path: root/net/sunrpc/xprtrdma/transport.c
2008-03-07SUNRPC: Fix a nfs4 over rdma transport oopsTom Talpey
Prevent an RPC oops when freeing a dynamically allocated RDMA buffer, used in certain special-case large metadata operations. Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up functions that free address_strings arrayChuck Lever
Clean up: document the rule (kfree) and the exceptions (RPC_DISPLAY_PROTO and RPC_DISPLAY_NETID) when freeing the objects in a transport's address_strings array. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Add support for per-client timeout valuesTrond Myklebust
In order to be able to support setting the timeo and retrans parameters on a per-mountpoint basis, we move the rpc_timeout structure into the rpc_clnt. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up the transport timeout initialisationTrond Myklebust
2008-01-30SUNRPC: Rename xprt_disconnect()Trond Myklebust
xprt_disconnect() should really only be called when the transport shutdown is completed, and it is time to wake up any pending tasks. Rename it to xprt_disconnect_done() in order to reflect the semantical change. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26SUNRPC: remove NFS/RDMA client's binary sysctlsJames Lentini
Support for binary sysctls is being deprecated in 2.6.24. Since there are no applications using the NFS/RDMA client's binary sysctls, it makes sense to remove them. The patch below does this while leaving the /proc/sys interface unchanged. Please consider this for 2.6.24. Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-14sunrpc/xprtrdma/transport.c: fix use-after-freeAdrian Bunk
Fix an obvious use-after-free spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09RPCRDMA: rpc rdma transport switch\"Talpey, Thomas\
This implements the configuration and building of the core transport switch implementation of the rpcrdma transport. Stubs are provided for the rpcrdma protocol handling, and the infiniband/iwarp verbs interface. These are provided in following patches. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
