path: root/net/tipc
2015-07-08net/tipc: initialize security state for new connection socketStephen Smalley
Calling connect() with an AF_TIPC socket would trigger a series of error messages from SELinux along the lines of: SELinux: Invalid class 0 type=AVC msg=audit(1434126658.487:34500): avc: denied { <unprintable> } for pid=292 comm="kworker/u16:5" scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=<unprintable> permissive=0 This was due to a failure to initialize the security state of the new connection sock by the tipc code, leaving it with junk in the security class field and an unlabeled secid. Add a call to security_sk_clone() to inherit the security state from the parent socket. Reported-by: Tim Shearer <tim.shearer@overturenetworks.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-28tipc: purge backlog queue counters when broadcast link is resetJon Paul Maloy
In commit 1f66d161ab3d8b518903fa6c3f9c1f48d6919e74 ("tipc: introduce starvation free send algorithm") we introduced a counter per priority level for buffers in the link backlog queue. We also introduced a new function tipc_link_purge_backlog(), to reset these counters to zero when the link is reset. Unfortunately, we missed to call this function when the broadcast link is reset, with the result that the values of these counters might be permanently skewed when new nodes are attached. This may in the worst case lead to permananent, but spurious, broadcast link congestion, where no broadcast packets can be sent at all. We fix this bug with this commit. Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2015-06-10tipc: disconnect socket directly after probe failureErik Hugne
If the TIPC connection timer expires in a probing state, a self abort message is supposed to be generated and delivered to the local socket. This is currently broken, and the abort message is actually sent out to the peer node with invalid addressing information. This will cause the link to enter a constant retransmission state and eventually reset. We fix this by removing the self-abort message creation and tear down connection immediately instead. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-30tipc: unconditionally put sock refcnt when sock timer to be deleted is pendingYing Xue
As sock refcnt is taken when sock timer is started in sk_reset_timer(), the sock refcnt should be put when sock timer to be deleted is in pending state no matter what "probing_state" value of tipc sock is. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-26tipc: fix bug in link protocol message create functionJon Paul Maloy
In commit dd3f9e70f59f43a5712eba9cf3ee4f1e6999540c ("tipc: add packet sequence number at instant of transmission") we made a change with the consequence that packets in the link backlog queue don't contain valid sequence numbers. However, when we create a link protocol message, we still use the sequence number of the first packet in the backlog, if there is any, as "next_sent" indicator in the message. This may entail unnecessary retransissions or stale packet transmission when there is very low traffic on the link. This commit fixes this issue by only using the current value of tipc_link::snd_nxt as indicator. Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: use sock_create_kern interface to create kernel socketYing Xue
After commit eeb1bd5c40ed ("net: Add a struct net parameter to sock_create_kern"), we should use sock_create_kern() to create kernel socket as the interface doesn't reference count struct net any more. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: add packet sequence number at instant of transmissionJon Paul Maloy
Currently, the packet sequence number is updated and added to each packet at the moment a packet is added to the link backlog queue. This is wasteful, since it forces the code to traverse the send packet list packet by packet when adding them to the backlog queue. It would be better to just splice the whole packet list into the backlog queue when that is the right action to do. In this commit, we do this change. Also, since the sequence numbers cannot now be assigned to the packets at the moment they are added the backlog queue, we do instead calculate and add them at the moment of transmission, when the backlog queue has to be traversed anyway. We do this in the function tipc_link_push_packet(). Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: improve link congestion algorithmJon Paul Maloy
The link congestion algorithm used until now implies two problems. - It is too generous towards lower-level messages in situations of high load by giving "absolute" bandwidth guarantees to the different priority levels. LOW traffic is guaranteed 10%, MEDIUM is guaranted 20%, HIGH is guaranteed 30%, and CRITICAL is guaranteed 40% of the available bandwidth. But, in the absence of higher level traffic, the ratio between two distinct levels becomes unreasonable. E.g. if there is only LOW and MEDIUM traffic on a system, the former is guaranteed 1/3 of the bandwidth, and the latter 2/3. This again means that if there is e.g. one LOW user and 10 MEDIUM users, the former will have 33.3% of the bandwidth, and the others will have to compete for the remainder, i.e. each will end up with 6.7% of the capacity. - Packets of type MSG_BUNDLER are created at SYSTEM importance level, but only after the packets bundled into it have passed the congestion test for their own respective levels. Since bundled packets don't result in incrementing the level counter for their own importance, only occasionally for the SYSTEM level counter, they do in practice obtain SYSTEM level importance. Hence, the current implementation provides a gap in the congestion algorithm that in the worst case may lead to a link reset. We now refine the congestion algorithm as follows: - A message is accepted to the link backlog only if its own level counter, and all superior level counters, permit it. - The importance of a created bundle packet is set according to its contents. A bundle packet created from messges at levels LOW to CRITICAL is given importance level CRITICAL, while a bundle created from a SYSTEM level message is given importance SYSTEM. In the latter case only subsequent SYSTEM level messages are allowed to be bundled into it. This solves the first problem described above, by making the bandwidth guarantee relative to the total number of users at all levels; only the upper limit for each level remains absolute. In the example described above, the single LOW user would use 1/11th of the bandwidth, the same as each of the ten MEDIUM users, but he still has the same guarantee against starvation as the latter ones. The fix also solves the second problem. If the CRITICAL level is filled up by bundle packets of that level, no lower level packets will be accepted any more. Suggested-by: Gergely Kiss <gergely.kiss@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: simplify link supervision checkpointingJon Paul Maloy
We change the sequence number checkpointing that is performed by the timer in order to discover if the peer is active. Currently, we store a checkpoint of the next expected sequence number "rcv_nxt" at each timer expiration, and compare it to the current expected number at next timeout expiration. Instead, we now use the already existing field "silent_intv_cnt" for this task. We step the counter at each timeout expiration, and zero it at each valid received packet. If no valid packet has been received from the peer after "abort_limit" number of silent timer intervals, the link is declared faulty and reset. We also remove the multiple instances of timer activation from inside the FSM function "link_state_event()", and now do it at only one place; at the end of the timer function itself. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: rename fields in struct tipc_linkJon Paul Maloy
We rename some fields in struct tipc_link, in order to give them more descriptive names: next_in_no -> rcv_nxt next_out_no-> snd_nxt fsm_msg_cnt-> silent_intv_cnt cont_intv -> keepalive_intv last_retransmitted -> last_retransm There are no functional changes in this commit. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: simplify packet sequence number handlingJon Paul Maloy
Although the sequence number in the TIPC protocol is 16 bits, we have until now stored it internally as an unsigned 32 bits integer. We got around this by always doing explicit modulo-65535 operations whenever we need to access a sequence number. We now make the incoming and outgoing sequence numbers to unsigned 16-bit integers, and remove the modulo operations where applicable. We also move the arithmetic inline functions for 16 bit integers to core.h, and the function buf_seqno() to msg.h, so they can easily be accessed from anywhere in the code. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: simplify include dependenciesJon Paul Maloy
When we try to add new inline functions in the code, we sometimes run into circular include dependencies. The main problem is that the file core.h, which really should be at the root of the dependency chain, instead is a leaf. I.e., core.h includes a number of header files that themselves should be allowed to include core.h. In reality this is unnecessary, because core.h does not need to know the full signature of any of the structs it refers to, only their type declaration. In this commit, we remove all dependencies from core.h towards any other tipc header file. As a consequence of this change, we can now move the function tipc_own_addr(net) from addr.c to addr.h, and make it inline. There are no functional changes in this commit. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: simplify link timer handlingJon Paul Maloy
Prior to this commit, the link timer has been running at a "continuity interval" of configured link tolerance/4. When a timer wakes up and discovers that there has been no sign of life from the peer during the previous interval, it divides its own timer interval by another factor four, and starts sending one probe per new interval. When the configured link tolerance time has passed without answer, i.e. after 16 unacked probes, the link is declared faulty and reset. This is unnecessary complex. It is sufficient to continue with the original continuity interval, and instead reset the link after four missed probe responses. This makes the timer handling in the link simpler, and opens up for some planned later changes in this area. This commit implements this change. Reviewed-by: Richard Alpe <richard.alpe@ericsson.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14tipc: simplify resetting and disabling of bearersJon Paul Maloy
Since commit 4b475e3f2f8e4e241de101c8240f1d74d0470494 ("tipc: eliminate delayed link deletion at link failover") the extra boolean parameter "shutting_down" is not any longer needed for the functions bearer_disable() and tipc_link_delete_list(). Furhermore, the function tipc_link_reset_links(), called from bearer_reset() is now unnecessary. We can just as well delete all the links, as we do in bearer_disable(), and start over with creating new links. This commit introduces those changes. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-11net: Pass kern from net_proto_family.create to sk_allocEric W. Biederman
In preparation for changing how struct net is refcounted on kernel sockets pass the knowledge that we are creating a kernel socket from sock_create_kern through to sk_alloc. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-09tipc: send explicit not supported error in nl compatRichard Alpe
The legacy netlink API treated EPERM (permission denied) as "operation not supported". Reported-by: Tomi Ollila <tomi.ollila@iki.fi> Signed-off-by: Richard Alpe <richard.alpe@ericsson.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-09tipc: add broadcast link window set/get to nl apiRichard Alpe
Add the ability to get or set the broadcast link window through the new netlink API. The functionality was unintentionally missing from the new netlink API. Adding this means that we also fix the breakage in the old API when coming through the compat layer. Fixes: 37e2d4843f9e (tipc: convert legacy nl link prop set to nl compat) Reported-by: Tomi Ollila <tomi.ollila@iki.fi> Signed-off-by: Richard Alpe <richard.alpe@ericsson.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-09tipc: fix default link prop regression in nl compatRichard Alpe
Default link properties can be set for media or bearer. This functionality was missed when introducing the NL compatibility layer. This patch implements this functionality in the compat netlink layer. It works the same way as it did in the old API. We search for media and bearers matching the "link name". If we find a matching media or bearer the link tolerance, priority or window is used as default for new links on that media or bearer. Fixes: 37e2d4843f9e (tipc: convert legacy nl link prop set to nl compat) Reported-by: Tomi Ollila <tomi.ollila@iki.fi> Signed-off-by: Richard Alpe <richard.alpe@ericsson.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-04tipc: deal with return value of tipc_conn_new callbackYing Xue
Once tipc_conn_new() returns NULL, the connection should be shut down immediately, otherwise, oops may happen due to the NULL pointer. Signed-off-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Jon Maloy <jon.maloy@ericson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-04tipc: adjust locking policy of subscriptionYing Xue
Currently subscriber's lock protects not only subscriber's subscription list but also all subscriptions linked into the list. However, as all members of subscription are never changed after they are initialized, it's unnecessary for subscription to be protected under subscriber's lock. If the lock is used to only protect subscriber's subscription list, the adjustment not only makes the locking policy simpler, but also helps to avoid a deadlock which may happen once creating a subscription is failed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Jon Maloy <jon.maloy@ericson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-04tipc: involve reference counter for subscriberYing Xue
At present subscriber's lock is used to protect the subscription list of subscriber as well as subscriptions linked into the list. While one or all subscriptions are deleted through iterating the list, the subscriber's lock must be held. Meanwhile, as deletion of subscription may happen in subscription timer's handler, the lock must be grabbed in the function as well. When subscription's timer is terminated with del_timer_sync() during above iteration, subscriber's lock has to be temporarily released, otherwise, deadlock may occur. However, the temporary release may cause the double free of a subscription as the subscription is not disconnected from the subscription list. Now if a reference counter is introduced to subscriber, subscription's timer can be asynchronously stopped with del_timer(). As a result, the issue is not only able to be fixed, but also relevant code is pretty readable and understandable. Signed-off-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Jon Maloy <jon.maloy@ericson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-04tipc: introduce tipc_subscrb_create routineYing Xue
Introducing a new function makes the purpose of tipc_subscrb_connect_cb callback routine more clear. Signed-off-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Jon Maloy <jon.maloy@ericson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-04tipc: rename functions defined in subscr.cYing Xue
When a topology server accepts a connection request from its client, it allocates a connection instance and a tipc_subscriber structure object. The former is used to communicate with client, and the latter is often treated as a subscriber which manages all subscription events requested from a same client. When a topology server receives a request of subscribing name services from a client through the connection, it creates a tipc_subscription structure instance which is seen as a subscription recording what name services are subscribed. In order to manage all subscriptions from a same client, topology server links them into the subscrp_list of the subscriber. So subscriber and subscription completely represents different meanings respectively, but function names associated with them make us so confused that we are unable to easily tell which function is against subscriber and which is to subscription. So we want to eliminate the confusion by renaming them. Signed-off-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Jon Maloy <jon.maloy@ericson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-29tipc: fix problem with parallel link synchronization mechanismJon Paul Maloy
Currently, we try to accumulate arrived packets in the links's 'deferred' queue during the parallel link syncronization phase. This entails two problems: - With an unlucky combination of arriving packets the algorithm may go into a lockstep with the out-of-sequence handling function, where the synch mechanism is adding a packet to the deferred queue, while the out-of-sequence handling is retrieving it again, thus ending up in a loop inside the node_lock scope. - Even if this is avoided, the link will very often send out unnecessary protocol messages, in the worst case leading to redundant retransmissions. We fix this by just dropping arriving packets on the upcoming link during the synchronization phase, thus relying on the retransmission protocol to resolve the situation once the two links have arrived to a synchronized state. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-29tipc: remove wrong use of NLM_F_MULTINicolas Dichtel
NLM_F_MULTI must be used only when a NLMSG_DONE message is sent. In fact, it is sent only at the end of a dump. Libraries like libnl will wait forever for NLMSG_DONE. Fixes: 35b9dd7607f0 ("tipc: add bearer get/dump to new netlink api") Fixes: 7be57fc69184 ("tipc: add link get/dump to new netlink api") Fixes: 46f15c6794fb ("tipc: add media get/dump to new netlink api") CC: Richard Alpe <richard.alpe@ericsson.com> CC: Jon Maloy <jon.maloy@ericsson.com> CC: Ying Xue <ying.xue@windriver.com> CC: tipc-discussion@lists.sourceforge.net Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-23tipc: fix node refcount issueErik Hugne
When link statistics is dumped over netlink, we iterate over the list of peer nodes and append each links statistics to the netlink msg. In the case where the dump is resumed after filling up a nlmsg, the node refcnt is decremented without having been incremented previously which may cause the node reference to be freed. When this happens, the following info/stacktrace will be generated, followed by a crash or undefined behavior. We fix this by removing the erroneous call to tipc_node_put inside the loop that iterates over nodes. [ 384.312303] INFO: trying to register non-static key. [ 384.313110] the code is fine but needs lockdep annotation. [ 384.313290] turning off the locking correctness validator. [ 384.313290] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.0.0+ #13 [ 384.313290] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 384.313290] ffff88003c6d0290 ffff88003cc03ca8 ffffffff8170adf1 0000000000000007 [ 384.313290] ffffffff82728730 ffff88003cc03d38 ffffffff810a6a6d 00000000001d7200 [ 384.313290] ffff88003c6d0ab0 ffff88003cc03ce8 0000000000000285 0000000000000001 [ 384.313290] Call Trace: [ 384.313290] <IRQ> [<ffffffff8170adf1>] dump_stack+0x4c/0x65 [ 384.313290] [<ffffffff810a6a6d>] __lock_acquire+0xf3d/0xf50 [ 384.313290] [<ffffffff810a7375>] lock_acquire+0xd5/0x290 [ 384.313290] [<ffffffffa0043e8c>] ? link_timeout+0x1c/0x170 [tipc] [ 384.313290] [<ffffffffa0043e70>] ? link_state_event+0x4e0/0x4e0 [tipc] [ 384.313290] [<ffffffff81712890>] _raw_spin_lock_bh+0x40/0x80 [ 384.313290] [<ffffffffa0043e8c>] ? link_timeout+0x1c/0x170 [tipc] [ 384.313290] [<ffffffffa0043e8c>] link_timeout+0x1c/0x170 [tipc] [ 384.313290] [<ffffffff810c4698>] call_timer_fn+0xb8/0x490 [ 384.313290] [<ffffffff810c45e0>] ? process_timeout+0x10/0x10 [ 384.313290] [<ffffffff810c5a2c>] run_timer_softirq+0x21c/0x420 [ 384.313290] [<ffffffffa0043e70>] ? link_state_event+0x4e0/0x4e0 [tipc] [ 384.313290] [<ffffffff8105a954>] __do_softirq+0xf4/0x630 [ 384.313290] [<ffffffff8105afdd>] irq_exit+0x5d/0x60 [ 384.313290] [<ffffffff8103ade1>] smp_apic_timer_interrupt+0x41/0x50 [ 384.313290] [<ffffffff817144a0>] apic_timer_interrupt+0x70/0x80 [ 384.313290] <EOI> [<ffffffff8100db10>] ? default_idle+0x20/0x210 [ 384.313290] [<ffffffff8100db0e>] ? default_idle+0x1e/0x210 [ 384.313290] [<ffffffff8100e61a>] arch_cpu_idle+0xa/0x10 [ 384.313290] [<ffffffff81099803>] cpu_startup_entry+0x2c3/0x530 [ 384.313290] [<ffffffff810d2893>] ? clockevents_register_device+0x113/0x200 [ 384.313290] [<ffffffff81038b0f>] start_secondary+0x13f/0x170 Fixes: 8a0f6ebe8494 ("tipc: involve reference counter for node structure") Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-23tipc: fix random link reset problemErik Hugne
In the function tipc_sk_rcv(), the stack variable 'err' is only initialized to TIPC_ERR_NO_PORT for the first iteration over the link input queue. If a chain of messages are received from a link, failure to lookup the socket for any but the first message will cause the message to bounce back out on a random link. We fix this by properly initializing err. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-23tipc: fix topology server broken issueYing Xue
When a new topology server is launched in a new namespace, its listening socket is inserted into the "init ns" namespace's socket hash table rather than the one owned by the new namespace. Although the socket's namespace is forcedly changed to the new namespace later, the socket is still stored in the socket hash table of "init ns" namespace. When a client created in the new namespace connects its own topology server, the connection is failed as its server's socket could not be found from its own namespace's socket table. If __sock_create() instead of original sock_create_kern() is used to create the server's socket through specifying an expected namesapce, the socket will be inserted into the specified namespace's socket table, thereby avoiding to the topology server broken issue. Fixes: 76100a8a64bc ("tipc: fix netns refcnt leak") Reported-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-07udp_tunnel: Pass UDP socket down through udp_tunnel{, 6}_xmit_skb().David Miller
That was we can make sure the output path of ipv4/ipv6 operate on the UDP socket rather than whatever random thing happens to be in skb->sk. Based upon a patch by Jiri Pirko. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
2015-04-02tipc: simplify link mtu negotiationJon Paul Maloy
When a link is being established, the two endpoints advertise their respective interface MTU in the transmitted RESET and ACTIVATE messages. If there is any difference, the lower of the two MTUs will be selected for use by both endpoints. However, as a remnant of earlier attempts to introduce TIPC level routing. there also exists an MTU discovery mechanism. If an intermediate node has a lower MTU than the two endpoints, they will discover this through a bisectional approach, and finally adopt this MTU for common use. Since there is no TIPC level routing, and probably never will be, this mechanism doesn't make any sense, and only serves to make the link level protocol unecessarily complex. In this commit, we eliminate the MTU discovery algorithm,and fall back to the simple MTU advertising approach. This change is fully backwards compatible. Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-02tipc: eliminate delayed link deletion at link failoverJon Paul Maloy
When a bearer is disabled manually, all its links have to be reset and deleted. However, if there is a remaining, parallel link ready to take over a deleted link's traffic, we currently delay the delete of the removed link until the failover procedure is finished. This is because the remaining link needs to access state from the reset link, such as the last received packet number, and any partially reassembled buffer, in order to perform a successful failover. In this commit, we do instead move the state data over to the new link, so that it can fulfill the procedure autonomously, without accessing any data on the old link. This means that we can now proceed and delete all pertaining links immediately when a bearer is disabled. This saves us from some unnecessary complexity in such situations. We also choose to change the confusing definitions CHANGEOVER_PROTOCOL, ORIGINAL_MSG and DUPLICATE_MSG to the more descriptive TUNNEL_PROTOCOL, FAILOVER_MSG and SYNCH_MSG respectively. Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-02tipc: drop tunneled packet duplicates at receptionJon Paul Maloy
In commit 8b4ed8634f8b3f9aacfc42b4a872d30c36b9e255 ("tipc: eliminate race condition at dual link establishment") we introduced a parallel link synchronization mechanism that guarentees sequential delivery even for users switching from an old to a newly established link. The new mechanism makes it unnecessary to deliver the tunneled duplicate packets back to the old link, as we are currently doing. It is now sufficient to use the last tunneled packet's inner sequence number as synchronization point between the two parallel links, whereafter it can be dropped. In this commit, we drop the duplicate packets arriving on the new link, after updating the synchronization point at each new arrival. Although it would now have been sufficient for the other endpoint to only tunnel the last packet in its send queue, and not the entire queue, we must still do this to maintain compatibility with older nodes. This commit makes it possible to get rid if some complex interaction between the two parallel links. Reviewed-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/asix_common.c drivers/net/usb/sr9800.c drivers/net/usb/usbnet.c include/linux/usb/usbnet.h net/ipv4/tcp_ipv4.c net/ipv6/tcp_ipv6.c The TCP conflicts were overlapping changes. In 'net' we added a READ_ONCE() to the socket cached RX route read, whilst in 'net-next' Eric Dumazet touched the surrounding code dealing with how mini sockets are handled. With USB, it's a case of the same bug fix first going into net-next and then I cherry picked it back into net. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31tipc: fix a slab object leakYing Xue
When remove TIPC module, there is a warning to remind us that a slab object is leaked like: root@localhost:~# rmmod tipc [ 19.056226] ============================================================================= [ 19.057549] BUG TIPC (Not tainted): Objects remaining in TIPC on kmem_cache_close() [ 19.058736] ----------------------------------------------------------------------------- [ 19.058736] [ 19.060287] INFO: Slab 0xffffea0000519a00 objects=23 used=1 fp=0xffff880014668b00 flags=0x100000000004080 [ 19.061915] INFO: Object 0xffff880014668000 @offset=0 [ 19.062717] kmem_cache_destroy TIPC: Slab cache still has objects This is because the listening socket of TIPC topology server is not closed before TIPC proto handler is unregistered with proto_unregister(). However, as the socket is closed in tipc_exit_net() which is called by unregister_pernet_subsys() during unregistering TIPC namespace operation, the warning can be eliminated if calling unregister_pernet_subsys() is moved before calling proto_unregister(). Fixes: e05b31f4bf89 ("tipc: make tipc socket support net namespace") Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29tipc: fix two bugs in secondary destination lookupJon Paul Maloy
A message sent to a node after a successful name table lookup may still find that the destination socket has disappeared, because distribution of name table updates is non-atomic. If so, the message will be rejected back to the sender with error code TIPC_ERR_NO_PORT. If the source socket of the message has disappeared in the meantime, the message should be dropped. However, in the currrent code, the message will instead be subject to an unwanted tertiary lookup, because the function tipc_msg_lookup_dest() doesn't check if there is an error code present in the message before performing the lookup. In the worst case, the message may now find the old destination again, and be redirected once more, instead of being dropped directly as it should be. A second bug in this function is that the "prev_node" field in the message is not updated after successful lookup, something that may have unpredictable consequences. The problems arising from those bugs occur very infrequently. The third change in this function; the test on msg_reroute_msg_cnt() is purely cosmetic, reflecting that the returned value never can be negative. This commit corrects the two bugs described above. Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29tipc: involve reference counter for node structureYing Xue
TIPC node hash node table is protected with rcu lock on read side. tipc_node_find() is used to look for a node object with node address through iterating the hash node table. As the entire process of what tipc_node_find() traverses the table is guarded with rcu read lock, it's safe for us. However, when callers use the node object returned by tipc_node_find(), there is no rcu read lock applied. Therefore, this is absolutely unsafe for callers of tipc_node_find(). Now we introduce a reference counter for node structure. Before tipc_node_find() returns node object to its caller, it first increases the reference counter. Accordingly, after its caller used it up, it decreases the counter again. This can prevent a node being used by one thread from being freed by another thread. Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Jon Maloy <jon.maloy@ericson.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29tipc: fix potential deadlock when all links are resetYing Xue
[ 60.988363] ====================================================== [ 60.988754] [ INFO: possible circular locking dependency detected ] [ 60.989152] 3.19.0+ #194 Not tainted [ 60.989377] ------------------------------------------------------- [ 60.989781] swapper/3/0 is trying to acquire lock: [ 60.990079] (&(&n_ptr->lock)->rlock){+.-...}, at: [<ffffffffa0006dca>] tipc_link_retransmit+0x1aa/0x240 [tipc] [ 60.990743] [ 60.990743] but task is already holding lock: [ 60.991106] (&(&bclink->lock)->rlock){+.-...}, at: [<ffffffffa00004be>] tipc_bclink_lock+0x8e/0xa0 [tipc] [ 60.991738] [ 60.991738] which lock already depends on the new lock. [ 60.991738] [ 60.992174] [ 60.992174] the existing dependency chain (in reverse order) is: [ 60.992174] -> #1 (&(&bclink->lock)->rlock){+.-...}: [ 60.992174] [<ffffffff810a9c0c>] lock_acquire+0x9c/0x140 [ 60.992174] [<ffffffff8179c41f>] _raw_spin_lock_bh+0x3f/0x50 [ 60.992174] [<ffffffffa00004be>] tipc_bclink_lock+0x8e/0xa0 [tipc] [ 60.992174] [<ffffffffa0000f57>] tipc_bclink_add_node+0x97/0xf0 [tipc] [ 60.992174] [<ffffffffa0011815>] tipc_node_link_up+0xf5/0x110 [tipc] [ 60.992174] [<ffffffffa0007783>] link_state_event+0x2b3/0x4f0 [tipc] [ 60.992174] [<ffffffffa00193c0>] tipc_link_proto_rcv+0x24c/0x418 [tipc] [ 60.992174] [<ffffffffa0008857>] tipc_rcv+0x827/0xac0 [tipc] [ 60.992174] [<ffffffffa0002ca3>] tipc_l2_rcv_msg+0x73/0xd0 [tipc] [ 60.992174] [<ffffffff81646e66>] __netif_receive_skb_core+0x746/0x980 [ 60.992174] [<ffffffff816470c1>] __netif_receive_skb+0x21/0x70 [ 60.992174] [<ffffffff81647295>] netif_receive_skb_internal+0x35/0x130 [ 60.992174] [<ffffffff81648218>] napi_gro_receive+0x158/0x1d0 [ 60.992174] [<ffffffff81559e05>] e1000_clean_rx_irq+0x155/0x490 [ 60.992174] [<ffffffff8155c1b7>] e1000_clean+0x267/0x990 [ 60.992174] [<ffffffff81647b60>] net_rx_action+0x150/0x360 [ 60.992174] [<ffffffff8105ec43>] __do_softirq+0x123/0x360 [ 60.992174] [<ffffffff8105f12e>] irq_exit+0x8e/0xb0 [ 60.992174] [<ffffffff8179f9f5>] do_IRQ+0x65/0x110 [ 60.992174] [<ffffffff8179da6f>] ret_from_intr+0x0/0x13 [ 60.992174] [<ffffffff8100de9f>] arch_cpu_idle+0xf/0x20 [ 60.992174] [<ffffffff8109dfa6>] cpu_startup_entry+0x2f6/0x3f0 [ 60.992174] [<ffffffff81033cda>] start_secondary+0x13a/0x150 [ 60.992174] -> #0 (&(&n_ptr->lock)->rlock){+.-...}: [ 60.992174] [<ffffffff810a8f7d>] __lock_acquire+0x163d/0x1ca0 [ 60.992174] [<ffffffff810a9c0c>] lock_acquire+0x9c/0x140 [ 60.992174] [<ffffffff8179c41f>] _raw_spin_lock_bh+0x3f/0x50 [ 60.992174] [<ffffffffa0006dca>] tipc_link_retransmit+0x1aa/0x240 [tipc] [ 60.992174] [<ffffffffa0001e11>] tipc_bclink_rcv+0x611/0x640 [tipc] [ 60.992174] [<ffffffffa0008646>] tipc_rcv+0x616/0xac0 [tipc] [ 60.992174] [<ffffffffa0002ca3>] tipc_l2_rcv_msg+0x73/0xd0 [tipc] [ 60.992174] [<ffffffff81646e66>] __netif_receive_skb_core+0x746/0x980 [ 60.992174] [<ffffffff816470c1>] __netif_receive_skb+0x21/0x70 [ 60.992174] [<ffffffff81647295>] netif_receive_skb_internal+0x35/0x130 [ 60.992174] [<ffffffff81648218>] napi_gro_receive+0x158/0x1d0 [ 60.992174] [<ffffffff81559e05>] e1000_clean_rx_irq+0x155/0x490 [ 60.992174] [<ffffffff8155c1b7>] e1000_clean+0x267/0x990 [ 60.992174] [<ffffffff81647b60>] net_rx_action+0x150/0x360 [ 60.992174] [<ffffffff8105ec43>] __do_softirq+0x123/0x360 [ 60.992174] [<ffffffff8105f12e>] irq_exit+0x8e/0xb0 [ 60.992174] [<ffffffff8179f9f5>] do_IRQ+0x65/0x110 [ 60.992174] [<ffffffff8179da6f>] ret_from_intr+0x0/0x13 [ 60.992174] [<ffffffff8100de9f>] arch_cpu_idle+0xf/0x20 [ 60.992174] [<ffffffff8109dfa6>] cpu_startup_entry+0x2f6/0x3f0 [ 60.992174] [<ffffffff81033cda>] start_secondary+0x13a/0x150 [ 60.992174] [ 60.992174] other info that might help us debug this: [ 60.992174] [ 60.992174] Possible unsafe locking scenario: [ 60.992174] [ 60.992174] CPU0 CPU1 [ 60.992174] ---- ---- [ 60.992174] lock(&(&bclink->lock)->rlock); [ 60.992174] lock(&(&n_ptr->lock)->rlock); [ 60.992174] lock(&(&bclink->lock)->rlock); [ 60.992174] lock(&(&n_ptr->lock)->rlock); [ 60.992174] [ 60.992174] *** DEADLOCK *** [ 60.992174] [ 60.992174] 3 locks held by swapper/3/0: [ 60.992174] #0: (rcu_read_lock){......}, at: [<ffffffff81646791>] __netif_receive_skb_core+0x71/0x980 [ 60.992174] #1: (rcu_read_lock){......}, at: [<ffffffffa0002c35>] tipc_l2_rcv_msg+0x5/0xd0 [tipc] [ 60.992174] #2: (&(&bclink->lock)->rlock){+.-...}, at: [<ffffffffa00004be>] tipc_bclink_lock+0x8e/0xa0 [tipc] [ 60.992174] The correct the sequence of grabbing n_ptr->lock and bclink->lock should be that the former is first held and the latter is then taken, which exactly happened on CPU1. But especially when the retransmission of broadcast link is failed, bclink->lock is first held in tipc_bclink_rcv(), and n_ptr->lock is taken in link_retransmit_failure() called by tipc_link_retransmit() subsequently, which is demonstrated on CPU0. As a result, deadlock occurs. If the order of holding the two locks happening on CPU0 is reversed, the deadlock risk will be relieved. Therefore, the node lock taken in link_retransmit_failure() originally is moved to tipc_bclink_rcv() so that it's obtained before bclink lock. But the precondition of the adjustment of node lock is that responding to bclink reset event must be moved from tipc_bclink_unlock() to tipc_node_unlock(). Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-25tipc: eliminate race condition at dual link establishmentJon Paul Maloy
Despite recent improvements, the establishment of dual parallel links still has a small glitch where messages can bypass each other. When the second link in a dual-link configuration is established, part of the first link's traffic will be steered over to the new link. Although we do have a mechanism to ensure that packets sent before and after the establishment of the new link arrive in sequence to the destination node, this is not enough. The arriving messages will still be delivered upwards in different threads, something entailing a risk of message disordering during the transition phase. To fix this, we introduce a synchronization mechanism between the two parallel links, so that traffic arriving on the new link cannot be added to its input queue until we are guaranteed that all pre-establishment messages have been delivered on the old, parallel link. This problem seems to always have been around, but its occurrence is so rare that it has not been noticed until recent intensive testing. Reviewed-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-25tipc: clean up handling of link congestionJon Paul Maloy
After the recent changes in message importance handling it becomes possible to simplify handling of messages and sockets when we encounter link congestion. We merge the function tipc_link_cong() into link_schedule_user(), and simplify the code of the latter. The code should now be easier to follow, especially regarding return codes and handling of the message that caused the situation. In case the scheduling function is unable to pre-allocate a wakeup message buffer, it now returns -ENOBUFS, which is a more correct code than the previously used -EHOSTUNREACH. Reviewed-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-25tipc: introduce starvation free send algorithmJon Paul Maloy
Currently, we only use a single counter; the length of the backlog queue, to determine whether a message should be accepted to the queue or not. Each time a message is being sent, the queue length is compared to a threshold value for the message's importance priority. If the queue length is beyond this threshold, the message is rejected. This algorithm implies a risk of starvation of low importance senders during very high load, because it may take a long time before the backlog queue has decreased enough to accept a lower level message. We now eliminate this risk by introducing a counter for each importance priority. When a message is sent, we check only the queue level for that particular message's priority. If that is ok, the message can be added to the backlog, irrespective of the queue level for other priorities. This way, each level is guaranteed a certain portion of the total bandwidth, and any risk of starvation is eliminated. Reviewed-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-25tipc: fix a link reset issue due to retransmission failuresYing Xue
When a node joins a cluster while we are transmitting a fragment stream over the broadcast link, it's missing the preceding fragments needed to build a meaningful message. As a result, the node has to drop it. However, as the fragment message is not acknowledged to its sender before it's dropped, it accidentally causes link reset of retransmission failure on the node. Reported-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Erik Hugne <erik.hugne@ericsson.com> Tested-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-24rhashtable: Disable automatic shrinking by defaultThomas Graf
Introduce a new bool automatic_shrinking to require the user to explicitly opt-in to automatic shrinking of tables. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-24tipc: fix compile error when IPV6=m and TIPC=yYing Xue
When IPV6=m and TIPC=y, below error will appear during building kernel image: net/tipc/udp_media.c:196: undefined reference to `ip6_dst_lookup' make: *** [vmlinux] Error 1 As ip6_dst_lookup() is implemented in IPV6 and IPV6 is compiled as module, ip6_dst_lookup() is not built-in core kernel image. As a result, compiler cannot find 'ip6_dst_lookup' reference while compiling TIPC code into core kernel image. But with the method introduced by commit 5f81bd2e5d80 ("ipv6: export a stub for IPv6 symbols used by vxlan"), we can avoid the compile error through "ipv6_stub" pointer to access ip6_dst_lookup(). Fixes: d0f91938bede ("tipc: add ip/udp media type") Suggested-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-24tipc: validate length of sockaddr in connect() for dgram/rdmSasha Levin
Commit f2f8036 ("tipc: add support for connect() on dgram/rdm sockets") hasn't validated user input length for the sockaddr structure which allows a user to overwrite kernel memory with arbitrary input. Fixes: f2f8036 ("tipc: add support for connect() on dgram/rdm sockets") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23tipc: Use default rhashtable hashfnHerbert Xu
This patch removes the explicit jhash value for the hashfn parameter of rhashtable. The default is now jhash so removing the setting makes no difference apart from making one less copy of jhash in the kernel. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20tipc: Use inlined rhashtable interfaceHerbert Xu
This patch converts tipc to the inlined rhashtable interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-19tipc: fix build issue when building without IPv6Marcelo Ricardo Leitner
We can't directly call ipv6_sock_mc_join() but should use the stub instead and protect it around IS_ENABLED. Fixes: d0f91938bede ("tipc: add ip/udp media type") Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-19tipc: add support for connect() on dgram/rdm socketsErik Hugne
Following the example of ip4_datagram_connect, we store the address in the socket structure for dgram/rdm sockets and use that as the default destination for subsequent send() calls. It is allowed to connect to any address types, and the behaviour of send() will be the same as a normal sendto() with this address provided. Binding to an AF_UNSPEC address clears the association. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-19tipc: do not report -EHOSTUNREACH for failed local deliveryErik Hugne
Since commit 1186adf7df04 ("tipc: simplify message forwarding and rejection in socket layer") -EHOSTUNREACH is propagated back to the sending process if we fail to deliver the message to another socket local to the node. This is wrong, host unreachable should only be reported when the destination port/name does not exist in the cluster, and that check is always done before sending the message. Also, this introduces inconsistent sendmsg() behavior for local/remote destinations. Errors occurring on the receiving side should not trickle up to the sender. If message delivery fails TIPC should either discard the packet or reject it back to the sender based on the destination droppable option. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Acked-by: Ying Xue <ying.xue@windriver.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
