path: root/net/tipc/discover.h
2011-05-10tipc: Add monitoring of number of nodes discovered by bearerAllan Stephens
Augments TIPC's discovery object to track the number of neighboring nodes having an active link to the associated bearer. This means tipc_disc_update_link_req() becomes either one of: tipc_disc_add_dest() or: tipc_disc_remove_dest() depending on the code flow direction of things. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-10tipc: Enhance handling of discovery object creation failuresAllan Stephens
Modifies bearer creation and deletion code to improve handling of scenarios when a neighbor discovery object cannot be created. The creation routine now aborts the creation of a bearer if its discovery object cannot be created, and deletes the newly created bearer, rather than failing quietly and leaving an unusable bearer hanging around. Since the exit via the goto label really isn't a definitive failure in all cases, relabel it appropriately. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-23tipc: Remove unused message header field for requested number of linksAllan Stephens
Eliminates support for the "number of requested links" field in a neighbor discovery message. This field was never used and has been removed from the TIPC 2.0 protocol specification. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-23tipc: Combine bearer structure with tipc_bearer structureAllan Stephens
Combines two distinct structures containing information about a TIPC bearer into a single structure. The structures were previously kept separate so that public information about a bearer could be made available to plug-in media types using TIPC's native API, while the remaining information was kept private for use by TIPC itself. However, now that the native API has been removed there is no longer any need for this arrangement. Since one of the structures was already embedded within the other, the change largely involves replacing instances of "publ.foo" with "foo". The changes do not otherwise alter the operation of TIPC bearers. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-12-02tipc: Remove obsolete inclusions of header filesAllan Stephens
Gets rid of #include statements that are no longer required as a result of the merging of obsolete native API header file content into other TIPC include files. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-16tipc: cleanup function namespacestephen hemminger
Do some cleanups of TIPC based on make namespacecheck 1. Don't export unused symbols 2. Eliminate dead code 3. Make functions and variables local 4. Rename buf_acquire to tipc_buf_acquire since it is used in several files Compile tested only. This make break out of tree kernel modules that depend on TIPC routines. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13tipc: clean out all instances of #if 0'd unused codePaul Gortmaker
Remove all instances of legacy, or as yet to be implemented code that is currently living within an #if 0 ... #endif block. In the rare instance that some of it be needed in the future, it can still be dragged out of history, but there is no need for it to sit in mainline. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04tipc: Minor optimizations to received message processingAllan Stephens
This patch enhances TIPC's handler for incoming messages in two ways: - the trivial, single-use routine for processing non-sequenced messages has been merged into the main handler - the interface that received a message is now identified without having to access and/or modify the associated sk_buff Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] TIPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Avoid polluting the global namespacePer Liden
This patch adds a tipc_ prefix to all externally visible symbols. Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-18[TIPC] Minor changes to #includesJon Maloy
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
2006-01-12[TIPC] Update of file headersPer Liden
The copyright statements from different parts of Ericsson have been merged into one. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] License header updatePer Liden
The license header in each file now more clearly state that this code is licensed under a dual BSD/GPL. Before this was only evident if you looked at the MODULE_LICENSE line in core.c. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
