path: root/net/tipc
2011-01-01tipc: update log.h re-include protection to reflect new namePaul Gortmaker
The tipc/dbg.h file was recently renamed to tipc/log.h, but the re-include define was not updated accordingly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove extraneous braces from single statementsAllan Stephens
Cleans up TIPC's source code to eliminate the presence of unnecessary use of {} around single statements. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove zeroing assignments to static global variablesAllan Stephens
Cleans up TIPC's source code to eliminate the needless initialization of static variables to zero. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: split variable assignments out of conditional expressionsAllan Stephens
Cleans up TIPC's source code to eliminate assigning values to variables within conditional expressions, improving code readability and reducing warnings from various code checker tools. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: cleanup various cosmetic whitespace issuesAllan Stephens
Cleans up TIPC's source code to eliminate deviations from generally accepted coding conventions relating to leading/trailing white space and white space around commas, braces, cases, and sizeof. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: recode getsockopt error handling for better readabilityPaul Gortmaker
The existing code for the copy to user and error handling at the end of getsockopt isn't easy to follow, due to the excessive use of if/else. By simply using return where appropriate, it can be made smaller and easier to follow at the same time. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove pointless check for NULL prior to kfreeAllan Stephens
It is acceptable to call kfree() with NULL, so these checks are not serving any useful purpose. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove redundant #includesAllan Stephens
Eliminates a number of #include statements that no longer serve any useful purpose. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Finish streamlining of debugging codeAllan Stephens
Completes the simplification of TIPC's debugging capabilities. By default TIPC includes no debugging code, and any debugging code added by developers that calls the dbg() and dbg_macros() is compiled out. If debugging support is enabled, TIPC prints out some additional data about its internal state when certain abnormal conditions occur, and any developer-added calls to the TIPC debug macros are compiled in. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Prune down link-specific debugging codeAllan Stephens
Eliminates most link-specific debugging code in TIPC, which is now largely unnecessary. All calls to the link-specific debugging macros have been removed, as are the macros themselves; in addition, the optional allocation of print buffers to hold debugging information for each link endpoint has been removed. The ability for TIPC to print out helpful diagnostic information when link retransmit failures occur has been retained for the time being, as an aid in tracking down the cause of such failures. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove dump() and tipc_dump_dbg()Allan Stephens
Eliminates calls to two debugging macros that are being completely obsoleted, as well as any associated debugging routines that are no longer required. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove calls to dbg() and msg_dbg()Allan Stephens
Eliminates obsolete calls to two of TIPC's main debugging macros, as well as a pair of associated debugging routines that are no longer required. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: rename dbg.[ch] to log.[ch]Allan Stephens
As the first step in removing obsolete debugging code from TIPC the files that implement TIPC's non-debug-related log buffer subsystem are renamed to better reflect their true nature. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove internal linked list of node objectsAllan Stephens
Eliminates a sorted list TIPC uses to keep track of the neighboring nodes it has links to, since this duplicates information already present in the internal array of node object pointers. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove user registry subsystemAllan Stephens
Eliminates routines, data structures, and files that make up TIPC's user registry. The user registry is no longer needed since the native API routines that utilized it no longer exist and there are no longer any internal TIPC services that use it. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Eliminate use of user registry by topology serviceAllan Stephens
Simplifies TIPC's network topology service so that it no longer registers its ports with the user registry, since the service doesn't take advantage of any of the registry's capabilities. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Eliminate use of user registry by configuration serviceAllan Stephens
Simplifies TIPC's configuration service so that it no longer registers its port with the user registry, since the service doesn't take advantage of any of the registry's capabilities. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting multiple clustersAllan Stephens
Eliminates routines, data structures, and files that were intended to allow TIPC to support a network containing multiple clusters. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting inter-cluster routingAllan Stephens
Eliminates routines and data structures that were intended to allow TIPC to route messages to other clusters. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting slave nodesAllan Stephens
Simplifies routines and data structures that were intended to allow TIPC to support slave nodes (i.e. nodes that did not have links to all of the other nodes in its cluster, forcing TIPC to route messages that it could not deliver directly through a non-slave node). Currently, TIPC supports only networks containing non-slave nodes, so this code is unnecessary. Note: The latest edition of the TIPC 2.0 Specification has eliminated the concept of slave nodes entirely. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting multiple zonesAllan Stephens
Eliminates routines, data structures, and files that were intended to allows TIPC to support a network containing multiple zones. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete tipc_ownidentity()Allan Stephens
Moves the content of the native API routine tipc_ownidentity() into the sole routine that calls it, since it can no longer be called in isolation. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate obsolete native API forwarding routinesAllan Stephens
Moves the content of each native API message forwarding routine into the sole routine that calls it, since the forwarding routines no longer be called in isolation. Also removes code in each routine that altered the outgoing message's importance level since this is now no longer possible. The previous function mapping (parent function, and child API) was as follows: tipc_send2name \--tipc_forward2name tipc_send2port \--tipc_forward2port tipc_send_buf2port \--tipc_forward_buf2port After this commit, the children don't exist and their functionality is completely in the respective parent. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate an unused symbolic constant in link codeAllan Stephens
Removes a symbol that is not referenced anywhere by TIPC's link code. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate useless initialization when creating subscriberAllan Stephens
Removes initialization of a local variable that is always assigned a different value before it is referenced. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove unused domain argument from multicast send routineAllan Stephens
Eliminates an unused argument from tipc_multicast(), now that this routine can no longer be called by kernel-based applications. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove support for TIPC mode change callbackAllan Stephens
Eliminates support for the callback routine invoked when TIPC changes its mode of operation from inactive to standalone or from standalone to networked. This callback was part of TIPC's obsolete native API and is not used by TIPC internally. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete useless function prototypesAllan Stephens
Removes several function declarations that aren't used anywhere, either because they reference routines that no longer exist or because all users of the function reference it after it has already been defined. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate useless return value when disabling a bearerAllan Stephens
Modifies bearer_disable() to return void since it always indicates success anyway. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete unused configuration service structure definitionAllan Stephens
Removes a structure definition that is no longer used by TIPC's configuration service. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove obsolete inclusions of header filesAllan Stephens
Gets rid of #include statements that are no longer required as a result of the merging of obsolete native API header file content into other TIPC include files. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove obsolete native API files and exportsAllan Stephens
As part of the removal of TIPC's native API support it is no longer necessary for TIPC to export symbols for routines that can be called by kernel-based applications, nor for it to have header files that kernel-based applications can include to access the declarations for those routines. This commit eliminates the exporting of symbols by TIPC and migrates the contents of each obsolete native API include file into its corresponding non-native API equivalent. The code which was migrated in this commit was migrated intact, in that there are no technical changes combined with the relocation. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-09net: tipc: fix information leak to userlandKulikov Vasiliy
Structure sockaddr_tipc is copied to userland with padding bytes after "id" field in union field "name" unitialized. It leads to leaking of contents of kernel stack memory. We have to initialize them to zero. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2010-10-21tipc: delete needless memset from bearer enabling.Allan Stephens
Eliminates zeroing out of the new bearer structure at the start of activation, since it is already in that state. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21Revert d88dca79d3852a3623f606f781e013d61486828aNeil Horman
TIPC needs to have its endianess issues fixed. Unfortunately, the format of a subscriber message is passed in directly from user space, so requiring this message to be in network byte order breaks user space ABI. Revert this change until such time as we can determine how to do this in a backwards compatible manner. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21Revert c6537d6742985da1fbf12ae26cde6a096fd35b5cNeil Horman
Backout the tipc changes to the flags int he subscription message. These changees, while reasonable on the surface, interefere with user space ABI compatibility which is a no-no. This was part of the changes to fix the endianess issues in the TIPC protocol, which would be really nice to do but we need to do so in a way that is backwards compatible with user space. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18tipc: Simplify bearer shutdown logicAllan Stephens
Optimize processing in TIPC's bearer shutdown code, including: 1. Remove an unnecessary check to see if TIPC bearer's can exist. 2. Don't release spinlocks before calling a media-specific disabling routine, since the routine can't sleep. 3. Make bearer_disable() operate directly on a struct bearer, instead of needlessly taking a name and then mapping that to the struct. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18tipc: Kill tipc_get_mode() completely.David S. Miller
It's completely unused and exporting a static symbol makes no sense and breaks the build. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-16tipc: cleanup function namespacestephen hemminger
Do some cleanups of TIPC based on make namespacecheck 1. Don't export unused symbols 2. Eliminate dead code 3. Make functions and variables local 4. Rename buf_acquire to tipc_buf_acquire since it is used in several files Compile tested only. This make break out of tree kernel modules that depend on TIPC routines. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13tipc: clean out all instances of #if 0'd unused codePaul Gortmaker
Remove all instances of legacy, or as yet to be implemented code that is currently living within an #if 0 ... #endif block. In the rare instance that some of it be needed in the future, it can still be dragged out of history, but there is no need for it to sit in mainline. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09tipc: Optimize handling excess content on incoming messagesPaul Gortmaker
Remove code that trimmed excess trailing info from incoming messages arriving over an Ethernet interface. TIPC now ignores the extra info while the message is being processed by the node, and only trims it off if the message is retransmitted to another node. (This latter step is done to ensure the extra info doesn't cause the sk_buff to exceed the outgoing interface's MTU limit.) The outgoing buffer is guaranteed to be linear. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-06tipc: Fix misleading error code when enabling Ethernet bearersAllan Stephens
Cause TIPC to return EAGAIN if it is unable to enable a new Ethernet bearer because one or more recently disabled Ethernet bearers are temporarily consuming resources during shut down. (The previous error code, EDQUOT, is now returned only if all available Ethernet bearer data structures are fully enabled at the time the request to enable an additional bearer is received.) Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-06tipc: Ensure outgoing messages on Ethernet have sufficient headroomAllan Stephens
Add code to expand the headroom of an outgoing TIPC message if the sk_buff has insufficient room to hold the header for the associated Ethernet device. This change is necessary to ensure that messages TIPC does not create itself (eg. incoming messages that are being routed to another node) do not cause problems, since TIPC has no control over the amount of headroom available in such messages. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-06tipc: Minor optimizations to name table translation codeAllan Stephens
Optimizes TIPC's name table translation code to avoid unnecessary manipulation of the node address field of the resulting port id when name translation fails. This change is possible because a valid port id cannot have a reference field of zero, so examining the reference only is sufficient to determine if the translation was successful. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17tipc: Prevent missing name table entries when link flip-flops rapidlyAllan Stephens
Ensure that TIPC does not re-establish communication with a neighboring node until it has finished updating all data structures containing information about that node to reflect the earlier loss of contact. Previously, it was possible for TIPC to perform its purge of name table entries relating to the node once contact had already been re-established, resulting in the unwanted removal of valid name table entries. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17tipc: Allow connect() to wait indefinitelyAllan Stephens
Cause a socket whose TIPC_CONN_TIMEOUT option is zero to wait indefinitely for a response to a connection request using connect(). Previously, specifying a timeout of 0 ms resulted in an immediate timeout, which was inconsistent with the behavior specified by Posix for a socket's receive and send timeout. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17tipc: Minor enhancements to name table display formatAllan Stephens
Eliminate printing of dashes after name table column headers (to adhere more closely to the standard format used in tipc-config), and simplify name table display logic using array lookups rather than if-then-else logic. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17tipc: Optimize tipc_node_has_active_links()Allan Stephens
Eliminate unnecessary checking for null node pointer and redundant check of second active link array entry. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
