path: root/net/tipc/net.c
2012-08-20tipc: change tipc_net_start routine return value typeYing Xue
Since now tipc_net_start() always returns a success code - 0, its return value type should be changed from integer to void, which can avoid unnecessary check for its return value. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-13tipc: use standard printk shortcut macros (pr_err etc.)Erik Hugne
All messages should go directly to the kernel log. The TIPC specific error, warning, info and debug trace macro's are removed and all references replaced with pr_err, pr_warn, pr_info and pr_debug. Commonly used sub-strings are explicitly declared as a const char to reduce .text size. Note that this means the debug messages (changed to pr_debug), are now enabled through dynamic debugging, instead of a TIPC specific Kconfig option (TIPC_DEBUG). The latter will be phased out completely Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> [PG: use pr_fmt as suggested by Joe Perches <joe@perches.com>] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-26tipc: Enhance re-initialization of network topology serviceAllan Stephens
Streamlines the job of re-initializing TIPC's network topology service when a node's network address is first assigned. Rather than destroying the topology server port and breaking its connections to existing subscribers, TIPC now simply lets the service continue running (since the change to the port identifier of each port used by the topology service no longer impacts the flow of messages between the service and its subscribers). This enhancement means that applications that utilize the topology service prior to the assignment of TIPC's network address no longer need to re-establish their subscriptions when the address is finally assigned. However, it is worth noting that any subsequent events for existing subscriptions report the new port identifier of the publishing port, rather than the original port identifier. (For example, a name that was previously reported as being published by <0.0.0:ref> may be subsequently withdrawn by <Z.C.N:ref>.) This doesn't impact any of the existing known userspace in tipc-utils, since (a) TIPC continues to treat references to the original port ID correctly and (b) normal use cases assign an address before active use. However if there does happen to be some rare/custom application out there that was relying on this, they can simply bypass the enhancement by issuing a subscription to {0,0} and break its connection to the topology service, if an associated withdrawal event occurs. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-26tipc: Optimize re-initialization of configuration serviceAllan Stephens
Streamlines the job of re-initializing TIPC's configuration service when a node's network address is first assigned. Rather than destroying the configuration server port and then recreating it, TIPC now simply withdraws the existing {0,<0.0.0>} name publication and creates a new {0,<Z.C.N>} name publication that identifies the node's network address to interested subscribers. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-19tipc: take lock while updating node network addressAllan Stephens
The routine that changes the node's network address now takes TIPC's network lock in write mode while the main address variable and associated data structures are being changed; this is needed to ensure that the link subsystem won't attempt to send a message off-node until the sending port's message header template has been updated with the node's new network address. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-24tipc: Eliminate support for tipc_mode global variableAllan Stephens
Removes all references to the global variable that records whether TIPC is running in "single node" mode or "network" mode, since this information can be easily deduced from the global variable that records TIPC's network address. (i.e. a non-zero network address means that TIPC is running in network mode.) The changes made update most existing mode-based checks to use the network address global variable. A few checks that are no longer needed are removed entirely, along with any associated code lying on non-executable control paths. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-24tipc: Eliminate trivial buffer manipulation helper routinesAllan Stephens
Gets rid of two inlined routines that simply call existing sk_buff manipulation routines, since there is no longer any extra processing done by the helper routines. Note that these changes are essentially cosmetic in nature, and have no impact on the actual operation of TIPC. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-12-27tipc: Eliminate dynamic allocation of broadcast link data structuresAllan Stephens
Creates global variables to hold the broadcast link's pseudo-bearer and pseudo-link structures, rather than allocating them dynamically. There is only a single instance of each structure, and changing over to static allocation allows elimination of code to handle the cases where dynamic allocation was unsuccessful. The memset in the teardown code may look like they aren't used, but the same teardown code is run when there is a non-fatal error at init-time, so that stale data isn't present when the user fixes the cause of the soft error. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-12-27tipc: Minor correction to TIPC module unloadingAllan Stephens
Modifies TIPC's module unloading logic to switch itself into "single node" mode before starting to terminate networking support. This helps to ensure that no operations that require TIPC to be in "networking" mode can initiate once unloading starts. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-01tipc: Remove obsolete manipulation of message re-route count fieldAllan Stephens
Eliminates code that increments and validates the re-route count field of payload messages, since the elimination of multi-cluster support means that it is no longer necessary for TIPC to forward incoming messages to another node. (The obsolete code was incorrect anyway, since it incorrectly incremented the re-route count field of messages that originated on the node that forwarded the message.) Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-14tipc: delete extra semicolon blocking node deletionPaul Gortmaker
Remove bogus semicolon only recently introduced in 34e46258cb9f5 that blocks cleanup of nodes for N>1 on shutdown. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: manually inline net_start/stop, make assoc. vars staticAllan Stephens
Relocates network-related variables into the subsystem files where they are now primarily used (following the recent rework of TIPC's node table), and converts globals into locals where possible. Changes the initialization of tipc_num_links from run-time to compile-time, and eliminates the net_start routine that becomes empty as a result. Also eliminates the corresponding net_stop routine by moving its (trivial) content into the one location that called the routine. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: Convert node object array to a hash tableAllan Stephens
Replaces the dynamically allocated array of pointers to the cluster's node objects with a static hash table. Hash collisions are resolved using chaining, with a typical hash chain having only a single node, to avoid degrading performance during processing of incoming packets. The conversion to a hash table reduces the memory requirements for TIPC's node table to approximately the same size it had prior to the previous commit. In addition to the hash table itself, TIPC now also maintains a linked list for the node objects, sorted by ascending network address. This list allows TIPC to continue sending responses to user space applications that request node and link information in sorted order. The list also improves performance when name table update messages are sent by making it easier to identify the nodes that must be notified. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: Eliminate configuration for maximum number of cluster nodesAllan Stephens
Gets rid of the need for users to specify the maximum number of cluster nodes supported by TIPC. TIPC now automatically provides support for all 4K nodes allowed by its addressing scheme. Note: This change sets TIPC's memory usage to the amount used by a maximum size node table with 4K entries. An upcoming patch that converts the node table from a linear array to a hash table will compact the node table to a more efficient design, but for clarity it is nice to have all the Kconfig infrastruture go away separately. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: Split up unified structure of network-related variablesAllan Stephens
Converts the fields of the global "tipc_net" structure into individual variables. Since the struct was never referenced as a complete unit, its existence was pointless. This will facilitate upcoming changes to TIPC's node table and simpify upcoming relocation of the variables so they are only visible to the files that actually use them. This change is essentially cosmetic in nature, and doesn't affect the operation of TIPC. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: Fix problem with missing link in "tipc-config -l" outputAllan Stephens
Removes a race condition that could cause TIPC's internal counter of the number of links it has to neighboring nodes to have the incorrect value if two independent threads of control simultaneously create new link endpoints connecting to two different nodes using two different bearers. Such under counting would result in TIPC failing to list the final link(s) in its response to a configuration request to list all of the node's links. The counter is now updated atomically to ensure that simultaneous increments do not interfere with each other. Thanks go to Peter Butler <pbutler@pt.com> for his assistance in diagnosing and fixing this problem. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-01tipc: remove redundant #includesAllan Stephens
Eliminates a number of #include statements that no longer serve any useful purpose. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove calls to dbg() and msg_dbg()Allan Stephens
Eliminates obsolete calls to two of TIPC's main debugging macros, as well as a pair of associated debugging routines that are no longer required. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting multiple clustersAllan Stephens
Eliminates routines, data structures, and files that were intended to allow TIPC to support a network containing multiple clusters. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting inter-cluster routingAllan Stephens
Eliminates routines and data structures that were intended to allow TIPC to route messages to other clusters. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting multiple zonesAllan Stephens
Eliminates routines, data structures, and files that were intended to allows TIPC to support a network containing multiple zones. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove obsolete inclusions of header filesAllan Stephens
Gets rid of #include statements that are no longer required as a result of the merging of obsolete native API header file content into other TIPC include files. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13tipc: clean out all instances of #if 0'd unused codePaul Gortmaker
Remove all instances of legacy, or as yet to be implemented code that is currently living within an #if 0 ... #endif block. In the rare instance that some of it be needed in the future, it can still be dragged out of history, but there is no need for it to sit in mainline. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09tipc: Optimize handling excess content on incoming messagesPaul Gortmaker
Remove code that trimmed excess trailing info from incoming messages arriving over an Ethernet interface. TIPC now ignores the extra info while the message is being processed by the node, and only trims it off if the message is retransmitted to another node. (This latter step is done to ensure the extra info doesn't cause the sk_buff to exceed the outgoing interface's MTU limit.) The outgoing buffer is guaranteed to be linear. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12tipc: add tipc_ prefix to fcns targeted for un-inliningAllan Stephens
These functions have enough code in them such that they seem like sensible targets for un-inlining. Prior to doing that, this adds the tipc_ prefix to the functions, so that in the event of a panic dump or similar, the subsystem from which the functions come from is immediately clear. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30tipc: define needless global scoped variable staticHagen Paul Pfeifer
struct _zone *tipc_zones has local scope level and should defined with the correct scoping. CC: Per Liden <per.liden@nospam.ericsson.com> Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-24tipc: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Per Liden <per.liden@ericsson.com> Cc: Jon Maloy <jon.maloy@ericsson.com> Cc: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-04tipc: Fix oops on send prior to entering networked mode (v3)Neil Horman
Fix TIPC to disallow sending to remote addresses prior to entering NET_MODE user programs can oops the kernel by sending datagrams via AF_TIPC prior to entering networked mode. The following backtrace has been observed: ID: 13459 TASK: ffff810014640040 CPU: 0 COMMAND: "tipc-client" [exception RIP: tipc_node_select_next_hop+90] RIP: ffffffff8869d3c3 RSP: ffff81002d9a5ab8 RFLAGS: 00010202 RAX: 0000000000000001 RBX: 0000000000000001 RCX: 0000000000000001 RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000001001001 RBP: 0000000001001001 R8: 0074736575716552 R9: 0000000000000000 R10: ffff81003fbd0680 R11: 00000000000000c8 R12: 0000000000000008 R13: 0000000000000001 R14: 0000000000000001 R15: ffff810015c6ca00 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 RIP: 0000003cbd8d49a3 RSP: 00007fffc84e0be8 RFLAGS: 00010206 RAX: 000000000000002c RBX: ffffffff8005d116 RCX: 0000000000000000 RDX: 0000000000000008 RSI: 00007fffc84e0c00 RDI: 0000000000000003 RBP: 0000000000000000 R8: 00007fffc84e0c10 R9: 0000000000000010 R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000 R13: 00007fffc84e0d10 R14: 0000000000000000 R15: 00007fffc84e0c30 ORIG_RAX: 000000000000002c CS: 0033 SS: 002b What happens is that, when the tipc module in inserted it enters a standalone node mode in which communication to its own address is allowed <0.0.0> but not to other addresses, since the appropriate data structures have not been allocated yet (specifically the tipc_net pointer). There is nothing stopping a client from trying to send such a message however, and if that happens, we attempt to dereference tipc_net.zones while the pointer is still NULL, and explode. The fix is pretty straightforward. Since these oopses all arise from the dereference of global pointers prior to their assignment to allocated values, and since these allocations are small (about 2k total), lets convert these pointers to static arrays of the appropriate size. All the accesses to these bits consider 0/NULL to be a non match when searching, so all the lookups still work properly, and there is no longer a chance of a bad dererence anywhere. As a bonus, this lets us eliminate the setup/teardown routines for those pointers, and elimnates the need to preform any locking around them to prevent access while their being allocated/freed. I've updated the tipc_net structure to behave this way to fix the exact reported problem, and also fixed up the tipc_bearers and media_list arrays to fix an obvious simmilar problem that arises from issuing tipc-config commands to manipulate bearers/links prior to entering networked mode I've tested this for a few hours by running the sanity tests and stress test with the tipcutils suite, and nothing has fallen over. There have been a few lockdep warnings, but those were there before, and can be addressed later, as they didn't actually result in any deadlock. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Allan Stephens <allan.stephens@windriver.com> CC: David S. Miller <davem@davemloft.net> CC: tipc-discussion@lists.sourceforge.net bearer.c | 37 ++++++------------------------------- bearer.h | 2 +- net.c | 25 ++++--------------------- 3 files changed, 11 insertions(+), 53 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-02tipc: Don't use structure names which easily globally conflict.David S. Miller
Andrew Morton reported a build failure on sparc32, because TIPC uses names like "struct node" and there is a like named data structure defined in linux/node.h This just regexp replaces "struct node*" to "struct tipc_node*" to avoid this and any future similar problems. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14tipc: Eliminate improper use of TIPC_OK error codeAllan Stephens
This patch corrects many places where TIPC routines indicated successful completion by returning TIPC_OK instead of 0. (The TIPC_OK symbol has the value 0, but it should only be used in contexts that deal with the error code field of a TIPC message header.) Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21tipc: Fix initialization sequence problems when entering network modeAllan Stephens
This patch ensures that TIPC's topology service and configuration service are shut down before switching into "network mode". This ensures that TIPC does not mistakenly try to send unnecessary "publication withdraw" messages to other nodes before it is fully initialized for sending off-node messages. Note that the node's current network address is now updated only after the two services are shut down; this ensures that any existing connections to the topology server are terminated correctly using the old address. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] TIPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[TIPC]: CleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global functions: - name_table.c: tipc_nametbl_print() - name_table.c: tipc_nametbl_dump() - net.c: tipc_net_next_node() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Fix simple sparse warningsSam Ravnborg
Tried to run the new tipc stack through sparse. Following patch fixes all cases where 0 was used as replacement of NULL. Use NULL to document this is a pointer and to silence sparse. This brough sparse warning count down with 127 to 24 warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Avoid polluting the global namespacePer Liden
This patch adds a tipc_ prefix to all externally visible symbols. Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-12[TIPC] More updates of file headersPer Liden
Updated copyright notice to include the year the file was actually created. Information about file creation dates was extracted from the files in the old CVS repository at tipc.sourceforge.net. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Update of file headersPer Liden
The copyright statements from different parts of Ericsson have been merged into one. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] License header updatePer Liden
The license header in each file now more clearly state that this code is licensed under a dual BSD/GPL. Before this was only evident if you looked at the MODULE_LICENSE line in core.c. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
