path: root/net/sunrpc/sysctl.c
2008-02-01svc: Add /proc/sys/sunrpc/transport filesTom Tucker
Add a file that when read lists the set of registered svc transports. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-01-30SUNRPC: Restrict sunrpc client exportsTrond Myklebust
The sunrpc client exports are not meant to be part of any official kernel API: they can change at the drop of a hat. Mark them as internal functions using EXPORT_SYMBOL_GPL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Move exported declarations to the function declarationsTrond Myklebust
Do this for all RPC client related functions and XDR functions. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-30sunrpc: fix rpc debuggingJ. Bruce Fields
Commit baa3a2a0d24ebcf1c451bec8e5bee3d3467f4cbb ("sysctl: remove broken sunrpc debug binary sysctls"), by removing initialization of the ctl_name field, broke this conditional, preventing the display of rpc_tasks that you previously got when turning on rpc debugging. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: remove broken sunrpc debug binary sysctlsEric W. Biederman
This is debug code so no need to support binary sysctl, and the binary sysctls as they were written were not consistent with what showed up in /proc so remove the binary sysctl support. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: sunrpc: don't unnecessarily set ctl_table->deEric W. Biederman
We don't need this to prevent module unload races so remove the unnecessary code. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: sunrpc: remove unnecessary insert_at_head flagEric W. Biederman
Because the sunrpc sysctls don't conflict with any other sysctls the setting the insert at head flag to register_sysctl has no semantic meaning. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] SUNRPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-06SUNRPC: relocate the creation of socket-specific tunablesChuck Lever
Clean-up: The RPC client currently creates some sysctls that are specific to the socket transport. Move those entirely into xprtsock.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04SUNRPC: allow sunrpc.o to link when CONFIG_SYSCTL is disabledChuck Lever
The sunrpc module should build properly even when CONFIG_SYSCTL is disabled. Reported by Jan-Benedict Glaw. Test plan: Compile kernel with CONFIG_NFS as a module and built-in, and CONFIG_SYSCTL enabled and disabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-09-23[PATCH] RPC: allow RPC client's port range to be adjustableChuck Lever
Select an RPC client source port between 650 and 1023 instead of between 1 and 800. The old range conflicts with a number of network services. Provide sysctls to allow admins to select a different port range. Note that this doesn't affect user-level RPC library behavior, which still uses 1 to 800. Based on a suggestion by Olaf Kirch <okir@suse.de>. Test-plan: Repeated mount and unmount. Destructive testing. Idle timeouts. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-09-23[PATCH] RPC: introduce client-side transport switchChuck Lever
Move the bulk of client-side socket-specific code into a separate source file, net/sunrpc/xprtsock.c. Test-plan: Millions of fsx operations. Performance characterization such as "sio" or "iozone". Destructive testing (unplugging the network temporarily, server reboots). Connectathon with v2, v3, and v4. Version: Thu, 11 Aug 2005 16:03:38 -0400 Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
