connect handlers
[ Upstream commit defbcf2decc903a28d8398aa477b6881e711e3ea ]
Verify that the caller-provided sockaddr structure is large enough to
contain the sa_family field, before accessing it in bind() and connect()
handlers of the AF_UNIX socket. Since neither syscall enforces a minimum
size of the corresponding memory region, very short sockaddrs (zero or
one byte long) result in operating on uninitialized memory while
referencing .sa_family.
Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com>
[ Upstream commit 7df9c24625b9981779afb8fcdbe2bb4765e61147 ]
Dmitry has reported that a BUG_ON() condition in unix_notinflight()
may be triggered by a simple code that forwards unix socket in an
SCM_RIGHTS message.
That is caused by incorrect unix socket GC implementation in unix_gc().
The GC first collects list of candidates, then (a) decrements their
"children's" inflight counter, (b) checks which inflight counters are
now 0, and then (c) increments all inflight counters back.
(a) and (c) are done by calling scan_children() with inc_inflight or
dec_inflight as the second argument.
Commit 6209344f5a37 ("net: unix: fix inflight counting bug in garbage
collector") changed scan_children() such that it no longer considers
sockets that do not have UNIX_GC_CANDIDATE flag. It also added a block
of code that that unsets this flag _before_ invoking
scan_children(, dec_iflight, ). This may lead to incorrect inflight
counters for some sockets.
This change fixes this bug by changing order of operations:
UNIX_GC_CANDIDATE is now unset only after all inflight counters are
restored to the original state.
kernel BUG at net/unix/garbage.c:149!
RIP: 0010:[<ffffffff8717ebf4>] [<ffffffff8717ebf4>]
unix_notinflight+0x3b4/0x490 net/unix/garbage.c:149
Call Trace:
[<ffffffff8716cfbf>] unix_detach_fds.isra.19+0xff/0x170 net/unix/af_unix.c:1487
[<ffffffff8716f6a9>] unix_destruct_scm+0xf9/0x210 net/unix/af_unix.c:1496
[<ffffffff86a90a01>] skb_release_head_state+0x101/0x200 net/core/skbuff.c:655
[<ffffffff86a9808a>] skb_release_all+0x1a/0x60 net/core/skbuff.c:668
[<ffffffff86a980ea>] __kfree_skb+0x1a/0x30 net/core/skbuff.c:684
[<ffffffff86a98284>] kfree_skb+0x184/0x570 net/core/skbuff.c:705
[<ffffffff871789d5>] unix_release_sock+0x5b5/0xbd0 net/unix/af_unix.c:559
[<ffffffff87179039>] unix_release+0x49/0x90 net/unix/af_unix.c:836
[<ffffffff86a694b2>] sock_release+0x92/0x1f0 net/socket.c:570
[<ffffffff86a6962b>] sock_close+0x1b/0x20 net/socket.c:1017
[<ffffffff81a76b8e>] __fput+0x34e/0x910 fs/file_table.c:208
[<ffffffff81a771da>] ____fput+0x1a/0x20 fs/file_table.c:244
[<ffffffff81483ab0>] task_work_run+0x1a0/0x280 kernel/task_work.c:116
[< inline >] exit_task_work include/linux/task_work.h:21
[<ffffffff8141287a>] do_exit+0x183a/0x2640 kernel/exit.c:828
[<ffffffff8141383e>] do_group_exit+0x14e/0x420 kernel/exit.c:931
[<ffffffff814429d3>] get_signal+0x663/0x1880 kernel/signal.c:2307
[<ffffffff81239b45>] do_signal+0xc5/0x2190 arch/x86/kernel/signal.c:807
[<ffffffff8100666a>] exit_to_usermode_loop+0x1ea/0x2d0
arch/x86/entry/common.c:156
[< inline >] prepare_exit_to_usermode arch/x86/entry/common.c:190
[<ffffffff81009693>] syscall_return_slowpath+0x4d3/0x570
arch/x86/entry/common.c:259
[<ffffffff881478e6>] entry_SYSCALL_64_fastpath+0xc4/0xc6
Link: https://lkml.org/lkml/2017/3/6/252
Signed-off-by: Andrey Ulanov <andreyu@google.com>
Fixes: 6209344 ("net: unix: fix inflight counting bug in garbage collector")
[ Upstream commit 0fb44559ffd67de8517098b81f675fa0210f13f0 ]
Dmitry reported a deadlock scenario:
unix_bind() path:
u->bindlock ==> sb_writer
do_splice() path:
sb_writer ==> pipe->mutex ==> u->bindlock
In the unix_bind() code path, unix_mknod() does not have to
be done with u->bindlock held, since it is a pure fs operation,
so we can just move unix_mknod() out.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Rainer Weikusat <rweikusat@mobileactivedefense.com>
[ Upstream commit 06a77b07e3b44aea2b3c0e64de420ea2cfdcbaa9 ]
Commit 2b15af6f95 ("af_unix: use freezable blocking calls in read")
converts schedule_timeout() to its freezable version, it was probably
correct at that time, but later, commit 2b514574f7e8
("net: af_unix: implement splice for stream af_unix sockets") breaks
the strong requirement for a freezable sleep, according to
commit 0f9548ca1091:
We shouldn't try_to_freeze if locks are held. Holding a lock can cause a
deadlock if the lock is later acquired in the suspend or hibernate path
(e.g. by dpm). Holding a lock can also cause a deadlock in the case of
cgroup_freezer if a lock is held inside a frozen cgroup that is later
acquired by a process outside that group.
The pipe_lock is still held at that point.
So use freezable version only for the recvmsg call path, avoid impact for
Android.
Fixes: 2b514574f7e8 ("net: af_unix: implement splice for stream af_unix sockets")
Cc: Tejun Heo <tj@kernel.org>
Cc: Colin Cross <ccross@android.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
commit 6e1ce3c3451291142a57c4f3f6f999a29fb5b3bc upstream.
Right now we use the 'readlock' both for protecting some of the af_unix
IO path and for making the bind be single-threaded.
The two are independent, but using the same lock makes for a nasty
deadlock due to ordering with regards to filesystem locking. The bind
locking would want to nest outside the VSF pathname locking, but the IO
locking wants to nest inside some of those same locks.
We tried to fix this earlier with commit c845acb324aa ("af_unix: Fix
splice-bind deadlock") which moved the readlock inside the vfs locks,
but that caused problems with overlayfs that will then call back into
filesystem routines that take the lock in the wrong order anyway.
Splitting the locks means that we can go back to having the bind lock be
the outermost lock, and we don't have any deadlocks with lock ordering.
Acked-by: Rainer Weikusat <rweikusat@cyberadapt.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
commit 38f7bd94a97b542de86a2be9229289717e33a7a4 upstream.
This reverts commit c845acb324aa85a39650a14e7696982ceea75dc1.
It turns out that it just replaces one deadlock with another one: we can
still get the wrong lock ordering with the readlock due to overlayfs
calling back into the filesystem layer and still taking the vfs locks
after the readlock.
The proper solution ends up being to just split the readlock into two
pieces: the bind lock (taken *outside* the vfs locks) and the IO lock
(taken *inside* the filesystem locks). The two locks are independent
anyway.
Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
commit eb0a4a47ae89aaa0674ab3180de6a162f3be2ddf upstream.
Overlayfs uses separate inodes even in the case of hard links on the
underlying filesystems. This is a problem for AF_UNIX socket
implementation which indexes sockets based on the inode. This resulted in
hard linked sockets not working.
The fix is to use the real, underlying inode.
Test case follows:
-- ovl-sock-test.c --
#include <unistd.h>
#include <err.h>
#include <sys/socket.h>
#include <sys/un.h>
#define SOCK "test-sock"
#define SOCK2 "test-sock2"
int main(void)
int fd, fd2;
struct sockaddr_un addr = {
.sun_family = AF_UNIX,
.sun_path = SOCK,
struct sockaddr_un addr2 = {
.sun_path = SOCK2,
unlink(SOCK);
unlink(SOCK2);
if ((fd = socket(AF_UNIX, SOCK_STREAM, 0)) == -1)
err(1, "socket");
if (bind(fd, (struct sockaddr *) &addr, sizeof(addr)) == -1)
err(1, "bind");
if (listen(fd, 0) == -1)
err(1, "listen");
if (link(SOCK, SOCK2) == -1)
err(1, "link");
if ((fd2 = socket(AF_UNIX, SOCK_STREAM, 0)) == -1)
err(1, "socket");
if (connect(fd2, (struct sockaddr *) &addr2, sizeof(addr2)) == -1)
err (1, "connect");
return 0;
Reported-by: Alexander Morozov <alexandr.morozov@docker.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
[ Upstream commit b5f0549231ffb025337be5a625b0ff9f52b016f0 ]
The value passed by unix_diag_get_exact to unix_lookup_by_ino has type
__u32, but unix_lookup_by_ino's argument ino has type int, which is not
a problem yet.
However, when ino is compared with sock_i_ino return value of type
unsigned long, ino is sign extended to signed long, and this results
to incorrect comparison on 64-bit architectures for inode numbers
greater than INT_MAX.
This bug was found by strace test suite.
Fixes: 5d3cae8bc39d ("unix_diag: Dumping exact socket core")
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit a5527dda344fff0514b7989ef7a755729769daa1 ]
The unix_dgram_sendmsg routine use the following test
if (unlikely(unix_peer(other) != sk && unix_recvq_full(other))) {
to determine if sk and other are in an n:1 association (either
established via connect or by using sendto to send messages to an
unrelated socket identified by address). This isn't correct as the
specified address could have been bound to the sending socket itself or
because this socket could have been connected to itself by the time of
the unix_peer_get but disconnected before the unix_state_lock(other). In
both cases, the if-block would be entered despite other == sk which
might either block the sender unintentionally or lead to trying to unlock
the same spin lock twice for a non-blocking send. Add a other != sk
check to guard against this.
Fixes: 7d267278a9ec ("unix: avoid use-after-free in ep_remove_wait_queue")
Reported-By: Philipp Hahn <pmhahn@pmhahn.de>
Signed-off-by: Rainer Weikusat <rweikusat@mobileactivedefense.com>
Tested-by: Philipp Hahn <pmhahn@pmhahn.de>
[ Upstream commit 1b92ee3d03af6643df395300ba7748f19ecdb0c5 ]
The present unix_stream_read_generic contains various code sequences of
the form
err = -EDISASTER;
if (<test>)
goto out;
This has the unfortunate side effect of possibly causing the error code
to bleed through to the final
out:
return copied ? : err;
and then to be wrongly returned if no data was copied because the caller
didn't supply a data buffer, as demonstrated by the program available at
http://pad.lv/1540731
Change it such that err is only set if an error condition was detected.
Fixes: 3822b5c2fc62 ("af_unix: Revert 'lock_interruptible' in stream receive code")
Reported-by: Joseph Salisbury <joseph.salisbury@canonical.com>
[ Upstream commit 415e3d3e90ce9e18727e8843ae343eda5a58fad6 ]
The commit referenced in the Fixes tag incorrectly accounted the number
of in-flight fds over a unix domain socket to the original opener
of the file-descriptor. This allows another process to arbitrary
deplete the original file-openers resource limit for the maximum of
open files. Instead the sending processes and its struct cred should
be credited.
To do so, we add a reference counted struct user_struct pointer to the
scm_fp_list and use it to account for the number of inflight unix fds.
Fixes: 712f4aad406bb1 ("unix: properly account for FDs passed over unix sockets")
Reported-by: David Herrmann <dh.herrmann@gmail.com>
Cc: David Herrmann <dh.herrmann@gmail.com>
Cc: Willy Tarreau <w@1wt.eu>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
[ Upstream commit fa0dc04df259ba2df3ce1920e9690c7842f8fa4b ]
Dmitry reported a struct pid leak detected by a syzkaller program.
Bug happens in unix_stream_recvmsg() when we break the loop when a
signal is pending, without properly releasing scm.
Fixes: b3ca9b02b007 ("net: fix multithreaded signal handling in unix recv routines")
[ Upstream commit 712f4aad406bb1ed67f3f98d04c044191f0ff593 ]
It is possible for a process to allocate and accumulate far more FDs than
the process' limit by sending them over a unix socket then closing them
to keep the process' fd count low.
This change addresses this problem by keeping track of the number of FDs
in flight per user and preventing non-privileged processes from having
more FDs in flight than their configured FD limit.
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Signed-off-by: Willy Tarreau <w@1wt.eu>
On 2015/11/06, Dmitry Vyukov reported a deadlock involving the splice
system call and AF_UNIX sockets,
http://lists.openwall.net/netdev/2015/11/06/24
The situation was analyzed as
(a while ago) A: socketpair()
B: splice() from a pipe to /mnt/regular_file
does sb_start_write() on /mnt
C: try to freeze /mnt
wait for B to finish with /mnt
A: bind() try to bind our socket to /mnt/new_socket_name
lock our socket, see it not bound yet
decide that it needs to create something in /mnt
try to do sb_start_write() on /mnt, block (it's
waiting for C).
D: splice() from the same pipe to our socket
lock the pipe, see that socket is connected
try to lock the socket, block waiting for A
B: get around to actually feeding a chunk from
pipe to file, try to lock the pipe. Deadlock.
on 2015/11/10 by Al Viro,
http://lists.openwall.net/netdev/2015/11/10/4
The patch fixes this by removing the kern_path_create related code from
unix_mknod and executing it as part of unix_bind prior acquiring the
readlock of the socket in question. This means that A (as used above)
will sb_start_write on /mnt before it acquires the readlock, hence, it
won't indirectly block B which first did a sb_start_write and then
waited for a thread trying to acquire the readlock. Consequently, A
being blocked by C waiting for B won't cause a deadlock anymore
(effectively, both A and B acquire two locks in opposite order in the
situation described above).
Dmitry Vyukov(<dvyukov@google.com>) tested the original patch.
With b3ca9b02b00704053a38bfe4c31dbbb9c13595d0, the AF_UNIX SOCK_STREAM
receive code was changed from using mutex_lock(&u->readlock) to
mutex_lock_interruptible(&u->readlock) to prevent signals from being
delayed for an indefinite time if a thread sleeping on the mutex
happened to be selected for handling the signal. But this was never a
problem with the stream receive code (as opposed to its datagram
counterpart) as that never went to sleep waiting for new messages with the
mutex held and thus, wouldn't cause secondary readers to block on the
mutex waiting for the sleeping primary reader. As the interruptible
locking makes the code more complicated in exchange for no benefit,
change it back to using mutex_lock.
This patch is a cleanup to make following patch easier to
review.
Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA
from (struct socket)->flags to a (struct socket_wq)->flags
to benefit from RCU protection in sock_wake_async()
To ease backports, we rename both constants.
Two new helpers, sk_set_bit(int nr, struct sock *sk)
and sk_clear_bit(int net, struct sock *sk) are added so that
following patch can change their implementation.
sendpage did not care about credentials at all. This could lead to
situations in which because of fd passing between processes we could
append data to skbs with different scm data. It is illegal to splice those
skbs together. Instead we have to allocate a new skb and if requested
fill out the scm details.
Fixes: 869e7c62486ec ("net: af_unix: implement stream sendpage support")
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Eric Dumazet <edumazet@google.com>
Rainer Weikusat <rweikusat@mobileactivedefense.com> writes:
An AF_UNIX datagram socket being the client in an n:1 association with
some server socket is only allowed to send messages to the server if the
receive queue of this socket contains at most sk_max_ack_backlog
datagrams. This implies that prospective writers might be forced to go
to sleep despite none of the message presently enqueued on the server
receive queue were sent by them. In order to ensure that these will be
woken up once space becomes again available, the present unix_dgram_poll
routine does a second sock_poll_wait call with the peer_wait wait queue
of the server socket as queue argument (unix_dgram_recvmsg does a wake
up on this queue after a datagram was received). This is inherently
problematic because the server socket is only guaranteed to remain alive
for as long as the client still holds a reference to it. In case the
connection is dissolved via connect or by the dead peer detection logic
in unix_dgram_sendmsg, the server socket may be freed despite "the
polling mechanism" (in particular, epoll) still has a pointer to the
corresponding peer_wait queue. There's no way to forcibly deregister a
wait queue with epoll.
Based on an idea by Jason Baron, the patch below changes the code such
that a wait_queue_t belonging to the client socket is enqueued on the
peer_wait queue of the server whenever the peer receive queue full
condition is detected by either a sendmsg or a poll. A wake up on the
peer queue is then relayed to the ordinary wait queue of the client
socket via wake function. The connection to the peer wait queue is again
dissolved if either a wake up is about to be relayed or the client
socket reconnects or a dead peer is detected or the client socket is
itself closed. This enables removing the second sock_poll_wait from
unix_dgram_poll, thus avoiding the use-after-free, while still ensuring
that no blocked writer sleeps forever.
Fixes: ec0d215f9420 ("af_unix: fix 'poll for write'/connected DGRAM sockets")
Reviewed-by: Jason Baron <jbaron@akamai.com>
While possibly in future we don't necessarily need to use
sk_buff_head.lock this is a rather larger change, as it affects the
af_unix fd garbage collector, diag and socket cleanups. This is too much
for a stable patch.
For the time being grab sk_buff_head.lock without disabling bh and irqs,
so don't use locked skb_queue_tail.
Fixes: 869e7c62486e ("net: af_unix: implement stream sendpage support")
Reported-by: Eric Dumazet <edumazet@google.com>
In case multiple writes to a unix stream socket race we could end up in a
situation where we pre-allocate a new skb for use in unix_stream_sendpage
but have to free it again in the locked section because another skb
has been appended meanwhile, which we must use. Accidentally we didn't
clear the pointer after consuming it and so we touched freed memory
while appending it to the sk_receive_queue. So, clear the pointer after
consuming the skb.
This bug has been found with syzkaller
(http://github.com/google/syzkaller) by Dmitry Vyukov.
Cc: Dmitry Vyukov <dvyukov@google.com>
During splicing an af-unix socket to a pipe we have to drop all
af-unix socket locks. While doing so we allow another reader to enter
unix_stream_read_generic which can read, copy and finally free another
skb. If exactly this skb is just in process of being spliced we get a
use-after-free report by kasan.
First, we must make sure to not have a free while the skb is used during
the splice operation. We simply increment its use counter before unlocking
the reader lock.
Stream sockets have the nice characteristic that we don't care about
zero length writes and they never reach the peer socket's queue. That
said, we can take the UNIXCB.consumed field as the indicator if the
skb was already freed from the socket's receive queue. If the skb was
fully consumed after we locked the reader side again we know it has been
dropped by a second reader. We indicate a short read to user space and
abort the current splice operation.
poll(POLLOUT) on a listener should not report fd is ready for
a write().
This would break some applications using poll() and pfd.events = -1,
as they would not block in poll()
Reported-by: Alan Burlison <Alan.Burlison@oracle.com>
Tested-by: Eric Dumazet <edumazet@google.com>
Now send with MSG_PEEK can return data from multiple SKBs.
Unfortunately we take into account the peek offset for each skb,
that is wrong. We need to apply the peek offset only once.
In addition, the peek offset should be used only if MSG_PEEK is set.
Cc: "David S. Miller" <davem@davemloft.net> (maintainer:NETWORKING
Cc: Eric Dumazet <edumazet@google.com> (commit_signer:1/14=7%)
Cc: Aaron Conole <aconole@bytheb.org>
Fixes: 9f389e35674f ("af_unix: return data from multiple SKBs on recv() with MSG_PEEK flag")
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Tested-by: Aaron Conole <aconole@bytheb.org>
AF_UNIX sockets now return multiple skbs from recv() when MSG_PEEK flag
is set.
This is referenced in kernel bugzilla #12323 @
https://bugzilla.kernel.org/show_bug.cgi?id=12323
As described both in the BZ and lkml thread @
http://lkml.org/lkml/2008/1/8/444 calling recv() with MSG_PEEK on an
AF_UNIX socket only reads a single skb, where the desired effect is
to return as much skb data has been queued, until hitting the recv
buffer size (whichever comes first).
The modified MSG_PEEK path will now move to the next skb in the tree
and jump to the again: label, rather than following the natural loop
structure. This requires duplicating some of the loop head actions.
This was tested using the python socketpair python code attached to
the bugzilla issue.
Signed-off-by: Aaron Conole <aconole@bytheb.org>
SCM_SECURITY was originally only implemented for datagram sockets,
not for stream sockets. However, SCM_CREDENTIALS is supported on
Unix stream sockets. For consistency, implement Unix stream support
for SCM_SECURITY as well. Also clean up the existing code and get
rid of the superfluous UNIXSID macro.
Motivated by https://bugzilla.redhat.com/show_bug.cgi?id=1224211,
where systemd was using SCM_CREDENTIALS and assumed wrongly that
SCM_SECURITY was also supported on Unix stream sockets.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Paul Moore <paul@paul-moore.com>
drivers/net/phy/amd-xgbe-phy.c
drivers/net/wireless/iwlwifi/Kconfig
include/net/mac80211.h
iwlwifi/Kconfig and mac80211.h were both trivial overlapping
changes.
The drivers/net/phy/amd-xgbe-phy.c file got removed in 'net-next' and
the bug fix that happened on the 'net' side is already integrated
into the rest of the amd-xgbe driver.
got a rare NULL pointer dereference in clear_bit
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
v2: switch to sock_flag(sk, SOCK_DEAD) and added net/caif/caif_socket.c
v3: return -ECONNRESET in upstream caller of wait function for SOCK_DEAD
unix_stream_recvmsg is refactored to unix_stream_read_generic in this
patch and enhanced to deal with pipe splicing. The refactoring is
inneglible, we mostly have to deal with a non-existing struct msghdr
argument.
This patch implements sendpage support for AF_UNIX SOCK_STREAM
sockets. This is also required for a complete splice implementation.
The implementation is a bit tricky because we append to already existing
skbs and so have to hold unix_sk->readlock to protect the reading side
from either advancing UNIXCB.consumed or freeing the skb at the socket
receive tail.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
Pull networking fixes from David Miller:
1) mlx4 doesn't check fully for supported valid RSS hash function, fix
from Amir Vadai
2) Off by one in ibmveth_change_mtu(), from David Gibson
3) Prevent altera chip from reporting false error interrupts in some
circumstances, from Chee Nouk Phoon
4) Get rid of that stupid endless loop trying to allocate a FIN packet
in TCP, and in the process kill deadlocks. From Eric Dumazet
5) Fix get_rps_cpus() crash due to wrong invalid-cpu value, also from
Eric Dumazet
6) Fix two bugs in async rhashtable resizing, from Thomas Graf
7) Fix topology server listener socket namespace bug in TIPC, from Ying
Xue
8) Add some missing HAS_DMA kconfig dependencies, from Geert
Uytterhoeven
9) bgmac driver intends to force re-polling but does so by returning
the wrong value from it's ->poll() handler. Fix from Rafał Miłecki
10) When the creater of an rhashtable configures a max size for it,
don't bark in the logs and drop insertions when that is exceeded.
Fix from Johannes Berg
11) Recover from out of order packets in ppp mppe properly, from Sylvain
Rochet
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (41 commits)
bnx2x: really disable TPA if 'disable_tpa' option is set
net:treewide: Fix typo in drivers/net
net/mlx4_en: Prevent setting invalid RSS hash function
mdio-mux-gpio: use new gpiod_get_array and gpiod_put_array functions
netfilter; Add some missing default cases to switch statements in nft_reject.
ppp: mppe: discard late packet in stateless mode
ppp: mppe: sanity error path rework
net/bonding: Make DRV macros private
net: rfs: fix crash in get_rps_cpus()
altera tse: add support for fixed-links.
pxa168: fix double deallocation of managed resources
net: fix crash in build_skb()
net: eth: altera: Resolve false errors from MSGDMA to TSE
ehea: Fix memory hook reference counting crashes
net/tg3: Release IRQs on permanent error
net: mdio-gpio: support access that may sleep
inet: fix possible panic in reqsk_queue_unlink()
rhashtable: don't attempt to grow when at max_size
bgmac: fix requests for extra polling calls from NAPI
tcp: avoid looping in tcp_send_fin()
fixed several comment and whitespace style issues
Signed-off-by: Jason Eastman <eastman.jason.linux@gmail.com>
places where we are dealing with S_ISSOCK file creation/lookups.
AF_UNIX sockets should call mknod on the top layer only and should not attempt
to modify the lower layer in a layered filesystem such as overlayfs.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
The sock_iocb structure is allocate on stack for each read/write-like
operation on sockets, and contains various fields of which only the
embedded msghdr and sometimes a pointer to the scm_cookie is ever used.
Get rid of the sock_iocb and put a msghdr directly on the stack and pass
the scm_cookie explicitly to netlink_mmap_sendmsg.
Contrary to common expectations for an "int" return, these functions
return only a positive value -- if used correctly they cannot even
return 0 because the message header will necessarily be in the skb.
This makes the very common pattern of
if (genlmsg_end(...) < 0) { ... }
be a whole bunch of dead code. Many places also simply do
return nlmsg_end(...);
and the caller is expected to deal with it.
This also commonly (at least for me) causes errors, because it is very
common to write
if (my_function(...))
/* error condition */
and if my_function() does "return nlmsg_end()" this is of course wrong.
Additionally, there's not a single place in the kernel that actually
needs the message length returned, and if anyone needs it later then
it'll be very easy to just use skb->len there.
Remove this, and make the functions void. This removes a bunch of dead
code as described above. The patch adds lines because I did
- return nlmsg_end(...);
+ nlmsg_end(...);
+ return 0;
I could have preserved all the function's return values by returning
skb->len, but instead I've audited all the places calling the affected
functions and found that none cared. A few places actually compared
the return value with <= 0 in dump functionality, but that could just
be changed to < 0 with no change in behaviour, so I opted for the more
efficient version.
One instance of the error I've made numerous times now is also present
in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't
check for <0 or <=0 and thus broke out of the loop every single time.
I've preserved this since it will (I think) have caused the messages to
userspace to be formatted differently with just a single message for
every SKB returned to userspace. It's possible that this isn't needed
for the tools that actually use this, but I don't even know what they
are so couldn't test that changing this behaviour would be acceptable.
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
... and kill skb_copy_datagram_iovec()
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
static values are automatically initialized to 0
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
Using whole of allocated pages reduces requested skb->data size.
This is just a little more thriftily allocation.
netperf does not show difference with the current performance.
Signed-off-by: Kirill Tkhai <ktkhai@parallels.com>
Mostly scripted conversion of the smp_mb__* barriers.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
Some applications didn't expect recvmsg() on a non blocking socket
could return -EINTR. This possibility was added as a side effect
of commit b3ca9b02b00704 ("net: fix multithreaded signal handling in
unix recv routines").
To hit this bug, you need to be a bit unlucky, as the u->readlock
mutex is usually held for very small periods.
Fixes: b3ca9b02b00704 ("net: fix multithreaded signal handling in unix recv routines")
The unix socket code is using the result of csum_partial to
hash into a lookup table:
unix_hash_fold(csum_partial(sunaddr, len, 0));
csum_partial is only guaranteed to produce something that can be
folded into a checksum, as its prototype explains:
* returns a 32-bit number suitable for feeding into itself
* or csum_tcpudp_magic
The 32bit value should not be used directly.
Depending on the alignment, the ppc64 csum_partial will return
different 32bit partial checksums that will fold into the same
16bit checksum.
This difference causes the following testcase (courtesy of
Gustavo) to sometimes fail:
#include <stdio.h>
int main()
int fd = socket(PF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC, 0);
int i = 1;
setsockopt(fd, SOL_SOCKET, SO_REUSEADDR, &i, 4);
struct sockaddr addr;
addr.sa_family = AF_LOCAL;
bind(fd, &addr, 2);
listen(fd, 128);
struct sockaddr_storage ss;
socklen_t sslen = (socklen_t)sizeof(ss);
getsockname(fd, (struct sockaddr*)&ss, &sslen);
if (connect(fd, (struct sockaddr*)&ss, sslen) == -1){
perror(NULL);
return 1;
printf("OK\n");
return 0;
As suggested by davem, fix this by using csum_fold to fold the
partial 32bit checksum into a 16bit checksum before using it.
Cc: stable@vger.kernel.org
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
drivers/net/ethernet/intel/i40e/i40e_main.c
drivers/net/macvtap.c
Both minor merge hassles, simple overlapping changes.
This is similar to the set_peek_off patch where calling bind while the
socket is stuck in unix_dgram_recvmsg() will block and cause a hung task
spew after a while.
This is also the last place that did a straightforward mutex_lock(), so
there shouldn't be any more of these patches.
