path: root/net/sunrpc/sched.c
2008-07-15SUNRPC: Remove the BKL from the callback functionsTrond Myklebust
Push it into those callback functions that actually need it. Note that all the NFS operations use their own locking, so don't need the BKL. Ditto for the rpcbind client. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09rpc: minor cleanup of scheduler callback code\\\"J. Bruce Fields\\\
Try to make the comment here a little more clear and concise. Also, this macro definition seems unnecessary. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Clean up rpcauth_bindcred()Trond Myklebust
2008-03-14SUNRPC: Fix RPCAUTH_LOOKUP_ROOTCREDSTrond Myklebust
The current RPCAUTH_LOOKUP_ROOTCREDS flag only works for AUTH_SYS authentication, and then only as a special case in the code. This patch removes the auth_sys special casing, and replaces it with generic code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-28SUNRPC: Remove now-redundant RCU-safe rpc_task free pathTrond Myklebust
Now that we've tightened up the locking rules for RPC queue wakeups, we can remove the RCU-safe kfree calls... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-28SUNRPC: Eliminate the now-redundant rpc_start_wakeup()Trond Myklebust
2008-02-28SUNRPC: Switch tasks to using the rpc_waitqueue's timer functionTrond Myklebust
2008-02-28SUNRPC: Add a timer function to wait queues.Trond Myklebust
This is designed to replace the timeout timer in the individual rpc_tasks. By putting the timer function in the wait queue, we will eventually be able to reduce the total number of timers in use by the RPC subsystem. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-28SUNRPC: Add a (empty for the moment) destructor for rpc_wait_queuesTrond Myklebust
2008-02-25SUNRPC: Run rpc timeout functions as callbacks instead of in softirqsTrond Myklebust
An audit of the current RPC timeout functions shows that they don't really ever need to run in the softirq context. As long as the softirq is able to signal that the wakeup is due to a timeout (which it can do by setting task->tk_status to -ETIMEDOUT) then the callback functions can just run as standard task->tk_callback functions (in the rpciod/process context). The only possible border-line case would be xprt_timer() for the case of UDP, when the callback is used to reduce the size of the transport congestion window. In testing, however, the effect of moving that update to a callback would appear to be minor. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25SUNRPC: Convert users of rpc_wake_up_task to use rpc_wake_up_queued_taskTrond Myklebust
2008-02-25SUNRPC: Add a new helper rpc_wake_up_queued_task()Trond Myklebust
In all cases where we currently use rpc_wake_up_task(), we almost always know on which waitqueue the rpc_task is actually sleeping. This will allows us to simplify the queue locking in a future patch. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25SUNRPC: Clean up rpc_run_timer()Trond Myklebust
All RPC timeout callback functions are expected to wake the task up. We can enforce this by moving the wakeup back into rpc_run_timer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25SUNRPC: Allow the rpc_release() callback to be run on another workqueueTrond Myklebust
A lot of the work done by the rpc_release() callback is inappropriate for rpciod as it will often involve things like starting a new rpc call in order to clean up state after an interrupted NFSv4 open() call, or calls to mntput(), etc. This patch allows the caller of rpc_run_task() to specify that the rpc_release callback should run on a different workqueue than the default rpciod_workqueue. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30SUNRPC: Cleanup to remove the last users of the RPC_WAITQ declarationTrond Myklebust
2008-01-30SUNRPC: Unexport rpc_init_task() and rpc_execute()Trond Myklebust
2008-01-30SUNRPC: allow the caller of rpc_run_task to preallocate the struct rpc_taskTrond Myklebust
2008-01-30SUNRPC: Allow rpc_init_task() to initialise the rpc_task->tk_msgTrond Myklebust
In preparation for the removal of rpc_call_setup(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up the initialisation of priority queue scheduling info.Trond Myklebust
We want the default scheduling priority (priority == 0) to remain RPC_PRIORITY_NORMAL. Also ensure that the priority wait queue scheduling is per process id instead of sometimes being per thread, and sometimes being per inode. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Cleanup of rpc_task initialisationTrond Myklebust
2008-01-30SUNRPC: Restrict sunrpc client exportsTrond Myklebust
The sunrpc client exports are not meant to be part of any official kernel API: they can change at the drop of a hat. Mark them as internal functions using EXPORT_SYMBOL_GPL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Move exported declarations to the function declarationsTrond Myklebust
Do this for all RPC client related functions and XDR functions. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09SUNRPC: add EXPORT_SYMBOL_GPL for generic transport functions\"Talpey, Thomas\
SUNRPC: add EXPORT_SYMBOL_GPL for generic transport functions As a preface to allowing arbitrary transport modules to be loaded dynamically, add EXPORT_SYMBOL_GPL for all generic transport functions that a transport implementation might want to use. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Acked-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-08-07SUNRPC: Fix a race in rpciod_down()Trond Myklebust
The commit 4ada539ed77c7a2bbcb75cafbbd7bd8d2b9bef7b lead to the unpleasant possibility of an asynchronous rpc_task being required to call rpciod_down() when it is complete. This again means that the rpciod workqueue may get to call destroy_workqueue on itself -> hang... Change rpciod_up/rpciod_down to just get/put the module, and then create/destroy the workqueues on module load/unload. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: clean up rpc_call_async/rpc_call_sync/rpc_run_taskTrond Myklebust
2007-07-10SUNRPC: Move rpc_register_client and friends into net/sunrpc/clnt.cTrond Myklebust
2007-07-10SUNRPC: Make create_client() take a reference to the rpciod workqueueTrond Myklebust
Ensures that an rpc_client always has the possibility to send asynchronous RPC calls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Optimise rpciod_up()Trond Myklebust
Instead of taking the mutex every time we just need to increment/decrement rpciod_users, we can optmise by using atomic_inc_not_zero and atomic_dec_and_test. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Kill rpc_clnt->cl_oneshotTrond Myklebust
Replace it with explicit calls to rpc_shutdown_client() or rpc_destroy_client() (for the case of asynchronous calls). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Convert rpc_clnt->cl_users to a krefTrond Myklebust
2007-07-10SUNRPC: Clean up tk_pid allocation and make it locklessTrond Myklebust
2007-07-10SUNRPC: Add a per-rpc_clnt spinlockTrond Myklebust
Use that to protect the rpc_clnt->cl_tasks list instead of using a global lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Move rpc_task->tk_task list into struct rpc_clntTrond Myklebust
2007-05-14SUNRPC: remove dead variable 'rpciod_running'Christoph Hellwig
rpciod_running is not used at all, but due to the way DECLARE_MUTEX_LOCKED works we don't get a warning for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09sunrpc: fix crash in rpc_malloc()Peter Zijlstra
While the comment says: * To prevent rpciod from hanging, this allocator never sleeps, * returning NULL if the request cannot be serviced immediately. The function does not actually check for NULL pointers being returned. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09SUNRPC: Fix pointer arithmetic bug recently introduced in rpc_malloc/freeChuck Lever
Use a cleaner method to find the size of an rpc_buffer. This actually works on x86-64! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-08Fix sunrpc warning noiseGeert Uytterhoeven
Commit c5a4dd8b7c15927a8fbff83171b57cad675a79b9 introduced the following compiler warnings: net/sunrpc/sched.c:766: warning: format '%u' expects type 'unsigned int', but argument 3 has type 'size_t' net/sunrpc/sched.c:785: warning: format '%u' expects type 'unsigned int', but argument 2 has type 'size_t' - Use %zu to format size_t - Kill 2 useless casts Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30SUNRPC: Eliminate side effects from rpc_mallocChuck Lever
Currently rpc_malloc sets req->rq_buffer internally. Make this a more generic interface: return a pointer to the new buffer (or NULL) and make the caller set req->rq_buffer and req->rq_bufsize. This looks much more like kmalloc and eliminates the side effects. To fix a potential deadlock, this patch also replaces GFP_NOFS with GFP_NOWAIT in rpc_malloc. This prevents async RPCs from sleeping outside the RPC's task scheduler while allocating their buffer. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-12Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: net/sunrpc/auth_gss/gss_krb5_crypto.c net/sunrpc/auth_gss/gss_spkm3_token.c net/sunrpc/clnt.c Merge with mainline and fix conflicts.
2007-02-10[NET] SUNRPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-03SUNRPC: fix print format for tk_pidChuck Lever
The tk_pid field is an unsigned short. The proper print format specifier for that type is %5u, not %4d. Also clean up some miscellaneous print formatting nits. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-03RPC: Clean up rpc_execute...Trond Myklebust
The error values are already propagated through task->tk_status, and none of the callers check one without checking the other, so we can drop the return value. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-01-24[PATCH] NFS: Fix Oops in rpc_call_sync()Trond Myklebust
Fix the Oops in http://bugzilla.linux-nfs.org/show_bug.cgi?id=138 We shouldn't be calling rpc_release_task() for tasks that are not active. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
Conflicts: include/linux/sunrpc/xprt.h net/sunrpc/xprtsock.c Fix up conflicts with the workqueue changes.
