connect handlers
[ Upstream commit defbcf2decc903a28d8398aa477b6881e711e3ea ]
Verify that the caller-provided sockaddr structure is large enough to
contain the sa_family field, before accessing it in bind() and connect()
handlers of the AF_UNIX socket. Since neither syscall enforces a minimum
size of the corresponding memory region, very short sockaddrs (zero or
one byte long) result in operating on uninitialized memory while
referencing .sa_family.
Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com>
[ Upstream commit 0fb44559ffd67de8517098b81f675fa0210f13f0 ]
Dmitry reported a deadlock scenario:
unix_bind() path:
u->bindlock ==> sb_writer
do_splice() path:
sb_writer ==> pipe->mutex ==> u->bindlock
In the unix_bind() code path, unix_mknod() does not have to
be done with u->bindlock held, since it is a pure fs operation,
so we can just move unix_mknod() out.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Rainer Weikusat <rweikusat@mobileactivedefense.com>
Commit 2b15af6f95 ("af_unix: use freezable blocking calls in read")
converts schedule_timeout() to its freezable version, it was probably
correct at that time, but later, commit 2b514574f7e8
("net: af_unix: implement splice for stream af_unix sockets") breaks
the strong requirement for a freezable sleep, according to
commit 0f9548ca1091:
We shouldn't try_to_freeze if locks are held. Holding a lock can cause a
deadlock if the lock is later acquired in the suspend or hibernate path
(e.g. by dpm). Holding a lock can also cause a deadlock in the case of
cgroup_freezer if a lock is held inside a frozen cgroup that is later
acquired by a process outside that group.
The pipe_lock is still held at that point.
So use freezable version only for the recvmsg call path, avoid impact for
Android.
Fixes: 2b514574f7e8 ("net: af_unix: implement splice for stream af_unix sockets")
Cc: Tejun Heo <tj@kernel.org>
Cc: Colin Cross <ccross@android.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Abstract unix domain socket may embed null characters,
these should be translated to '@' when printed out to
proc the same way the null prefix is currently being
translated.
This helps for tools such as netstat, lsof and the proc
based implementation in ss to show all the significant
bytes of the name (instead of getting cut at the first
null occurrence).
Signed-off-by: Isaac Boukris <iboukris@gmail.com>
since pipe_lock is the outermost now, we don't need to drop/regain
socket locks around the call of splice_to_pipe() from skb_splice_bits(),
which kills the need to have a socket-specific callback; we can just
call splice_to_pipe() and be done with that.
Right now we use the 'readlock' both for protecting some of the af_unix
IO path and for making the bind be single-threaded.
The two are independent, but using the same lock makes for a nasty
deadlock due to ordering with regards to filesystem locking. The bind
locking would want to nest outside the VSF pathname locking, but the IO
locking wants to nest inside some of those same locks.
We tried to fix this earlier with commit c845acb324aa ("af_unix: Fix
splice-bind deadlock") which moved the readlock inside the vfs locks,
but that caused problems with overlayfs that will then call back into
filesystem routines that take the lock in the wrong order anyway.
Splitting the locks means that we can go back to having the bind lock be
the outermost lock, and we don't have any deadlocks with lock ordering.
Acked-by: Rainer Weikusat <rweikusat@cyberadapt.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This reverts commit c845acb324aa85a39650a14e7696982ceea75dc1.
It turns out that it just replaces one deadlock with another one: we can
still get the wrong lock ordering with the readlock due to overlayfs
calling back into the filesystem layer and still taking the vfs locks
after the readlock.
The proper solution ends up being to just split the readlock into two
pieces: the bind lock (taken *outside* the vfs locks) and the IO lock
(taken *inside* the filesystem locks). The two locks are independent
anyway.
Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Unix sockets can consume a significant amount of system memory, hence
they should be accounted to kmemcg.
Since unix socket buffers are always allocated from process context, all
we need to do to charge them to kmemcg is set __GFP_ACCOUNT in
sock->sk_allocation mask.
Eric asked:
> 1) What happens when a buffer, allocated from socket <A> lands in a
> different socket <B>, maybe owned by another user/process.
> Who owns it now, in term of kmemcg accounting ?
We never move memcg charges. E.g. if two processes from different
cgroups are sharing a memory region, each page will be charged to the
process which touched it first. Or if two processes are working with
the same directory tree, inodes and dentries will be charged to the
first user. The same is fair for unix socket buffers - they will be
charged to the sender.
> 2) Has performance impact been evaluated ?
I ran netperf STREAM_STREAM with default options in a kmemcg on a 4 core
x2 HT box. The results are below:
# clients bandwidth (10^6bits/sec)
base patched
1 67643 +- 725 64874 +- 353 - 4.0 %
4 193585 +- 2516 186715 +- 1460 - 3.5 %
8 194820 +- 377 187443 +- 1229 - 3.7 %
So the accounting doesn't come for free - it takes ~4% of performance.
I believe we could optimize it by using per cpu batching not only on
charge, but also on uncharge in memcg core, but that's beyond the scope
of this patch set - I'll take a look at this later.
Anyway, if performance impact is found to be unacceptable, it is always
possible to disable kmem accounting at boot time (cgroup.memory=nokmem)
or not use memory cgroups at runtime at all (thanks to jump labels
there'll be no overhead even if they are compiled in).
Link: http://lkml.kernel.org/r/fcfe6cae27a59fbc5e40145664b3cf085a560c68.1464079538.git.vdavydov@virtuozzo.com
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
Overlayfs uses separate inodes even in the case of hard links on the
underlying filesystems. This is a problem for AF_UNIX socket
implementation which indexes sockets based on the inode. This resulted in
hard linked sockets not working.
The fix is to use the real, underlying inode.
Test case follows:
-- ovl-sock-test.c --
#include <unistd.h>
#include <err.h>
#include <sys/socket.h>
#include <sys/un.h>
#define SOCK "test-sock"
#define SOCK2 "test-sock2"
int main(void)
int fd, fd2;
struct sockaddr_un addr = {
.sun_family = AF_UNIX,
.sun_path = SOCK,
struct sockaddr_un addr2 = {
.sun_path = SOCK2,
unlink(SOCK);
unlink(SOCK2);
if ((fd = socket(AF_UNIX, SOCK_STREAM, 0)) == -1)
err(1, "socket");
if (bind(fd, (struct sockaddr *) &addr, sizeof(addr)) == -1)
err(1, "bind");
if (listen(fd, 0) == -1)
err(1, "listen");
if (link(SOCK, SOCK2) == -1)
err(1, "link");
if ((fd2 = socket(AF_UNIX, SOCK_STREAM, 0)) == -1)
err(1, "socket");
if (connect(fd2, (struct sockaddr *) &addr2, sizeof(addr2)) == -1)
err (1, "connect");
return 0;
Reported-by: Alexander Morozov <alexandr.morozov@docker.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Cc: <stable@vger.kernel.org>
... as well as unix_mknod() and may_o_create()
drivers/net/phy/bcm7xxx.c
drivers/net/phy/marvell.c
drivers/net/vxlan.c
All three conflicts were cases of simple overlapping changes.
The unix_stream_read_generic function tries to use a continue statement
to restart the receive loop after waiting for a message. This may not
work as intended as the caller might use a recvmsg call to peek at
control messages without specifying a message buffer. If this was the
case, the continue will cause the function to return without an error
and without the credential information if the function had to wait for a
message while it had returned with the credentials otherwise. Change to
using goto to restart the loop without checking the condition first in
this case so that credentials are returned either way.
Signed-off-by: Rainer Weikusat <rweikusat@mobileactivedefense.com>
The unix_dgram_sendmsg routine use the following test
if (unlikely(unix_peer(other) != sk && unix_recvq_full(other))) {
to determine if sk and other are in an n:1 association (either
established via connect or by using sendto to send messages to an
unrelated socket identified by address). This isn't correct as the
specified address could have been bound to the sending socket itself or
because this socket could have been connected to itself by the time of
the unix_peer_get but disconnected before the unix_state_lock(other). In
both cases, the if-block would be entered despite other == sk which
might either block the sender unintentionally or lead to trying to unlock
the same spin lock twice for a non-blocking send. Add a other != sk
check to guard against this.
Fixes: 7d267278a9ec ("unix: avoid use-after-free in ep_remove_wait_queue")
Reported-By: Philipp Hahn <pmhahn@pmhahn.de>
Tested-by: Philipp Hahn <pmhahn@pmhahn.de>
The present unix_stream_read_generic contains various code sequences of
the form
err = -EDISASTER;
if (<test>)
goto out;
This has the unfortunate side effect of possibly causing the error code
to bleed through to the final
out:
return copied ? : err;
and then to be wrongly returned if no data was copied because the caller
didn't supply a data buffer, as demonstrated by the program available at
http://pad.lv/1540731
Change it such that err is only set if an error condition was detected.
Fixes: 3822b5c2fc62 ("af_unix: Revert 'lock_interruptible' in stream receive code")
Reported-by: Joseph Salisbury <joseph.salisbury@canonical.com>
The commit referenced in the Fixes tag incorrectly accounted the number
of in-flight fds over a unix domain socket to the original opener
of the file-descriptor. This allows another process to arbitrary
deplete the original file-openers resource limit for the maximum of
open files. Instead the sending processes and its struct cred should
be credited.
To do so, we add a reference counted struct user_struct pointer to the
scm_fp_list and use it to account for the number of inflight unix fds.
Fixes: 712f4aad406bb1 ("unix: properly account for FDs passed over unix sockets")
Reported-by: David Herrmann <dh.herrmann@gmail.com>
Cc: David Herrmann <dh.herrmann@gmail.com>
Cc: Willy Tarreau <w@1wt.eu>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Remove a write-only stack variable from unix_attach_fds(). This is a
left-over from the security fix in:
commit 712f4aad406bb1ed67f3f98d04c044191f0ff593
Author: willy tarreau <w@1wt.eu>
Date: Sun Jan 10 07:54:56 2016 +0100
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Dmitry reported a struct pid leak detected by a syzkaller program.
Bug happens in unix_stream_recvmsg() when we break the loop when a
signal is pending, without properly releasing scm.
Fixes: b3ca9b02b007 ("net: fix multithreaded signal handling in unix recv routines")
drivers/net/bonding/bond_main.c
drivers/net/ethernet/mellanox/mlxsw/spectrum.h
drivers/net/ethernet/mellanox/mlxsw/spectrum_switchdev.c
The bond_main.c and mellanox switch conflicts were cases of
It is possible for a process to allocate and accumulate far more FDs than
the process' limit by sending them over a unix socket then closing them
to keep the process' fd count low.
This change addresses this problem by keeping track of the number of FDs
in flight per user and preventing non-privileged processes from having
more FDs in flight than their configured FD limit.
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Signed-off-by: Willy Tarreau <w@1wt.eu>
On 2015/11/06, Dmitry Vyukov reported a deadlock involving the splice
system call and AF_UNIX sockets,
http://lists.openwall.net/netdev/2015/11/06/24
The situation was analyzed as
(a while ago) A: socketpair()
B: splice() from a pipe to /mnt/regular_file
does sb_start_write() on /mnt
C: try to freeze /mnt
wait for B to finish with /mnt
A: bind() try to bind our socket to /mnt/new_socket_name
lock our socket, see it not bound yet
decide that it needs to create something in /mnt
try to do sb_start_write() on /mnt, block (it's
waiting for C).
D: splice() from the same pipe to our socket
lock the pipe, see that socket is connected
try to lock the socket, block waiting for A
B: get around to actually feeding a chunk from
pipe to file, try to lock the pipe. Deadlock.
on 2015/11/10 by Al Viro,
http://lists.openwall.net/netdev/2015/11/10/4
The patch fixes this by removing the kern_path_create related code from
unix_mknod and executing it as part of unix_bind prior acquiring the
readlock of the socket in question. This means that A (as used above)
will sb_start_write on /mnt before it acquires the readlock, hence, it
won't indirectly block B which first did a sb_start_write and then
waited for a thread trying to acquire the readlock. Consequently, A
being blocked by C waiting for B won't cause a deadlock anymore
(effectively, both A and B acquire two locks in opposite order in the
situation described above).
Dmitry Vyukov(<dvyukov@google.com>) tested the original patch.
drivers/net/geneve.c
Here we had an overlapping change, where in 'net' the extraneous stats
bump was being removed whilst in 'net-next' the final argument to
udp_tunnel6_xmit_skb() was being changed.
With b3ca9b02b00704053a38bfe4c31dbbb9c13595d0, the AF_UNIX SOCK_STREAM
receive code was changed from using mutex_lock(&u->readlock) to
mutex_lock_interruptible(&u->readlock) to prevent signals from being
delayed for an indefinite time if a thread sleeping on the mutex
happened to be selected for handling the signal. But this was never a
problem with the stream receive code (as opposed to its datagram
counterpart) as that never went to sleep waiting for new messages with the
mutex held and thus, wouldn't cause secondary readers to block on the
mutex waiting for the sleeping primary reader. As the interruptible
locking makes the code more complicated in exchange for no benefit,
change it back to using mutex_lock.
The current unix_dgram_recvsmg code acquires the u->readlock mutex in
order to protect access to the peek offset prior to calling
__skb_recv_datagram for actually receiving data. This implies that a
blocking reader will go to sleep with this mutex held if there's
presently no data to return to userspace. Two non-desirable side effects
of this are that a later non-blocking read call on the same socket will
block on the ->readlock mutex until the earlier blocking call releases it
(or the readers is interrupted) and that later blocking read calls
will wait longer than the effective socket read timeout says they
should: The timeout will only start 'ticking' once such a reader hits
the schedule_timeout in wait_for_more_packets (core.c) while the time it
already had to wait until it could acquire the mutex is unaccounted for.
The patch avoids both by using the __skb_try_recv_datagram and
__skb_wait_for_more packets functions created by the first patch to
implement a unix_dgram_recvmsg read loop which releases the readlock
mutex prior to going to sleep and reacquires it as needed
afterwards. Non-blocking readers will thus immediately return with
-EAGAIN if there's no data available regardless of any concurrent
blocking readers and all blocking readers will end up sleeping via
schedule_timeout, thus honouring the configured socket receive timeout.
drivers/net/ethernet/renesas/ravb_main.c
kernel/bpf/syscall.c
net/ipv4/ipmr.c
All three conflicts were cases of overlapping changes.
This patch is a cleanup to make following patch easier to
review.
Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA
from (struct socket)->flags to a (struct socket_wq)->flags
to benefit from RCU protection in sock_wake_async()
To ease backports, we rename both constants.
Two new helpers, sk_set_bit(int nr, struct sock *sk)
and sk_clear_bit(int net, struct sock *sk) are added so that
following patch can change their implementation.
The current unix_dgram_recvmsg does a wake up for every received
datagram. This seems wasteful as only SOCK_DGRAM client sockets in an
n:1 association with a server socket will ever wait because of the
associated condition. The patch below changes the function such that the
wake up only happens if wq_has_sleeper indicates that someone actually
wants to be notified. Testing with SOCK_SEQPACKET and SOCK_DGRAM socket
seems to confirm that this is an improvment.
Signed-Off-By: Rainer Weikusat <rweikusat@mobileactivedefense.com>
sendpage did not care about credentials at all. This could lead to
situations in which because of fd passing between processes we could
append data to skbs with different scm data. It is illegal to splice those
skbs together. Instead we have to allocate a new skb and if requested
fill out the scm details.
Fixes: 869e7c62486ec ("net: af_unix: implement stream sendpage support")
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Eric Dumazet <edumazet@google.com>
The memory barrier in the helper wq_has_sleeper is needed by just
about every user of waitqueue_active. This patch generalises it
by making it take a wait_queue_head_t directly. The existing
helper is renamed to skwq_has_sleeper.
Rainer Weikusat <rweikusat@mobileactivedefense.com> writes:
An AF_UNIX datagram socket being the client in an n:1 association with
some server socket is only allowed to send messages to the server if the
receive queue of this socket contains at most sk_max_ack_backlog
datagrams. This implies that prospective writers might be forced to go
to sleep despite none of the message presently enqueued on the server
receive queue were sent by them. In order to ensure that these will be
woken up once space becomes again available, the present unix_dgram_poll
routine does a second sock_poll_wait call with the peer_wait wait queue
of the server socket as queue argument (unix_dgram_recvmsg does a wake
up on this queue after a datagram was received). This is inherently
problematic because the server socket is only guaranteed to remain alive
for as long as the client still holds a reference to it. In case the
connection is dissolved via connect or by the dead peer detection logic
in unix_dgram_sendmsg, the server socket may be freed despite "the
polling mechanism" (in particular, epoll) still has a pointer to the
corresponding peer_wait queue. There's no way to forcibly deregister a
wait queue with epoll.
Based on an idea by Jason Baron, the patch below changes the code such
that a wait_queue_t belonging to the client socket is enqueued on the
peer_wait queue of the server whenever the peer receive queue full
condition is detected by either a sendmsg or a poll. A wake up on the
peer queue is then relayed to the ordinary wait queue of the client
socket via wake function. The connection to the peer wait queue is again
dissolved if either a wake up is about to be relayed or the client
socket reconnects or a dead peer is detected or the client socket is
itself closed. This enables removing the second sock_poll_wait from
unix_dgram_poll, thus avoiding the use-after-free, while still ensuring
that no blocked writer sleeps forever.
Fixes: ec0d215f9420 ("af_unix: fix 'poll for write'/connected DGRAM sockets")
Reviewed-by: Jason Baron <jbaron@akamai.com>
While possibly in future we don't necessarily need to use
sk_buff_head.lock this is a rather larger change, as it affects the
af_unix fd garbage collector, diag and socket cleanups. This is too much
for a stable patch.
For the time being grab sk_buff_head.lock without disabling bh and irqs,
so don't use locked skb_queue_tail.
Fixes: 869e7c62486e ("net: af_unix: implement stream sendpage support")
Reported-by: Eric Dumazet <edumazet@google.com>
In case multiple writes to a unix stream socket race we could end up in a
situation where we pre-allocate a new skb for use in unix_stream_sendpage
but have to free it again in the locked section because another skb
has been appended meanwhile, which we must use. Accidentally we didn't
clear the pointer after consuming it and so we touched freed memory
while appending it to the sk_receive_queue. So, clear the pointer after
consuming the skb.
This bug has been found with syzkaller
(http://github.com/google/syzkaller) by Dmitry Vyukov.
Cc: Dmitry Vyukov <dvyukov@google.com>
During splicing an af-unix socket to a pipe we have to drop all
af-unix socket locks. While doing so we allow another reader to enter
unix_stream_read_generic which can read, copy and finally free another
skb. If exactly this skb is just in process of being spliced we get a
use-after-free report by kasan.
First, we must make sure to not have a free while the skb is used during
the splice operation. We simply increment its use counter before unlocking
the reader lock.
Stream sockets have the nice characteristic that we don't care about
zero length writes and they never reach the peer socket's queue. That
said, we can take the UNIXCB.consumed field as the indicator if the
skb was already freed from the socket's receive queue. If the skb was
fully consumed after we locked the reader side again we know it has been
dropped by a second reader. We indicate a short read to user space and
abort the current splice operation.
poll(POLLOUT) on a listener should not report fd is ready for
a write().
This would break some applications using poll() and pfd.events = -1,
as they would not block in poll()
Reported-by: Alan Burlison <Alan.Burlison@oracle.com>
Tested-by: Eric Dumazet <edumazet@google.com>
Now send with MSG_PEEK can return data from multiple SKBs.
Unfortunately we take into account the peek offset for each skb,
that is wrong. We need to apply the peek offset only once.
In addition, the peek offset should be used only if MSG_PEEK is set.
Cc: "David S. Miller" <davem@davemloft.net> (maintainer:NETWORKING
Cc: Eric Dumazet <edumazet@google.com> (commit_signer:1/14=7%)
Cc: Aaron Conole <aconole@bytheb.org>
Fixes: 9f389e35674f ("af_unix: return data from multiple SKBs on recv() with MSG_PEEK flag")
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Tested-by: Aaron Conole <aconole@bytheb.org>
AF_UNIX sockets now return multiple skbs from recv() when MSG_PEEK flag
is set.
This is referenced in kernel bugzilla #12323 @
https://bugzilla.kernel.org/show_bug.cgi?id=12323
As described both in the BZ and lkml thread @
http://lkml.org/lkml/2008/1/8/444 calling recv() with MSG_PEEK on an
AF_UNIX socket only reads a single skb, where the desired effect is
to return as much skb data has been queued, until hitting the recv
buffer size (whichever comes first).
The modified MSG_PEEK path will now move to the next skb in the tree
and jump to the again: label, rather than following the natural loop
structure. This requires duplicating some of the loop head actions.
This was tested using the python socketpair python code attached to
the bugzilla issue.
Signed-off-by: Aaron Conole <aconole@bytheb.org>
SCM_SECURITY was originally only implemented for datagram sockets,
not for stream sockets. However, SCM_CREDENTIALS is supported on
Unix stream sockets. For consistency, implement Unix stream support
for SCM_SECURITY as well. Also clean up the existing code and get
rid of the superfluous UNIXSID macro.
Motivated by https://bugzilla.redhat.com/show_bug.cgi?id=1224211,
where systemd was using SCM_CREDENTIALS and assumed wrongly that
SCM_SECURITY was also supported on Unix stream sockets.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Paul Moore <paul@paul-moore.com>
drivers/net/phy/amd-xgbe-phy.c
drivers/net/wireless/iwlwifi/Kconfig
include/net/mac80211.h
iwlwifi/Kconfig and mac80211.h were both trivial overlapping
changes.
The drivers/net/phy/amd-xgbe-phy.c file got removed in 'net-next' and
the bug fix that happened on the 'net' side is already integrated
into the rest of the amd-xgbe driver.
got a rare NULL pointer dereference in clear_bit
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
v2: switch to sock_flag(sk, SOCK_DEAD) and added net/caif/caif_socket.c
v3: return -ECONNRESET in upstream caller of wait function for SOCK_DEAD
unix_stream_recvmsg is refactored to unix_stream_read_generic in this
patch and enhanced to deal with pipe splicing. The refactoring is
inneglible, we mostly have to deal with a non-existing struct msghdr
argument.
This patch implements sendpage support for AF_UNIX SOCK_STREAM
sockets. This is also required for a complete splice implementation.
The implementation is a bit tricky because we append to already existing
skbs and so have to hold unix_sk->readlock to protect the reading side
from either advancing UNIXCB.consumed or freeing the skb at the socket
receive tail.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
places where we are dealing with S_ISSOCK file creation/lookups.
AF_UNIX sockets should call mknod on the top layer only and should not attempt
to modify the lower layer in a layered filesystem such as overlayfs.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
The sock_iocb structure is allocate on stack for each read/write-like
operation on sockets, and contains various fields of which only the
embedded msghdr and sometimes a pointer to the scm_cookie is ever used.
Get rid of the sock_iocb and put a msghdr directly on the stack and pass
the scm_cookie explicitly to netlink_mmap_sendmsg.
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
... and kill skb_copy_datagram_iovec()
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
