commit 526f5b851a96566803ee4bee60d0a34df56c77f8 upstream.
Error message printed:
modprobe: ERROR: could not insert 'tipc': Address family not
supported by protocol.
when modprobe tipc after the following patch: switch order of
device registration, commit 7e27e8d6130c
("tipc: switch order of device registration to fix a crash")
Because sock_create_kern(net, AF_TIPC, ...) called by
tipc_topsrv_create_listener() in the initialization process
of tipc_init_net(), so tipc_socket_init() must be execute before that.
Meanwhile, tipc_net_id need to be initialized when sock_create()
called, and tipc_socket_init() is no need to be called for each namespace.
I add a variable tipc_topsrv_net_ops, and split the
register_pernet_subsys() of tipc into two parts, and split
tipc_socket_init() with initialization of pernet params.
By the way, I fixed resources rollback error when tipc_bcast_init()
failed in tipc_init_net().
Fixes: 7e27e8d6130c ("tipc: switch order of device registration to fix a crash")
Signed-off-by: Junwei Hu <hujunwei4@huawei.com>
Reported-by: Wang Wang <wangwang2@huawei.com>
Reported-by: syzbot+1e8114b61079bfe9cbc5@syzkaller.appspotmail.com
Reviewed-by: Kang Zhou <zhoukang7@huawei.com>
Reviewed-by: Suanming Mou <mousuanming@huawei.com>
commit 29e270fc32192e7729057963ae7120663856c93e upstream.
Got below warning with gcc 8.2 compiler.
net/tipc/topsrv.c: In function ‘tipc_topsrv_start’:
net/tipc/topsrv.c:660:2: warning: ‘strncpy’ specified bound depends on the length of the source argument [-Wstringop-overflow=]
strncpy(srv->name, name, strlen(name) + 1);
net/tipc/topsrv.c:660:27: note: length computed here
So change it to correct length and use strscpy.
Signed-off-by: Guoqing Jiang <gqjiang@suse.com>
Acked-by: Ying Xue <ying.xue@windriver.com>
[ Upstream commit fd849b7c41f0fabfe783d0691a63c5518e8ebc99 ]
No matter whether a request is inserted into workqueue as a work item
to cancel a subscription or to delete a subscription's subscriber
asynchronously, the work items may be executed in different workers.
As a result, it doesn't mean that one request which is raised prior to
another request is definitely handled before the latter. By contrast,
if the latter request is executed before the former request, below
error may happen:
[ 656.183644] BUG: spinlock bad magic on CPU#0, kworker/u8:0/12117
[ 656.184487] general protection fault: 0000 [#1] SMP
[ 656.185160] Modules linked in: tipc ip6_udp_tunnel udp_tunnel 9pnet_virtio 9p 9pnet virtio_net virtio_pci virtio_ring virtio [last unloaded: ip6_udp_tunnel]
[ 656.187003] CPU: 0 PID: 12117 Comm: kworker/u8:0 Not tainted 4.11.0-rc7+ #6
[ 656.187920] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 656.188690] Workqueue: tipc_rcv tipc_recv_work [tipc]
[ 656.189371] task: ffff88003f5cec40 task.stack: ffffc90004448000
[ 656.190157] RIP: 0010:spin_bug+0xdd/0xf0
[ 656.190678] RSP: 0018:ffffc9000444bcb8 EFLAGS: 00010202
[ 656.191375] RAX: 0000000000000034 RBX: ffff88003f8d1388 RCX: 0000000000000000
[ 656.192321] RDX: ffff88003ba13708 RSI: ffff88003ba0cd08 RDI: ffff88003ba0cd08
[ 656.193265] RBP: ffffc9000444bcd0 R08: 0000000000000030 R09: 000000006b6b6b6b
[ 656.194208] R10: ffff8800bde3e000 R11: 00000000000001b4 R12: 6b6b6b6b6b6b6b6b
[ 656.195157] R13: ffffffff81a3ca64 R14: ffff88003f8d1388 R15: ffff88003f8d13a0
[ 656.196101] FS: 0000000000000000(0000) GS:ffff88003ba00000(0000) knlGS:0000000000000000
[ 656.197172] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 656.197935] CR2: 00007f0b3d2e6000 CR3: 000000003ef9e000 CR4: 00000000000006f0
[ 656.198873] Call Trace:
[ 656.199210] do_raw_spin_lock+0x66/0xa0
[ 656.199735] _raw_spin_lock_bh+0x19/0x20
[ 656.200258] tipc_subscrb_subscrp_delete+0x28/0xf0 [tipc]
[ 656.200990] tipc_subscrb_rcv_cb+0x45/0x260 [tipc]
[ 656.201632] tipc_receive_from_sock+0xaf/0x100 [tipc]
[ 656.202299] tipc_recv_work+0x2b/0x60 [tipc]
[ 656.202872] process_one_work+0x157/0x420
[ 656.203404] worker_thread+0x69/0x4c0
[ 656.203898] kthread+0x138/0x170
[ 656.204328] ? process_one_work+0x420/0x420
[ 656.204889] ? kthread_create_on_node+0x40/0x40
[ 656.205527] ret_from_fork+0x29/0x40
[ 656.206012] Code: 48 8b 0c 25 00 c5 00 00 48 c7 c7 f0 24 a3 81 48 81 c1 f0 05 00 00 65 8b 15 61 ef f5 7e e8 9a 4c 09 00 4d 85 e4 44 8b 4b 08 74 92 <45> 8b 84 24 40 04 00 00 49 8d 8c 24 f0 05 00 00 eb 8d 90 0f 1f
[ 656.208504] RIP: spin_bug+0xdd/0xf0 RSP: ffffc9000444bcb8
[ 656.209798] ---[ end trace e2a800e6eb0770be ]---
In above scenario, the request of deleting subscriber was performed
earlier than the request of canceling a subscription although the
latter was issued before the former, which means tipc_subscrb_delete()
was called before tipc_subscrp_cancel(). As a result, when
tipc_subscrb_subscrp_delete() called by tipc_subscrp_cancel() was
executed to cancel a subscription, the subscription's subscriber
refcnt had been decreased to 1. After tipc_subscrp_delete() where
the subscriber was freed because its refcnt was decremented to zero,
but the subscriber's lock had to be released, as a consequence, panic
happened.
By contrast, if we increase subscriber's refcnt before
tipc_subscrb_subscrp_delete() is called in tipc_subscrp_cancel(),
the panic issue can be avoided.
Fixes: d094c4d5f5c7 ("tipc: add subscription refcount to avoid invalid delete")
Reported-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
[ Upstream commit 557d054c01da0337ca81de9e9d9206d57245b57e ]
Until now, tipc_nametbl_unsubscribe() is called at subscriptions
reference count cleanup. Usually the subscriptions cleanup is
called at subscription timeout or at subscription cancel or at
subscriber delete.
We have ignored the possibility of this being called from other
locations, which causes deadlock as we try to grab the
tn->nametbl_lock while holding it already.
CPU1: CPU2:
tipc_nametbl_publish
spin_lock_bh(&tn->nametbl_lock)
tipc_nametbl_insert_publ
tipc_nameseq_insert_publ
tipc_subscrp_report_overlap
tipc_subscrp_get
tipc_subscrp_send_event
tipc_close_conn
tipc_subscrb_release_cb
tipc_subscrb_delete
tipc_subscrp_put
tipc_subscrp_put
tipc_subscrp_kref_release
<<grab nametbl_lock again>>
CPU1: CPU2:
tipc_nametbl_stop
tipc_purge_publications
tipc_nameseq_remove_publ
tipc_subscrp_get
tipc_close_conn
tipc_subscrb_delete
tipc_subscrp_put
tipc_subscrp_put
In this commit, we advance the calling of tipc_nametbl_unsubscribe()
from the refcount cleanup to the intended callers.
Reported-by: John Thompson <thompa.atl@gmail.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
[ Upstream commit d094c4d5f5c7e1b225e94227ca3f007be3adc4e8 ]
Until now, the subscribers keep track of the subscriptions using
reference count at subscriber level. At subscription cancel or
subscriber delete, we delete the subscription only if the timer
was pending for the subscription. This approach is incorrect as:
1. del_timer() is not SMP safe, if on CPU0 the check for pending
timer returns true but CPU1 might schedule the timer callback
thereby deleting the subscription. Thus when CPU0 is scheduled,
it deletes an invalid subscription.
2. We export tipc_subscrp_report_overlap(), which accesses the
subscription pointer multiple times. Meanwhile the subscription
timer can expire thereby freeing the subscription and we might
continue to access the subscription pointer leading to memory
violations.
In this commit, we introduce subscription refcount to avoid deleting
Reported-and-Tested-by: John Thompson <thompa.atl@gmail.com>
This is never called with a NULL "buf" and anyway, we dereference 's' on
the lines before so it would Oops before we reach the check.
Until now, the requests sent to topology server are queued
to a workqueue by the generic server framework.
These messages are processed by worker threads and trigger the
registered callbacks.
To reduce latency on uniprocessor systems, explicit rescheduling
is performed using cond_resched() after MAX_RECV_MSG_COUNT(25)
messages.
This implementation on SMP systems leads to an subscriber refcnt
error as described below:
When a worker thread yields by calling cond_resched() in a SMP
system, a new worker is created on another CPU to process the
pending workitem. Sometimes the sleeping thread wakes up before
the new thread finishes execution.
This breaks the assumption on ordering and being single threaded.
The fault is more frequent when MAX_RECV_MSG_COUNT is lowered.
If the first thread was processing subscription create and the
second thread processing close(), the close request will free
the subscriber and the create request oops as follows:
[31.224137] WARNING: CPU: 2 PID: 266 at include/linux/kref.h:46 tipc_subscrb_rcv_cb+0x317/0x380 [tipc]
[31.228143] CPU: 2 PID: 266 Comm: kworker/u8:1 Not tainted 4.5.0+ #97
[31.228377] Workqueue: tipc_rcv tipc_recv_work [tipc]
[31.228377] Call Trace:
[31.228377] [<ffffffff812fbb6b>] dump_stack+0x4d/0x72
[31.228377] [<ffffffff8105a311>] __warn+0xd1/0xf0
[31.228377] [<ffffffff8105a3fd>] warn_slowpath_null+0x1d/0x20
[31.228377] [<ffffffffa0098067>] tipc_subscrb_rcv_cb+0x317/0x380 [tipc]
[31.228377] [<ffffffffa00a4984>] tipc_receive_from_sock+0xd4/0x130 [tipc]
[31.228377] [<ffffffffa00a439b>] tipc_recv_work+0x2b/0x50 [tipc]
[31.228377] [<ffffffff81071925>] process_one_work+0x145/0x3d0
[31.246554] ---[ end trace c3882c9baa05a4fd ]---
[31.248327] BUG: spinlock bad magic on CPU#2, kworker/u8:1/266
[31.249119] BUG: unable to handle kernel NULL pointer dereference at 0000000000000428
[31.249323] IP: [<ffffffff81099d0c>] spin_dump+0x5c/0xe0
[31.249323] PGD 0
[31.249323] Oops: 0000 [#1] SMP
In this commit, we
- rename tipc_conn_shutdown() to tipc_conn_release().
- move connection release callback execution from tipc_close_conn()
to a new function tipc_sock_release(), which is executed before
we free the connection.
Thus we release the subscriber during connection release procedure
rather than connection shutdown procedure.
Several cases of overlapping changes, as well as one instance
(vxlan) of a bug fix in 'net' overlapping with code movement
in 'net-next'.
commit 4d5cfcba2f6e ('tipc: fix connection abort during subscription
cancel'), removes the check for a valid subscription before calling
tipc_nametbl_subscribe().
This will lead to a nullptr exception when we process a
subscription cancel request. For a cancel request, a null
subscription is passed to tipc_nametbl_subscribe() resulting
in exception.
In this commit, we call tipc_nametbl_subscribe() only for
a valid subscription.
Fixes: 4d5cfcba2f6e ('tipc: fix connection abort during subscription cancel')
Reported-by: Anders Widell <anders.widell@ericsson.com>
Until now, we create timers even for the subscription requests
with timeout = TIPC_WAIT_FOREVER.
This can be improved by avoiding timer creation when the timeout
is set to TIPC_WAIT_FOREVER.
In this commit, we introduce a check to creates timers only
when timeout != TIPC_WAIT_FOREVER.
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
Until now, during subscription creation the mod_time() &
tipc_subscrb_get() are called after releasing the subscriber
spin lock.
In a SMP system when performing a subscription creation, if the
subscription timeout occurs simultaneously (the timer is
scheduled to run on another CPU) then the timer thread
might decrement the subscribers refcount before the create
thread increments the refcount.
This can be simulated by creating subscription with timeout=0 and
sometimes the timeout occurs before the create request is complete.
This leads to the following message:
[30.702949] BUG: spinlock bad magic on CPU#1, kworker/u8:3/87
[30.703834] general protection fault: 0000 [#1] SMP
[30.704826] CPU: 1 PID: 87 Comm: kworker/u8:3 Not tainted 4.4.0-rc8+ #18
[30.704826] Workqueue: tipc_rcv tipc_recv_work [tipc]
[30.704826] task: ffff88003f878600 ti: ffff88003fae0000 task.ti: ffff88003fae0000
[30.704826] RIP: 0010:[<ffffffff8109196c>] [<ffffffff8109196c>] spin_dump+0x5c/0xe0
[30.704826] Call Trace:
[30.704826] [<ffffffff81091a16>] spin_bug+0x26/0x30
[30.704826] [<ffffffff81091b75>] do_raw_spin_lock+0xe5/0x120
[30.704826] [<ffffffff81684439>] _raw_spin_lock_bh+0x19/0x20
[30.704826] [<ffffffffa0096f10>] tipc_subscrb_rcv_cb+0x1d0/0x330 [tipc]
[30.704826] [<ffffffffa00a37b1>] tipc_receive_from_sock+0xc1/0x150 [tipc]
[30.704826] [<ffffffffa00a31df>] tipc_recv_work+0x3f/0x80 [tipc]
[30.704826] [<ffffffff8106a739>] process_one_work+0x149/0x3c0
[30.704826] [<ffffffff8106aa16>] worker_thread+0x66/0x460
[30.704826] [<ffffffff8106a9b0>] ? process_one_work+0x3c0/0x3c0
[30.704826] [<ffffffff8107029d>] kthread+0xed/0x110
[30.704826] [<ffffffff810701b0>] ? kthread_create_on_node+0x190/0x190
[30.704826] [<ffffffff81684bdf>] ret_from_fork+0x3f/0x70
In this commit,
1. we remove the check for the return code for mod_timer()
2. we protect tipc_subscrb_get() using the subscriber spin lock.
We increment the subscriber's refcount as soon as we add the
subscription to subscriber's subscription list.
Until now, while creating a subscription the subscriber lock
protects only the subscribers subscription list and not the
nametable. The call to tipc_nametbl_subscribe() is outside
the lock. However, at subscription timeout and cancel both
the subscribers subscription list and the nametable are
protected by the subscriber lock.
This asymmetric locking mechanism leads to the following problem:
In a SMP system, the timer can be fire on another core before
When the timer thread calls tipc_nametbl_unsubscribe() before create
thread calls tipc_nametbl_subscribe(), we get a nullptr exception.
The following is the oops:
[57.569661] BUG: unable to handle kernel NULL pointer dereference at (null)
[57.577498] IP: [<ffffffffa02135aa>] tipc_nametbl_unsubscribe+0x8a/0x120 [tipc]
[57.584820] PGD 0
[57.586834] Oops: 0002 [#1] SMP
[57.685506] CPU: 14 PID: 10077 Comm: kworker/u40:1 Tainted: P OENX 3.12.48-52.27.1. 9688.1.PTF-default #1
[57.703637] Workqueue: tipc_rcv tipc_recv_work [tipc]
[57.708697] task: ffff88064c7f00c0 ti: ffff880629ef4000 task.ti: ffff880629ef4000
[57.716181] RIP: 0010:[<ffffffffa02135aa>] [<ffffffffa02135aa>] tipc_nametbl_unsubscribe+0x8a/ 0x120 [tipc]
[57.812327] Call Trace:
[57.814806] [<ffffffffa0211c77>] tipc_subscrp_delete+0x37/0x90 [tipc]
[57.821357] [<ffffffffa0211e2f>] tipc_subscrp_timeout+0x3f/0x70 [tipc]
[57.827982] [<ffffffff810618c1>] call_timer_fn+0x31/0x100
[57.833490] [<ffffffff81062709>] run_timer_softirq+0x1f9/0x2b0
[57.839414] [<ffffffff8105a795>] __do_softirq+0xe5/0x230
[57.844827] [<ffffffff81520d1c>] call_softirq+0x1c/0x30
[57.850150] [<ffffffff81004665>] do_softirq+0x55/0x90
[57.855285] [<ffffffff8105aa35>] irq_exit+0x95/0xa0
[57.860290] [<ffffffff815215b5>] smp_apic_timer_interrupt+0x45/0x60
[57.866644] [<ffffffff8152005d>] apic_timer_interrupt+0x6d/0x80
[57.872686] [<ffffffffa02121c5>] tipc_subscrb_rcv_cb+0x2a5/0x3f0 [tipc]
[57.879425] [<ffffffffa021c65f>] tipc_receive_from_sock+0x9f/0x100 [tipc]
[57.886324] [<ffffffffa021c826>] tipc_recv_work+0x26/0x60 [tipc]
[57.892463] [<ffffffff8106fb22>] process_one_work+0x172/0x420
[57.898309] [<ffffffff8107079a>] worker_thread+0x11a/0x3c0
[57.903871] [<ffffffff81077114>] kthread+0xb4/0xc0
[57.908751] [<ffffffff8151f318>] ret_from_fork+0x58/0x90
In this commit, we do the following at subscription creation:
1. set the subscription's subscriber pointer before performing
tipc_nametbl_subscribe(), as this value is required further in
the call chain ex: by tipc_subscrp_send_event().
2. move tipc_nametbl_subscribe() under the scope of subscriber lock
Until now, the subscribers endianness for a subscription
create/cancel request is determined as:
swap = !(s->filter & (TIPC_SUB_PORTS | TIPC_SUB_SERVICE))
The checks are performed only for port/service subscriptions.
The swap calculation is incorrect if the filter in the subscription
cancellation request is set to TIPC_SUB_CANCEL (it's a malformed
cancel request, as the corresponding subscription create filter
is missing).
Thus, the check if the request is for cancellation fails and the
request is treated as a subscription create request. The
subscription creation fails as the request is illegal, which
terminates this connection.
In this commit we determine the endianness by including
TIPC_SUB_CANCEL, which will set swap correctly and the
request is processed as a cancellation request.
In 'commit 7fe8097cef5f ("tipc: fix nullpointer bug when subscribing
to events")', we terminate the connection if the subscription
creation fails.
In the same commit, the subscription creation result was based on
the value of subscription pointer (set in the function) instead of
the return code.
Unfortunately, the same function also handles subscription
cancellation request. For a subscription cancellation request,
the subscription pointer cannot be set. Thus the connection is
terminated during cancellation request.
In this commit, we move the subcription cancel check outside
of tipc_subscrp_create(). Hence,
- tipc_subscrp_create() will create a subscripton
- tipc_subscrb_rcv_cb() will subscribe or cancel a subscription.
Fixes: 'commit 7fe8097cef5f ("tipc: fix nullpointer bug when subscribing to events")'
In this commit, we split tipc_subscrp_create() into two:
1. tipc_subscrp_create() creates a subscription
2. A new function tipc_subscrp_subscribe() adds the
subscription to the subscriber subscription list,
activates the subscription timer and subscribes to
the nametable updates.
In future commits, the purpose of tipc_subscrb_rcv_cb() will
be to either subscribe or cancel a subscription.
There is no functional change in this commit.
Until now, struct tipc_subscriber has duplicate fields for
type, upper and lower (as member of struct tipc_name_seq) at:
1. as member seq in struct tipc_subscription
2. as member seq in struct tipc_subscr, which is contained
in struct tipc_event
The former structure contains the type, upper and lower
values in network byte order and the later contains the
intact copy of the request.
The struct tipc_subscription contains a field swap to
determine if request needs network byte order conversion.
Thus by using swap, we can convert the request when
required instead of duplicating it.
In this commit,
1. we remove the references to these elements as members of
struct tipc_subscription and replace them with elements
from struct tipc_subscr.
2. provide new functions to convert the user request into
network byte order.
Until now, struct tipc_subscription has duplicate timeout and filter
attributes present:
1. directly as members of struct tipc_subscription
2. in struct tipc_subscr, which is contained in struct tipc_event
In this commit, we remove the references to these elements as
members of struct tipc_subscription and replace them with elements
Until now, during subscription creation we set sub->timeout by
converting the timeout request value in milliseconds to jiffies.
This is followed by setting the timeout value in the timer if
sub->timeout != TIPC_WAIT_FOREVER.
For a subscription create request with a timeout value of
TIPC_WAIT_FOREVER, msecs_to_jiffies(TIPC_WAIT_FOREVER)
returns MAX_JIFFY_OFFSET (0xfffffffe). This is not equal to
TIPC_WAIT_FOREVER (0xffffffff).
In this commit, we remove this check.
creation fails.
the value of the subscription pointer (set in the function) instead
of the return code.
Unfortunately, the same function tipc_subscrp_create() handles
subscription cancel request. For a subscription cancellation request,
the subscription pointer cannot be set. Thus if a subscriber has
several subscriptions and cancels any of them, the connection is
terminated.
In this commit, we terminate the connection based on the return value
Fixes: commit 7fe8097cef5f ("tipc: fix nullpointer bug when subscribing to events")
Currently subscriber's lock protects not only subscriber's subscription
list but also all subscriptions linked into the list. However, as all
members of subscription are never changed after they are initialized,
it's unnecessary for subscription to be protected under subscriber's
lock. If the lock is used to only protect subscriber's subscription
list, the adjustment not only makes the locking policy simpler, but
also helps to avoid a deadlock which may happen once creating a
subscription is failed.
Reviewed-by: Jon Maloy <jon.maloy@ericson.com>
At present subscriber's lock is used to protect the subscription list
of subscriber as well as subscriptions linked into the list. While one
or all subscriptions are deleted through iterating the list, the
subscriber's lock must be held. Meanwhile, as deletion of subscription
may happen in subscription timer's handler, the lock must be grabbed
in the function as well. When subscription's timer is terminated with
del_timer_sync() during above iteration, subscriber's lock has to be
temporarily released, otherwise, deadlock may occur. However, the
temporary release may cause the double free of a subscription as the
subscription is not disconnected from the subscription list.
Now if a reference counter is introduced to subscriber, subscription's
timer can be asynchronously stopped with del_timer(). As a result, the
issue is not only able to be fixed, but also relevant code is pretty
readable and understandable.
Introducing a new function makes the purpose of tipc_subscrb_connect_cb
callback routine more clear.
When a topology server accepts a connection request from its client,
it allocates a connection instance and a tipc_subscriber structure
object. The former is used to communicate with client, and the latter
is often treated as a subscriber which manages all subscription events
requested from a same client. When a topology server receives a request
of subscribing name services from a client through the connection, it
creates a tipc_subscription structure instance which is seen as a
subscription recording what name services are subscribed. In order to
manage all subscriptions from a same client, topology server links
them into the subscrp_list of the subscriber. So subscriber and
subscription completely represents different meanings respectively,
but function names associated with them make us so confused that we
are unable to easily tell which function is against subscriber and
which is to subscription. So we want to eliminate the confusion by
renaming them.
If a subscription request is sent to a topology server
connection, and any error occurs (malformed request, oom
or limit reached) while processing this request, TIPC should
terminate the subscriber connection. While doing so, it tries
to access fields in an already freed (or never allocated)
subscription element leading to a nullpointer exception.
We fix this by removing the subscr_terminate function and
terminate the connection immediately upon any subscription
failure.
Signed-off-by: Erik Hugne <erik.hugne@ericsson.com>
TIPC establishes one subscriber server which allows users to subscribe
their interesting name service status. After tipc supports namespace,
one dedicated tipc stack instance is created for each namespace, and
each instance can be deemed as one independent TIPC node. As a result,
subscriber server must be built for each namespace.
Tested-by: Tero Aho <Tero.Aho@coriant.com>
TIPC name table is used to store the mapping relationship between
TIPC service name and socket port ID. When tipc supports namespace,
it allows users to publish service names only owned by a certain
namespace. Therefore, every namespace must have its private name
table to prevent service names published to one namespace from being
contaminated by other service names in another namespace. Therefore,
The name table global variable (ie, nametbl) and its lock must be
moved to tipc_net structure, and a parameter of namespace must be
added for necessary functions so that they can obtain name table
variable defined in tipc_net structure.
Not only some wrapper function like k_term_timer() is empty, but also
some others including k_start_timer() and k_cancel_timer() don't return
back any value to its caller, what's more, there is no any component
in the kernel world to do such thing. Therefore, these timer interfaces
defined in tipc module should be purged.
When a list_head variable is seen as a new entry to be added to a
list head, it's unnecessary to be initialized with INIT_LIST_HEAD().
Reviewed-by: Erik Hugne <erik.hugne@ericsson.com>
Tested-by: Erik Hugne <erik.hugne@ericsson.com>
We move the inline functions in the file port.h to socket.c, and modify
their names accordingly.
We move struct tipc_port and some macros to socket.h.
Finally, we remove the file port.h.
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
Reviewed-by: Ying Xue <ying.xue@windriver.com>
If a topology event subscription fails for any reason, such as out
of memory, max number reached or because we received an invalid
request the correct behavior is to terminate the subscribers
connection to the topology server. This is currently broken and
produces the following oops:
[27.953662] tipc: Subscription rejected, illegal request
[27.955329] BUG: spinlock recursion on CPU#1, kworker/u4:0/6
[27.957066] lock: 0xffff88003c67f408, .magic: dead4ead, .owner: kworker/u4:0/6, .owner_cpu: 1
[27.958054] CPU: 1 PID: 6 Comm: kworker/u4:0 Not tainted 3.14.0-rc6+ #5
[27.960230] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[27.960874] Workqueue: tipc_rcv tipc_recv_work [tipc]
[27.961430] ffff88003c67f408 ffff88003de27c18 ffffffff815c0207 ffff88003de1c050
[27.962292] ffff88003de27c38 ffffffff815beec5 ffff88003c67f408 ffffffff817f0a8a
[27.963152] ffff88003de27c58 ffffffff815beeeb ffff88003c67f408 ffffffffa0013520
[27.964023] Call Trace:
[27.964292] [<ffffffff815c0207>] dump_stack+0x45/0x56
[27.964874] [<ffffffff815beec5>] spin_dump+0x8c/0x91
[27.965420] [<ffffffff815beeeb>] spin_bug+0x21/0x26
[27.965995] [<ffffffff81083df6>] do_raw_spin_lock+0x116/0x140
[27.966631] [<ffffffff815c6215>] _raw_spin_lock_bh+0x15/0x20
[27.967256] [<ffffffffa0008540>] subscr_conn_shutdown_event+0x20/0xa0 [tipc]
[27.968051] [<ffffffffa000fde4>] tipc_close_conn+0xa4/0xb0 [tipc]
[27.968722] [<ffffffffa00101ba>] tipc_conn_terminate+0x1a/0x30 [tipc]
[27.969436] [<ffffffffa00089a2>] subscr_conn_msg_event+0x1f2/0x2f0 [tipc]
[27.970209] [<ffffffffa0010000>] tipc_receive_from_sock+0x90/0xf0 [tipc]
[27.970972] [<ffffffffa000fa79>] tipc_recv_work+0x29/0x50 [tipc]
[27.971633] [<ffffffff8105dbf5>] process_one_work+0x165/0x3e0
[27.972267] [<ffffffff8105e869>] worker_thread+0x119/0x3a0
[27.972896] [<ffffffff8105e750>] ? manage_workers.isra.25+0x2a0/0x2a0
[27.973622] [<ffffffff810648af>] kthread+0xdf/0x100
[27.974168] [<ffffffff810647d0>] ? kthread_create_on_node+0x1a0/0x1a0
[27.974893] [<ffffffff815ce13c>] ret_from_fork+0x7c/0xb0
[27.975466] [<ffffffff810647d0>] ? kthread_create_on_node+0x1a0/0x1a0
The recursion occurs when subscr_terminate tries to grab the
subscriber lock, which is already taken by subscr_conn_msg_event.
We fix this by checking if the request to establish a new
subscription was successful, and if not we initiate termination of
the subscriber after we have released the subscriber lock.
When a topology server subscriber is disconnected, the associated
connection id is set to zero. A check vs zero is then done in the
subscription timeout function to see if the subscriber have been
shut down. This is unnecessary, because all subscription timers
will be cancelled when a subscriber terminates. Setting the
connection id to zero is actually harmful because id zero is the
identity of the topology server listening socket, and can cause a
race that leads to this socket being closed instead.
Currently connection shutdown callback function is called when
connection instance is released in tipc_conn_kref_release(), and
receiving packets and sending packets are running in different
threads. Even if connection is closed by the thread of receiving
packets, its shutdown callback may not be called immediately as
the connection reference count is non-zero at that moment. So,
although the connection is shut down by the thread of receiving
packets, the thread of sending packets doesn't know it. Before
its shutdown callback is invoked to tell the sending thread its
connection has been closed, the sending thread may deliver
messages by tipc_conn_sendmsg(), this is why the following error
information appears:
"Sending subscription event failed, no memory"
To eliminate it, allow connection shutdown callback function to
be called before connection id is removed in tipc_close_conn(),
which makes the sending thread know the truth in time that its
socket is closed so that it doesn't send message to it. We also
remove the "Sending XXX failed..." error reporting for topology
and config services.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
No runtime code changes here. Just a realign of the function
arguments to start where the 1st one was, and fit as many args
as can be put in an 80 char line.
As the new TIPC server infrastructure has been introduced, we can
now convert the TIPC topology server to it. We get two benefits
from doing this:
1) It simplifies the topology server locking policy. In the
original locking policy, we placed one spin lock pointer in the
tipc_subscriber structure to reuse the lock of the subscriber's
server port, controlling access to members of tipc_subscriber
instance. That is, we only used one lock to ensure both
tipc_port and tipc_subscriber members were safely accessed.
Now we introduce another spin lock for tipc_subscriber structure
only protecting themselves, to get a finer granularity locking
policy. Moreover, the change will allow us to make the topology
server code more readable and maintainable.
2) It fixes a bug where sent subscription events may be lost when
the topology port is congested. Using the new service, the
topology server now queues sent events into an outgoing buffer,
and then wakes up a sender process which has been blocked in
workqueue context. The process will keep picking events from the
buffer and send them to their respective subscribers, using the
kernel socket interface, until the buffer is empty. Even if the
socket is congested during transmission there is no risk that
events may be dropped, since the sender process may block when
needed.
Some minor reordering of initialization is done, since we now
have a scenario where the topology server must be started after
socket initialization has taken place, as the former depends
on the latter. And overall, we see a simplification of the
TIPC subscriber code in making this changeover.
Currently we have tipc_disconnect and tipc_disconnect_port. It is
not clear from the names alone, what they do or how they differ.
It turns out that tipc_disconnect just deals with the port locking
and then calls tipc_disconnect_port which does all the work.
If we rename as follows: tipc_disconnect_port --> __tipc_disconnect
then we will be following typical linux convention, where:
__tipc_disconnect: "raw" function that does all the work.
tipc_disconnect: wrapper that deals with locking and then calls
the real core __tipc_disconnect function
With this, the difference is immediately evident, and locking
violations are more apt to be spotted by chance while working on,
or even just while reading the code.
On the connect side of things, we currently only have the single
"tipc_connect2port" function. It does both the locking at enter/exit,
and the core of the work. Pending changes will make it desireable to
have the connect be a two part locking wrapper + worker function,
just like the disconnect is already.
Here, we make the connect look just like the updated disconnect case,
for the above reason, and for consistency. In the process, we also
get rid of the "2port" suffix that was on the original name, since
it adds no descriptive value.
On close examination, one might notice that the above connect
changes implicitly move the call to tipc_link_get_max_pkt() to be
within the scope of tipc_port_lock() protected region; when it was
not previously. We don't see any issues with this, and it is in
keeping with __tipc_connect doing the work and tipc_connect just
handling the locking.
Gets rid of the need for users to specify the maximum number of
name subscriptions supported by TIPC. TIPC now automatically provides
support for the maximum number of name subscriptions to 65535.
All messages should go directly to the kernel log. The TIPC
specific error, warning, info and debug trace macro's are
removed and all references replaced with pr_err, pr_warn,
pr_info and pr_debug.
Commonly used sub-strings are explicitly declared as a const
char to reduce .text size.
Note that this means the debug messages (changed to pr_debug),
are now enabled through dynamic debugging, instead of a TIPC
specific Kconfig option (TIPC_DEBUG). The latter will be
phased out completely
[PG: use pr_fmt as suggested by Joe Perches <joe@perches.com>]
Some of the comment blocks are floating in limbo between two
functions, or between blocks of code. Delete the extra line
feeds between any comment and its associated following block
of code, to be consistent with the majority of the rest of
the kernel. Also delete trailing newlines at EOF and fix
a couple trivial typos in existing comments.
This is a 100% cosmetic change with no runtime impact. We get
rid of over 500 lines of non-code, and being blank line deletes,
they won't even show up as noise in git blame.
Eliminate code to zero-out the main topology service structure,
which is already zeroed-out.
Get rid of a comment documenting a field of the main topology
service structure that no longer exists.
Both are cosmetic changes with no impact on runtime behaviour.
Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
Streamlines the logic that prevents an application from binding a
reserved TIPC name type to a port by moving the check to the code
that handles a socket bind() operation. This allows internal TIPC
subsystems to bind a reserved name without having to set an atomic
flag to gain permission to use such a name. (This simplification is
now possible due to the elimination of support for TIPC's native API.)
Make this rename so that it is consistent with the majority
of the other tipc structs and to assist in removing any
ambiguity with other similar names in other subsystems.
Eliminate the "event_cb" member from TIPC's "subscription" structure
since the function pointer it holds always points to subscr_send_event().
Rework TIPC's message sending routines to take advantage of the total
amount of data value passed to it by the kernel socket infrastructure.
This change eliminates the need for TIPC to compute the size of outgoing
messages itself, as well as the check for an oversize message in
tipc_msg_build(). In addition, this change warrants an explanation:
- res = send_packet(NULL, sock, &my_msg, 0);
+ res = send_packet(NULL, sock, &my_msg, bytes_to_send);
Previously, the final argument to send_packet() was ignored (since the
amount of data being sent was recalculated by a lower-level routine)
and we could just pass in a dummy value (0). Now that the
recalculation is being eliminated, the argument value being passed to
send_packet() is significant and we have to supply the actual amount
of data we want to send.
Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com>
Eliminates a local iovec structure containing no data, which was
previously used during the establishment of a topology service connection,
since the same effect can be achieved by passing in a NULL pointer and
an iovec length of zero.
Modifies the initialization code for TIPC's topology service to
avoid taking the spinlock protecting the subscriber list, since
there is no need to do this.
Merge two distinct structures containing information about a TIPC port
into a single structure. The structures were previously kept separate
so that public information about a port could be made available to
applications using TIPC's native API, while the remaining information
was kept private for use by TIPC itself. However, now that the native
API has been removed there is no longer any need for this somewhat
confusing arrangement.
Since one of the structures was already embedded within the other, the
change largely involves replacing instances of "publ.foo" with "foo".
The changes do not otherwise alter the operation of TIPC ports.
Cleans up TIPC's source code to eliminate the needless initialization
of static variables to zero.
These changes are purely cosmetic and do not alter the operation of TIPC
in any way.
Cleans up TIPC's source code to eliminate deviations from generally
accepted coding conventions relating to leading/trailing white space
and white space around commas, braces, cases, and sizeof.
in any way.
