commit 5afa9133cfe67f1bfead6049a9640c9262a7101c upstream.
Fix a couple of instances where we were exiting the RPC client on
arbitrary signals. We should only do so on fatal signals.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit fe19a96b10032035a35779f42ad59e35d6dd8ffd upstream.
The TCP connection state code depends on the state_change() callback
being called when the SYN_SENT state is set. However the networking layer
doesn't actually call us back in that case.
commit 246408dcd5dfeef2df437ccb0ef4d6ee87805f58 upstream.
If we call xs_close(), we're in one of two situations:
- Autoclose, which means we don't expect to resend a request
- bind+connect failed, which probably means the port is in use
commit e020c6800c9621a77223bf2c1ff68180e41e8ebf upstream.
This fixes a race in which the task->tk_callback() puts the rpc_task
to sleep, setting a new callback. Under certain circumstances, the current
code may end up executing the task->tk_action before it gets round to the
callback.
commit a5990ea1254cd186b38744507aeec3136a0c1c95 upstream.
Don't forget to release the module refcnt if seq_open() returns failure.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: J. Bruce Fields <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Cc: maximilian attems <max@stro.at>
commit ed2849d3ecfa339435818eeff28f6c3424300cec upstream.
When an xprt is created, it has a refcount of 1, and XPT_BUSY is set.
The refcount is *not* owned by the thread that created the xprt
(as is clear from the fact that creators never put the reference).
Rather, it is owned by the absence of XPT_DEAD. Once XPT_DEAD is set,
(And XPT_BUSY is clear) that initial reference is dropped and the xprt
can be freed.
So when a creator clears XPT_BUSY it is dropping its only reference and
so must not touch the xprt again.
However svc_recv, after calling ->xpo_accept (and so getting an XPT_BUSY
reference on a new xprt), calls svc_xprt_recieved. This clears
XPT_BUSY and then svc_xprt_enqueue - this last without owning a reference.
This is dangerous and has been seen to leave svc_xprt_enqueue working
with an xprt containing garbage.
So we need to hold an extra counted reference over that call to
svc_xprt_received.
For safety, any time we clear XPT_BUSY and then use the xprt again, we
first get a reference, and the put it again afterwards.
Note that svc_close_all does not need this extra protection as there are
no threads running, and the final free can only be called asynchronously
from such a thread.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit b76ce56192bcf618013fb9aecd83488cffd645cc upstream.
If the attempt to read the calldir fails, then instead of storing the read
bytes, we currently discard them. This leads to a garbage final result when
upon re-entry to the same routine, we read the remaining bytes.
Fixes the regression in bugzilla number 16213. Please see
https://bugzilla.kernel.org/show_bug.cgi?id=16213
commit f1f0abe192a72e75d7c59972e30784d043fd8d73 upstream.
__rpc_lookup_create() can return ERR_PTR(-ENOMEM).
commit cdead7cf12896c0e50a8be2e52de52c364603095 upstream.
The function alloc_enc_pages() currently fails to release the pointer
rqstp->rq_enc_pages in the error path.
Acked-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 301e99ce4a2f42a317129230fd42e6cd874c64b0 upstream.
One the changes in commit d7979ae4a "svc: Move close processing to a
single place" is:
err_delete:
- svc_delete_socket(svsk);
+ set_bit(SK_CLOSE, &svsk->sk_flags);
return -EAGAIN;
This is insufficient. The recvfrom methods must always call
svc_xprt_received on completion so that the socket gets re-queued if
there is any more work to do. This particular path did not make that
call because it actually destroyed the svsk, making requeue pointless.
When the svc_delete_socket was change to just set a bit, we should have
added a call to svc_xprt_received,
This is the problem that b0401d7253 attempted to fix, incorrectly.
commit 1b644b6e6f6160ae35ce4b52c2ca89ed3e356e18 upstream.
This reverts commit b0401d725334a94d57335790b8ac2404144748ee, which
moved svc_delete_xprt() outside of XPT_BUSY, and allowed it to be called
after svc_xpt_recived(), removing its last reference and destroying it
after it had already been queued for future processing.
commit f5822754ea006563e1bf0a1f43faaad49c0d8bb2 upstream.
This reverts commit b292cf9ce70d221c3f04ff62db5ab13d9a249ca8. The
commit that it attempted to patch up,
b0401d725334a94d57335790b8ac2404144748ee, was fundamentally wrong, and
will also be reverted.
commit 9fcfe0c83c3b04a759cde6b8c5f961237f17808b upstream.
This can, for instance, happen if the user specifies a link local IPv6
address.
commit ab1b18f70a007ea6caeb007d269abb75b131a410 upstream.
The 'struct svc_deferred_req's on the xpt_deferred queue do not
own a reference to the owning xprt. This is seen in svc_revisit
which is where things are added to this queue. dr->xprt is set to
NULL and the reference to the xprt it put.
So when this list is cleaned up in svc_delete_xprt, we mustn't
put the reference.
Also, replace the 'for' with a 'while' which is arguably
simpler and more likely to compile efficiently.
Cc: Tom Tucker <tom@opengridcomputing.com>
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
nfs: fix oops in nfs_rename()
sunrpc: fix build-time warning
sunrpc: on successful gss error pipe write, don't return error
SUNRPC: Fix the return value in gss_import_sec_context()
SUNRPC: Fix up an error return value in gss_import_sec_context_kerberos()
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux:
sunrpc: fix peername failed on closed listener
nfsd: make sure data is on disk before calling ->fsync
nfsd: fix "insecure" export option
There're some warnings of "nfsd: peername failed (err 107)!"
socket error -107 means Transport endpoint is not connected.
This warning message was outputed by svc_tcp_accept() [net/sunrpc/svcsock.c],
when kernel_getpeername returns -107. This means socket might be CLOSED.
And svc_tcp_accept was called by svc_recv() [net/sunrpc/svc_xprt.c]
if (test_bit(XPT_LISTENER, &xprt->xpt_flags)) {
<snip>
newxpt = xprt->xpt_ops->xpo_accept(xprt);
<snip>
So this might happen when xprt->xpt_flags has both XPT_LISTENER and XPT_CLOSE.
Let's take a look at commit b0401d72, this commit has moved the close
processing after do recvfrom method, but this commit also introduces this
warnings, if the xpt_flags has both XPT_LISTENER and XPT_CLOSED, we should
close it, not accpet then close.
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Cc: stable@kernel.org
Fix auth_gss printk format warning:
net/sunrpc/auth_gss/auth_gss.c:660: warning: format '%ld' expects type 'long int', but argument 3 has type 'ssize_t'
Acked-by: Jeff Layton <jlayton@redhat.com>
When handling the gssd downcall, the kernel should distinguish between a
successful downcall that contains an error code and a failed downcall
(i.e. where the parsing failed or some other sort of problem occurred).
In the former case, gss_pipe_downcall should be returning the number of
bytes written to the pipe instead of an error. In the event of other
errors, we generally want the initiating task to retry the upcall so
we set msg.errno to -EAGAIN. An unexpected error code here is a bug
however, so BUG() in that case.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
If the context allocation fails, it will return GSS_S_FAILURE, which is
neither a valid error code, nor is it even negative.
Return ENOMEM instead...
Reported-by: Jeff Layton <jlayton@redhat.com>
If the context allocation fails, the function currently returns a random
error code, since the variable 'p' still points to a valid memory location.
Ensure that it returns ENOMEM...
NFSv4: Fix a regression in the NFSv4 state manager
NFSv4: Release the sequence id before restarting a CLOSE rpc call
nfs41: fix session fore channel negotiation
nfs41: do not zero seqid portion of stateid on close
nfs: run state manager in privileged mode
nfs: make recovery state manager operations privileged
nfs: enforce FIFO ordering of operations trying to acquire slot
rpc: add a new priority in RPC task
nfs: remove rpc_task argument from nfs4_find_slot
rpc: add rpc_queue_empty function
nfs: change nfs4_do_setlk params to identify recovery type
nfs: do not do a LOOKUP after open
nfs: minor cleanup of session draining
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits)
nfsd: remove pointless paths in file headers
nfsd: move most of nfsfh.h to fs/nfsd
nfsd: remove unused field rq_reffh
nfsd: enable V4ROOT exports
nfsd: make V4ROOT exports read-only
nfsd: restrict filehandles accepted in V4ROOT case
nfsd: allow exports of symlinks
nfsd: filter readdir results in V4ROOT case
nfsd: filter lookup results in V4ROOT case
nfsd4: don't continue "under" mounts in V4ROOT case
nfsd: introduce export flag for v4 pseudoroot
nfsd: let "insecure" flag vary by pseudoflavor
nfsd: new interface to advertise export features
nfsd: Move private headers to source directory
vfs: nfsctl.c un-used nfsd #includes
lockd: Remove un-used nfsd headers #includes
s390: remove un-used nfsd #includes
sparc: remove un-used nfsd #includes
parsic: remove un-used nfsd #includes
compat.c: Remove dependence on nfsd private headers
Signed-off-by: Alexandros Batsakis <batsakis@netapp.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
The pointer to struct gss_auth parameter in gss_add_msg is not really needed
after commit 5b7ddd4a. Zap it.
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
IS_ERR returns 1 or 0, PTR_ERR returns the error value.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits)
mac80211: fix reorder buffer release
iwmc3200wifi: Enable wimax core through module parameter
iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter
iwmc3200wifi: Coex table command does not expect a response
iwmc3200wifi: Update wiwi priority table
iwlwifi: driver version track kernel version
iwlwifi: indicate uCode type when fail dump error/event log
iwl3945: remove duplicated event logging code
b43: fix two warnings
ipw2100: fix rebooting hang with driver loaded
cfg80211: indent regulatory messages with spaces
iwmc3200wifi: fix NULL pointer dereference in pmkid update
mac80211: Fix TX status reporting for injected data frames
ath9k: enable 2GHz band only if the device supports it
airo: Fix integer overflow warning
rt2x00: Fix padding bug on L2PAD devices.
WE: Fix set events not propagated
b43legacy: avoid PPC fault during resume
b43: avoid PPC fault during resume
tcp: fix a timewait refcnt race
Fix up conflicts due to sysctl cleanups (dead sysctl_check code and
CTL_UNNUMBERED removed) in
kernel/sysctl_check.c
net/ipv4/sysctl_net_ipv4.c
net/ipv6/addrconf.c
net/sctp/sysctl.c
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits)
security/tomoyo: Remove now unnecessary handling of security_sysctl.
security/tomoyo: Add a special case to handle accesses through the internal proc mount.
sysctl: Drop & in front of every proc_handler.
sysctl: Remove CTL_NONE and CTL_UNNUMBERED
sysctl: kill dead ctl_handler definitions.
sysctl: Remove the last of the generic binary sysctl support
sysctl net: Remove unused binary sysctl code
sysctl security/tomoyo: Don't look at ctl_name
sysctl arm: Remove binary sysctl support
sysctl x86: Remove dead binary sysctl support
sysctl sh: Remove dead binary sysctl support
sysctl powerpc: Remove dead binary sysctl support
sysctl ia64: Remove dead binary sysctl support
sysctl s390: Remove dead sysctl binary support
sysctl frv: Remove dead binary sysctl support
sysctl mips/lasat: Remove dead binary sysctl support
sysctl drivers: Remove dead binary sysctl support
sysctl crypto: Remove dead binary sysctl support
sysctl security/keys: Remove dead binary sysctl support
sysctl kernel: Remove binary sysctl logic
kernel/irq/chip.c
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Introduce soft connect behavior for UDP transports. In this case, a
major timeout returns ETIMEDOUT instead of EIO.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Currently, if a remote RPC service is unreachable, an RPC ping will
hang until the underlying transport connect attempt times out. A more
desirable behavior might be to have the ping fail immediately so upper
layers can recover appropriately.
In the case of an NFS mount, for instance, this would mean the
mount(2) system call could fail immediately if the server isn't
listening, rather than hanging uninterruptibly for more than 3
minutes.
Change rpc_ping() so that it fails immediately for connection-oriented
transports. rpc_create() will then fail immediately for such
transports if an RPC ping was requested.
Autobinding is handled by the rpciod process, not in user processes
that are generating regular RPC requests. Thus autobinding is usually
not affected by signals targetting user processes, such as KILL or
timer expiration events.
In addition, an RPC request generated by a user process that has
RPC_TASK_SOFTCONN set and needs to perform an autobind will hang if
the remote rpcbind service is not available.
For rpcbind queries on connection-oriented transports, let's use the
new soft connect semantic to return control to the user's process
quickly, if the kernel's rpcbind client can't connect to the remote
rpcbind service.
Logic is introduced in call_bind_status() to handle connection errors
that occurred during an asynchronous rpcbind query. The logic
abandons the rpcbind query if the RPC request has SOFTCONN set, and
retries after a few seconds in the normal case.
Use TCP with the soft connect semantic for local rpcbind upcalls so
the kernel can detect immediately if the local rpcbind daemon is not
running.
The kernel's rpcbind client creates and deletes an rpc_clnt and its
underlying transport socket for every upcall to the local rpcbind
daemon.
When starting a typical NFS server on IPv4 and IPv6, the NFS service
itself does three upcalls (one per version) times two upcalls (one
per transport) times two upcalls (one per address family), making 12,
plus another one for the initial call to unregister previous NFS
services. Starting the NLM service adds an additional 13 upcalls,
for similar reasons.
(Currently the NFS service doesn't start IPv6 listeners, but it will
soon enough).
Instead, let's create an rpc_clnt for rpcbind upcalls during the
first local rpcbind query, and cache it. This saves the overhead of
creating and destroying an rpc_clnt and a socket for every upcall.
The new logic also prevents the kernel from attempting an RPCB_SET or
RPCB_UNSET if it knows from the start that the local portmapper does
not support rpcbind protocol version 4. This will cut down on the
number of rpcbind upcalls in legacy environments.
Clean up: At one point, rpcb_local_clnt() handled IPv6 loopback
addresses too, but it doesn't any more; only IPv4 loopback is used
now. Get rid of the @addr and @addrlen arguments to
rpcb_local_clnt().
The kernel sometimes makes RPC calls to services that aren't running.
Because the kernel's RPC client always assumes the hard retry semantic
when reconnecting a connection-oriented RPC transport, the underlying
reconnect logic takes a long while to time out, even though the remote
may have responded immediately with ECONNREFUSED.
In certain cases, like upcalls to our local rpcbind daemon, or for NFS
mount requests, we'd like the kernel to fail immediately if the remote
service isn't reachable. This allows another transport to be tried
immediately, or the pending request can be abandoned quickly.
Introduce a per-request flag which controls how call_transmit_status()
behaves when request transmission fails because the server cannot be
reached.
We don't want soft connection semantics to apply to other errors. The
default case of the switch statement in call_transmit_status() no
longer falls through; the fall through code is copied to the default
case, and a "break;" is added.
The transport's connection re-establishment timeout is also ignored for
such requests. We want the request to fail immediately, so the
reconnect delay is skipped. Additionally, we don't want a connect
failure here to further increase the reconnect timeout value, since
this request will not be retried.
The success case, where task->tk_status == 0, is by far the most
frequent case in call_transmit_status().
The default: arm of the switch statement in call_transmit_status()
handles the 0 case. default: was moved close to the top of the switch
statement in call_transmit_status() under the theory that the compiler
places object code for the earliest arms of a switch statement first,
making the CPU do less work.
The default: arm of a switch statement, however, is executed only
after all the other cases have been checked. Even if the compiler
rearranges the object code, the default: arm is the "last resort",
meaning all of the other cases have been explicitly exhausted. That
makes the current arrangement about as inefficient as it gets for the
common case.
To fix this, add an explicit check for zero before the switch
statement. That forces the compiler to do the zero check first, no
matter what optimizations it might try to do to the switch statement.
Recent changes to snprintf() introduced the %pI6c formatter, which can
display an IPv6 address with standard shorthanding. Using a
shorthanded address can save us a few bytes of memory for each stored
presentation address, or a few bytes on the wire when sending these in
a universal address.
It is possible for rpcauth_destroy_credcache() to cause the rpc credentials
to be unhashed while put_rpccred is waiting for the rpc_credcache_lock on
another cpu. Should this happen, then we can end up calling
hlist_del_rcu(&cred->cr_hash) a second time in put_rpccred, thus causing
list corruption.
Should the credential actually be hashed, it is also possible for
rpcauth_lookup_credcache to find and reference it before we get round to
unhashing it. In this case, the call to rpcauth_unhash_cred will fail, and
so we should just exit without destroying the cred.
Reported-by: Neil Brown <neilb@suse.de>
If the XPRT_CLOSE_WAIT flag is set, we need to ensure that we call
xprt->ops->close() while holding xprt_lock_write() before we can
start reconnecting.
net/mac80211/ht.c
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
This reverts commit 59a252ff8c0f2fa32c896f69d56ae33e641ce7ad.
This helps in an entirely cached workload but not necessarily in
workloads that require waiting on disk.
include/linux/sunrpc/svc.h
Reported-by: Simon Kirby <sim@hostway.ca>
Tested-by: Jesper Krogh <jesper@krogh.cc>
