Fix incorrect start markers, wrapped summary lines, missing section
breaks, incorrect separators, and some name mismatches.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Some of the comment blocks are floating in limbo between two
functions, or between blocks of code. Delete the extra line
feeds between any comment and its associated following block
of code, to be consistent with the majority of the rest of
the kernel. Also delete trailing newlines at EOF and fix
a couple trivial typos in existing comments.
This is a 100% cosmetic change with no runtime impact. We get
rid of over 500 lines of non-code, and being blank line deletes,
they won't even show up as noise in git blame.
The addition of the "s" to indicate pluralization is intentional,
since the struct actually contains two name variants.
This converts the following:
struct link -> struct tipc_link
struct link_req -> struct tipc_link_req
struct link_name -> struct tipc_link_name
Give it a meaningful prefix, as suggested by DaveM, so that it
is consistent with things like struct tipc_bearer, and so it isn't
confused with anything else. This has no impact on the actual
runtime code behaviour.
Permits run-time alteration of default link settings on a per-media
and per-bearer basis, in addition to the existing per-link basis.
The following syntax can now be used:
tipc-config -lt=<link-name|bearer-name|media-name>/<tolerance>
tipc-config -lp=<link-name|bearer-name|media-name>/<priority>
tipc-config -lw=<link-name|bearer-name|media-name>/<window>
Note that changes to the default settings for a given media type has
no effect on the default settings used by existing bearers. Similarly,
changes to default bearer settings has no effect on existing link
endpoints that utilize that interface.
Thanks to Florian Westphal <fw@strlen.de> for his contributions to
the development of this enhancement.
Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
Reworks TIPC's media address data structure and associated processing
routines to transfer all media-specific details of address conversion
to the associated TIPC media adaptation code. TIPC's generic bearer code
now only needs to know which media type an address is associated with
and whether or not it is a broadcast address, and totally ignores the
"value" field that contains the actual media-specific addressing info.
These changes eliminate the need for a number of endianness conversion
operations and will make it easier for TIPC to support new media types
in the future.
Enhances TIPC's Ethernet media support to provide 3 new address conversion
routines, which allow TIPC to interpret an address that is in string form
and to convert an address to and from the 20 byte format used in TIPC's
neighbor discovery messages.
These routines are pre-requisites to a follow on commit that hides all
media-specific addressing details from TIPC's generic bearer code.
Enhances conversion of a media address to printable form so that an
unconvertable address will be displayed as a string of hex digits,
rather than not being displayed at all. (Also removes a pointless check
for the existence of the media-specific address conversion routine,
since the routine is not optional.)
Speeds up the registration of TIPC media types by passing in a structure
containing the required information, rather than by passing in the various
fields describing the media type individually.
Reduces the number of bearers a node can support to 2, which can use
identical or non-identical media. This change won't impact users,
since they are currently limited to a maximum of 2 Ethernet bearers,
and will save memory by eliminating a number of unused entries in
TIPC's media and bearer arrays.
Gets rid of counter that records the number of times a bearer has
resumed after congestion or blocking, since the value is never
referenced anywhere.
Eliminates the flag in the TIPC bearer structure that indicates if
the bearer supports broadcasting, since the flag is always set to 1
and serves no useful purpose.
Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com>
Eliminates a field in TIPC's bearer objects that is set, but never
referenced.
Renames items that are improperly labelled as "network scope" items
(which are represented by simple integer values) rather than "network
domain" items (which are represented by <Z.C.N>-type network addresses).
This change is purely cosmetic, and does not affect the operation of TIPC.
Combines two distinct structures containing information about a TIPC bearer
into a single structure. The structures were previously kept separate so
that public information about a bearer could be made available to plug-in
media types using TIPC's native API, while the remaining information was
kept private for use by TIPC itself. However, now that the native API has
been removed there is no longer any need for this arrangement.
Since one of the structures was already embedded within the other, the
change largely involves replacing instances of "publ.foo" with "foo".
The changes do not otherwise alter the operation of TIPC bearers.
Removes several function declarations that aren't used anywhere,
either because they reference routines that no longer exist or
because all users of the function reference it after it has already
been defined.
Gets rid of #include statements that are no longer required as a
result of the merging of obsolete native API header file content
into other TIPC include files.
As part of the removal of TIPC's native API support it is no longer
necessary for TIPC to export symbols for routines that can be called
by kernel-based applications, nor for it to have header files that
kernel-based applications can include to access the declarations for
those routines. This commit eliminates the exporting of symbols by
TIPC and migrates the contents of each obsolete native API include
file into its corresponding non-native API equivalent.
The code which was migrated in this commit was migrated intact, in
that there are no technical changes combined with the relocation.
Convert bearer congestion inline routine that is more than one line into
a standard function, thereby eliminating some repeated code.
Fix TIPC to disallow sending to remote addresses prior to entering NET_MODE
user programs can oops the kernel by sending datagrams via AF_TIPC prior to
entering networked mode. The following backtrace has been observed:
ID: 13459 TASK: ffff810014640040 CPU: 0 COMMAND: "tipc-client"
[exception RIP: tipc_node_select_next_hop+90]
RIP: ffffffff8869d3c3 RSP: ffff81002d9a5ab8 RFLAGS: 00010202
RAX: 0000000000000001 RBX: 0000000000000001 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000001001001
RBP: 0000000001001001 R8: 0074736575716552 R9: 0000000000000000
R10: ffff81003fbd0680 R11: 00000000000000c8 R12: 0000000000000008
R13: 0000000000000001 R14: 0000000000000001 R15: ffff810015c6ca00
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
RIP: 0000003cbd8d49a3 RSP: 00007fffc84e0be8 RFLAGS: 00010206
RAX: 000000000000002c RBX: ffffffff8005d116 RCX: 0000000000000000
RDX: 0000000000000008 RSI: 00007fffc84e0c00 RDI: 0000000000000003
RBP: 0000000000000000 R8: 00007fffc84e0c10 R9: 0000000000000010
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 00007fffc84e0d10 R14: 0000000000000000 R15: 00007fffc84e0c30
ORIG_RAX: 000000000000002c CS: 0033 SS: 002b
What happens is that, when the tipc module in inserted it enters a standalone
node mode in which communication to its own address is allowed <0.0.0> but not
to other addresses, since the appropriate data structures have not been
allocated yet (specifically the tipc_net pointer). There is nothing stopping a
client from trying to send such a message however, and if that happens, we
attempt to dereference tipc_net.zones while the pointer is still NULL, and
explode. The fix is pretty straightforward. Since these oopses all arise from
the dereference of global pointers prior to their assignment to allocated
values, and since these allocations are small (about 2k total), lets convert
these pointers to static arrays of the appropriate size. All the accesses to
these bits consider 0/NULL to be a non match when searching, so all the lookups
still work properly, and there is no longer a chance of a bad dererence
anywhere. As a bonus, this lets us eliminate the setup/teardown routines for
those pointers, and elimnates the need to preform any locking around them to
prevent access while their being allocated/freed.
I've updated the tipc_net structure to behave this way to fix the exact reported
problem, and also fixed up the tipc_bearers and media_list arrays to fix an
obvious simmilar problem that arises from issuing tipc-config commands to
manipulate bearers/links prior to entering networked mode
I've tested this for a few hours by running the sanity tests and stress test
with the tipcutils suite, and nothing has fallen over. There have been a few
lockdep warnings, but those were there before, and can be addressed later, as
they didn't actually result in any deadlock.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Allan Stephens <allan.stephens@windriver.com>
CC: David S. Miller <davem@davemloft.net>
CC: tipc-discussion@lists.sourceforge.net
bearer.c | 37 ++++++-------------------------------
bearer.h | 2 +-
net.c | 25 ++++---------------------
3 files changed, 11 insertions(+), 53 deletions(-)
Andrew Morton reported a build failure on sparc32, because TIPC
uses names like "struct node" and there is a like named data
structure defined in linux/node.h
This just regexp replaces "struct node*" to "struct tipc_node*"
to avoid this and any future similar problems.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch adds a tipc_ prefix to all externally visible symbols.
Signed-off-by: Per Liden <per.liden@ericsson.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
Updated copyright notice to include the year the file was
actually created. Information about file creation dates
was extracted from the files in the old CVS repository
at tipc.sourceforge.net.
Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
The copyright statements from different parts of Ericsson
have been merged into one.
The license header in each file now more clearly state that this
code is licensed under a dual BSD/GPL. Before this was only
evident if you looked at the MODULE_LICENSE line in core.c.
TIPC (Transparent Inter Process Communication) is a protocol designed for
intra cluster communication. For more information see
http://tipc.sourceforge.net
