path: root/net/tipc/port.h
2011-05-10tipc: Avoid recomputation of outgoing message lengthAllan Stephens
Rework TIPC's message sending routines to take advantage of the total amount of data value passed to it by the kernel socket infrastructure. This change eliminates the need for TIPC to compute the size of outgoing messages itself, as well as the check for an oversize message in tipc_msg_build(). In addition, this change warrants an explanation: - res = send_packet(NULL, sock, &my_msg, 0); + res = send_packet(NULL, sock, &my_msg, bytes_to_send); Previously, the final argument to send_packet() was ignored (since the amount of data being sent was recalculated by a lower-level routine) and we could just pass in a dummy value (0). Now that the recalculation is being eliminated, the argument value being passed to send_packet() is significant and we have to supply the actual amount of data we want to send. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-23tipc: Remove support for per-connection message sequence numberingAllan Stephens
Eliminates TIPC's prototype support for message sequence numbering on routable connections (i.e. connections requiring more than one hop). This capability isn't currently used, and can be removed since TIPC only supports systems in which all inter-node communication can be achieved in a single hop. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-23tipc: Fix port counter handling to correct congestion controlAllan Stephens
Modifies TIPC's congestion control between a connected port and its peer so that it works as documented. The following changes have been made: 1) The counter of the number of messages sent by a port now starts at zero, rather than one. This prevents the port from reporting port congestion one message earlier than it was supposed to. 2) The counter of the number of messages sent by a port is now incremented only if a non-empty message is sent successfully. This prevents the port from becoming permanently congested if too many send attempts are unsuccessful because of congestion (or other reasons). It also removes the risk that empty hand- shaking messages used during connection setup might cause the port to report congestion earlier than it was supposed to. 3) The counter of the number of unacknowledged messages received by a port controlled by an internal TIPC service is now incremented only if the message is non-empty, in order to be consistent with the aforementioned changes. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-23tipc: Combine port structure with tipc_port structureAllan Stephens
Merge two distinct structures containing information about a TIPC port into a single structure. The structures were previously kept separate so that public information about a port could be made available to applications using TIPC's native API, while the remaining information was kept private for use by TIPC itself. However, now that the native API has been removed there is no longer any need for this somewhat confusing arrangement. Since one of the structures was already embedded within the other, the change largely involves replacing instances of "publ.foo" with "foo". The changes do not otherwise alter the operation of TIPC ports. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-01tipc: cleanup various cosmetic whitespace issuesAllan Stephens
Cleans up TIPC's source code to eliminate deviations from generally accepted coding conventions relating to leading/trailing white space and white space around commas, braces, cases, and sizeof. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove calls to dbg() and msg_dbg()Allan Stephens
Eliminates obsolete calls to two of TIPC's main debugging macros, as well as a pair of associated debugging routines that are no longer required. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove user registry subsystemAllan Stephens
Eliminates routines, data structures, and files that make up TIPC's user registry. The user registry is no longer needed since the native API routines that utilized it no longer exist and there are no longer any internal TIPC services that use it. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete tipc_ownidentity()Allan Stephens
Moves the content of the native API routine tipc_ownidentity() into the sole routine that calls it, since it can no longer be called in isolation. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate obsolete native API forwarding routinesAllan Stephens
Moves the content of each native API message forwarding routine into the sole routine that calls it, since the forwarding routines no longer be called in isolation. Also removes code in each routine that altered the outgoing message's importance level since this is now no longer possible. The previous function mapping (parent function, and child API) was as follows: tipc_send2name \--tipc_forward2name tipc_send2port \--tipc_forward2port tipc_send_buf2port \--tipc_forward_buf2port After this commit, the children don't exist and their functionality is completely in the respective parent. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove unused domain argument from multicast send routineAllan Stephens
Eliminates an unused argument from tipc_multicast(), now that this routine can no longer be called by kernel-based applications. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete useless function prototypesAllan Stephens
Removes several function declarations that aren't used anywhere, either because they reference routines that no longer exist or because all users of the function reference it after it has already been defined. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove obsolete inclusions of header filesAllan Stephens
Gets rid of #include statements that are no longer required as a result of the merging of obsolete native API header file content into other TIPC include files. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove obsolete native API files and exportsAllan Stephens
As part of the removal of TIPC's native API support it is no longer necessary for TIPC to export symbols for routines that can be called by kernel-based applications, nor for it to have header files that kernel-based applications can include to access the declarations for those routines. This commit eliminates the exporting of symbols by TIPC and migrates the contents of each obsolete native API include file into its corresponding non-native API equivalent. The code which was migrated in this commit was migrated intact, in that there are no technical changes combined with the relocation. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-16tipc: cleanup function namespacestephen hemminger
Do some cleanups of TIPC based on make namespacecheck 1. Don't export unused symbols 2. Eliminate dead code 3. Make functions and variables local 4. Rename buf_acquire to tipc_buf_acquire since it is used in several files Compile tested only. This make break out of tree kernel modules that depend on TIPC routines. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12tipc: Eliminate obsolete port's "congested_link" fieldAllan Stephens
Eliminate a field of the TIPC port structure that is populated, but never referenced. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-02tipc: Don't use structure names which easily globally conflict.David S. Miller
Andrew Morton reported a build failure on sparc32, because TIPC uses names like "struct node" and there is a like named data structure defined in linux/node.h This just regexp replaces "struct node*" to "struct tipc_node*" to avoid this and any future similar problems. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[TIPC]: Optimize stream send routine to avoid fragmentationAllan Stephens
This patch enhances TIPC's stream socket send routine so that it avoids transmitting data in chunks that require fragmentation and reassembly, thereby improving performance at both the sending and receiving ends of the connection. The "maximum packet size" hint that records MTU info allows the socket to decide how big a chunk it should send; in the event that the hint has become stale, fragmentation may still occur, but the data will be passed correctly and the hint will be updated in time for the following send. Note: The 66060 byte pseudo-MTU used for intra-node connections requires the send routine to perform an additional check to ensure it does not exceed TIPC"s limit of 66000 bytes of user data per chunk. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Jon Paul Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] TIPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Avoid polluting the global namespacePer Liden
This patch adds a tipc_ prefix to all externally visible symbols. Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-18[TIPC] Minor changes to #includesJon Maloy
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
2006-01-12[TIPC] More updates of file headersPer Liden
Updated copyright notice to include the year the file was actually created. Information about file creation dates was extracted from the files in the old CVS repository at tipc.sourceforge.net. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Update of file headersPer Liden
The copyright statements from different parts of Ericsson have been merged into one. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] License header updatePer Liden
The license header in each file now more clearly state that this code is licensed under a dual BSD/GPL. Before this was only evident if you looked at the MODULE_LICENSE line in core.c. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
