It seems strange to maintain stats for bytes_sent in one structure, and
bytes received in another. Try to assemble all the RPC request-related
stats in struct rpc_rqst
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
We should not allow soft tasks to wait for longer than the major timeout
period when waiting for a reconnect to occur.
Remove the field xprt->connect_timeout since it has been obsoleted by
xprt->reestablish_timeout.
This fixes a bug with setting xprt->stat.connect_start.
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
fs/nfsd/nfs4callback.c
svc_xprt_received must be called when ->xpo_recvfrom has finished
receiving a message, so that the XPT_BUSY flag will be cleared and
if necessary, requeued for further work.
This call is currently made in each ->xpo_recvfrom function, often
from multiple different points. In each case it is the earliest point
on a particular path where it is known that the protection provided by
XPT_BUSY is no longer needed.
However there are (still) some error paths which do not call
svc_xprt_received, and requiring each ->xpo_recvfrom to make the call
does not encourage robustness.
So: move the svc_xprt_received call to be made just after the
call to ->xpo_recvfrom(), and move it of the various ->xpo_recvfrom
methods.
This means that it may not be called at the earliest possible instant,
but this is unlikely to be a measurable performance issue.
Note that there are still other calls to svc_xprt_received as it is
also needed when an xprt is newly created.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux:
svcrdma: RDMA support not yet compatible with RPC6
RPC6 requires that it be possible to create endpoints that listen
exclusively for IPv4 or IPv6 connection requests. This is not currently
supported by the RDMA API.
This fixes a server RDMA regression introduced by 37498292a "NFSD:
Create PF_INET6 listener in write_ports".
Signed-off-by: Tom Tucker<tom@opengridcomputing.com>
Tested-by: Steve Wise <swise@opengridcomputing.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
(Applies on top of "Remove uses of NIPQUAD, use %pI4")
Casts to void of snprintf are most uncommon in kernel source.
9 use casts, 1301 do not.
Remove the remaining uses in net/sunrpc/
Originally submitted Jan 1, 2010
http://patchwork.kernel.org/patch/71221/
Convert NIPQUAD to the %pI4 format extension where possible
Convert %02x%02x%02x%02x/NIPQUAD to %08x/ntohl
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits)
mac80211: fix reorder buffer release
iwmc3200wifi: Enable wimax core through module parameter
iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter
iwmc3200wifi: Coex table command does not expect a response
iwmc3200wifi: Update wiwi priority table
iwlwifi: driver version track kernel version
iwlwifi: indicate uCode type when fail dump error/event log
iwl3945: remove duplicated event logging code
b43: fix two warnings
ipw2100: fix rebooting hang with driver loaded
cfg80211: indent regulatory messages with spaces
iwmc3200wifi: fix NULL pointer dereference in pmkid update
mac80211: Fix TX status reporting for injected data frames
ath9k: enable 2GHz band only if the device supports it
airo: Fix integer overflow warning
rt2x00: Fix padding bug on L2PAD devices.
WE: Fix set events not propagated
b43legacy: avoid PPC fault during resume
b43: avoid PPC fault during resume
tcp: fix a timewait refcnt race
Fix up conflicts due to sysctl cleanups (dead sysctl_check code and
CTL_UNNUMBERED removed) in
kernel/sysctl_check.c
net/ipv4/sysctl_net_ipv4.c
net/ipv6/addrconf.c
net/sctp/sysctl.c
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
For consistency drop & in front of every proc_handler. Explicity
taking the address is unnecessary and it prevents optimizations
like stubbing the proc_handlers to NULL.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Joe Perches <joe@perches.com>
Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 into for-2.6.32-incoming
net/sunrpc/cache.c
At some point, I recall that rpc_pipe_fs used RPC_DISPLAY_ALL.
Currently there are no uses of RPC_DISPLAY_ALL outside the transport
modules themselves, so we can safely get rid of it.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Clean up: In addition to using the new generic rpc_ntop() and
rpc_get_port() functions, have the RPC client compute the presentation
address buffer sizes dynamically using kstrdup().
RPC universal address generation is currently done in several places:
rpcb_clnt.c, nfs4proc.c xprtsock.c, and xprtrdma.c. Remove the
redundant cases that convert a socket address to a universal
address. The nfs4proc.c case takes a pre-formatted presentation
address string, not a socket address, so we'll leave that one.
Because the new uaddr constructor uses the recently introduced
rpc_ntop(), it now supports proper "::" shorthanding for IPv6
addresses. This allows the kernel to register properly formed
universal addresses with the local rpcbind service, in _all_ cases.
The kernel can now also send properly formed universal addresses in
RPCB_GETADDR requests, and support link-local properly when
encoding and decoding IPv6 addresses.
ib_alloc_fast_reg_mr() and ib_alloc_fast_reg_page_list() returns
ERR_PTR() and not NULL. Compile tested only.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
In case the check on ch_count fails the cleanup path is skipped and the
previously allocated memory 'rpl_map', 'chl_map' is not freed.
Reported by Coverity.
Signed-off-by: Christian Engelmayer <christian.engelmayer@frequentis.com>
* 'for-2.6.30' of git://linux-nfs.org/~bfields/linux:
svcrdma: dma unmap the correct length for the RPCRDMA header page.
nfsd: Revert "svcrpc: take advantage of tcp autotuning"
nfsd: fix hung up of nfs client while sync write data to nfs server
The svcrdma module was incorrectly unmapping the RPCRDMA header page.
On IBM pserver systems this causes a resource leak that results in
running out of bus address space (10 cthon iterations will reproduce it).
The code was mapping the full page but only unmapping the actual header
length. The fix is to only map the header length.
I also cleaned up the use of ib_dma_map_page() calls since the unmap
logic always uses ib_dma_unmap_single(). I made these symmetrical.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
mlx4/connectX FRMR requires local write enable together with remote
rdma write enable. This fixes NFS/RDMA operation over the ConnectX
Infiniband HCA in the default memreg mode.
Signed-off-by: Vu Pham <vu@mellanox.com>
Signed-off-by: Tom Talpey <tmtalpey@gmail.com>
These fixes resolved crashes due to resource leak BUG_ON checks. The
resource leaks were detected by introducing asynchronous transport errors.
The nfs server rdma transport was mapping rdma read target pages for
TO_DEVICE instead of FROM_DEVICE. This causes data corruption on non
cache-coherent systems if frmrs are used.
printk formats in prior commit were reversed/incorrect.
Compiled without warning on x86 and x86_64, but detected on ppc.
Certain client rpc's which contain both lengthy page-contained
metadata and a non-empty xdr_tail buffer require careful handling
to avoid overlapped memory copying. Rearranging of existing rpcrdma
marshaling code avoids it; this fixes an NFSv4 symlink creation error
detected with connectathon basic/test8 to multiple servers.
Certain client-provided RPCRDMA chunk alignments result in an
additional scatter/gather entry, which triggered nfs/rdma server
assertions incorrectly. OpenSolaris nfs/rdma client connectathon
testing was blocked by these in the special/locking section.
Cc: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Sparse asked whether these could be static.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
fix this warning:
net/sunrpc/xprtrdma/verbs.c: In function ‘rpcrdma_conn_upcall’:
net/sunrpc/xprtrdma/verbs.c:279: warning: unused variable ‘addr’
this warning:
net/sunrpc/xprtrdma/svc_rdma_transport.c: In function ‘svc_rdma_accept’:
net/sunrpc/xprtrdma/svc_rdma_transport.c:830: warning: ‘dma_mr_acc’ may be used uninitialized in this function
triggers because GCC does not recognize the (correct) flow connection
between need_dma_mr and dma_mr_acc.
Annotate it.
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
* 'for-2.6.28' of git://linux-nfs.org/~bfields/linux: (59 commits)
svcrdma: Fix IRD/ORD polarity
svcrdma: Update svc_rdma_send_error to use DMA LKEY
svcrdma: Modify the RPC reply path to use FRMR when available
svcrdma: Modify the RPC recv path to use FRMR when available
svcrdma: Add support to svc_rdma_send to handle chained WR
svcrdma: Modify post recv path to use local dma key
svcrdma: Add a service to register a Fast Reg MR with the device
svcrdma: Query device for Fast Reg support during connection setup
svcrdma: Add FRMR get/put services
NLM: Remove unused argument from svc_addsock() function
NLM: Remove "proto" argument from lockd_up()
NLM: Always start both UDP and TCP listeners
lockd: Remove unused fields in the nlm_reboot structure
lockd: Add helper to sanity check incoming NOTIFY requests
lockd: change nlmclnt_grant() to take a "struct sockaddr *"
lockd: Adjust nlmsvc_lookup_host() to accomodate AF_INET6 addresses
lockd: Adjust nlmclnt_lookup_host() signature to accomodate non-AF_INET
lockd: Support non-AF_INET addresses in nlm_lookup_host()
NLM: Convert nlm_lookup_host() to use a single argument
svcrdma: Add Fast Reg MR Data Types
The RPC/RDMA connection logic could return early from reconnection
attempts, leading to additional spurious retries.
Signed-off-by: Tom Talpey <talpey@netapp.com>
The RPC/RDMA code had a constant 5-second reconnect backoff, and
always performed it, even when re-establishing a connection to a
server after the RPC layer closed it due to being idle. Make it
an geometric backoff (up to 30 seconds), and don't delay idle
reconnect.
The send marshaling code split a particular dprintk across two
lines, which makes it hard to extract from logfiles.
Add defensive timeouts to wait_for_completion() calls in RDMA
address resolution, and make them interruptible. Fix the timeout
units to milliseconds (formerly jiffies) and move to private header.
The RPC/RDMA code can leak RDMA connection manager endpoints in
certain error cases on connect. Don't signal unwanted events,
and be certain to destroy any allocated qp.
The xprt_connect call path does not expect such errors as ECONNREFUSED
to be returned from failed transport connection attempts, otherwise it
translates them to EIO and signals fatal errors. For example, mount.nfs
prints simply "internal error". Translate all such errors to ENOTCONN
from RPC/RDMA to match sockets behavior.
The RPC/RDMA protocol allows clients and servers to avoid RDMA
operations for data which is purely the result of XDR padding.
On the client, automatically insert the necessary padding for
such server replies, and optionally don't marshal such chunks.
RDMA disconnects yield an upcall from the RDMA connection manager,
which can race with rpc transport close, e.g. on ^C of a mount.
Ensure any rdma cm_id and qp are fully destroyed before continuing.
An RPC/RDMA client cannot retransmit on an unbroken connection,
doing so violates its flow control with the server.
