linux-nfs.org/~bfields/linux: (49 commits)
SUNRPC: make AF_LOCAL connect synchronous
nfsd: fix compiler warning about ambiguous types in nfsd_cache_csum
svcrpc: fix rpc server shutdown races
svcrpc: make svc_age_temp_xprts enqueue under sv_lock
lockd: nlmclnt_reclaim(): avoid stack overflow
nfsd: enable NFSv4 state in containers
nfsd: disable usermode helper client tracker in container
nfsd: use proper net while reading "exports" file
nfsd: containerize NFSd filesystem
nfsd: fix comments on nfsd_cache_lookup
SUNRPC: move cache_detail->cache_request callback call to cache_read()
SUNRPC: remove "cache_request" argument in sunrpc_cache_pipe_upcall() function
SUNRPC: rework cache upcall logic
SUNRPC: introduce cache_detail->cache_request callback
NFS: simplify and clean cache library
NFS: use SUNRPC cache creation and destruction helper for DNS cache
nfsd4: free_stid can be static
nfsd: keep a checksum of the first 256 bytes of request
sunrpc: trim off trailing checksum before returning decrypted or integrity authenticated buffer
sunrpc: fix comment in struct xdr_buf definition
For most of SUNRPC caches (except NFS DNS cache) cache_detail->cache_upcall is
redundant since all that it's implementations are doing is calling
sunrpc_cache_pipe_upcall() with proper function address argument.
Cache request function address is now stored on cache_detail structure and
thus all the code can be simplified.
Now, for those cache details, which doesn't have cache_upcall callback (the
only one, which still has is nfs_dns_resolve_template)
sunrpc_cache_pipe_upcall will be called instead.
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
This callback will allow to simplify upcalls in further patches in this
series.
For each received uid call make_kuid and validate the result.
For each received gid call make_kgid and validate the result.
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
When GSSAPI integrity signatures are in use, or when we're using GSSAPI
privacy with the v2 token format, there is a trailing checksum on the
xdr_buf that is returned.
It's checked during the authentication stage, and afterward nothing
cares about it. Ordinarily, it's not a problem since the XDR code
generally ignores it, but it will be when we try to compute a checksum
over the buffer to help prevent XID collisions in the duplicate reply
cache.
Fix the code to trim off the checksums after verifying them. Note that
in unwrap_integ_data, we must avoid trying to reverify the checksum if
the request was deferred since it will no longer be present when it's
revisited.
Pull the rest of the nfsd commits from Bruce Fields:
"... and then I cherry-picked the remainder of the patches from the
head of my previous branch"
This is the rest of the original nfsd branch, rebased without the
delegation stuff that I thought really needed to be redone.
I don't like rebasing things like this in general, but in this situation
this was the lesser of two evils.
* 'for-3.5' of git://linux-nfs.org/~bfields/linux: (50 commits)
nfsd4: fix, consolidate client_has_state
nfsd4: don't remove rebooted client record until confirmation
nfsd4: remove some dprintk's and a comment
nfsd4: return "real" sequence id in confirmed case
nfsd4: fix exchange_id to return confirm flag
nfsd4: clarify that renewing expired client is a bug
nfsd4: simpler ordering of setclientid_confirm checks
nfsd4: setclientid: remove pointless assignment
nfsd4: fix error return in non-matching-creds case
nfsd4: fix setclientid_confirm same_cred check
nfsd4: merge 3 setclientid cases to 2
nfsd4: pull out common code from setclientid cases
nfsd4: merge last two setclientid cases
nfsd4: setclientid/confirm comment cleanup
nfsd4: setclientid remove unnecessary terms from a logical expression
nfsd4: move rq_flavor into svc_cred
nfsd4: stricter cred comparison for setclientid/exchange_id
nfsd4: move principal name into svc_cred
nfsd4: allow removing clients not holding state
nfsd4: rearrange exchange_id logic to simplify
Pull nfsd update from Bruce Fields.
* 'for-3.5-take-2' of git://linux-nfs.org/~bfields/linux: (23 commits)
nfsd: trivial: use SEEK_SET instead of 0 in vfs_llseek
SUNRPC: split upcall function to extract reusable parts
nfsd: allocate id-to-name and name-to-id caches in per-net operations.
nfsd: make name-to-id cache allocated per network namespace context
nfsd: make id-to-name cache allocated per network namespace context
nfsd: pass network context to idmap init/exit functions
nfsd: allocate export and expkey caches in per-net operations.
nfsd: make expkey cache allocated per network namespace context
nfsd: make export cache allocated per network namespace context
nfsd: pass pointer to export cache down to stack wherever possible.
nfsd: pass network context to export caches init/shutdown routines
Lockd: pass network namespace to creation and destruction routines
NFSd: remove hard-coded dereferences to name-to-id and id-to-name caches
nfsd: pass pointer to expkey cache down to stack wherever possible.
nfsd: use hash table from cache detail in nfsd export seq ops
nfsd: pass svc_export_cache pointer as private data to "exports" seq file ops
nfsd: use exp_put() for svc_export_cache put
nfsd: use cache detail pointer from svc_export structure on cache put
nfsd: add link to owner cache detail to svc_export structure
nfsd: use passed cache_detail pointer expkey_parse()
Move the rq_flavor into struct svc_cred, and use it in setclientid and
exchange_id comparisons as well.
Instead of keeping the principal name associated with a request in a
structure that's private to auth_gss and using an accessor function,
move it to svc_cred.
As a first step to converting struct cred to be all kuid_t and kgid_t
values convert the group values stored in group_info to always be
kgid_t values. Unless user namespaces are used this change should
have no effect.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
This is needed to share code between the current server upcall mechanism
and the new gssproxy upcall mechanism introduced in a following patch.
This patch makes GSS auth cache details allocated and registered per network
namespace context.
Thus with this patch rsi_cache and rsc_cache contents for network namespace "X"
are controlled from proc file system mount for the same network namespace "X".
Acked-by: J. Bruce Fields <bfields@redhat.com>
These macros never be used for several years.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Code like:
switch(xxx) {
case -error1:
case -error2:
return;
case 0:
stuff;
can more naturally be written:
if (xxx < 0)
return;
stuff;
