path: root/net/sysctl_net.c
2013-10-06net: Update the sysctl permissions handler to test effective uid/gidEric W. Biederman
Modify the code to use current_euid(), and in_egroup_p, as in done in fs/proc/proc_sysctl.c:test_perm() Cc: stable@vger.kernel.org Reviewed-by: Eric Sandeen <sandeen@redhat.com> Reported-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-18user_ns: get rid of duplicate code in net_ctl_permissionsZhao Hongjiang
Get rid of duplicate code in net_ctl_permissions and fix the comment. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Update the per network namespace sysctls to be available to the network ↵Eric W. Biederman
namespace owner - Allow anyone with CAP_NET_ADMIN rights in the user namespace of the the netowrk namespace to change sysctls. - Allow anyone the uid of the user namespace root the same permissions over the network namespace sysctls as the global root. - Allow anyone with gid of the user namespace root group the same permissions over the network namespace sysctl as the global root group. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18sysctl: Pass useful parameters to sysctl permissionsEric W. Biederman
- Current is implicitly avaiable so passing current->nsproxy isn't useful. - The ctl_table_header is needed to find how the sysctl table is connected to the rest of sysctl. - ctl_table_root is avaiable in the ctl_table_header so no need to it. With these changes it becomes possible to write a version of net_sysctl_permission that takes into account the network namespace of the sysctl table, an important feature in extending the user namespace. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-15net: delete all instances of special processing for token ringPaul Gortmaker
We are going to delete the Token ring support. This removes any special processing in the core networking for token ring, (aside from net/tr.c itself), leaving the drivers and remaining tokenring support present but inert. The mass removal of the drivers and net/tr.c will be in a separate commit, so that the history of these files that we still care about won't have the giant deletion tied into their history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-20net: Remove register_net_sysctl_tableEric W. Biederman
All of the users have been converted to use registera_net_sysctl so we no longer need register_net_sysctl. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Kill register_sysctl_rotableEric W. Biederman
register_sysctl_rotable never caught on as an interesting way to register sysctls. My take on the situation is that what we want are sysctls that we can only see in the initial network namespace. What we have implemented with register_sysctl_rotable are sysctls that we can see in all of the network namespaces and can only change in the initial network namespace. That is a very silly way to go. Just register the network sysctls in the initial network namespace and we don't have any weird special cases to deal with. The sysctls affected are: /proc/sys/net/ipv4/ipfrag_secret_interval /proc/sys/net/ipv4/ipfrag_max_dist /proc/sys/net/ipv6/ip6frag_secret_interval /proc/sys/net/ipv6/mld_max_msf I really don't expect anyone will miss them if they can't read them in a child user namespace. CC: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net sysctl: Initialize the network sysctls sooner to avoid problems.Eric W. Biederman
If the netfilter code is modified to use register_net_sysctl_table the kernel fails to boot because the per net sysctl infrasturce is not setup soon enough. So to avoid races call net_sysctl_init from sock_init(). Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net sysctl: Register an empty /proc/sys/netEric W. Biederman
Implementation limitations of the sysctl core won't let /proc/sys/net reside in a network namespace. /proc/sys/net at least must be registered as a normal sysctl. So register /proc/sys/net early as an empty directory to guarantee we don't violate this constraint and hit bugs in the sysctl implementation. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Implement register_net_sysctl.Eric W. Biederman
Right now all of the networking sysctl registrations are running in a compatibiity mode. The natvie sysctl registration api takes a cstring for a path and a simple ctl_table. Implement register_net_sysctl so that we can register network sysctls without needing to use compatiblity code in the sysctl core. Switching from a ctl_path to a cstring results in less boiler plate and denser code that is a little easier to read. I would simply have changed the arguments to register_net_sysctl_table instead of keeping two functions in parallel but gcc will allow a ctl_path pointer to be passed to a char * pointer with only issuing a warning resulting in completely incorrect code can be built. Since I have to change the function name I am taking advantage of the situation to let both register_net_sysctl and register_net_sysctl_table live for a short time in parallel which makes clean conversion patches a bit easier to read and write. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-24sysctl: Modify __register_sysctl_paths to take a set instead of a root and ↵Eric W. Biederman
an nsproxy An nsproxy argument here has always been awkard and now the nsproxy argument is completely unnecessary so remove it, replacing it with the set we want the registered tables to show up in. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-24sysctl: Add a root pointer to ctl_table_setEric W. Biederman
Add a ctl_table_root pointer to ctl_table set so it is easy to go from a ctl_table_set to a ctl_table_root. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-24sysctl: Remove the unnecessary sysctl_set parent concept.Eric W. Biederman
In sysctl_net register the two networking roots in the proper order. In register_sysctl walk the sysctl sets in the reverse order of the sysctl roots. Remove parent from ctl_table_set and setup_sysctl_set as it is no longer needed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-24sysctl: Implement retire_sysctl_setEric W. Biederman
This adds a small helper retire_sysctl_set to remove the intimate knowledge about the how a sysctl_set is implemented from net/sysct_net.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-24sysctl: Register the base sysctl table like any other sysctl table.Eric W. Biederman
Simplify the code by treating the base sysctl table like any other sysctl table and register it with register_sysctl_table. To ensure this table is registered early enough to avoid problems call sysctl_init from proc_sys_init. Rename sysctl_net.c:sysctl_init() to net_sysctl_init() to avoid name conflicts now that kernel/sysctl.c:sysctl_init() is no longer static. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-16net: sysctl_net - use net_eq to compare netsCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-07-27missing bits of net-namespace / sysctlAl Viro
Piss-poor sysctl registration API strikes again, film at 11... What we really need is _pathname_ required to be present in already registered table, so that kernel could warn about bad order. That's the next target for sysctl stuff (and generally saner and more explicit order of initialization of ipv[46] internals wouldn't hurt either). For the time being, here are full fixups required by ..._rotable() stuff; we make per-net sysctl sets descendents of "ro" one and make sure that sufficient skeleton is there before we start registering per-net sysctls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] beginning of sysctl cleanup - ctl_table_setAl Viro
New object: set of sysctls [currently - root and per-net-ns]. Contains: pointer to parent set, list of tables and "should I see this set?" method (->is_seen(set)). Current lists of tables are subsumed by that; net-ns contains such a beast. ->lookup() for ctl_table_root returns pointer to ctl_table_set instead of that to ->list of that ctl_table_set. [folded compile fixes by rdd for configs without sysctl] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25sysctl: allow override of /proc/sys/net with CAP_NET_ADMINStephen Hemminger
Extend the permission check for networking sysctl's to allow modification when current process has CAP_NET_ADMIN capability and is not root. This version uses the until now unused permissions hook to override the mode value for /proc/sys/net if accessed by a user with capabilities. Found while working with Quagga. It is impossible to turn forwarding on/off through the command interface because Quagga uses secure coding practice of dropping privledges during initialization and only raising via capabilities when necessary. Since the dameon has reset real/effective uid after initialization, all attempts to access /proc/sys/net variables will fail. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morgan <morgan@kernel.org> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19netns: Introduce sysctl root for read-only net sysctls.Pavel Emelyanov
This one stores all ctl-heads in one list and restricts the permissions not give write access to non-init net namespaces. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-01net: fix returning void-valued expression warningsHarvey Harrison
drivers/net/8390.c:37:2: warning: returning void-valued expression drivers/net/bnx2.c:1635:3: warning: returning void-valued expression drivers/net/xen-netfront.c:1806:2: warning: returning void-valued expression net/ipv4/tcp_hybla.c:105:3: warning: returning void-valued expression net/ipv4/tcp_vegas.c:171:3: warning: returning void-valued expression net/ipv4/tcp_veno.c:123:3: warning: returning void-valued expression net/sysctl_net.c:85:2: warning: returning void-valued expression Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Remove the empty net_tablePavel Emelyanov
I have removed all the entries from this table (core_table, ipv4_table and tr_table), so now we can safely drop it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TR]: Use ctl paths to register net/token-ring/ tablePavel Emelyanov
The same thing for token-ring - use ctl paths and get rid of external references on the tr_table. Unfortunately, I couldn't split this patch into cleanup and use-the-paths parts. As a lame excuse I can say, that the cleanup is just moving the tr_table from one file to another - closet to a single variable, that this ctl table tunes. Since the source file becomes empty after the move, I remove it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Use ctl paths to register net/ipv4/ tablePavel Emelyanov
This is the same as I did for the net/core/ table in the second patch in his series: use the paths and isolate the whole table in the .c file. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Isolate the net/core/ sysctl tablePavel Emelyanov
Using ctl paths we can put all the stuff, related to net/core/ sysctl table, into one file and remove all the references on it. As a good side effect this hides the "core_table" name from the global scope :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Implement the per network namespace sysctl infrastructureEric W. Biederman
The user interface is: register_net_sysctl_table and unregister_net_sysctl_table. Very much like the current interface except there is a network namespace parameter. With this any sysctl registered with register_net_sysctl_table will only show up to tasks in the same network namespace. All other sysctls continue to be globally visible. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-05[NET]: Eliminate unused /proc/sys/net/ethernetJes Sorensen
The /proc/sys/net/ethernet directory has been sitting empty for more than 10 years! Time to eliminate it! Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[NET]: Fix "sysctl_net.c:36: error: 'core_table' undeclared here"Russell King
During the build for ARM machine type "fortunet", this error occurred: CC net/sysctl_net.o net/sysctl_net.c:36: error: 'core_table' undeclared here (not in a function) It appears that the following configuration settings cause this error due to a missing include: CONFIG_SYSCTL=y CONFIG_NET=y # CONFIG_INET is not set core_table appears to be declared in net/sock.h. if CONFIG_INET were defined, net/sock.h would have been included via: sysctl_net.c -> net/ip.h -> linux/ip.h -> net/sock.h so include it directly. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
