path: root/net/sysctl_net.c
2006-06-05[NET]: Eliminate unused /proc/sys/net/ethernetJes Sorensen
The /proc/sys/net/ethernet directory has been sitting empty for more than 10 years! Time to eliminate it! Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[NET]: Fix "sysctl_net.c:36: error: 'core_table' undeclared here"Russell King
During the build for ARM machine type "fortunet", this error occurred: CC net/sysctl_net.o net/sysctl_net.c:36: error: 'core_table' undeclared here (not in a function) It appears that the following configuration settings cause this error due to a missing include: CONFIG_SYSCTL=y CONFIG_NET=y # CONFIG_INET is not set core_table appears to be declared in net/sock.h. if CONFIG_INET were defined, net/sock.h would have been included via: sysctl_net.c -> net/ip.h -> linux/ip.h -> net/sock.h so include it directly. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
