The memory barrier in the helper wq_has_sleeper is needed by just
about every user of waitqueue_active. This patch generalises it
by making it take a wait_queue_head_t directly. The existing
helper is renamed to skwq_has_sleeper.
Rainer Weikusat <rweikusat@mobileactivedefense.com> writes:
An AF_UNIX datagram socket being the client in an n:1 association with
some server socket is only allowed to send messages to the server if the
receive queue of this socket contains at most sk_max_ack_backlog
datagrams. This implies that prospective writers might be forced to go
to sleep despite none of the message presently enqueued on the server
receive queue were sent by them. In order to ensure that these will be
woken up once space becomes again available, the present unix_dgram_poll
routine does a second sock_poll_wait call with the peer_wait wait queue
of the server socket as queue argument (unix_dgram_recvmsg does a wake
up on this queue after a datagram was received). This is inherently
problematic because the server socket is only guaranteed to remain alive
for as long as the client still holds a reference to it. In case the
connection is dissolved via connect or by the dead peer detection logic
in unix_dgram_sendmsg, the server socket may be freed despite "the
polling mechanism" (in particular, epoll) still has a pointer to the
corresponding peer_wait queue. There's no way to forcibly deregister a
wait queue with epoll.
Based on an idea by Jason Baron, the patch below changes the code such
that a wait_queue_t belonging to the client socket is enqueued on the
peer_wait queue of the server whenever the peer receive queue full
condition is detected by either a sendmsg or a poll. A wake up on the
peer queue is then relayed to the ordinary wait queue of the client
socket via wake function. The connection to the peer wait queue is again
dissolved if either a wake up is about to be relayed or the client
socket reconnects or a dead peer is detected or the client socket is
itself closed. This enables removing the second sock_poll_wait from
unix_dgram_poll, thus avoiding the use-after-free, while still ensuring
that no blocked writer sleeps forever.
Signed-off-by: Rainer Weikusat <rweikusat@mobileactivedefense.com>
Fixes: ec0d215f9420 ("af_unix: fix 'poll for write'/connected DGRAM sockets")
Reviewed-by: Jason Baron <jbaron@akamai.com>
While possibly in future we don't necessarily need to use
sk_buff_head.lock this is a rather larger change, as it affects the
af_unix fd garbage collector, diag and socket cleanups. This is too much
for a stable patch.
For the time being grab sk_buff_head.lock without disabling bh and irqs,
so don't use locked skb_queue_tail.
Fixes: 869e7c62486e ("net: af_unix: implement stream sendpage support")
Cc: Eric Dumazet <edumazet@google.com>
Reported-by: Eric Dumazet <edumazet@google.com>
In case multiple writes to a unix stream socket race we could end up in a
situation where we pre-allocate a new skb for use in unix_stream_sendpage
but have to free it again in the locked section because another skb
has been appended meanwhile, which we must use. Accidentally we didn't
clear the pointer after consuming it and so we touched freed memory
while appending it to the sk_receive_queue. So, clear the pointer after
consuming the skb.
This bug has been found with syzkaller
(http://github.com/google/syzkaller) by Dmitry Vyukov.
Cc: Dmitry Vyukov <dvyukov@google.com>
During splicing an af-unix socket to a pipe we have to drop all
af-unix socket locks. While doing so we allow another reader to enter
unix_stream_read_generic which can read, copy and finally free another
skb. If exactly this skb is just in process of being spliced we get a
use-after-free report by kasan.
First, we must make sure to not have a free while the skb is used during
the splice operation. We simply increment its use counter before unlocking
the reader lock.
Stream sockets have the nice characteristic that we don't care about
zero length writes and they never reach the peer socket's queue. That
said, we can take the UNIXCB.consumed field as the indicator if the
skb was already freed from the socket's receive queue. If the skb was
fully consumed after we locked the reader side again we know it has been
dropped by a second reader. We indicate a short read to user space and
abort the current splice operation.
Fixes: 2b514574f7e8 ("net: af_unix: implement splice for stream af_unix sockets")
poll(POLLOUT) on a listener should not report fd is ready for
a write().
This would break some applications using poll() and pfd.events = -1,
as they would not block in poll()
Reported-by: Alan Burlison <Alan.Burlison@oracle.com>
Tested-by: Eric Dumazet <edumazet@google.com>
Now send with MSG_PEEK can return data from multiple SKBs.
Unfortunately we take into account the peek offset for each skb,
that is wrong. We need to apply the peek offset only once.
In addition, the peek offset should be used only if MSG_PEEK is set.
Cc: "David S. Miller" <davem@davemloft.net> (maintainer:NETWORKING
Cc: Eric Dumazet <edumazet@google.com> (commit_signer:1/14=7%)
Cc: Aaron Conole <aconole@bytheb.org>
Fixes: 9f389e35674f ("af_unix: return data from multiple SKBs on recv() with MSG_PEEK flag")
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Tested-by: Aaron Conole <aconole@bytheb.org>
AF_UNIX sockets now return multiple skbs from recv() when MSG_PEEK flag
is set.
This is referenced in kernel bugzilla #12323 @
https://bugzilla.kernel.org/show_bug.cgi?id=12323
As described both in the BZ and lkml thread @
http://lkml.org/lkml/2008/1/8/444 calling recv() with MSG_PEEK on an
AF_UNIX socket only reads a single skb, where the desired effect is
to return as much skb data has been queued, until hitting the recv
buffer size (whichever comes first).
The modified MSG_PEEK path will now move to the next skb in the tree
and jump to the again: label, rather than following the natural loop
structure. This requires duplicating some of the loop head actions.
This was tested using the python socketpair python code attached to
the bugzilla issue.
Signed-off-by: Aaron Conole <aconole@bytheb.org>
SCM_SECURITY was originally only implemented for datagram sockets,
not for stream sockets. However, SCM_CREDENTIALS is supported on
Unix stream sockets. For consistency, implement Unix stream support
for SCM_SECURITY as well. Also clean up the existing code and get
rid of the superfluous UNIXSID macro.
Motivated by https://bugzilla.redhat.com/show_bug.cgi?id=1224211,
where systemd was using SCM_CREDENTIALS and assumed wrongly that
SCM_SECURITY was also supported on Unix stream sockets.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Paul Moore <paul@paul-moore.com>
drivers/net/phy/amd-xgbe-phy.c
drivers/net/wireless/iwlwifi/Kconfig
include/net/mac80211.h
iwlwifi/Kconfig and mac80211.h were both trivial overlapping
changes.
The drivers/net/phy/amd-xgbe-phy.c file got removed in 'net-next' and
the bug fix that happened on the 'net' side is already integrated
into the rest of the amd-xgbe driver.
got a rare NULL pointer dereference in clear_bit
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
v2: switch to sock_flag(sk, SOCK_DEAD) and added net/caif/caif_socket.c
v3: return -ECONNRESET in upstream caller of wait function for SOCK_DEAD
unix_stream_recvmsg is refactored to unix_stream_read_generic in this
patch and enhanced to deal with pipe splicing. The refactoring is
inneglible, we mostly have to deal with a non-existing struct msghdr
argument.
This patch implements sendpage support for AF_UNIX SOCK_STREAM
sockets. This is also required for a complete splice implementation.
The implementation is a bit tricky because we append to already existing
skbs and so have to hold unix_sk->readlock to protect the reading side
from either advancing UNIXCB.consumed or freeing the skb at the socket
receive tail.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
places where we are dealing with S_ISSOCK file creation/lookups.
AF_UNIX sockets should call mknod on the top layer only and should not attempt
to modify the lower layer in a layered filesystem such as overlayfs.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
The sock_iocb structure is allocate on stack for each read/write-like
operation on sockets, and contains various fields of which only the
embedded msghdr and sometimes a pointer to the scm_cookie is ever used.
Get rid of the sock_iocb and put a msghdr directly on the stack and pass
the scm_cookie explicitly to netlink_mmap_sendmsg.
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
... and kill skb_copy_datagram_iovec()
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
Using whole of allocated pages reduces requested skb->data size.
This is just a little more thriftily allocation.
netperf does not show difference with the current performance.
Signed-off-by: Kirill Tkhai <ktkhai@parallels.com>
Mostly scripted conversion of the smp_mb__* barriers.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
Some applications didn't expect recvmsg() on a non blocking socket
could return -EINTR. This possibility was added as a side effect
of commit b3ca9b02b00704 ("net: fix multithreaded signal handling in
unix recv routines").
To hit this bug, you need to be a bit unlucky, as the u->readlock
mutex is usually held for very small periods.
Fixes: b3ca9b02b00704 ("net: fix multithreaded signal handling in unix recv routines")
Cc: Rainer Weikusat <rweikusat@mobileactivedefense.com>
The unix socket code is using the result of csum_partial to
hash into a lookup table:
unix_hash_fold(csum_partial(sunaddr, len, 0));
csum_partial is only guaranteed to produce something that can be
folded into a checksum, as its prototype explains:
* returns a 32-bit number suitable for feeding into itself
* or csum_tcpudp_magic
The 32bit value should not be used directly.
Depending on the alignment, the ppc64 csum_partial will return
different 32bit partial checksums that will fold into the same
16bit checksum.
This difference causes the following testcase (courtesy of
Gustavo) to sometimes fail:
#include <sys/socket.h>
#include <stdio.h>
int main()
int fd = socket(PF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC, 0);
int i = 1;
setsockopt(fd, SOL_SOCKET, SO_REUSEADDR, &i, 4);
struct sockaddr addr;
addr.sa_family = AF_LOCAL;
bind(fd, &addr, 2);
listen(fd, 128);
struct sockaddr_storage ss;
socklen_t sslen = (socklen_t)sizeof(ss);
getsockname(fd, (struct sockaddr*)&ss, &sslen);
if (connect(fd, (struct sockaddr*)&ss, sslen) == -1){
perror(NULL);
return 1;
printf("OK\n");
return 0;
As suggested by davem, fix this by using csum_fold to fold the
partial 32bit checksum into a 16bit checksum before using it.
Cc: stable@vger.kernel.org
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
drivers/net/ethernet/intel/i40e/i40e_main.c
drivers/net/macvtap.c
Both minor merge hassles, simple overlapping changes.
This is similar to the set_peek_off patch where calling bind while the
socket is stuck in unix_dgram_recvmsg() will block and cause a hung task
spew after a while.
This is also the last place that did a straightforward mutex_lock(), so
there shouldn't be any more of these patches.
unix_dgram_recvmsg() will hold the readlock of the socket until recv
is complete.
In the same time, we may try to setsockopt(SO_PEEK_OFF) which will hang until
unix_dgram_recvmsg() will complete (which can take a while) without allowing
us to break out of it, triggering a hung task spew.
Instead, allow set_peek_off to fail, this way userspace will not hang.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
use pr_<level> instead of printk(LEVEL)
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
In the case of credentials passing in unix stream sockets (dgram
sockets seem not affected), we get a rather sparse race after
commit 16e5726 ("af_unix: dont send SCM_CREDENTIALS by default").
We have a stream server on receiver side that requests credential
passing from senders (e.g. nc -U). Since we need to set SO_PASSCRED
on each spawned/accepted socket on server side to 1 first (as it's
not inherited), it can happen that in the time between accept() and
setsockopt() we get interrupted, the sender is being scheduled and
continues with passing data to our receiver. At that time SO_PASSCRED
is neither set on sender nor receiver side, hence in cmsg's
SCM_CREDENTIALS we get eventually pid:0, uid:65534, gid:65534
(== overflow{u,g}id) instead of what we actually would like to see.
On the sender side, here nc -U, the tests in maybe_add_creds()
invoked through unix_stream_sendmsg() would fail, as at that exact
time, as mentioned, the sender has neither SO_PASSCRED on his side
nor sees it on the server side, and we have a valid 'other' socket
in place. Thus, sender believes it would just look like a normal
connection, not needing/requesting SO_PASSCRED at that time.
As reverting 16e5726 would not be an option due to the significant
performance regression reported when having creds always passed,
one way/trade-off to prevent that would be to set SO_PASSCRED on
the listener socket and allow inheriting these flags to the spawned
socket on server side in accept(). It seems also logical to do so
if we'd tell the listener socket to pass those flags onwards, and
would fix the race.
Before, strace:
recvmsg(4, {msg_name(0)=NULL, msg_iov(1)=[{"blub\n", 4096}],
msg_controllen=32, {cmsg_len=28, cmsg_level=SOL_SOCKET,
cmsg_type=SCM_CREDENTIALS{pid=0, uid=65534, gid=65534}},
msg_flags=0}, 0) = 5
After, strace:
cmsg_type=SCM_CREDENTIALS{pid=11580, uid=1000, gid=1000}},
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
commit e370a723632 ("af_unix: improve STREAM behavior with fragmented
memory") added a bug on large send() because the
skb_copy_datagram_from_iovec() call always start from the beginning
of iovec.
We must instead use the @sent variable to properly skip the
already processed part.
Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Adding paged frags skbs to af_unix sockets introduced a performance
regression on large sends because of additional page allocations, even
if each skb could carry at least 100% more payload than before.
We can instruct sock_alloc_send_pskb() to attempt high order
allocations.
Most of the time, it does a single page allocation instead of 8.
I added an additional parameter to sock_alloc_send_pskb() to
let other users to opt-in for this new feature on followup patches.
Tested:
Before patch :
$ netperf -t STREAM_STREAM
STREAM STREAM TEST
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
2304 212992 212992 10.00 46861.15
After patch :
STREAM STREAM TEST
Recv Send Send
2304 212992 212992 10.00 57981.11
unix_stream_sendmsg() currently uses order-2 allocations,
and we had numerous reports this can fail.
The __GFP_REPEAT flag present in sock_alloc_send_pskb() is
not helping.
This patch extends the work done in commit eb6a24816b247c
("af_unix: reduce high order page allocations) for
datagram sockets.
This opens the possibility of zero copy IO (splice() and
friends)
The trick is to not use skb_pull() anymore in recvmsg() path,
and instead add a @consumed field in UNIXCB() to track amount
of already read payload in the skb.
There is a performance regression for large sends
because of extra page allocations that will be addressed
in a follow-up patch, allowing sock_alloc_send_pskb()
to attempt high order page allocations.
Avoid waking up every thread sleeping in read call on an AF_UNIX
socket during suspend and resume by calling a freezable blocking
call. Previous patches modified the freezer to avoid sending
wakeups to threads that are blocked in freezable blocking calls.
This call was selected to be converted to a freezable call because
it doesn't hold any locks or release any resources when interrupted
that might be needed by another freezing task or a kernel driver
during suspend, and is a common site where idle userspace tasks are
blocked.
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Colin Cross <ccross@android.com>
drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
drivers/net/ethernet/emulex/benet/be.h
include/net/tcp.h
net/mac802154/mac802154.h
Most conflicts were minor overlapping stuff.
The be2net driver brought in some fixes that added __vlan_put_tag
calls, which in net-next take an additional argument.
Currently, peeking on a unix stream socket with an offset larger than len of
the data in the sk receive queue returns immediately with bogus data.
This patch fixes this so that the behavior is the same as peeking with no
offset on an empty queue: the caller blocks.
Signed-off-by: Benjamin Poirier <bpoirier@suse.de>
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
Now that uids and gids are completely encapsulated in kuid_t
and kgid_t we no longer need to pass struct cred which allowed
us to test both the uid and the user namespace for equality.
Passing struct cred potentially allows us to pass the entire group
list as BSD does but I don't believe the cost of cache line misses
justifies retaining code for a future potential application.
drivers/nfc/microread/mei.c
net/netfilter/nfnetlink_queue_core.c
Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which
some cleanups are going to go on-top.
It was reported that the following LSB test case failed
https://lsbbugs.linuxfoundation.org/attachment.cgi?id=2144 because we
were not coallescing unix stream messages when the application was
expecting us to.
The problem was that the first send was before the socket was accepted
and thus sock->sk_socket was NULL in maybe_add_creds, and the second
send after the socket was accepted had a non-NULL value for sk->socket
and thus we could tell the credentials were not needed so we did not
bother.
The unnecessary credentials on the first message cause
unix_stream_recvmsg to start verifying that all messages had the same
credentials before coallescing and then the coallescing failed because
the second message had no credentials.
Ignoring credentials when we don't care in unix_stream_recvmsg fixes a
long standing pessimization which would fail to coallesce messages when
reading from a unix stream socket if the senders were different even if
we did not care about their credentials.
I have tested this and verified that the in the LSB test case mentioned
above that the messages do coallesce now, while the were failing to
coallesce without this change.
Reported-by: Karel Srot <ksrot@redhat.com>
Reported-by: Ding Tianhong <dingtianhong@huawei.com>
This reverts commit 14134f6584212d585b310ce95428014b653dfaf6.
The problem that the above patch was meant to address is that af_unix
messages are not being coallesced because we are sending unnecesarry
credentials. Not sending credentials in maybe_add_creds totally
breaks unconnected unix domain sockets that wish to send credentails
to other sockets.
In practice this break some versions of udev because they receive a
message and the sending uid is bogus so they drop the message.
Reported-by: Sven Joachim <svenjoac@gmx.de>
Commit 7d4c04fc170087119727119074e72445f2bb192b ("net: add option to enable
error queue packets waking select") has an issue due to operator precedence
causing the bit-wise OR to bind to the sock_flags call instead of the result of
the terniary conditional. This fixes the *_poll functions to work properly. The
old code results in "mask |= POLLPRI" instead of what was intended, which is to
only include POLLPRI when the socket option is enabled.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Currently, when a socket receives something on the error queue it only wakes up
the socket on select if it is in the "read" list, that is the socket has
something to read. It is useful also to wake the socket if it is in the error
list, which would enable software to wait on error queue packets without waking
up for regular data on the socket. The main use case is for receiving
timestamped transmit packets which return the timestamp to the socket via the
error queue. This enables an application to select on the socket for the error
queue only instead of for the regular traffic.
-v2-
* Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file
* Modified every socket poll function that checks error queue
Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Matthew Vick <matthew.vick@intel.com>
SCM_SCREDENTIALS should apply to write() syscalls only either source or destination
socket asserted SOCK_PASSCRED. The original implememtation in maybe_add_creds is wrong,
and breaks several LSB testcases ( i.e. /tset/LSB.os/netowkr/recvfrom/T.recvfrom).
Origionally-authored-by: Karel Srot <ksrot@redhat.com>
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
As reported by Jan, and others over the past few years, there is a
race condition caused by unix_release setting the sock->sk pointer
to NULL before properly marking the socket as dead/orphaned. This
can cause a problem with the LSM hook security_unix_may_send() if
there is another socket attempting to write to this partially
released socket in between when sock->sk is set to NULL and it is
marked as dead/orphaned. This patch fixes this by only setting
sock->sk to NULL after the socket has been marked as dead; I also
take the opportunity to make unix_release_sock() a void function
as it only ever returned 0/success.
Dave, I think this one should go on the -stable pile.
Special thanks to Jan for coming up with a reproducer for this
problem.
Reported-by: Jan Stancek <jan.stancek@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
