path: root/net/sunrpc
2011-04-24SUNRPC: Allow RPC calls to return ETIMEDOUT instead of EIOTrond Myklebust
On occasion, it is useful for the NFS layer to distinguish between soft timeouts and other EIO errors due to (say) encoding errors, or authentication errors. The following patch ensures that the default behaviour of the RPC layer remains to return EIO on soft timeouts (until we have audited all the callers). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-04-18NFSv4.1: Don't update sequence number if rpc_task is not sentBryan Schumaker
If we fail to contact the gss upcall program, then no message will be sent to the server. The client still updated the sequence number, however, and this lead to NFS4ERR_SEQ_MISMATCH for the next several RPC calls. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-04-15SUNRPC: Fix the SUNRPC Kerberos V RPCSEC_GSS module dependenciesTrond Myklebust
Since kernel 2.6.35, the SUNRPC Kerberos support has had an implicit dependency on a number of additional crypto modules. The following patch makes that dependency explicit. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-04-13NFS: Fix infinite loop in gss_create_upcall()Bryan Schumaker
There can be an infinite loop if gss_create_upcall() is called without the userspace program running. To prevent this, we return -EACCES if we notice that pipe_version hasn't changed (indicating that the pipe has not been opened). Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-04-08Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Change initial mount authflavor only when server returns NFS4ERR_WRONGSEC NFS: Fix a signed vs. unsigned secinfo bug Revert "net/sunrpc: Use static const char arrays"
2011-04-06Revert "net/sunrpc: Use static const char arrays"Trond Myklebust
This reverts commit 411b5e05617593efebc06241dbc56f42150f2abe. Olga Kornievskaia reports: Problem: linux client mounting linux server using rc4-hmac-md5 enctype. gssd fails with create a context after receiving a reply from the server. Diagnose: putting printout statements in the server kernel and kerberos libraries revealed that client and server derived different integrity keys. Server kernel code was at fault due the the commit [aglo@skydive linux-pnfs]$ git show 411b5e05617593efebc06241dbc56f42150f2abe Trond: The problem is that since it relies on virt_to_page(), you cannot call sg_set_buf() for data in the const section. Reported-by: Olga Kornievskaia <aglo@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org [2.6.36+]
2011-03-27NFS: Ensure that rpc_release_resources_task() can be called twice.OGAWA Hirofumi
BUG: atomic_dec_and_test(): -1: atomic counter underflow at: Pid: 2827, comm: mount.nfs Not tainted 2.6.38 #1 Call Trace: [<ffffffffa02223a0>] ? put_rpccred+0x44/0x14e [sunrpc] [<ffffffffa021bbe9>] ? rpc_ping+0x4e/0x58 [sunrpc] [<ffffffffa021c4a5>] ? rpc_create+0x481/0x4fc [sunrpc] [<ffffffffa022298a>] ? rpcauth_lookup_credcache+0xab/0x22d [sunrpc] [<ffffffffa028be8c>] ? nfs_create_rpc_client+0xa6/0xeb [nfs] [<ffffffffa028c660>] ? nfs4_set_client+0xc2/0x1f9 [nfs] [<ffffffffa028cd3c>] ? nfs4_create_server+0xf2/0x2a6 [nfs] [<ffffffffa0295d07>] ? nfs4_remote_mount+0x4e/0x14a [nfs] [<ffffffff810dd570>] ? vfs_kern_mount+0x6e/0x133 [<ffffffffa029605a>] ? nfs_do_root_mount+0x76/0x95 [nfs] [<ffffffffa029643d>] ? nfs4_try_mount+0x56/0xaf [nfs] [<ffffffffa0297434>] ? nfs_get_sb+0x435/0x73c [nfs] [<ffffffff810dd59b>] ? vfs_kern_mount+0x99/0x133 [<ffffffff810dd693>] ? do_kern_mount+0x48/0xd8 [<ffffffff810f5b75>] ? do_mount+0x6da/0x741 [<ffffffff810f5c5f>] ? sys_mount+0x83/0xc0 [<ffffffff8100293b>] ? system_call_fastpath+0x16/0x1b Well, so, I think this is real bug of nfs codes somewhere. With some review, the code rpc_call_sync() rpc_run_task rpc_execute() __rpc_execute() rpc_release_task() rpc_release_resources_task() put_rpccred() <= release cred rpc_put_task rpc_do_put_task() rpc_release_resources_task() put_rpccred() <= release cred again seems to be release cred unintendedly. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-25Merge branch 'nfs-for-2.6.39' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.39' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (28 commits) Cleanup XDR parsing for LAYOUTGET, GETDEVICEINFO NFSv4.1 convert layoutcommit sync to boolean NFSv4.1 pnfs_layoutcommit_inode fixes NFS: Determine initial mount security NFS: use secinfo when crossing mountpoints NFS: Add secinfo procedure NFS: lookup supports alternate client NFS: convert call_sync() to a function NFSv4.1 remove temp code that prevented ds commits NFSv4.1: layoutcommit NFSv4.1: filelayout driver specific code for COMMIT NFSv4.1: remove GETATTR from ds commits NFSv4.1: add generic layer hooks for pnfs COMMIT NFSv4.1: alloc and free commit_buckets NFSv4.1: shift filelayout_free_lseg NFSv4.1: pull out code from nfs_commit_release NFSv4.1: pull error handling out of nfs_commit_list NFSv4.1: add callback to nfs4_commit_done NFSv4.1: rearrange nfs_commit_rpcsetup NFSv4.1: don't send COMMIT to ds for data sync writes ...
2011-03-24Merge branch 'nfs-for-2.6.39' into nfs-for-nextTrond Myklebust
2011-03-24NFS: Determine initial mount securityBryan Schumaker
When sec=<something> is not presented as a mount option, we should attempt to determine what security flavor the server is using. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-24NFS: use secinfo when crossing mountpointsBryan Schumaker
A submount may use different security than the parent mount does. We should figure out what sec flavor the submount uses at mount time. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-24Merge branch 'for-2.6.39' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.39' of git://linux-nfs.org/~bfields/linux: SUNRPC: Remove resource leak in svc_rdma_send_error() nfsd: wrong index used in inner loop nfsd4: fix comment and remove unused nfsd4_file fields nfs41: make sure nfs server return right ca_maxresponsesize_cached nfsd: fix compile error svcrpc: fix bad argument in unix_domain_find nfsd4: fix struct file leak nfsd4: minor nfs4state.c reshuffling svcrpc: fix rare race on unix_domain creation nfsd41: modify the members value of nfsd4_op_flags nfsd: add proc file listing kernel's gss_krb5 enctypes gss:krb5 only include enctype numbers in gm_upcall_enctypes NFSD, VFS: Remove dead code in nfsd_rename() nfsd: kill unused macro definition locks: use assign_type()
2011-03-22SUNRPC: Never reuse the socket port after an xs_close()Trond Myklebust
If we call xs_close(), we're in one of two situations: - Autoclose, which means we don't expect to resend a request - bind+connect failed, which probably means the port is in use Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2011-03-17Merge branch 'nfs-for-2.6.39' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.39' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (54 commits) RPC: killing RPC tasks races fixed xprt: remove redundant check SUNRPC: Convert struct rpc_xprt to use atomic_t counters SUNRPC: Ensure we always run the tk_callback before tk_action sunrpc: fix printk format warning xprt: remove redundant null check nfs: BKL is no longer needed, so remove the include NFS: Fix a warning in fs/nfs/idmap.c Cleanup: Factor out some cut-and-paste code. cleanup: save 60 lines/100 bytes by combining two mostly duplicate functions. NFS: account direct-io into task io accounting gss:krb5 only include enctype numbers in gm_upcall_enctypes RPCRDMA: Fix FRMR registration/invalidate handling. RPCRDMA: Fix to XDR page base interpretation in marshalling logic. NFSv4: Send unmapped uid/gids to the server when using auth_sys NFSv4: Propagate the error NFS4ERR_BADOWNER to nfs4_do_setattr NFSv4: cleanup idmapper functions to take an nfs_server argument NFSv4: Send unmapped uid/gids to the server if the idmapper fails NFSv4: If the server sends us a numeric uid/gid then accept it NFSv4.1: reject zero layout with zeroed stripe unit ...
2011-03-17SUNRPC: Remove resource leak in svc_rdma_send_error()Jesper Juhl
We leak the memory allocated to 'ctxt' when we return after 'ib_dma_mapping_error()' returns !=0. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-17RPC: killing RPC tasks races fixedStanislav Kinsbursky
RPC task RPC_TASK_QUEUED bit is set must be checked before trying to wake up task rpc_killall_tasks() because task->tk_waitqueue can not be set (equal to NULL). Also, as Trond Myklebust mentioned, such approach (instead of checking tk_waitqueue to NULL) allows us to "optimise away the call to rpc_wake_up_queued_task() altogether for those tasks that aren't queued". Here is an example of dereferencing of tk_waitqueue equal to NULL: CPU 0 CPU 1 CPU 2 -------------------- --------------------- -------------------------- nfs4_run_open_task rpc_run_task rpc_execute rpc_set_active rpc_make_runnable (waiting) rpc_async_schedule nfs4_open_prepare nfs_wait_on_sequence nfs_umount_begin rpc_killall_tasks rpc_wake_up_task rpc_wake_up_queued_task spin_lock(tk_waitqueue == NULL) BUG() rpc_sleep_on spin_lock(&q->lock) __rpc_sleep_on task->tk_waitqueue = q Signed-off-by: Stanislav Kinsbursky <skinsbursky@openvz.org> Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-17xprt: remove redundant checkj223yang@asset.uwaterloo.ca
remove redundant check. Signed-off-by: Jinqiu Yang <crindy646@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-17SUNRPC: Convert struct rpc_xprt to use atomic_t countersTrond Myklebust
2011-03-17SUNRPC: Ensure we always run the tk_callback before tk_actionTrond Myklebust
This fixes a race in which the task->tk_callback() puts the rpc_task to sleep, setting a new callback. Under certain circumstances, the current code may end up executing the task->tk_action before it gets round to the callback. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-15sunrpc: fix printk format warningRandy Dunlap
Fix printk format build warning: net/sunrpc/xprtrdma/verbs.c:1463: warning: format '%llx' expects type 'long long unsigned int', but argument 3 has type 'dma_addr_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-15xprt: remove redundant null checkj223yang@asset.uwaterloo.ca
'req' is dereferenced before checked for NULL. The patch simply removes the check. Signed-off-by: Jinqiu Yang<crindy646@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11gss:krb5 only include enctype numbers in gm_upcall_enctypesKevin Coffman
Make the value in gm_upcall_enctypes just the enctype values. This allows the values to be used more easily elsewhere. Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11RPCRDMA: Fix FRMR registration/invalidate handling.Tom Tucker
When the rpc_memreg_strategy is 5, FRMR are used to map RPC data. This mode uses an FRMR to map the RPC data, then invalidates (i.e. unregisers) the data in xprt_rdma_free. These FRMR are used across connections on the same mount, i.e. if the connection goes away on an idle timeout and reconnects later, the FRMR are not destroyed and recreated. This creates a problem for transport errors because the WR that invalidate an FRMR may be flushed (i.e. fail) leaving the FRMR valid. When the FRMR is later used to map an RPC it will fail, tearing down the transport and starting over. Over time, more and more of the FRMR pool end up in the wrong state resulting in seemingly random disconnects. This fix keeps track of the FRMR state explicitly by setting it's state based on the successful completion of a reg/inv WR. If the FRMR is ever used and found to be in the wrong state, an invalidate WR is prepended, re-syncing the FRMR state and avoiding the connection loss. Signed-off-by: Tom Tucker <tom@ogc.us> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11RPCRDMA: Fix to XDR page base interpretation in marshalling logic.Tom Tucker
The RPCRDMA marshalling logic assumed that xdr->page_base was an offset into the first page of xdr->page_list. It is in fact an offset into the xdr->page_list itself, that is, it selects the first page in the page_list and the offset into that page. The symptom depended in part on the rpc_memreg_strategy, if it was FRMR, or some other one-shot mapping mode, the connection would get torn down on a base and bounds error. When the badly marshalled RPC was retransmitted it would reconnect, get the error, and tear down the connection again in a loop forever. This resulted in a hung-mount. For the other modes, it would result in silent data corruption. This bug is most easily reproduced by writing more data than the filesystem has space for. This fix corrects the page_base assumption and otherwise simplifies the iov mapping logic. Signed-off-by: Tom Tucker <tom@ogc.us> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: filelayout async error handlerAndy Adamson
Use our own async error handler. Mark the layout as failed and retry i/o through the MDS on specified errors. Update the mds_offset in nfs_readpage_retry so that a failed short-read retry to a DS gets correctly resent through the MDS. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11RPC: clarify rpc_run_task error handlingFred Isaman
rpc_run_task can only fail if it is not passed in a preallocated task. However, that is not at all clear with the current code. So remove several impossible to occur failure checks. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11RPC: remove check for impossible condition in rpc_make_runnableFred Isaman
queue_work() only returns 0 or 1, never a negative value. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-10sunrpc: Propagate errors from xs_bind() through xs_create_sock()Ben Hutchings
xs_create_sock() is supposed to return a pointer or an ERR_PTR-encoded error, but it currently returns 0 if xs_bind() fails. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Cc: stable@kernel.org [v2.6.37] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-10SUNRPC: Remove resource leak in svc_rdma_send_error()Jesper Juhl
We leak the memory allocated to 'ctxt' when we return after 'ib_dma_mapping_error()' returns !=0. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-10SUNRPC: Close a race in __rpc_wait_for_completion_task()Trond Myklebust
Although they run as rpciod background tasks, under normal operation (i.e. no SIGKILL), functions like nfs_sillyrename(), nfs4_proc_unlck() and nfs4_do_close() want to be fully synchronous. This means that when we exit, we want all references to the rpc_task to be gone, and we want any dentry references etc. held by that task to be released. For this reason these functions call __rpc_wait_for_completion_task(), followed by rpc_put_task() in the expectation that the latter will be releasing the last reference to the rpc_task, and thus ensuring that the callback_ops->rpc_release() has been called synchronously. This patch fixes a race which exists due to the fact that rpciod calls rpc_complete_task() (in order to wake up the callers of __rpc_wait_for_completion_task()) and then subsequently calls rpc_put_task() without ensuring that these two steps are done atomically. In order to avoid adding new spin locks, the patch uses the existing waitqueue spin lock to order the rpc_task reference count releases between the waiting process and rpciod. The common case where nobody is waiting for completion is optimised for by checking if the RPC_TASK_ASYNC flag is cleared and/or if the rpc_task reference count is 1: in those cases we drop trying to grab the spin lock, and immediately free up the rpc_task. Those few processes that need to put the rpc_task from inside an asynchronous context and that do not care about ordering are given a new helper: rpc_put_task_async(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-09svcrpc: fix bad argument in unix_domain_findJ. Bruce Fields
"After merging the nfsd tree, today's linux-next build (powerpc ppc64_defconfig) produced this warning: net/sunrpc/svcauth_unix.c: In function 'unix_domain_find': net/sunrpc/svcauth_unix.c:58: warning: passing argument 1 of +'svcauth_unix_domain_release' from incompatible pointer type net/sunrpc/svcauth_unix.c:41: note: expected 'struct auth_domain *' but argument +is of type 'struct unix_domain *' Introduced by commit 8b3e07ac908d ("svcrpc: fix rare race on unix_domain creation")." Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-08svcrpc: fix rare race on unix_domain creationJ. Bruce Fields
Note that "new" here is not yet fully initialized; auth_domain_put should be called only on auth_domains that have actually been added to the hash. Before this fix, two attempts to add the same domain at once could cause the hlist_del in auth_domain_put to fail. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-07gss:krb5 only include enctype numbers in gm_upcall_enctypesKevin Coffman
Make the value in gm_upcall_enctypes just the enctype values. This allows the values to be used more easily elsewhere. Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-02-22net: add __rcu annotations to sk_wq and wqEric Dumazet
Add proper RCU annotations/verbs to sk_wq and wq members Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access) Fix sunrpc sk_sleep() abuse too Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-21Merge branch 'master' into for-2.6.39Tejun Heo
2011-01-25NFS do not find client in NFSv4 pg_authenticateAndy Adamson
The information required to find the nfs_client cooresponding to the incoming back channel request is contained in the NFS layer. Perform minimal checking in the RPC layer pg_authenticate method, and push more detailed checking into the NFS layer where the nfs_client can be found. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUERTejun Heo
WQ_RESCUER is now an internal flag and should only be used in the workqueue implementation proper. Use WQ_MEM_RECLAIM instead. This doesn't introduce any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: dm-devel@redhat.com Cc: Neil Brown <neilb@suse.de>
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-11Merge branch 'nfs-for-2.6.38' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.38' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (89 commits) NFS fix the setting of exchange id flag NFS: Don't use vm_map_ram() in readdir NFSv4: Ensure continued open and lockowner name uniqueness NFS: Move cl_delegations to the nfs_server struct NFS: Introduce nfs_detach_delegations() NFS: Move cl_state_owners and related fields to the nfs_server struct NFS: Allow walking nfs_client.cl_superblocks list outside client.c pnfs: layout roc code pnfs: update nfs4_callback_recallany to handle layouts pnfs: add CB_LAYOUTRECALL handling pnfs: CB_LAYOUTRECALL xdr code pnfs: change lo refcounting to atomic_t pnfs: check that partial LAYOUTGET return is ignored pnfs: add layout to client list before sending rpc pnfs: serialize LAYOUTGET(openstateid) pnfs: layoutget rpc code cleanup pnfs: change how lsegs are removed from layout list pnfs: change layout state seqlock to a spinlock pnfs: add prefix to struct pnfs_layout_hdr fields pnfs: add prefix to struct pnfs_layout_segment fields ...
2011-01-11rpc: allow xprt_class->setup to return a preexisting xprtJ. Bruce Fields
This allows us to reuse the xprt associated with a server connection if one has already been set up. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-11rpc: keep backchannel xprt as long as server connectionJ. Bruce Fields
Multiple backchannels can share the same tcp connection; from rfc 5661 section 2.10.3.1: A connection's association with a session is not exclusive. A connection associated with the channel(s) of one session may be simultaneously associated with the channel(s) of other sessions including sessions associated with other client IDs. However, multiple backchannels share a connection, they must all share the same xid stream (hence the same rpc_xprt); the only way we have to match replies with calls at the rpc layer is using the xid. So, keep the rpc_xprt around as long as the connection lasts, in case we're asked to use the connection as a backchannel again. Requests to create new backchannel clients over a given server connection should results in creating new clients that reuse the existing rpc_xprt. But to start, just reject attempts to associate multiple rpc_xprt's with the same underlying bc_xprt. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-11rpc: move sk_bc_xprt to svc_xprtJ. Bruce Fields
This seems obviously transport-level information even if it's currently used only by the server socket code. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-10Merge branch 'bugfixes' into nfs-for-2.6.38Trond Myklebust
Conflicts: fs/nfs/nfs2xdr.c fs/nfs/nfs3xdr.c fs/nfs/nfs4xdr.c
2011-01-10NFS: Don't use vm_map_ram() in readdirTrond Myklebust
vm_map_ram() is not available on NOMMU platforms, and causes trouble on incoherrent architectures such as ARM when we access the page data through both the direct and the virtual mapping. The alternative is to use the direct mapping to access page data for the case when we are not crossing a page boundary, but to copy the data into a linear scratch buffer when we are accessing data that spans page boundaries. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Marc Kleine-Budde <mkl@pengutronix.de> Cc: stable@kernel.org [2.6.37]
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2011-01-07Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: (57 commits) fs: scale mntget/mntput fs: rename vfsmount counter helpers fs: implement faster dentry memcmp fs: prefetch inode data in dcache lookup fs: improve scalability of pseudo filesystems fs: dcache per-inode inode alias locking fs: dcache per-bucket dcache hash locking bit_spinlock: add required includes kernel: add bl_list xfs: provide simple rcu-walk ACL implementation btrfs: provide simple rcu-walk ACL implementation ext2,3,4: provide simple rcu-walk ACL implementation fs: provide simple rcu-walk generic_check_acl implementation fs: provide rcu-walk aware permission i_ops fs: rcu-walk aware d_revalidate method fs: cache optimise dentry and inode for rcu-walk fs: dcache reduce branches in lookup path fs: dcache remove d_mounted fs: fs_struct use seqlock fs: rcu-walk for path lookup ...
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
