path: root/net/tipc/node_subscr.h
2012-04-30tipc: compress out gratuitous extra carriage returnsPaul Gortmaker
Some of the comment blocks are floating in limbo between two functions, or between blocks of code. Delete the extra line feeds between any comment and its associated following block of code, to be consistent with the majority of the rest of the kernel. Also delete trailing newlines at EOF and fix a couple trivial typos in existing comments. This is a 100% cosmetic change with no runtime impact. We get rid of over 500 lines of non-code, and being blank line deletes, they won't even show up as noise in git blame. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: Cosmetic changes to node subscription codeAllan Stephens
Relocates the code that notifies users of node subscriptions so that it is adjacent to the rest of the routines that implement TIPC's node subscription capability. Renames the name table routine that is invoked by a node subscription to better reflect its purpose and to be consistent with other, similar name table routines. These changes are cosmetic in nature, and do not alter the behavior of TIPC. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-09-02tipc: Don't use structure names which easily globally conflict.David S. Miller
Andrew Morton reported a build failure on sparc32, because TIPC uses names like "struct node" and there is a like named data structure defined in linux/node.h This just regexp replaces "struct node*" to "struct tipc_node*" to avoid this and any future similar problems. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] TIPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Avoid polluting the global namespacePer Liden
This patch adds a tipc_ prefix to all externally visible symbols. Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-12[TIPC] More updates of file headersPer Liden
Updated copyright notice to include the year the file was actually created. Information about file creation dates was extracted from the files in the old CVS repository at tipc.sourceforge.net. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Update of file headersPer Liden
The copyright statements from different parts of Ericsson have been merged into one. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] License header updatePer Liden
The license header in each file now more clearly state that this code is licensed under a dual BSD/GPL. Before this was only evident if you looked at the MODULE_LICENSE line in core.c. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
