path: root/net/tipc
2013-08-30tipc: set sk_err correctly when connection failsErik Hugne
Should a connect fail, if the publication/server is unavailable or due to some other error, a positive value will be returned and errno is never set. If the application code checks for an explicit zero return from connect (success) or a negative return (failure), it will not catch the error and subsequent send() calls will fail as shown from the strace snippet below. socket(0x1e /* PF_??? */, SOCK_SEQPACKET, 0) = 3 connect(3, {sa_family=0x1e /* AF_??? */, sa_data="\2\1\322\4\0\0\322\4\0\0\0\0\0\0"}, 16) = 111 sendto(3, "test", 4, 0, NULL, 0) = -1 EPIPE (Broken pipe) The reason for this behaviour is that TIPC wrongly inverts error codes set in sk_err. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-11tipc: avoid possible deadlock while enable and disable bearerdingtianhong
We met lockdep warning when enable and disable the bearer for commands such as: tipc-config -netid=1234 -addr=1.1.3 -be=eth:eth0 tipc-config -netid=1234 -addr=1.1.3 -bd=eth:eth0 --------------------------------------------------- [ 327.693595] ====================================================== [ 327.693994] [ INFO: possible circular locking dependency detected ] [ 327.694519] 3.11.0-rc3-wwd-default #4 Tainted: G O [ 327.694882] ------------------------------------------------------- [ 327.695385] tipc-config/5825 is trying to acquire lock: [ 327.695754] (((timer))#2){+.-...}, at: [<ffffffff8105be80>] del_timer_sync+0x0/0xd0 [ 327.696018] [ 327.696018] but task is already holding lock: [ 327.696018] (&(&b_ptr->lock)->rlock){+.-...}, at: [<ffffffffa02be58d>] bearer_disable+ 0xdd/0x120 [tipc] [ 327.696018] [ 327.696018] which lock already depends on the new lock. [ 327.696018] [ 327.696018] [ 327.696018] the existing dependency chain (in reverse order) is: [ 327.696018] [ 327.696018] -> #1 (&(&b_ptr->lock)->rlock){+.-...}: [ 327.696018] [<ffffffff810b3b4d>] validate_chain+0x6dd/0x870 [ 327.696018] [<ffffffff810b40bb>] __lock_acquire+0x3db/0x670 [ 327.696018] [<ffffffff810b4453>] lock_acquire+0x103/0x130 [ 327.696018] [<ffffffff814d65b1>] _raw_spin_lock_bh+0x41/0x80 [ 327.696018] [<ffffffffa02c5d48>] disc_timeout+0x18/0xd0 [tipc] [ 327.696018] [<ffffffff8105b92a>] call_timer_fn+0xda/0x1e0 [ 327.696018] [<ffffffff8105bcd7>] run_timer_softirq+0x2a7/0x2d0 [ 327.696018] [<ffffffff8105379a>] __do_softirq+0x16a/0x2e0 [ 327.696018] [<ffffffff81053a35>] irq_exit+0xd5/0xe0 [ 327.696018] [<ffffffff81033005>] smp_apic_timer_interrupt+0x45/0x60 [ 327.696018] [<ffffffff814df4af>] apic_timer_interrupt+0x6f/0x80 [ 327.696018] [<ffffffff8100b70e>] arch_cpu_idle+0x1e/0x30 [ 327.696018] [<ffffffff810a039d>] cpu_idle_loop+0x1fd/0x280 [ 327.696018] [<ffffffff810a043e>] cpu_startup_entry+0x1e/0x20 [ 327.696018] [<ffffffff81031589>] start_secondary+0x89/0x90 [ 327.696018] [ 327.696018] -> #0 (((timer))#2){+.-...}: [ 327.696018] [<ffffffff810b33fe>] check_prev_add+0x43e/0x4b0 [ 327.696018] [<ffffffff810b3b4d>] validate_chain+0x6dd/0x870 [ 327.696018] [<ffffffff810b40bb>] __lock_acquire+0x3db/0x670 [ 327.696018] [<ffffffff810b4453>] lock_acquire+0x103/0x130 [ 327.696018] [<ffffffff8105bebd>] del_timer_sync+0x3d/0xd0 [ 327.696018] [<ffffffffa02c5855>] tipc_disc_delete+0x15/0x30 [tipc] [ 327.696018] [<ffffffffa02be59f>] bearer_disable+0xef/0x120 [tipc] [ 327.696018] [<ffffffffa02be74f>] tipc_disable_bearer+0x2f/0x60 [tipc] [ 327.696018] [<ffffffffa02bfb32>] tipc_cfg_do_cmd+0x2e2/0x550 [tipc] [ 327.696018] [<ffffffffa02c8c79>] handle_cmd+0x49/0xe0 [tipc] [ 327.696018] [<ffffffff8143e898>] genl_family_rcv_msg+0x268/0x340 [ 327.696018] [<ffffffff8143ed30>] genl_rcv_msg+0x70/0xd0 [ 327.696018] [<ffffffff8143d4c9>] netlink_rcv_skb+0x89/0xb0 [ 327.696018] [<ffffffff8143e617>] genl_rcv+0x27/0x40 [ 327.696018] [<ffffffff8143d21e>] netlink_unicast+0x15e/0x1b0 [ 327.696018] [<ffffffff8143ddcf>] netlink_sendmsg+0x22f/0x400 [ 327.696018] [<ffffffff813f7836>] __sock_sendmsg+0x66/0x80 [ 327.696018] [<ffffffff813f7957>] sock_aio_write+0x107/0x120 [ 327.696018] [<ffffffff8117f76d>] do_sync_write+0x7d/0xc0 [ 327.696018] [<ffffffff8117fc56>] vfs_write+0x186/0x190 [ 327.696018] [<ffffffff811803e0>] SyS_write+0x60/0xb0 [ 327.696018] [<ffffffff814de852>] system_call_fastpath+0x16/0x1b [ 327.696018] [ 327.696018] other info that might help us debug this: [ 327.696018] [ 327.696018] Possible unsafe locking scenario: [ 327.696018] [ 327.696018] CPU0 CPU1 [ 327.696018] ---- ---- [ 327.696018] lock(&(&b_ptr->lock)->rlock); [ 327.696018] lock(((timer))#2); [ 327.696018] lock(&(&b_ptr->lock)->rlock); [ 327.696018] lock(((timer))#2); [ 327.696018] [ 327.696018] *** DEADLOCK *** [ 327.696018] [ 327.696018] 5 locks held by tipc-config/5825: [ 327.696018] #0: (cb_lock){++++++}, at: [<ffffffff8143e608>] genl_rcv+0x18/0x40 [ 327.696018] #1: (genl_mutex){+.+.+.}, at: [<ffffffff8143ed66>] genl_rcv_msg+0xa6/0xd0 [ 327.696018] #2: (config_mutex){+.+.+.}, at: [<ffffffffa02bf889>] tipc_cfg_do_cmd+0x39/ 0x550 [tipc] [ 327.696018] #3: (tipc_net_lock){++.-..}, at: [<ffffffffa02be738>] tipc_disable_bearer+ 0x18/0x60 [tipc] [ 327.696018] #4: (&(&b_ptr->lock)->rlock){+.-...}, at: [<ffffffffa02be58d>] bearer_disable+0xdd/0x120 [tipc] [ 327.696018] [ 327.696018] stack backtrace: [ 327.696018] CPU: 2 PID: 5825 Comm: tipc-config Tainted: G O 3.11.0-rc3-wwd- default #4 [ 327.696018] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 327.696018] 00000000ffffffff ffff880037fa77a8 ffffffff814d03dd 0000000000000000 [ 327.696018] ffff880037fa7808 ffff880037fa77e8 ffffffff810b1c4f 0000000037fa77e8 [ 327.696018] ffff880037fa7808 ffff880037e4db40 0000000000000000 ffff880037e4e318 [ 327.696018] Call Trace: [ 327.696018] [<ffffffff814d03dd>] dump_stack+0x4d/0xa0 [ 327.696018] [<ffffffff810b1c4f>] print_circular_bug+0x10f/0x120 [ 327.696018] [<ffffffff810b33fe>] check_prev_add+0x43e/0x4b0 [ 327.696018] [<ffffffff810b3b4d>] validate_chain+0x6dd/0x870 [ 327.696018] [<ffffffff81087a28>] ? sched_clock_cpu+0xd8/0x110 [ 327.696018] [<ffffffff810b40bb>] __lock_acquire+0x3db/0x670 [ 327.696018] [<ffffffff810b4453>] lock_acquire+0x103/0x130 [ 327.696018] [<ffffffff8105be80>] ? try_to_del_timer_sync+0x70/0x70 [ 327.696018] [<ffffffff8105bebd>] del_timer_sync+0x3d/0xd0 [ 327.696018] [<ffffffff8105be80>] ? try_to_del_timer_sync+0x70/0x70 [ 327.696018] [<ffffffffa02c5855>] tipc_disc_delete+0x15/0x30 [tipc] [ 327.696018] [<ffffffffa02be59f>] bearer_disable+0xef/0x120 [tipc] [ 327.696018] [<ffffffffa02be74f>] tipc_disable_bearer+0x2f/0x60 [tipc] [ 327.696018] [<ffffffffa02bfb32>] tipc_cfg_do_cmd+0x2e2/0x550 [tipc] [ 327.696018] [<ffffffff81218783>] ? security_capable+0x13/0x20 [ 327.696018] [<ffffffffa02c8c79>] handle_cmd+0x49/0xe0 [tipc] [ 327.696018] [<ffffffff8143e898>] genl_family_rcv_msg+0x268/0x340 [ 327.696018] [<ffffffff8143ed30>] genl_rcv_msg+0x70/0xd0 [ 327.696018] [<ffffffff8143ecc0>] ? genl_lock+0x20/0x20 [ 327.696018] [<ffffffff8143d4c9>] netlink_rcv_skb+0x89/0xb0 [ 327.696018] [<ffffffff8143e608>] ? genl_rcv+0x18/0x40 [ 327.696018] [<ffffffff8143e617>] genl_rcv+0x27/0x40 [ 327.696018] [<ffffffff8143d21e>] netlink_unicast+0x15e/0x1b0 [ 327.696018] [<ffffffff81289d7c>] ? memcpy_fromiovec+0x6c/0x90 [ 327.696018] [<ffffffff8143ddcf>] netlink_sendmsg+0x22f/0x400 [ 327.696018] [<ffffffff813f7836>] __sock_sendmsg+0x66/0x80 [ 327.696018] [<ffffffff813f7957>] sock_aio_write+0x107/0x120 [ 327.696018] [<ffffffff813fe29c>] ? release_sock+0x8c/0xa0 [ 327.696018] [<ffffffff8117f76d>] do_sync_write+0x7d/0xc0 [ 327.696018] [<ffffffff8117fa24>] ? rw_verify_area+0x54/0x100 [ 327.696018] [<ffffffff8117fc56>] vfs_write+0x186/0x190 [ 327.696018] [<ffffffff811803e0>] SyS_write+0x60/0xb0 [ 327.696018] [<ffffffff814de852>] system_call_fastpath+0x16/0x1b ----------------------------------------------------------------------- The problem is that the tipc_link_delete() will cancel the timer disc_timeout() when the b_ptr->lock is hold, but the disc_timeout() still call b_ptr->lock to finish the work, so the dead lock occurs. We should unlock the b_ptr->lock when del the disc_timeout(). Remove link_timeout() still met the same problem, the patch: http://article.gmane.org/gmane.network.tipc.general/4380 fix the problem, so no need to send patch for fix link_timeout() deadlock warming. Signed-off-by: Wang Weidong <wangweidong1@huawei.com> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Acked-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01tipc: fix oops when creating server socket failsYing Xue
When creation of TIPC internal server socket fails, we get an oops with the following dump: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc] PGD 13719067 PUD 12008067 PMD 0 Oops: 0000 [#1] SMP DEBUG_PAGEALLOC Modules linked in: tipc(+) CPU: 4 PID: 4340 Comm: insmod Not tainted 3.10.0+ #1 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 task: ffff880014360000 ti: ffff88001374c000 task.ti: ffff88001374c000 RIP: 0010:[<ffffffffa0011f49>] [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc] RSP: 0018:ffff88001374dc98 EFLAGS: 00010292 RAX: 0000000000000000 RBX: ffff880012ac09d8 RCX: 0000000000000000 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffff880014360000 RBP: ffff88001374dcb8 R08: 0000000000000001 R09: 0000000000000001 R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa0016fa0 R13: ffffffffa0017010 R14: ffffffffa0017010 R15: ffff880012ac09d8 FS: 0000000000000000(0000) GS:ffff880016600000(0063) knlGS:00000000f76668d0 CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b CR2: 0000000000000020 CR3: 0000000012227000 CR4: 00000000000006e0 Stack: ffff88001374dcb8 ffffffffa0016fa0 0000000000000000 0000000000000001 ffff88001374dcf8 ffffffffa0012922 ffff88001374dce8 00000000ffffffea ffffffffa0017100 0000000000000000 ffff8800134241a8 ffffffffa0017150 Call Trace: [<ffffffffa0012922>] tipc_server_stop+0xa2/0x1b0 [tipc] [<ffffffffa0009995>] tipc_subscr_stop+0x15/0x20 [tipc] [<ffffffffa00130f5>] tipc_core_stop+0x1d/0x33 [tipc] [<ffffffffa001f0d4>] tipc_init+0xd4/0xf8 [tipc] [<ffffffffa001f000>] ? 0xffffffffa001efff [<ffffffff8100023f>] do_one_initcall+0x3f/0x150 [<ffffffff81082f4d>] ? __blocking_notifier_call_chain+0x7d/0xd0 [<ffffffff810cc58a>] load_module+0x11aa/0x19c0 [<ffffffff810c8d60>] ? show_initstate+0x50/0x50 [<ffffffff8190311c>] ? retint_restore_args+0xe/0xe [<ffffffff810cce79>] SyS_init_module+0xd9/0x110 [<ffffffff8190dc65>] sysenter_dispatch+0x7/0x1f Code: 6c 24 70 4c 89 ef e8 b7 04 8f e1 8b 73 04 4c 89 e7 e8 7c 9e 32 e1 41 83 ac 24 b8 00 00 00 01 4c 89 ef e8 eb 0a 8f e1 48 8b 43 08 <4c> 8b 68 20 4d 8d a5 48 03 00 00 4c 89 e7 e8 04 05 8f e1 4c 89 RIP [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc] RSP <ffff88001374dc98> CR2: 0000000000000020 ---[ end trace b02321f40e4269a3 ]--- We have the following call chain: tipc_core_start() ret = tipc_subscr_start() ret = tipc_server_start(){ server->enabled = 1; ret = tipc_open_listening_sock() } I.e., the server->enabled flag is unconditionally set to 1, whatever the return value of tipc_open_listening_sock(). This causes a crash when tipc_core_start() tries to clean up resources after a failed initialization: if (ret == failed) tipc_subscr_stop() tipc_server_stop(){ if (server->enabled) tipc_close_conn(){ NULL reference of con->sock-sk OOPS! } } To avoid this, tipc_server_start() should only set server->enabled to 1 in case of a succesful socket creation. In case of failure, it should release all allocated resources before returning. Problem introduced in commit c5fa7b3cf3cb22e4ac60485fc2dc187fe012910f ("tipc: introduce new TIPC server infrastructure") in v3.11-rc1. Note that it won't be seen often; it takes a module load under memory constrained conditions in order to trigger the failure condition. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-11net/tipc: use %*phC to dump small buffers in hex formAndy Shevchenko
Instead of passing each byte by stack let's use nice specifier for that. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: remove dev_base_lock use from enable_bearerYing Xue
Convert enable_bearer() to RCU locking with dev_get_by_name(). Based on a similar changeset in commit 840a185d ["aoe: remove dev_base_lock use from aoecmd_cfg_pkts()"] -- quoting that: "dev_base_lock is the legacy way to lock the device list, and is planned to disappear. (writers hold RTNL, readers hold RCU lock)" Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: fix wrong return value for link_send_sections_long routineYing Xue
When skb buffer cannot be allocated in link_send_sections_long(), -ENOMEM error code instead of -EFAULT should be returned to its caller. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: make tipc_link_send_sections_fast exit earlierYing Xue
Once message build request function returns invalid code, the process of sending message cannot continue. So in case of message build failure, tipc_link_send_sections_fast() should return immediately. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: enhance priority of link protocol packetYing Xue
pfifo_fast is set as default traffic class queueing discipline. This queue has three so called "bands". Within each band, FIFO rules apply. However, as long as there are packets waiting in band 0, band 1 won't be processed. Now all kind of TIPC type packet priorities are never set, that is, their priorities are 0, so they are mapped to band 1 of pfifo_fast qdisc. But, especially during link congestion, if link protocol packet can be sent out as earlier as possible than other type of packets so that protocol packet can arrive at peer endpoint in time, the peer will timely reset its link timeout timer to keep the link alive. So enhancing the priority of link protocol packets can meet the specific demand to avoid unnecessary link reset due to a transient link congestion. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: cosmetic realignment of function argumentsPaul Gortmaker
No runtime code changes here. Just a realign of the function arguments to start where the 1st one was, and fit as many args as can be put in an 80 char line. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: save sock structure pointer instead of void pointer to tipc_portYing Xue
Directly save sock structure pointer instead of void pointer to avoid unnecessary cast conversions. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: convert config_lock from spinlock to mutexYing Xue
As the configuration server is now running under process context, it's unnecessary for us to have a spinlock serializing the TIPC configuration process. Instead, we replace it with a mutex lock, which gives us more freedom. For instance, we can now call pre-emptable functions within the protected area. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: rename tipc_createport_raw to tipc_createportYing Xue
After the removal of the native API, there is now only one way to to create a TIPC port instance -- the function tipc_createport_raw(). We make it more readable by renaming it to tipc_createport(). Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: remove user_port instance from tipc_port structureYing Xue
After the native API has been completely removed, the 'user_port' field in struct tipc_port becomes unused, and can be removed. As a consequence, the "usrmem" argument in tipc_msg_build() is no longer needed, and so we remove that one too. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: delete code orphaned by new server infrastructureYing Xue
Having completed the conversion of the topology server and configuration server to use the new server infrastructure, the following functions become unused, and can be deleted: - tipc_createport() - port_wakeup_sh() - port_dispatcher() - port_dispatcher_sigh() - tipc_send_buf_fast() - tipc_send_buf2port Additionally, the following variables become orphaned, and can be deleted: - tipc_msg_err_event - tipc_named_msg_err_event - tipc_conn_shutdown_event - tipc_msg_event - tipc_named_msg_event - tipc_conn_msg_event - tipc_continue_event - msg_queue_head - msg_queue_tail - queue_lock Deletion is done here in a separate commit in order to allow the actual conversion changes to be more easily viewed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: convert configuration server to use new server facilityYing Xue
As the new socket-based TIPC server infrastructure has been introduced, we can now convert the configuration server to use it. Then we can take future steps to simplify the configuration server locking policy. Some minor reordering of initialization is done, due to the dependency on having tipc_socket_init completed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: convert topology server to use new server facilityYing Xue
As the new TIPC server infrastructure has been introduced, we can now convert the TIPC topology server to it. We get two benefits from doing this: 1) It simplifies the topology server locking policy. In the original locking policy, we placed one spin lock pointer in the tipc_subscriber structure to reuse the lock of the subscriber's server port, controlling access to members of tipc_subscriber instance. That is, we only used one lock to ensure both tipc_port and tipc_subscriber members were safely accessed. Now we introduce another spin lock for tipc_subscriber structure only protecting themselves, to get a finer granularity locking policy. Moreover, the change will allow us to make the topology server code more readable and maintainable. 2) It fixes a bug where sent subscription events may be lost when the topology port is congested. Using the new service, the topology server now queues sent events into an outgoing buffer, and then wakes up a sender process which has been blocked in workqueue context. The process will keep picking events from the buffer and send them to their respective subscribers, using the kernel socket interface, until the buffer is empty. Even if the socket is congested during transmission there is no risk that events may be dropped, since the sender process may block when needed. Some minor reordering of initialization is done, since we now have a scenario where the topology server must be started after socket initialization has taken place, as the former depends on the latter. And overall, we see a simplification of the TIPC subscriber code in making this changeover. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: introduce new TIPC server infrastructureYing Xue
TIPC has two internal servers, one providing a subscription service for topology events, and another providing the configuration interface. These servers have previously been running in BH context, accessing the TIPC-port (aka native) API directly. Apart from these servers, even the TIPC socket implementation is partially built on this API. As this API may simultaneously be called via different paths and in different contexts, a complex and costly lock policiy is required in order to protect TIPC internal resources. To eliminate the need for this complex lock policiy, we introduce a new, generic service API that uses kernel sockets for message passing instead of the native API. Once the toplogy and configuration servers are converted to use this new service, all code pertaining to the native API can be removed. This entails a significant reduction in code amount and complexity, and opens up for a complete rework of the locking policy in TIPC. The new service also solves another problem: As the current topology server works in BH context, it cannot easily be blocked when sending of events fails due to congestion. In such cases events may have to be silently dropped, something that is unacceptable. Therefore, the new service keeps a dedicated outbound queue receiving messages from BH context. Once messages are inserted into this queue, we will immediately schedule a work from a special workqueue. This way, messages/events from the topology server are in reality sent in process context, and the server can block if necessary. Analogously, there is a new workqueue for receiving messages. Once a notification about an arriving message is received in BH context, we schedule a work from the receive workqueue to do the job of receiving the message in process context. As both sending and receive messages are now finished in processes, subscribed events cannot be dropped any more. As of this commit, this new server infrastructure is built, but not actually yet called by the existing TIPC code, but since the conversion changes required in order to use it are significant, the addition is kept here as a separate commit. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: allow implicit connect for stream socketsErik Hugne
TIPC's implied connect feature, aka piggyback connect, allows applications to save one syscall and all SYN/SYN-ACK signalling overhead when setting up a connection. Until now, this has only been supported for SEQPACKET sockets. Here, we make it possible to use this feature even with stream sockets. At the connecting side, the connection is completed when the first data message arrives from the accepting peer. This means that we must allow the connecting user to call blocking recv() before the socket has reached state SS_CONNECTED. So we must must relax the state machine check at recv_stream(), and allow the recv() call even if socket is in state SS_CONNECTING. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: change socket buffer overflow control to respect sk_rcvbufYing Xue
As per feedback from the netdev community, we change the buffer overflow protection algorithm in receiving sockets so that it always respects the nominal upper limit set in sk_rcvbuf. Instead of scaling up from a small sk_rcvbuf value, which leads to violation of the configured sk_rcvbuf limit, we now calculate the weighted per-message limit by scaling down from a much bigger value, still in the same field, according to the importance priority of the received message. To allow for administrative tunability of the socket receive buffer size, we create a tipc_rmem sysctl variable to allow the user to configure an even bigger value via sysctl command. It is a size of three (min/default/max) to be consistent with things like tcp_rmem. By default, the value initialized in tipc_rmem[1] is equal to the receive socket size needed by a TIPC_CRITICAL_IMPORTANCE message. This value is also set as the default value of sk_rcvbuf. Originally-by: Jon Maloy <jon.maloy@ericsson.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Jon Maloy <jon.maloy@ericsson.com> [Ying: added sysctl variation to Jon's original patch] Signed-off-by: Ying Xue <ying.xue@windriver.com> [PG: don't compile sysctl.c if not config'd; add Documentation] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06tipc: potential divide by zero in tipc_link_recv_fragment()Dan Carpenter
The worry here is that fragm_sz could be zero since it comes from skb->data. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06tipc: add a bounds check in link_recv_changeover_msg()Dan Carpenter
The bearer_id here comes from skb->data and it can be a number from 0 to 7. The problem is that the ->links[] array has only 2 elements so I have added a range check. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-03tipc: pskb_copy() buffers when sending on more than one bearerGerlando Falauto
When sending packets, TIPC bearers use skb_clone() before writing their hardware header. This will however NOT copy the data buffer. So when the same packet is sent over multiple bearers (to reach multiple nodes), the same socket buffer data will be treated by multiple tipc_media drivers which will write their own hardware header through dev_hard_header(). Most of the time this is not a problem, because by the time the packet is processed by the second media, it has already been sent over the first one. However, when the first transmission is delayed (e.g. because of insufficient bandwidth or through a shaper), the next bearer will overwrite the hardware header, resulting in the packet being sent: a) with the wrong source address, when bearers of the same type, e.g. ethernet, are involved b) with a completely corrupt header, or even dropped, when bearers of different types are involved. So when the same socket buffer is to be sent multiple times, send a pskb_copy() instead (from the second instance on), and release it afterwards (the bearer will skb_clone() it anyway). Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-03tipc: tipc_bcbearer_send(): simplify bearer selectionGerlando Falauto
2013-05-03tipc: cosmetic: clean up comments and break a long lineGerlando Falauto
2013-04-17tipc: add InfiniBand media typePatrick McHardy
Add InfiniBand media type based on the ethernet media type. The only real difference is that in case of InfiniBand, we need the entire 20 bytes of space reserved for media addresses, so the TIPC media type ID is not explicitly stored in the packet payload. Sample output of tipc-config: # tipc-config -v -addr -netid -nt=all -p -m -b -n -ls node address: <10.1.4> current network id: 4711 Type Lower Upper Port Identity Publication Scope 0 167776257 167776257 <10.1.1:1855512577> 1855512578 cluster 167776260 167776260 <10.1.4:1216454657> 1216454658 zone 1 1 1 <10.1.4:1216479235> 1216479236 node Ports: 1216479235: bound to {1,1} 1216454657: bound to {0,167776260} Media: eth ib Bearers: ib:ib0 Nodes known: <10.1.1>: up Link <broadcast-link> Window:20 packets RX packets:0 fragments:0/0 bundles:0/0 TX packets:0 fragments:0/0 bundles:0/0 RX naks:0 defs:0 dups:0 TX naks:0 acks:0 dups:0 Congestion bearer:0 link:0 Send queue max:0 avg:0 Link <10.1.4:ib0-10.1.1:ib0> ACTIVE MTU:2044 Priority:10 Tolerance:1500 ms Window:50 packets RX packets:80 fragments:0/0 bundles:0/0 TX packets:40 fragments:0/0 bundles:0/0 TX profile sample:22 packets average:54 octets 0-64:100% -256:0% -1024:0% -4096:0% -16384:0% -32768:0% -66000:0% RX states:410 probes:213 naks:0 defs:0 dups:0 TX states:410 probes:197 naks:0 acks:0 dups:0 Congestion bearer:0 link:0 Send queue max:1 avg:0 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17tipc: set skb->protocol in eth_media packet transmissionPatrick McHardy
The skb->protocol field is used by packet classifiers and for AF_PACKET cooked format, TIPC needs to set it properly. Fixes packet classification and ethertype of 0x0000 in cooked captures: Out 20:c9:d0:43:12:d9 ethertype Unknown (0x0000), length 56: 0x0000: 5b50 0028 0000 30d4 0100 1000 0100 1001 [P.(..0......... 0x0010: 0000 03e8 0000 0001 20c9 d043 12d9 0000 ...........C.... 0x0020: 0000 0000 0000 0000 ........ Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17tipc: move bcast_addr from struct tipc_media to struct tipc_bearerPatrick McHardy
Some network protocols, like InfiniBand, don't have a fixed broadcast address but one that depends on the configuration. Move the bcast_addr to struct tipc_bearer and initialize it with the broadcast address of the network device when the bearer is enabled. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17tipc: remove unused str2addr media callbackPatrick McHardy
2013-04-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/nfc/microread/mei.c net/netfilter/nfnetlink_queue_core.c Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which some cleanups are going to go on-top. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07tipc: fix info leaks via msg_name in recv_msg/recv_streamMathias Krause
The code in set_orig_addr() does not initialize all of the members of struct sockaddr_tipc when filling the sockaddr info -- namely the union is only partly filled. This will make recv_msg() and recv_stream() -- the only users of this function -- leak kernel stack memory as the msg_name member is a local variable in net/socket.c. Additionally to that both recv_msg() and recv_stream() fail to update the msg_namelen member to 0 while otherwise returning with 0, i.e. "success". This is the case for, e.g., non-blocking sockets. This will lead to a 128 byte kernel stack leak in net/socket.c. Fix the first issue by initializing the memory of the union with memset(0). Fix the second one by setting msg_namelen to 0 early as it will be updated later if we're going to fill the msg_name member. Cc: Jon Maloy <jon.maloy@ericsson.com> Cc: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-28net-next: replace obsolete NLMSG_* with type safe nlmsg_*Hong zhi guo
Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net into netDavid S. Miller
Pull in 'net' to take in the bug fixes that didn't make it into 3.8-final. Also, deal with the semantic conflict of the change made to net/ipv6/xfrm6_policy.c A missing rt6->n neighbour release was added to 'net', but in 'net-next' we no longer cache the neighbour entries in the ipv6 routes so that change is not appropriate there. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-15tipc: remove redundant checking for the number of iovecs in a send requestYing Xue
As the number of iovecs in a send request is already limited within UIO_MAXIOV(i.e. 1024) in __sys_sendmsg(), it's unnecessary to check it again in TIPC stack. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-02-15tipc: byte-based overload control on socket receive queueYing Xue
Change overload control to be purely byte-based, using sk->sk_rmem_alloc as byte counter, and compare it to a calculated upper limit for the socket receive queue. For all connection messages, irrespective of message importance, the overload limit is set to a constant value (i.e, 67MB). This limit should normally never be reached because of the lower limit used by the flow control algorithm, and is there only as a last resort in case a faulty peer doesn't respect the send window limit. For datagram messages, message importance is taken into account when calculating the overload limit. The calculation is based on sk->sk_rcvbuf, and is hence configurable via the socket option SO_RCVBUF. Cc: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-02-15tipc: eliminate duplicated discard_rx_queue routineYing Xue
The tipc function discard_rx_queue() is just a duplicated implementation of __skb_queue_purge(). Remove the former and directly invoke __skb_queue_purge(). In doing so, the underscores convey to the code reader, more information about the current locking state that is assumed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-02-15tipc: fix missing spinlock init in broadcast codeErik Hugne
After commit 3c294cb3 "tipc: remove the bearer congestion mechanism", we try to grab the broadcast bearer lock when sending multicast messages over the broadcast link. This will cause an oops because the lock is never initialized. This is an old bug, but the lock was never actually used before commit 3c294cb3, so that why it was not visible until now. The oops will look something like: BUG: spinlock bad magic on CPU#2, daemon/147 lock: bcast_bearer+0x48/0xffffffffffffd19a [tipc], .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 Pid: 147, comm: daemon Not tainted 3.8.0-rc3+ #206 Call Trace: spin_dump+0x8a/0x8f spin_bug+0x21/0x26 do_raw_spin_lock+0x114/0x150 _raw_spin_lock_bh+0x19/0x20 tipc_bearer_blocked+0x1f/0x40 [tipc] tipc_link_send_buf+0x82/0x280 [tipc] ? __alloc_skb+0x9f/0x2b0 tipc_bclink_send_msg+0x77/0xa0 [tipc] tipc_multicast+0x11b/0x1b0 [tipc] send_msg+0x225/0x530 [tipc] sock_sendmsg+0xca/0xe0 The above can be triggered by running the multicast demo program. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-11net/tipc: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Jon Maloy <jon.maloy@ericsson.com> CC: Allan Stephens <allan.stephens@windriver.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2012-12-07tipc: refactor accept() code for improved readabilityPaul Gortmaker
In TIPC's accept() routine, there is a large block of code relating to initialization of a new socket, all within an if condition checking if the allocation succeeded. Here, we simply flip the check of the if, so that the main execution path stays at the same indentation level, which improves readability. If the allocation fails, we jump to an already existing exit label. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: add lock nesting notation to quiet lockdep warningYing Xue
TIPC accept() call grabs the socket lock on a newly allocated socket while holding the socket lock on an old socket. But lockdep worries that this might be a recursive lock attempt: [ INFO: possible recursive locking detected ] --------------------------------------------- kworker/u:0/6 is trying to acquire lock: (sk_lock-AF_TIPC){+.+.+.}, at: [<c8c1226c>] accept+0x15c/0x310 [tipc] but task is already holding lock: (sk_lock-AF_TIPC){+.+.+.}, at: [<c8c12138>] accept+0x28/0x310 [tipc] other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(sk_lock-AF_TIPC); lock(sk_lock-AF_TIPC); *** DEADLOCK *** May be due to missing lock nesting notation [...] Tell lockdep that this locking is safe by using lock_sock_nested(). This is similar to what was done in commit 5131a184a3458d9 for SCTP code ("SCTP: lock_sock_nested in sctp_sock_migrate"). Also note that this is isn't something that is seen normally, as it was uncovered with some experimental work-in-progress code not yet ready for mainline. So no need for stable backports or similar of this commit. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: eliminate connection setup for implied connect in recv_msg()Ying Xue
As connection setup is now completed asynchronously in BH context, in the function filter_connect(), the corresponding code in recv_msg() becomes redundant. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: introduce non-blocking socket connectYing Xue
TIPC has so far only supported blocking connect(), meaning that a call to connect() doesn't return until either the connection is fully established, or an error occurs. This has proved insufficient for many users, so we now introduce non-blocking connect(), analogous to how this is done in TCP and other protocols. With this feature, if a connection cannot be established instantly, connect() will return the error code "-EINPROGRESS". If the user later calls connect() again, he will either have the return code "-EALREADY" or "-EISCONN", depending on whether the connection has been established or not. The user must have explicitly set the socket to be non-blocking (SOCK_NONBLOCK or O_NONBLOCK, depending on method used), so unless for some reason they had set this already (the socket would anyway remain blocking in current TIPC) this change should be completely backwards compatible. It is also now possible to call select() or poll() to wait for the completion of a connection. An effect of the above is that the actual completion of a connection may now be performed asynchronously, independent of the calls from user space. Therefore, we now execute this code in BH context, in the function filter_rcv(), which is executed upon reception of messages in the socket. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> [PG: minor refactoring for improved connect/disconnect function names] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: consolidate connection-oriented message reception in one functionYing Xue
Handling of connection-related message reception is currently scattered around at different places in the code. This makes it harder to verify that things are handled correctly in all possible scenarios. So we consolidate the existing processing of connection-oriented message reception in a single routine. In the process, we convert the chain of if/else into a switch/case for improved readability. A cast on the socket_state in the switch is needed to avoid compile warnings on 32 bit, like "net/tipc/socket.c:1252:2: warning: case value ‘4294967295’ not in enumerated type". This happens because existing tipc code pseudo extends the default linux socket state values with: #define SS_LISTENING -1 /* socket is listening */ #define SS_READY -2 /* socket is connectionless */ It may make sense to add these as _positive_ values to the existing socket state enum list someday, vs. these already existing defines. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> [PG: add cast to fix warning; remove returns from middle of switch] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: standardize across connect/disconnect function namingPaul Gortmaker
Currently we have tipc_disconnect and tipc_disconnect_port. It is not clear from the names alone, what they do or how they differ. It turns out that tipc_disconnect just deals with the port locking and then calls tipc_disconnect_port which does all the work. If we rename as follows: tipc_disconnect_port --> __tipc_disconnect then we will be following typical linux convention, where: __tipc_disconnect: "raw" function that does all the work. tipc_disconnect: wrapper that deals with locking and then calls the real core __tipc_disconnect function With this, the difference is immediately evident, and locking violations are more apt to be spotted by chance while working on, or even just while reading the code. On the connect side of things, we currently only have the single "tipc_connect2port" function. It does both the locking at enter/exit, and the core of the work. Pending changes will make it desireable to have the connect be a two part locking wrapper + worker function, just like the disconnect is already. Here, we make the connect look just like the updated disconnect case, for the above reason, and for consistency. In the process, we also get rid of the "2port" suffix that was on the original name, since it adds no descriptive value. On close examination, one might notice that the above connect changes implicitly move the call to tipc_link_get_max_pkt() to be within the scope of tipc_port_lock() protected region; when it was not previously. We don't see any issues with this, and it is in keeping with __tipc_connect doing the work and tipc_connect just handling the locking. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: change sk_receive_queue upper limitJon Maloy
The sk_recv_queue upper limit for connectionless sockets has empirically turned out to be too low. When we double the current limit we get much fewer rejected messages and no noticable negative side-effects. Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: eliminate aggregate sk_receive_queue limitYing Xue
As a complement to the per-socket sk_recv_queue limit, TIPC keeps a global atomic counter for the sum of sk_recv_queue sizes across all tipc sockets. When incremented, the counter is compared to an upper threshold value, and if this is reached, the message is rejected with error code TIPC_OVERLOAD. This check was originally meant to protect the node against buffer exhaustion and general CPU overload. However, all experience indicates that the feature not only is redundant on Linux, but even harmful. Users run into the limit very often, causing disturbances for their applications, while removing it seems to have no negative effects at all. We have also seen that overall performance is boosted significantly when this bottleneck is removed. Furthermore, we don't see any other network protocols maintaining such a mechanism, something strengthening our conviction that this control can be eliminated. As a result, the atomic variable tipc_queue_size is now unused and so it can be deleted. There is a getsockopt call that used to allow reading it; we retain that but just return zero for maximum compatibility. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Cc: Neil Horman <nhorman@tuxdriver.com> [PG: phase out tipc_queue_size as pointed out by Neil Horman] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-06tipc: remove obsolete flush of stale reassembly bufferErik Hugne
Each link instance has a periodic job checking if there is a stale ongoing message reassembly associated to the link. If no new fragment has been received during the last 4*[link_tolerance] period, it is assumed the missing fragment will never arrive. As a consequence, the reassembly buffer is discarded, and a gap in the message sequence occurs. This assumption is wrong. After we abandoned our ambition to develop packet routing for multi-cluster networks, only single-hop packet transfer remains as an option. For those, all packets are guaranteed to be delivered in sequence to the defragmentation layer. Any failure to achieve sequenced delivery will eventually lead to link reset, and the reassembly buffer will be flushed anyway. So we just remove this periodic check, which is now obsolete. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Acked-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> [PG: also delete get/inc_timer count, since they are now unused] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-11-22tipc: delete TIPC_ADVANCED Kconfig variablePaul Gortmaker
There used to be a time when TIPC had lots of Kconfig knobs the end user could alter, but they have all been made automatic or obsolete, with the exception of CONFIG_TIPC_PORTS. This previously existing set of options was all hidden under the TIPC_ADVANCED setting, which does not exist in any code, but only in Kconfig scope. Having this now, just to hide the one remaining "advanced" option no longer makes sense. Remove it. Also get rid of the ifdeffery in the TIPC code that allowed for TIPC_PORTS to be possibly undefined. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
