path: root/net/tipc
2008-04-27tipc: endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25net: Fix wrong interpretation of some copy_to_user() results.Pavel Emelyanov
I found some places, that erroneously return the value obtained from the copy_to_user() call: if some amount of bytes were not able to get to the user (this is what this one returns) the proper behavior is to return the -EFAULT error, not that number itself. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[TIPC]: Cleanup of TIPC reference table codeAllan Stephens
This patch is a largely cosmetic cleanup of the TIPC reference table code. - The object reference field in each table entry is now single 32-bit integer instead of a union of two 32-bit integers. - Variable naming has been made more consistent. - Error message output has been made more consistent. - Useless #includes have been eliminated. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[TIPC]: Optimized initialization of TIPC reference tableAllan Stephens
This patch modifies TIPC's reference table code to delay initializing table entries until they are actually needed by applications. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[TIPC]: Remove inlining of reference table locking routinesAllan Stephens
This patch converts the TIPC reference table locking routines into non-inlined routines, since they are mainly called from non-performance critical areas of TIPC and the added code footprint incurred through inlining can no longer be justified. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Enhance validation of format on incoming messagesAllan Stephens
This patch ensures that TIPC properly handles incoming messages that have incorrect or unexpected formats. Most significantly, it now ensures that each sl_buff has at least as much data as the message header indicates it should, and that the entire message header is stored contiguously; this prevents TIPC from accidentally accessing memory that is not part of the sk_buff. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Force linearization of non-linear sk_buffsAllan Stephens
This patch allows TIPC to process incoming messages that are stored in a fragmented sk_buff, by forcing the linearization of any such messages it receives. Note: This is an interim solution to allow TIPC to operate with Ethernet devices that generate non-linear buffers (such as the gianfar driver), until such time as the rest of TIPC is enhanced to handle sk_buffs with multiple data areas. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Use fast buffer cloning to improve performanceAllan Stephens
This patch causes TIPC to allocate fast clonable sk_buffs, rather than standard ones. This speeds up the cloning operation done by the link code each time a message is sent off-node. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Remove redundant NULL check when discarding buffersAllan Stephens
This patch eliminates a null pointer check when discarding a TIPC message buffer, since kfree_skb() already handles this situation. Acknowledgements to Florian Westphal (fw@strlen.de> for suggesting this enhancement. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Overhaul of socket locking logicAllan Stephens
This patch modifies TIPC's socket code to follow the same approach used by other protocols. This change eliminates the need for a mutex in the TIPC-specific portion of the socket protocol data structure -- in its place, the standard Linux socket backlog queue and associated locking routines are utilized. These changes fix a long-standing receive queue bug on SMP systems, and also enable individual read and write threads to utilize a socket without unnecessarily interfering with each other. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Cosmetic changes to TIPC connect() codeAllan Stephens
This patch fixes TIPC's connect routine to conform to Linux kernel style norms of indentation, line length, etc. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Add error check to detect non-blocking form of connect()Allan Stephens
This patch causes TIPC to return an error indication if the non- blocking form of connect() is requested (which TIPC does not yet support). Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Correct "off by 1" error in socket queue limit enforcementAllan Stephens
This patch fixes a bug that allowed TIPC to queue 1 more message than allowed by the socket receive queue threshold limits. The patch also improves the threshold code's logic and naming to help prevent this sort of error from recurring in the future. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Ignore message padding when receiving stream dataAllan Stephens
This patch ensures that padding bytes appearing at the end of an incoming TIPC message are not returned as valid stream data. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Allow stream receive to read from multiple TIPC messagesAllan Stephens
This patch allows a stream socket to receive data from multiple TIPC messages in its receive queue, without requiring the use of the MSG_WAITALL flag. Acknowledgements to Florian Westphal <fw-tipc@strlen.de> for identifying this issue and suggesting how to correct it. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Skip connection flow control in connectionless socketsAllan Stephens
This patch optimizes the receive path for SOCK_DGRAM and SOCK_RDM messages by skipping over code that handles connection-based flow control. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[TIPC]: Improve socket time conversionsAllan Stephens
This patch modifies TIPC's socket code to use standard kernel routines to handle time conversions between jiffies and ms. This ensures proper operation even when HZ isn't 1000. Acknowledgements to Eric Sesterhenn <snakebyte@gmx.de> for identifying this issue and proposing a solution. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[TIPC]: Remove redundant socket wait queue initializationAllan Stephens
This patch eliminates re-initialization of the standard socket wait queue used for sleeping in TIPC's socket creation code. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[TIPC]: Cosmetic cleanup of TIPC polling logicAllan Stephens
This patch eliminates an unnecessary poll-related routine by merging it into TIPC's main polling routine, and updates the comments associated with this code. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-06[TIPC]: Update version to 1.6.3Allan Stephens
This patch updates TIPC's version number to 1.6.3. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Enhancements to message header writingAllan Stephens
This patch makes two enhancements to the routine used to set bit fields within a TIPC message header: 1) It now ignores any bits of the new field value that are not covered by the mask being used. (Previously, if the new value exceeded the size of the mask the extra bits could corrupt other fields in the message header word being updated.) 2) The code has been optimized to minimize the number of run-time endianness conversion operations by leveraging the fact that the mask (and, in some cases, the value as well) is constant and the necessary conversion can be performed by the compiler. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Use correct bitmask when setting versionAllan Stephens
This patch ensures that the 3-bit version field of the TIPC message header is masked correctly when written into a message. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Minor cleanup of message header codeAllan Stephens
This patch eliminates some unused or duplicate message header symbols, and fixes up the comments and/or location of a few other symbols. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Eliminate "sparse" symbol warningsAllan Stephens
This patch eliminates warnings about undeclared symbols. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Add argument validation for shutdown()Allan Stephens
This patch validates that the "how" argument to shutdown() is SHUT_RDWR, since this is the only form that TIPC supports. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Removal of message header option codeAllan Stephens
This patch removes code associated with optional, user-specified fields of the TIPC message header. Such fields were never utilized by TIPC, and have now been removed from the protocol specification. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-03[TIPC]: Convert tsock->sem in a mutexMatthias Kaehlcke
The semaphore tsock->sem is used as mutex, convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-24tipc: fix integer as NULL pointer sparse warnings in tipcHarvey Harrison
net/tipc/cluster.c:145:2: warning: Using plain integer as NULL pointer net/tipc/link.c:3254:36: warning: Using plain integer as NULL pointer net/tipc/ref.c:151:15: warning: Using plain integer as NULL pointer net/tipc/zone.c:85:2: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07[TIPC]: declare proto_ops structures as 'const'.Florian Westphal
Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07[TIPC]: Kill unused static inline (x5)Ilpo Järvinen
All these static inlines are unused: in_own_zone 1 (net/tipc/addr.h) msg_dataoctet 1 (net/tipc/msg.h) msg_direct 1 (include/net/tipc/tipc_msg.h) msg_options 1 (include/net/tipc/tipc_msg.h) tipc_nmap_get 1 (net/tipc/bcast.h) Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TIPC]: Use tipc_port_unlockJulia Lawall
The file net/tipc/port.c takes a lock using the function tipc_port_lock and then releases the lock sometimes using tipc_port_unlock and sometimes using spin_unlock_bh(p_ptr->publ.lock). tipc_port_unlock simply does the spin_unlock_bh, but it seems cleaner to use it everywhere. The problem was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct port *p_ptr; @@ p_ptr = tipc_port_lock(...) ... ( p_ptr = tipc_port_lock(...); | ?- spin_unlock_bh(p_ptr->publ.lock); + tipc_port_unlock(p_ptr); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Jon Paul Maloy <maloy@donjonn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-14[TIPC]: Fix semaphore handling.Andrew Morton
As noted by Kevin, tipc's release() does down_interruptible() and ignores the return value. So if signal_pending() we'll end up doing up() on a non-downed semaphore. Fix. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-13[TIPC]: Clean up duplicate includes in net/tipc/Jesper Juhl
This patch cleans up duplicate includes in net/tipc/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-02[TIPC]: Fix two minor sparse warnings.Florian Westphal
fix two warnings generated by sparse: link.c:2386 symbol 'msgcount' shadows an earlier one node.c:244 symbol 'addr_string' shadows an earlier one Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-02[TIPC]: Make function tipc_nameseq_subscribe static.Florian Westphal
make needlessly global function tipc_nameseq_subscribe static. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[TIPC]: fix tipc_link_create error handlingFlorian Westphal
if printbuf allocation or tipc_node_attach_link() fails, invalid references to the link are left in the associated node and bearer structures. Fix by allocating printbuf early and moving timer initialization and the addition of the new link to the b_ptr->links list after tipc_node_attach_link() succeeded. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-26net/* misc endianness annotationsAl Viro
2007-07-19Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits) [TG3]: Fix msi issue with kexec/kdump. [NET] XFRM: Fix whitespace errors. [NET] TIPC: Fix whitespace errors. [NET] SUNRPC: Fix whitespace errors. [NET] SCTP: Fix whitespace errors. [NET] RXRPC: Fix whitespace errors. [NET] ROSE: Fix whitespace errors. [NET] RFKILL: Fix whitespace errors. [NET] PACKET: Fix whitespace errors. [NET] NETROM: Fix whitespace errors. [NET] NETFILTER: Fix whitespace errors. [NET] IPV4: Fix whitespace errors. [NET] DCCP: Fix whitespace errors. [NET] CORE: Fix whitespace errors. [NET] BLUETOOTH: Fix whitespace errors. [NET] AX25: Fix whitespace errors. [PATCH] mac80211: remove rtnl locking in ieee80211_sta.c [PATCH] mac80211: fix GCC warning on 64bit platforms [GENETLINK]: Dynamic multicast groups. [NETLIKN]: Allow removing multicast groups. ...
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
